[geos-devel] signal 11 with GEOS rc4_svn and postgis 1.2.1
strk at refractions.net
Tue Feb 20 03:03:00 EST 2007
On Fri, Feb 16, 2007 at 06:50:09PM -0500, Carl Anderson wrote:
> I ran it through XMLTester without any problems.
> I got a production PostGIS and a development PostGIS server to crash
> with the SQL statement.
Here's my result:
=# select astext(intersection('POLYGON((0 0,0 1,1 1,1 0,0 0))', 'POLYGON((10 10,10 11,11 11,11 10,10 10))'));
GEOMETRYCOLLECTION EMPTY
PGSQL versioN;
PostgreSQL 8.1.8 on i486-pc-linux-gnu, compiled by GCC gcc-4.0.gcc-opt (GCC) 4.0.3 (Ubuntu 4.0.3-1ubuntu5)
Postgis versions:
POSTGIS="1.2.0" GEOS="3.0.0rc4-CAPI-1.3.2" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
POSTGIS="1.2.1" GEOS="3.0.0rc4-CAPI-1.3.2" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
--strk;
> strk at refractions.net wrote:
> >The attached XML can be run by GEOS's XMLTester standalone, to
> >get PostGIS out of the way.
> >It works fine here, with both inlines enabled or disabled.
> >Do you get a segfault on your side ?
> >--strk;
> >On Fri, Feb 16, 2007 at 05:05:51PM -0500, Carl Anderson wrote:
> >> I am getting Signal 11 faults from geos through Postgis in the
> >> following example,
> >> where the geometries a and b do not really intersect.
> >> select intersection(a, b) from
> >> (select geometry('POLYGON((0 0,0 1,1 1,1 0,0 0))') as a ,
> >> geometry('POLYGON((10 10,10 11,11 11,11 10,10 10))') as b
> >> ) as part
> >> backtrace from Postgres 8.1.6, PostGIS 1.2.1
> >> Reading symbols from /usr/lib/libgeos-3.0.0rc4.so...done.
> >> Loaded symbols for /usr/lib/libgeos-3.0.0rc4.so
> >> Reading symbols from /usr/lib/libstdc++.so.6...done.
> >> Loaded symbols for /usr/lib/libstdc++.so.6
> >> Reading symbols from /lib/libgcc_s.so.1...done.
> >> Loaded symbols for /lib/libgcc_s.so.1
> >> 0x00ecd402 in __kernel_vsyscall ()
> >> (gdb) continue
> >> Continuing.
> >> Program received signal SIGSEGV, Segmentation fault.
> >> 0x06fd4199 in geos::geom::operator<< () from
> >> (gdb) bt
> >> #0 0x06fd4199 in geos::geom::operator<< () from
> >> #1 0x06fd42a7 in geos::geom::Coordinate::toString () from
> >> #2 0x06fcd98e in geos::algorithm::LineIntersector::toString () from
> >> #3 0x0708094b in geos::operation::overlay::OverlayOp::computeOverlay ()
> >> #4 0x07080e90 in geos::operation::overlay::OverlayOp::getResultGeometry
> >> () from /usr/lib/libgeos-3.0.0rc4.so
> >> #5 0x07081905 in geos::operation::overlay::OverlayOp::overlayOp () from
> >> #6 0x004a8721 in geos::operation::overlay::overlayOp::operator() ()
> >> from /usr/lib/libgeos_c.so.1
> >> #7 0x004a8a32 in
> >> geos::geom::BinaryOp<geos::operation::overlay::overlayOp> () from
> >> #8 0x004a4ffc in GEOSIntersection () from /usr/lib/libgeos_c.so.1
> >> #9 0x00f95398 in intersection (fcinfo=0xbf7fedb8) at
> >lwgeom_geos_c.c:882
> >> #10 0x081367fc in ExecMakeFunctionResult (fcache=0x9d82ac0,
> >> econtext=0x99e0a40, isNull=0xbf7ff0ff "",
> >> isDone=0x0) at execQual.c:1095
> >> (gdb)
> >> Carl Anderson
> >> GIS Manager Fulton County, Georgia
> >> carl.anderson at co.fulton.ga.us
> >> 404.730.8026
> >> _______________________________________________
> >> geos-devel mailing list
> >> geos-devel at geos.refractions.net
> >> http://geos.refractions.net/mailman/listinfo/geos-devel
> > () ASCII Ribbon Campaign
> > /\ Keep it simple!
> ><run>
> ><precisionModel type="FLOATING"/>
> ><case>
> ><a>
> ></a>
> ><b>
> ></b>
> ><test>
> > <op name="intersection">GEOMETRYCOLLECTION EMPTY</op>
> ></test>
> ></case>
> ></run>
> Carl Anderson
> 404.730.8026
/\ Keep it simple!
