[geos-devel] signal 11 with GEOS rc4_svn and postgis 1.2.1
Carl Anderson
carl.anderson at co.fulton.ga.us
Fri Feb 16 18:50:09 EST 2007
I ran it through XMLTester without any problems.
I got a production PostGIS and a development PostGIS server to crash
with the SQL statement.
strk at refractions.net wrote:
> The attached XML can be run by GEOS's XMLTester standalone, to
> get PostGIS out of the way.
> It works fine here, with both inlines enabled or disabled.
> Do you get a segfault on your side ?
> --strk;
> On Fri, Feb 16, 2007 at 05:05:51PM -0500, Carl Anderson wrote:
> > I am getting Signal 11 faults from geos through Postgis in the
> > following example,
> > where the geometries a and b do not really intersect.
> > select intersection(a, b) from
> > (select geometry('POLYGON((0 0,0 1,1 1,1 0,0 0))') as a ,
> > geometry('POLYGON((10 10,10 11,11 11,11 10,10 10))') as b
> > ) as part
> > backtrace from Postgres 8.1.6, PostGIS 1.2.1
> > Reading symbols from /usr/lib/libgeos-3.0.0rc4.so...done.
> > Loaded symbols for /usr/lib/libgeos-3.0.0rc4.so
> > Reading symbols from /usr/lib/libstdc++.so.6...done.
> > Loaded symbols for /usr/lib/libstdc++.so.6
> > Reading symbols from /lib/libgcc_s.so.1...done.
> > Loaded symbols for /lib/libgcc_s.so.1
> > 0x00ecd402 in __kernel_vsyscall ()
> > (gdb) continue
> > Continuing.
> > Program received signal SIGSEGV, Segmentation fault.
> > 0x06fd4199 in geos::geom::operator<< () from
> > (gdb) bt
> > #0 0x06fd4199 in geos::geom::operator<< () from
> > #1 0x06fd42a7 in geos::geom::Coordinate::toString () from
> > #2 0x06fcd98e in geos::algorithm::LineIntersector::toString () from
> > #3 0x0708094b in geos::operation::overlay::OverlayOp::computeOverlay ()
> > #4 0x07080e90 in geos::operation::overlay::OverlayOp::getResultGeometry
> > () from /usr/lib/libgeos-3.0.0rc4.so
> > #5 0x07081905 in geos::operation::overlay::OverlayOp::overlayOp () from
> > #6 0x004a8721 in geos::operation::overlay::overlayOp::operator() ()
> > from /usr/lib/libgeos_c.so.1
> > #7 0x004a8a32 in
> > geos::geom::BinaryOp<geos::operation::overlay::overlayOp> () from
> > #8 0x004a4ffc in GEOSIntersection () from /usr/lib/libgeos_c.so.1
> > #9 0x00f95398 in intersection (fcinfo=0xbf7fedb8) at
> lwgeom_geos_c.c:882
> > #10 0x081367fc in ExecMakeFunctionResult (fcache=0x9d82ac0,
> > econtext=0x99e0a40, isNull=0xbf7ff0ff "",
> > isDone=0x0) at execQual.c:1095
> > (gdb)
> > Carl Anderson
> > GIS Manager Fulton County, Georgia
> > 404.730.8026
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> () ASCII Ribbon Campaign
> /\ Keep it simple!
> <run>
> <precisionModel type="FLOATING"/>
> <case>
> <a>
> </a>
> <b>
> </b>
> <test>
> <op name="intersection">GEOMETRYCOLLECTION EMPTY</op>
> </test>
> </case>
> </run>
Carl Anderson
404.730.8026
