[geos-devel] timeval.h simplification
Charlie Savage
cfis at savagexi.com
Fri Aug 31 16:08:11 EDT 2007
> On Thu, 2007-08-30 at 14:16 -0600, Charlie Savage wrote:
> Here's an experimental patch for this. It seems to work for me under
> Linux when gettimeofday() is present, but I haven't had a chance to
> check in a proper MingW environment. Hopefully this should not affect
> your MingW build when applied - as before you'll need to re-run
> autogen.sh.
Mark,
This looks good - it works for me on both msys and msvc++. I assume
you'll apply?
Thanks for fixing this.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070831/3b1f10b9/smime.bin
