[geos-devel] signal 11 with GEOS rc4_svn and postgis 1.2.1
strk at refractions.net strk at refractions.net
Fri Feb 16 18:06:05 EST 2007
The attached XML can be run by GEOS's XMLTester standalone, to
get PostGIS out of the way.
It works fine here, with both inlines enabled or disabled.
Do you get a segfault on your side ?
--strk;
On Fri, Feb 16, 2007 at 05:05:51PM -0500, Carl Anderson wrote:
> I am getting Signal 11 faults from geos through Postgis  in the
> following example,
> where the geometries a and b do not really intersect.
> select intersection(a, b) from
>  (select geometry('POLYGON((0 0,0 1,1 1,1 0,0 0))') as a ,
>     geometry('POLYGON((10 10,10 11,11 11,11 10,10 10))') as b
>  ) as part
> backtrace from Postgres 8.1.6, PostGIS 1.2.1
> Reading symbols from /usr/lib/libgeos-3.0.0rc4.so...done.
> Loaded symbols for /usr/lib/libgeos-3.0.0rc4.so
> Reading symbols from /usr/lib/libstdc++.so.6...done.
> Loaded symbols for /usr/lib/libstdc++.so.6
> Reading symbols from /lib/libgcc_s.so.1...done.
> Loaded symbols for /lib/libgcc_s.so.1
> 0x00ecd402 in __kernel_vsyscall ()
> (gdb) continue
> Continuing.
> Program received signal SIGSEGV, Segmentation fault.
> 0x06fd4199 in geos::geom::operator<< () from /usr/lib/libgeos-3.0.0rc4.so
> (gdb) bt
> #0  0x06fd4199 in geos::geom::operator<< () from
> #1  0x06fd42a7 in geos::geom::Coordinate::toString () from
> #2  0x06fcd98e in geos::algorithm::LineIntersector::toString () from
> #3  0x0708094b in geos::operation::overlay::OverlayOp::computeOverlay ()
> #4  0x07080e90 in geos::operation::overlay::OverlayOp::getResultGeometry
> #5  0x07081905 in geos::operation::overlay::OverlayOp::overlayOp () from
> #6  0x004a8721 in geos::operation::overlay::overlayOp::operator() ()
> from /usr/lib/libgeos_c.so.1
> #7  0x004a8a32 in
> geos::geom::BinaryOp<geos::operation::overlay::overlayOp> () from
> #8  0x004a4ffc in GEOSIntersection () from /usr/lib/libgeos_c.so.1
> #9  0x00f95398 in intersection (fcinfo=0xbf7fedb8) at lwgeom_geos_c.c:882
> #10 0x081367fc in ExecMakeFunctionResult (fcache=0x9d82ac0,
> econtext=0x99e0a40, isNull=0xbf7ff0ff "",
>    isDone=0x0) at execQual.c:1095
> (gdb)
> Carl Anderson
> GIS Manager Fulton County, Georgia
> carl.anderson at co.fulton.ga.us
> 404.730.8026
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
 ()   ASCII Ribbon Campaign
 /\   Keep it simple!
<run>
<precisionModel type="FLOATING"/>
<case>
<a>
</a>
<b>
</b>
<test>
	<op name="intersection">GEOMETRYCOLLECTION EMPTY</op>
</test>
</case>
</run>
