[geos-devel] Problem with building 3.0.0rc
John Cartwright john.c.cartwright at comcast.net
Fri Dec 28 12:39:15 EST 2007
The release version
(http://geos.refractions.net/downloads/geos-3.0.0.tar.bz2) seems to work
OK for me w/o the python SWIG bindings.  My system is 64bit RHEL 5.
By the way what is the status of the python bindings at 3.0?  I couldn't
get them to compile and recall that they were not actively maintained.
Can someone confirm?
Thanks!
--john
Sean Gillies wrote:
> I'm encountering a problem with the 3.0 release candidate that blocks a
> build on my Ubuntu 6.10 i686.
> "configure --prefix=/tmp; make; make install" bails out here:
> Making install in swig
> make[1]: Entering directory `/tmp/geos-3.0.0rc5/swig'
> Making install in python
> make[2]: Entering directory `/tmp/geos-3.0.0rc5/swig/python'
> Making install in tests
> make[3]: Entering directory `/tmp/geos-3.0.0rc5/swig/python/tests'
> make[4]: Entering directory `/tmp/geos-3.0.0rc5/swig/python/tests'
> make[4]: Nothing to be done for `install-exec-am'.
> make[4]: Nothing to be done for `install-data-am'.
> make[4]: Leaving directory `/tmp/geos-3.0.0rc5/swig/python/tests'
> make[3]: Leaving directory `/tmp/geos-3.0.0rc5/swig/python/tests'
> make[3]: Entering directory `/tmp/geos-3.0.0rc5/swig/python'
> make[4]: Entering directory `/tmp/geos-3.0.0rc5/swig/python'
> /bin/bash ../../mkinstalldirs
> shift: 49: can't shift that many
> make[4]: *** [install-pkgpythonPYTHON] Error 2
> make[4]: Leaving directory `/tmp/geos-3.0.0rc5/swig/python'
> make[3]: *** [install-am] Error 2
> make[3]: Leaving directory `/tmp/geos-3.0.0rc5/swig/python'
> make[2]: *** [install-recursive] Error 1
> make[2]: Leaving directory `/tmp/geos-3.0.0rc5/swig/python'
> make[1]: *** [install-recursive] Error 1
> make[1]: Leaving directory `/tmp/geos-3.0.0rc5/swig'
> make: *** [install-recursive] Error 1
> I don't understand why the install-pkgpythonPYTHON target is attempted
> when I haven't enabled the swig python bindings. Any idea what's up here?
> Sean
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
