[geos-devel] Geos 3.0.0 RC 4 on OS X 10.5
William Kyngesburye
woklist at kyngchaos.com
Wed Dec 12 10:01:48 EST 2007
Sorry, missed the part that it's failing on a different problem. I
didn't have any problems in XMLTester.cpp.
Did you download and try to compile the whole SVN source, or just
patch the finite() bug? Maybe there's a new bug in SVN.
On Dec 12, 2007, at 8:44 AM, William Kyngesburye wrote:
> I ran into this problem a couple months ago, and so did mateusz who
> filed a bug and fixed it in SVN.
> http://trac.osgeo.org/geos/ticket/162
> You can either grab SVN source, or apply the fix, as I did.
> On Dec 12, 2007, at 7:54 AM, Richard Greenwood wrote:
>> I am trying to build Geos 3.0.0 RC 4 on OS X 10.5. HCoordinate.cpp
>> fails because finite() is not defined. Changing it to the FINITE()
>> macro fixes the problem. I notice that Revision 1.19 switched it from
>> the macro to the function.
>> I tried to post a bug report in Trac, but my OSGeo account seems to
>> be
>> completely foobar.
>> Hmm, now the build is failing on:
>> XMLTester.cpp: In function 'void tolower(std::string&)':
>> XMLTester.cpp:75: error: 'std::tolower' is not a valid template
>> argument for type 'int ()(int)' because function 'int tolower(int)'
>> has not external linkage
>> Rich
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
