[geos-devel] Building under windows using mingw
Charlie Savage cfis at savagexi.com
Tue Sep 12 23:44:15 EDT 2006
Interesting - do you just install the windows version of CMake or do you
  have to build it specifically for MinGW?
Charlie
孙高勇 wrote:
> use the cmake to build it with the CMakefile.txt i had write.
> #   CMakeLists.txt for geos 3.0 by sungaoyong
> #   2006-09-04 sungaoyong at gmail.com <mailto:sungaoyong at gmail.com>
> #     Building on Cmake 2.4
> #   test on windows mingw32 g++ 3.4.2、msvc 2003,linux g++ 4.1
> #   hope it's usefull
> # 2006/09/06 15:43:22  sungaoyong
> #     use AUX_SOURCE_DIRECTORY to find source
> #     some type check
> #     capi build and Test
> # 2006/09/04 14:34:12  sungaoyong
> #     first version,can build geos with cmake
> On 9/13/06, * Charlie Savage* <cfis at savagexi.com
> <mailto:cfis at savagexi.com>> wrote:
>     Geos 2.x.x builds fine under windows using MingW.  Just do the usual
>     ./configure, make, make install.
>     I haven't had any luck with Geos 3.x.  The problem is a link issue where
>     declarations are defined twice, once in the .inc (contain inlines) files
>     are once in the header files.  It should be simple to fix but I haven't
>     had the time to look into it.
>     Charlie
>     Tim Sutton wrote:
>      > Hi
>      > Is there any information available for building geos in mingw? Is it
>      > possible?
>      > Thanks
>      > Tim
>     _______________________________________________
>     geos-devel mailing list
>     geos-devel at geos.refractions.net <mailto:geos-devel at geos.refractions.net>
>     http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060912/8ac75112/smime.bin
