cmake (was Re: [geos-devel] 3.0?)
=?GB2312?B?y++439PC?=
sungaoyong at gmail.com
Mon Sep 4 03:08:43 EDT 2006
also i think it's bettle to set a var to replace more ../../,hehe
example
SET(GEOS_ROOTDIR ${CMAKE_SOURCE_DIR}/../../)
so every ${CMAKE_SOURCE_DIR}/../../ can replace with $GEOS_ROOTDIR, it's
clear.
On 9/4/06, 孙高勇 <sungaoyong at gmail.com> wrote:
> SET(GEOS_SRCS Hello.c File2.c File3.c)
> this can delete,this only my test.
> On 9/4/06, Mateusz Loskot <mateusz at loskot.net > wrote:
> > Mateusz Loskot wrote:
> > 孙高勇 wrote:
> >> # CMakeLists.txt for geos 3.0 by sungaoyong
> >> # 2006-09-04 sungaoyong at gmail.com <mailto:sungaoyong at gmail.com>
> >> # Building on Cmake 2.4
> >> # test on windows mingw32 g++ 3.4.2、msvc 2003,linux g++ 4.1
> >> # hope it's usefull
> > First, I'd like to thank you on behalf of GEOS team for
> > this contribution!
> > I also run it with success!
> > I use Linux (Ubuntu 6.06) + gcc 4.0.3 + cmake 2.4.3 (compiled
> > from sources)
> > Here are binaries generated by cmake:
> > libgeos_i.a
> > libgeos.so
> > TestSweepLineSpeed
> > Is it possible to put CMakeLists.txt file outside the 'source' tree?
> > For example, to <GEOS ROOT>/build/cmake
> > cmake generates Makefile on the same level as automake, so
> > I'd suggest to put cmake outside the tree to avoid potential
> > conflicts with autotools (some problems may be unknown at the moment).
> > Is this possible to use cmake thisway?
> Hi,
> I played for a few minutes with cmake and CMakeLists.txtfile
> and I managed to do complete build from outside the sources tree.
> I atteched my version of CMakeLists.txt file. Please note, I'm not sure
> it's correct, as I'm not a cmake user yet, though it works for me :-)
> I copied this file to following location:
> <GEOS>/build/cmake/CMakeLists.txt
> where <GEOS> is root sources dir of GEOS.
> In my environment it's $HOME/dev/geos/_svn/geos/
> Now, to build outside the sources tree I run:
> $ cd $HOME/dev/geos/_svn/geos/build/cmake
> $ cmake .
> $ make
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> /home/mloskot/dev/geos/_svn/geos/build/cmake
> [ 0%] Building CXX object
> CMakeFiles/geos.dir/home/mloskot/dev/geos/_svn/geos/source/inlines.o
> [ 99%] Building CXX object
> CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/math.o
> [100%] Building CXX object
> CMakeFiles/geos_i.dir/home/mloskot/dev/geos/_svn/geos-cmake/source/util/Profiler.o
> Linking CXX static library libgeos_i.a
> [100%] Built target geos_i
> $ pwd
> $ ls
> libgeos_i.a
> libgeos.so
> TestSweepLineSpeed
> So, it seems to work.
> It may need some more work to tune it but I'd stick to this
> approach of "building outside the sources tree".
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> # 2006-09-04 mateusz at loskot.net
> # Modified to build from outside the source tree (<GEOS>/build/cmake)
> # test on windows mingw32 g++ 3.4.2¡¢msvc 2003,linux g++ 4.1
> # hope it's usefull
> PROJECT(GEOS)
> INCLUDE_DIRECTORIES(${CMAKE_SOURCE_DIR}/../../source/headers)
> set (JTS_PORT 1.7.1)
> set (VERSION_MAJOR 3)
> set (VERSION_MINOR 0)
> set (VERSION_PATCH 0rc1)
> set (VERSION 3.0.0rc1)
> INCLUDE(CheckSymbolExists)
> #CHECK_SYMBOL_EXISTS(int64_t types.h HAVE_INT64_T_64)
> IF(MINGW)
> set (HAVE_INT64_T_64 1)
> ENDIF(MINGW)
> IF(UNIX)
> ENDIF(UNIX)
> CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h.in
> ${CMAKE_SOURCE_DIR}/../../source/headers/geos/version.h)
> CONFIGURE_FILE(${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h.in.cmake
> ${CMAKE_SOURCE_DIR}/../../source/headers/geos/platform.h ESCAPE_QUOTES)
> #ADD_LIBRARY(geos STATIC inlines.cpp)
> #ADD_LIBRARY(geos inlines.cpp)
> #ADD_LIBRARY(geos SHARED inlines.cpp
> SET(GEOS_SRCS ${CMAKE_SOURCE_DIR}/../../source/inlines.cpp
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidArea.cpp
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidLine
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/CentroidPoint
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/CGAlgorithms
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/ConvexHull
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/HCoordinate
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointArea
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointLine
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/InteriorPointPoint
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/LineIntersector
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/MCPointInRing
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/MinimumDiameter
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/NotRepresentableException
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/PointLocator
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/RobustDeterminant
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInAreaLocator
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/SimplePointInRing
> ${CMAKE_SOURCE_DIR}/../../source/algorithm/SIRtreePointInRing
> ${CMAKE_SOURCE_DIR}/../../source/geom/Coordinate
> ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequence
> ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateArraySequenceFactory
> ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequence
> # ${CMAKE_SOURCE_DIR}/../../source/geom/CoordinateSequenceFactory
> ${CMAKE_SOURCE_DIR}/../../source/geom/Dimension
> ${CMAKE_SOURCE_DIR}/../../source/geom/Envelope
> ${CMAKE_SOURCE_DIR}/../../source/geom/Geometry
> ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryCollection
> ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryComponentFilter
> ${CMAKE_SOURCE_DIR}/../../source/geom/GeometryFactory
> ${CMAKE_SOURCE_DIR}/../../source/geom/IntersectionMatrix
> ${CMAKE_SOURCE_DIR}/../../source/geom/LinearRing
> ${CMAKE_SOURCE_DIR}/../../source/geom/LineSegment
