[geos-devel] GEOS compilation VS7.1
abhay menon
abhay.menon at gmail.com
Wed Aug 15 14:16:22 EDT 2007
Hi Mateusz,
On 8/15/07, Mateusz Loskot <mateusz at loskot.net> wrote:
> abhay menon wrote:
> > I want to use the same in VC++ 6.0 binded with GDAL. So had create a sln
> for
> > VC7.1 as that was the permissible framework environment that I could
> use.
> > If you still have the working VC7.1 build sln + project file similar to
> your
> > msvc80 build could please mail it to me.
> It seems my explanation was imprecise.
> Yes, I did use msvc71 to build GEOS but only using makefile.vc files
> provided in the GEOS source code.
> I didn't use solution/project to build GEOS with msvc71.
Ok .for some reason I was not able to get the GEOS compiled using
makefile.vc in VC7.1.
After I switched to msvc80 I created solution/project and
> submitted it to the GEOS SVN (trunk/geos/build/msvc80).
yeap that where I found the solution and project in MS VC 8.0.
I hope it's clear now.
It crystal clear to me .
Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Since I have the access to all the version of VS. I made the
solution/project in MS VC 7.1 changing certain param in solution and project
of MS VC 8.0 that you had submitted in svn.
I shall try to make use the makefile.vc in VS7.1 again and post back if the
problem still persist.
Best Regards
Abhay Menon
http://abhaymenon.info
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20070815/b65d8672/attachment.html
