[geos-devel] Geos 3.0.0 RC 4 on OS X 10.5
William Kyngesburye
woklist at kyngchaos.com
Wed Dec 12 09:44:06 EST 2007
I ran into this problem a couple months ago, and so did mateusz who
filed a bug and fixed it in SVN.
http://trac.osgeo.org/geos/ticket/162
You can either grab SVN source, or apply the fix, as I did.
On Dec 12, 2007, at 7:54 AM, Richard Greenwood wrote:
> I am trying to build Geos 3.0.0 RC 4 on OS X 10.5. HCoordinate.cpp
> fails because finite() is not defined. Changing it to the FINITE()
> macro fixes the problem. I notice that Revision 1.19 switched it from
> the macro to the function.
> I tried to post a bug report in Trac, but my OSGeo account seems to be
> completely foobar.
> Hmm, now the build is failing on:
> XMLTester.cpp: In function 'void tolower(std::string&)':
> XMLTester.cpp:75: error: 'std::tolower' is not a valid template
> argument for type 'int ()(int)' because function 'int tolower(int)'
> has not external linkage
> Rich
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
