[geos-devel] timeval.h simplification
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Aug 31 02:53:22 EDT 2007
On Thu, 2007-08-30 at 14:16 -0600, Charlie Savage wrote:
> Hi Mark,
> Gah - I just checked in those changes so I broke your build.  Sorry
> about that.  Want to upgrade mingw :)
> Seems like an autoconf test is the way to go then.
> Charlie
Hi Charlie,
Here's an experimental patch for this. It seems to work for me under
Linux when gettimeofday() is present, but I haven't had a chance to
check in a proper MingW environment. Hopefully this should not affect
your MingW build when applied - as before you'll need to re-run
autogen.sh.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070831/57eff7ab/geos-gettimeofday.bin
