[geos-devel] GEOS compilation VS7.1
Mateusz Loskot mateusz at loskot.net
Wed Aug 15 13:59:40 EDT 2007
abhay menon wrote:
> On 8/15/07, Mateusz Loskot <mateusz at loskot.net> wrote:
>> abhay menon wrote:
>>> Has anyone tried this hack for building GEOS in msvc71.
>>> I want to know that if this version of  the GEOS library is working
>>> correctly or if some one has been able to compile in a similar fashion.
>> What's the exact problem?
>> I did build GEOS using Visual C++ 7.1.
>> Currently, I use Visual C++ 8.0.
>> Both versions work well.
>> The only known version that is not supported is Visual C++ 6.0.
> Hi Mateusz,
> Have you tried the sln msvc71 that I had provided. Did it give a correct
> output in the Release build or was there any error msg will building that.
No, I have not becasue I don't have msvc71 license anymore.
I have only access to msvc80.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
