[geos-devel] Python/Swig/Configure Bug
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Thu Aug 30 03:21:55 EDT 2007
On Thu, 2007-08-30 at 00:55 -0600, Charlie Savage wrote:
> That would be great - thanks for looking. If you have the
> time/inclination to look at the other Python automake error I'm seeing
> (see other email) I would be grateful.
Actually... am I right in thinking that SWIG is only needed if
--enable-python or --enable-ruby is specified? In which case perhaps the
following would be better:
If Python Or Ruby Enabled Then
If Detect SWIG Then
If Python Enabled Then
Check For Python
If Python is found Then
use_python = true
Else
use_python = false
End If
Else
use_python = false
End If
If Ruby Enabled Then
Check For Ruby
If Ruby is found Then
use_ruby = true
Else
use_ruby = false
End If
Else
use_ruby = false
End If
Else
use_python = false
use_ruby = false
End If
Else
use_python = false
use_ruby = false
End If
And then we could just ignore the --enable/disable-swig switch
completely. This strikes me as being a much better solution since the
SWIG detection is handled automatically.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
