[geos-devel] GEOS compilation VS7.1
abhay menon abhay.menon at gmail.com
Wed Aug 15 13:44:30 EDT 2007
On 8/15/07, Mateusz Loskot <mateusz at loskot.net> wrote:
> abhay menon wrote:
> > Has anyone tried this hack for building GEOS in msvc71.
> > I want to know that if this version of  the GEOS library is working
> > correctly or if some one has been able to compile in a similar fashion.
> What's the exact problem?
> I did build GEOS using Visual C++ 7.1.
> Currently, I use Visual C++ 8.0.
> Both versions work well.
> The only known version that is not supported is Visual C++ 6.0.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Hi Mateusz,
Have you tried the sln msvc71 that I had provided. Did it give a correct
output in the Release build or was there any error msg will building that.
Best Regards
Abhay Menon
http://abhaymenon.info
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20070815/4f3a55a4/attachment.html
