[geos-devel] nasty ring bug
strk at refractions.net
Wed Feb 21 05:07:26 EST 2007
On a second look, he "expected" result inside badguy.xml seems
bogus. It seems it expects many circles to be removed from input.
IIRC I got the "expected" result from JTS, so this might be a bug
in it !
I can't visually check results as QGIS 0.7.4 segfaults on imput :(
If you have a more recent QGIS or any other gis viewer, you can
call XMLTester with -v --sql-output to produce an SQL file for
importing into a table.
Attached the badguy.xml file.
--strk;
On Wed, Feb 21, 2007 at 10:28:39AM +0100, strk at refractions.net wrote:
> All tests i nGEOS testsuite still pass with this patch,
> and the badguy.xml testcase doesn't abort. Still, the result
> for badguy.xml doesn't seem completely fine. A couple of cirlcles
> are missing from the obtained result.
> Can you send me the bug_nasty.xml and hole_red.xml files to include
> in repository ?
> Can you find the badguy.xml testcase or should I send it to you ?
> --strk;
> On Wed, Feb 21, 2007 at 12:25:39AM -0500, Carl Anderson wrote:
> > strk,
> > This patch avoids the defective logic (that exists later, somewhere)
> > It makes a logic short circuit more robust instead of fixing the
> > underlying logic defect.
> > So be it.
> > It works for me.. for now.
> > I'll let you know how further testing goes.
> > bug_nasty.xml
> > and
> > hole_red.xml
> > both pass testing with this patch.
> > --- source/operation/buffer/SubgraphDepthLocater.cpp (revision 1972)
> > +++ source/operation/buffer/SubgraphDepthLocater.cpp (working copy)
> > @@ -180,11 +180,16 @@
> > BufferSubgraph *bsg=(*subgraphs)[i];
> > +#ifdef GEOS_DEBUG > 1
> > + std::cerr << "findStabbedSegments envelope: " <<
> > bsg->getEnvelope() << " RayLeftpt: " << stabbingRayLeftPt << std::endl;
> > +#endif
> > // optimization - don't bother checking subgraphs
> > // which the ray does not intersect
> > Envelope *env = bsg->getEnvelope();
> > if ( stabbingRayLeftPt.y < env->getMinY()
> > - || stabbingRayLeftPt.y > env->getMaxY() )
> > + || stabbingRayLeftPt.y > env->getMaxY()
> > + || stabbingRayLeftPt.x < env->getMinX()
> > + || stabbingRayLeftPt.x > env->getMaxX())
> > continue;
> > findStabbedSegments(stabbingRayLeftPt,
> > bsg->getDirectedEdges(),
> > C.
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
> () ASCII Ribbon Campaign
> /\ Keep it simple!
/\ Keep it simple!
<run>
<!--precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/-->
<precisionModel type="FLOATING"/>
<case>
<desc>Big Bad Nasty buffer</desc>
<a>
GEOMETRYCOLLECTION (MULTIPOLYGON (((3144083.7883107070811093 10078712.6012399587780237,
3144048.9466011249460280 10078747.4429495409131050,
3144020.5386967407539487 10078803.1966011244803667,
3144010.7500000000000000 10078865.0000000000000000,
3144020.5386967407539487 10078926.8033988755196333,
3144048.9466011249460280 10078982.5570504590868950,
3144093.1929495413787663 10079026.8033988755196333,
3144138.6631982573308051 10079049.9716477897018194,
3144145.2886967407539487 10079091.8033988755196333,
3144159.6389670395292342 10079119.9673901218920946,
3144163.1983127109706402 10079142.4402142446488142,
3144191.6062170951627195 10079198.1938658282160759,
3144235.8525655115954578 10079242.4402142446488142,
3144291.6062170951627195 10079270.8481186274439096,
3144300.3315549301914871 10079272.2300763763487339,
3144296.2500000000000000 10079298.0000000000000000,
3144299.1934952498413622 10079316.5844975933432579,
3144280.5386967407539487 10079353.1966011244803667,
3144270.7500000000000000 10079415.0000000000000000,
3144280.0666346335783601 10079473.8229160327464342,
3144271.4466011249460280 10079482.4429495409131050,
3144243.0386967407539487 10079538.1966011244803667,
3144236.3288886700756848 10079580.5606619957834482,
3144217.4466011249460280 10079599.4429495409131050,
3144189.0386967407539487 10079655.1966011244803667,
3144179.2500000000000000 10079717.0000000000000000,
3144189.0386967407539487 10079778.8033988755196333,
3144217.4466011249460280 10079834.5570504590868950,
3144261.6929495413787663 10079878.8033988755196333,
3144317.4466011249460280 10079907.2113032583147287,
3144379.2500000000000000 10079917.0000000000000000,
3144411.5590361021459103 10079911.8827513996511698,
3144413.2886967407539487 10079922.8033988755196333,
3144441.6966011249460280 10079978.5570504590868950,
3144485.9429495413787663 10080022.8033988755196333,
3144541.6966011249460280 10080051.2113032583147287,
3144603.5000000000000000 10080061.0000000000000000,
3144665.3033988750539720 10080051.2113032583147287,
3144721.0570504586212337 10080022.8033988755196333,
3144765.3033988750539720 10079978.5570504590868950,
3144793.7113032592460513 10079922.8033988755196333,