> ${CMAKE_SOURCE_DIR}/../../source/geom/LineString
> ${CMAKE_SOURCE_DIR}/../../source/geom/Location
> ${CMAKE_SOURCE_DIR}/../../source/geom/MultiLineString
> ${CMAKE_SOURCE_DIR}/../../source/geom/MultiPoint
> ${CMAKE_SOURCE_DIR}/../../source/geom/MultiPolygon
> ${CMAKE_SOURCE_DIR}/../../source/geom/Point
> ${CMAKE_SOURCE_DIR}/../../source/geom/Polygon
> ${CMAKE_SOURCE_DIR}/../../source/geom/PrecisionModel
> ${CMAKE_SOURCE_DIR}/../../source/geom/Triangle
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/CoordinateOperation
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryEditor
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/GeometryTransformer
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/LinearComponentExtracter
> # ${CMAKE_SOURCE_DIR}/../../source/geom/util/PointExtracter
> # ${CMAKE_SOURCE_DIR}/../../source/geom/util/PolygonExtracter
> ${CMAKE_SOURCE_DIR}/../../source/geom/util/ShortCircuitedGeometryVisitor
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Depth
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdge
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/DirectedEdgeStar
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Edge
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEnd
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeEndStar
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersection
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeIntersectionList
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeList
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeNodingValidator
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/EdgeRing
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/GeometryGraph
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/GraphComponent
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Label
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Node
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeFactory
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/NodeMap
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/PlanarGraph
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Position
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/Quadrant
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/TopologyLocation
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainEdge
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/MonotoneChainIndexer
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SegmentIntersector
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleEdgeSetIntersector
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleMCSweepLineIntersector
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SimpleSweepLineIntersector
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineEvent
> ${CMAKE_SOURCE_DIR}/../../source/geomgraph/index/SweepLineSegment
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Bintree
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Interval
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Key
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Node
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/NodeBase
> ${CMAKE_SOURCE_DIR}/../../source/index/bintree/Root
> ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChain
> ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainBuilder
> ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainOverlapAction
> ${CMAKE_SOURCE_DIR}/../../source/index/chain/MonotoneChainSelectAction
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/DoubleBits
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/IntervalSize
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Key
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Node
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/NodeBase
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Root
> ${CMAKE_SOURCE_DIR}/../../source/index/quadtree/Quadtree
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractNode
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/AbstractSTRtree
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/Interval
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/ItemBoundable
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/SIRtree
> ${CMAKE_SOURCE_DIR}/../../source/index/strtree/STRtree
> ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineEvent
> ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineIndex
> ${CMAKE_SOURCE_DIR}/../../source/index/sweepline/SweepLineInterval
> ${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderDataInStream
> ${CMAKE_SOURCE_DIR}/../../source/io/ByteOrderValues
> ${CMAKE_SOURCE_DIR}/../../source/io/ParseException
> ${CMAKE_SOURCE_DIR}/../../source/io/StringTokenizer
> ${CMAKE_SOURCE_DIR}/../../source/io/Unload
> ${CMAKE_SOURCE_DIR}/../../source/io/WKBReader
> ${CMAKE_SOURCE_DIR}/../../source/io/WKBWriter
> ${CMAKE_SOURCE_DIR}/../../source/io/WKTReader
> ${CMAKE_SOURCE_DIR}/../../source/io/WKTWriter
> ${CMAKE_SOURCE_DIR}/../../source/io/Writer
> ${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionAdder
> ${CMAKE_SOURCE_DIR}/../../source/noding/IntersectionFinderAdder
> ${CMAKE_SOURCE_DIR}/../../source/noding/IteratedNoder
> ${CMAKE_SOURCE_DIR}/../../source/noding/MCIndexNoder
> ${CMAKE_SOURCE_DIR}/../../source/noding/NodingValidator
> ${CMAKE_SOURCE_DIR}/../../source/noding/Octant
> ${CMAKE_SOURCE_DIR}/../../source/noding/ScaledNoder
> ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNode
> ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentNodeList
> ${CMAKE_SOURCE_DIR}/../../source/noding/SegmentString
> ${CMAKE_SOURCE_DIR}/../../source/noding/SimpleNoder
> ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/HotPixel
> ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexPointSnapper
> ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/MCIndexSnapRounder
> ${CMAKE_SOURCE_DIR}/../../source/noding/snapround/SimpleSnapRounder
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/BufferSubgraph
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/OffsetCurveSetBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/RightmostEdgeFinder
> ${CMAKE_SOURCE_DIR}/../../source/operation/buffer/SubgraphDepthLocater
> ${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementLocationFilter
> ${CMAKE_SOURCE_DIR}/../../source/operation/distance/ConnectedElementPointFilter
> ${CMAKE_SOURCE_DIR}/../../source/operation/distance/DistanceOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/distance/GeometryLocation
> ${CMAKE_SOURCE_DIR}/../../source/operation/GeometryGraphOperation
> ${CMAKE_SOURCE_DIR}/../../source/operation/IsSimpleOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/EdgeString
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeDirectedEdge
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeEdge
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMergeGraph
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineMerger
> ${CMAKE_SOURCE_DIR}/../../source/operation/linemerge/LineSequencer
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/EdgeSetNoder
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrix
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/ElevationMatrixCell
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/LineBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MaximalEdgeRing
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/MinimalEdgeRing
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayNodeFactory
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/OverlayOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PointBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/overlay/PolygonBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeDirectedEdge
> ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeEdge
> ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/EdgeRing
> ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/PolygonizeGraph
> ${CMAKE_SOURCE_DIR}/../../source/operation/polygonize/Polygonizer
> ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleContains
> ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/RectangleIntersects
> ${CMAKE_SOURCE_DIR}/../../source/operation/predicate/SegmentIntersectionTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBuilder
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundle
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/EdgeEndBundleStar
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateComputer
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNode
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeFactory
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateNodeGraph
> ${CMAKE_SOURCE_DIR}/../../source/operation/relate/RelateOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConnectedInteriorTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/ConsistentAreaTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/IsValidOp
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/QuadtreeNestedRingTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/RepeatedPointTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/SimpleNestedRingTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/SweeplineNestedRingTester
> ${CMAKE_SOURCE_DIR}/../../source/operation/valid/TopologyValidationError
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdge
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/DirectedEdgeStar
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/Edge
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/Node
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/NodeMap
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/PlanarGraph
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/Subgraph
> ${CMAKE_SOURCE_DIR}/../../source/planargraph/algorithm/ConnectedSubgraphFinder
> ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBits
> ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsOp
> ${CMAKE_SOURCE_DIR}/../../source/precision/CommonBitsRemover
> ${CMAKE_SOURCE_DIR}/../../source/precision/EnhancedPrecisionOp
> ${CMAKE_SOURCE_DIR}/../../source/precision/GeometrySnapper
> ${CMAKE_SOURCE_DIR}/../../source/precision/LineStringSnapper
> ${CMAKE_SOURCE_DIR}/../../source/precision/SimpleGeometryPrecisionReducer
> ${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerLineSimplifier
> ${CMAKE_SOURCE_DIR}/../../source/simplify/DouglasPeuckerSimplifier
> ${CMAKE_SOURCE_DIR}/../../source/simplify/LineSegmentIndex
> ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineSegment
> ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLinesSimplifier
> ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineString
> ${CMAKE_SOURCE_DIR}/../../source/simplify/TaggedLineStringSimplifier
> ${CMAKE_SOURCE_DIR}/../../source/simplify/TopologyPreservingSimplifier
> ${CMAKE_SOURCE_DIR}/../../source/util/Assert
> # ${CMAKE_SOURCE_DIR}/../../source/util/AssertionFailedException
> ${CMAKE_SOURCE_DIR}/../../source/util/GeometricShapeFactory
> # ${CMAKE_SOURCE_DIR}/../../source/util/IllegalArgumentException
> ${CMAKE_SOURCE_DIR}/../../source/util/math
> ${CMAKE_SOURCE_DIR}/../../source/util/Profiler
> ${CMAKE_SOURCE_DIR}/../../source/util/UnsupportedOperationException
> ADD_LIBRARY(geos SHARED ${GEOS_SRCS})
> ADD_LIBRARY(geos_i STATIC ${GEOS_SRCS})
> ADD_EXECUTABLE(TestSweepLineSpeed
> ${CMAKE_SOURCE_DIR}/../../tests/bigtest/GeometryTestFactory
> ${CMAKE_SOURCE_DIR}/../../tests/bigtest/TestSweepLineSpeed)
> TARGET_LINK_LIBRARIES(TestSweepLineSpeed geos)
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060904/2dd65238/attachment.html
