[geos-devel] signal 11 with GEOS rc4_svn and postgis 1.2.1
Carl Anderson
carl.anderson at co.fulton.ga.us
Tue Feb 20 11:06:02 EST 2007
WRT the latest Signal11
I compiled all debugging off in GEOS and no longer see it. I will retry
and let you know.
There is some lint that no longer works, hidden in #ifdef debugging
blocks.
try ./configure CXXFLAGS=-DGEOS_DEBUG to see some of the problems.
I have run into the nasty bug you mentioned a week or so ago.
I enabled GEOS_DEBUG in overlay/PolygonBuilder.cpp
and ran XMLTester on the problem test.
I see that inResult is set to 0 for both Directed Edged parts of the
Edge of the problem ring.
From there buildMaximalEdgeRing skips the Edge entirely when building a
Polygon.
The hole allocation routine then assumes the unallocated ring is a hole
and attempts to assign
the hole to a shell and doesn't find any.
So I am back tracking through the mechanism that sets inResult for a
Directed Edge to see why
the problem ring does not get tagged as inResult.
C.
strk at refractions.net wrote:
> On Fri, Feb 16, 2007 at 06:50:09PM -0500, Carl Anderson wrote:
> > I ran it through XMLTester without any problems.
> > I got a production PostGIS and a development PostGIS server to crash
> > with the SQL statement.
> Here's my result:
> =# select astext(intersection('POLYGON((0 0,0 1,1 1,1 0,0 0))',
> 'POLYGON((10 10,10 11,11 11,11 10,10 10))'));
> GEOMETRYCOLLECTION EMPTY
> PGSQL versioN;
> PostgreSQL 8.1.8 on i486-pc-linux-gnu, compiled by GCC
> gcc-4.0.gcc-opt (GCC) 4.0.3 (Ubuntu 4.0.3-1ubuntu5)
> Postgis versions:
> POSTGIS="1.2.0" GEOS="3.0.0rc4-CAPI-1.3.2" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STATS
> POSTGIS="1.2.1" GEOS="3.0.0rc4-CAPI-1.3.2" PROJ="Rel. 4.4.9, 29 Oct
> 2004" USE_STATS
> --strk;
> > >The attached XML can be run by GEOS's XMLTester standalone, to
> > >get PostGIS out of the way.
> > >It works fine here, with both inlines enabled or disabled.
> > >Do you get a segfault on your side ?
> > >--strk;
> > >On Fri, Feb 16, 2007 at 05:05:51PM -0500, Carl Anderson wrote:
> > >> I am getting Signal 11 faults from geos through Postgis in the
> > >> following example,
> > >> where the geometries a and b do not really intersect.
> > >> select intersection(a, b) from
> > >> (select geometry('POLYGON((0 0,0 1,1 1,1 0,0 0))') as a ,
> > >> geometry('POLYGON((10 10,10 11,11 11,11 10,10 10))') as b
> > >> ) as part
> > >> backtrace from Postgres 8.1.6, PostGIS 1.2.1
> > >> Reading symbols from /usr/lib/libgeos-3.0.0rc4.so...done.
> > >> Loaded symbols for /usr/lib/libgeos-3.0.0rc4.so
> > >> Reading symbols from /usr/lib/libstdc++.so.6...done.
> > >> Loaded symbols for /usr/lib/libstdc++.so.6
> > >> Reading symbols from /lib/libgcc_s.so.1...done.
> > >> Loaded symbols for /lib/libgcc_s.so.1
> > >> 0x00ecd402 in __kernel_vsyscall ()
> > >> (gdb) continue
> > >> Continuing.
> > >> Program received signal SIGSEGV, Segmentation fault.
> > >> 0x06fd4199 in geos::geom::operator<< () from
> > >> (gdb) bt
> > >> #0 0x06fd4199 in geos::geom::operator<< () from
> > >> #1 0x06fd42a7 in geos::geom::Coordinate::toString () from
> > >> #2 0x06fcd98e in geos::algorithm::LineIntersector::toString () from
> > >> #3 0x0708094b in
> geos::operation::overlay::OverlayOp::computeOverlay ()
> > >> #4 0x07080e90 in
> geos::operation::overlay::OverlayOp::getResultGeometry
> > >> () from /usr/lib/libgeos-3.0.0rc4.so
> > >> #5 0x07081905 in geos::operation::overlay::OverlayOp::overlayOp
> () from
> > >> #6 0x004a8721 in geos::operation::overlay::overlayOp::operator() ()
> > >> from /usr/lib/libgeos_c.so.1
> > >> #7 0x004a8a32 in
> > >> geos::geom::BinaryOp<geos::operation::overlay::overlayOp> () from
> > >> #8 0x004a4ffc in GEOSIntersection () from /usr/lib/libgeos_c.so.1
> > >> #9 0x00f95398 in intersection (fcinfo=0xbf7fedb8) at
> > >lwgeom_geos_c.c:882
> > >> #10 0x081367fc in ExecMakeFunctionResult (fcache=0x9d82ac0,
> > >> econtext=0x99e0a40, isNull=0xbf7ff0ff "",
> > >> isDone=0x0) at execQual.c:1095
> > >> (gdb)
> > >> Carl Anderson
> > >> GIS Manager Fulton County, Georgia
> > >> 404.730.8026
> > >> _______________________________________________
> > >> geos-devel mailing list
> > >> geos-devel at geos.refractions.net
> > >> http://geos.refractions.net/mailman/listinfo/geos-devel
> > > () ASCII Ribbon Campaign
> > > /\ Keep it simple!
> > ><run>
> > ><precisionModel type="FLOATING"/>
> > ><case>
> > ><a>
> > ></a>
> > ><b>
> > ></b>
> > ><test>
> > > <op name="intersection">GEOMETRYCOLLECTION EMPTY</op>
> > ></test>
> > ></case>
> > ></run>
> > Carl Anderson
> > 404.730.8026
> /\ Keep it simple!
Carl Anderson
404.730.8026
