[geos-devel] Python/Swig/Configure Bug
Charlie Savage cfis at savagexi.com
Thu Aug 30 02:55:52 EDT 2007
Hi Mark,
> 	(SWIG check enabled by default)
> 	If SWIG is found then
> 		If Python enabled then
> 			Check for Python
> 			If Python is found then
> 				use_python = true
> 			Else
> 				use_python = false
> 			End If
> 		Else
> 			use_python = false
> 		End If
> 		If Ruby enabled then
> 			Check for Ruby
> 			If Ruby is found then
> 				use_ruby = true
> 			Else
> 				use_ruby = false
> 			End If
> 		Else
> 			use_ruby = false
> 		End If
> 	End If
> If you're happy with this, let me know, and I'll post something later
> today as it should only take a few mins to fix.
That would be great - thanks for looking.  If you have the
time/inclination to look at the other Python automake error I'm seeing
(see other email) I would be grateful.
> BTW I've seen some of your other PostGIS related postings, but am
> currently extremely busy - they look interesting and I hope to review
> them soon.
No problem, I'll be around...
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070830/4bcb53a6/smime.bin
