[geos-devel] Building under windows using mingw
Tim Sutton tim at linfiniti.com
Wed Sep 13 00:03:16 EDT 2006
Hi
Thanks for the tips guys - Ill try to build it tomorrow and report
back then!
Regards
Tim
On 13/09/2006, at 00:44, Charlie Savage wrote:
> Interesting - do you just install the windows version of CMake or
> do you  have to build it specifically for MinGW?
> Charlie
> 孙高勇 wrote:
>> use the cmake to build it with the CMakefile.txt i had write.
>> #   CMakeLists.txt for geos 3.0 by sungaoyong
>> #   2006-09-04 sungaoyong at gmail.com <mailto:sungaoyong at gmail.com>
>> #     Building on Cmake 2.4
>> #   test on windows mingw32 g++ 3.4.2、msvc 2003,linux g++ 4.1
>> #   hope it's usefull
>> # 2006/09/06 15:43:22  sungaoyong
>> #     use AUX_SOURCE_DIRECTORY to find source
>> #     some type check
>> #     capi build and Test
>> ---------   # 2006/09/04 14:34:12  sungaoyong
>> #     first version,can build geos with cmake
>> On 9/13/06, * Charlie Savage* <cfis at savagexi.com
>> <mailto:cfis at savagexi.com>> wrote:
>>     Geos 2.x.x builds fine under windows using MingW.  Just do the
>> usual
>>     ./configure, make, make install.
>>     I haven't had any luck with Geos 3.x.  The problem is a link
>> issue where
>>     declarations are defined twice, once in the .inc (contain
>> inlines) files
>>     are once in the header files.  It should be simple to fix but
>> I haven't
>>     had the time to look into it.
>>     Charlie
>>     Tim Sutton wrote:
>>      > Hi
>>      > Is there any information available for building geos in
>> mingw? Is it
>>      > possible?
>>      > Thanks
>>      > Tim
>>     _______________________________________________
>>     geos-devel mailing list
>>     geos-devel at geos.refractions.net <mailto:geos-
>> devel at geos.refractions.net>
>>     http://geos.refractions.net/mailman/listinfo/geos-devel
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20060913/c169eaf0/attachment.html
