[geos-devel] Geos 3.0.0 RC 4 on OS X 10.5
Richard Greenwood
richard.greenwood at gmail.com
Wed Dec 12 09:56:35 EST 2007
William,
As always, thanks! I'll grab SVN and see if that happens to resolve my
XMLTester.cpp also.
Rich
On Dec 12, 2007 7:44 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I ran into this problem a couple months ago, and so did mateusz who
> filed a bug and fixed it in SVN.
> http://trac.osgeo.org/geos/ticket/162
> You can either grab SVN source, or apply the fix, as I did.
> On Dec 12, 2007, at 7:54 AM, Richard Greenwood wrote:
> > I am trying to build Geos 3.0.0 RC 4 on OS X 10.5. HCoordinate.cpp
> > fails because finite() is not defined. Changing it to the FINITE()
> > macro fixes the problem. I notice that Revision 1.19 switched it from
> > the macro to the function.
> > I tried to post a bug report in Trac, but my OSGeo account seems to be
> > completely foobar.
> > Hmm, now the build is failing on:
> > XMLTester.cpp: In function 'void tolower(std::string&)':
> > XMLTester.cpp:75: error: 'std::tolower' is not a valid template
> > argument for type 'int ()(int)' because function 'int tolower(int)'
> > has not external linkage
> > Rich
> > Richard Greenwood
> > www.greenwoodmap.com
> > geos-devel mailing list
> > geos-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geos-devel
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
Richard Greenwood
