[geos-devel] GEOS compilation VS7.1
Mateusz Loskot
mateusz at loskot.net
Wed Aug 15 13:37:34 EDT 2007
abhay menon wrote:
> Has anyone tried this hack for building GEOS in msvc71.
> I want to know that if this version of the GEOS library is working
> correctly or if some one has been able to compile in a similar fashion.
What's the exact problem?
I did build GEOS using Visual C++ 7.1.
Currently, I use Visual C++ 8.0.
Both versions work well.
The only known version that is not supported is Visual C++ 6.0.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