3144803.5000000000000000 10079861.0000000000000000,
3144793.7113032592460513 10079799.1966011244803667,
3144765.3033988750539720 10079743.4429495409131050,
3144735.0586849180981517 10079713.1982355844229460,
3144740.0000000000000000 10079682.0000000000000000,
3144730.2113032592460513 10079620.1966011244803667,
3144701.8033988750539720 10079564.4429495409131050,
3144683.2366796284914017 10079545.8762302938848734,
3144726.5570504586212337 10079523.8033988755196333,
3144770.8033988750539720 10079479.5570504590868950,
3144799.2113032592460513 10079423.8033988755196333,
3144809.0000000000000000 10079362.0000000000000000,
3144799.2113032592460513 10079300.1966011244803667,
3144770.8033988750539720 10079244.4429495409131050,
3144742.6100971987470984 10079216.2496478650718927,
3144749.4613032592460513 10079202.8033988755196333,
3144759.2500000000000000 10079141.0000000000000000,
3144749.4613032592460513 10079079.1966011244803667,
3144721.0533988750539720 10079023.4429495409131050,
3144676.8070504586212337 10078979.1966011244803667,
3144621.0533988750539720 10078950.7886967416852713,
3144592.1650020405650139 10078946.2132241781800985,
3144596.0000000000000000 10078922.0000000000000000,
3144591.6861204565502703 10078894.7632364984601736,
3144633.0533988750539720 10078888.2113032583147287,
3144688.8070504586212337 10078859.8033988755196333,
3144733.0533988750539720 10078815.5570504590868950,
3144761.4613032592460513 10078759.8033988755196333,
3144771.2500000000000000 10078698.0000000000000000,
3144761.4613032592460513 10078636.1966011244803667,
3144733.0533988750539720 10078580.4429495409131050,
3144688.8070504586212337 10078536.1966011244803667,
3144633.0533988750539720 10078507.7886967416852713,
3144619.8000165307894349 10078505.6895671971142292,
3144616.3070504586212337 10078502.1966011244803667,
3144560.5533988750539720 10078473.7886967416852713,
3144543.7354436498135328 10078471.1249943152070045,
3144539.8070504586212337 10078467.1966011244803667,
3144484.0533988750539720 10078438.7886967416852713,
3144422.2500000000000000 10078429.0000000000000000,
3144360.4466011249460280 10078438.7886967416852713,
3144304.6929495413787663 10078467.1966011244803667,
3144260.4466011249460280 10078511.4429495409131050,
3144255.9190343273803592 10078520.3287997022271156,
3144221.4466011249460280 10078525.7886967416852713,
3144165.6929495413787663 10078554.1966011244803667,
3144121.4466011249460280 10078598.4429495409131050,
3144093.0386967407539487 10078654.1966011244803667,
3144083.7883107070811093 10078712.6012399587780237)),
((3144355.5287439506500959 10081795.1419496573507786,
3144316.7500000000000000 10081789.0000000000000000,
3144254.9466011249460280 10081798.7886967416852713,
3144199.1929495413787663 10081827.1966011244803667,
3144154.9466011249460280 10081871.4429495409131050,
3144126.5386967407539487 10081927.1966011244803667,
3144116.7500000000000000 10081989.0000000000000000,
3144126.5386967407539487 10082050.8033988755196333,
3144154.9466011249460280 10082106.5570504590868950,
3144199.1929495413787663 10082150.8033988755196333,
3144254.9466011249460280 10082179.2113032583147287,
3144316.7500000000000000 10082189.0000000000000000,
3144378.5533988750539720 10082179.2113032583147287,
3144434.3070504586212337 10082150.8033988755196333,
3144478.5533988750539720 10082106.5570504590868950,
3144506.9613032592460513 10082050.8033988755196333,
3144512.9712560493499041 10082012.8580503426492214,
3144551.7500000000000000 10082019.0000000000000000,
3144613.5533988750539720 10082009.2113032583147287,
3144669.3070504586212337 10081980.8033988755196333,
3144713.5533988750539720 10081936.5570504590868950,
3144741.9613032592460513 10081880.8033988755196333,
3144751.7500000000000000 10081819.0000000000000000,
3144741.9613032592460513 10081757.1966011244803667,
3144713.5533988750539720 10081701.4429495409131050,
3144686.8604493341408670 10081674.7500000000000000,
3144688.0533988750539720 10081673.5570504590868950,
3144716.4613032592460513 10081617.8033988755196333,
3144726.2500000000000000 10081556.0000000000000000,
3144716.4613032592460513 10081494.1966011244803667,
3144688.0533988750539720 10081438.4429495409131050,
3144643.8070504586212337 10081394.1966011244803667,
3144588.0533988750539720 10081365.7886967416852713,
3144526.2500000000000000 10081356.0000000000000000,
3144464.4466011249460280 10081365.7886967416852713,
3144408.6929495413787663 10081394.1966011244803667,
3144364.4466011249460280 10081438.4429495409131050,
3144336.0386967407539487 10081494.1966011244803667,
3144326.2500000000000000 10081556.0000000000000000,
3144336.0386967407539487 10081617.8033988755196333,
3144364.4466011249460280 10081673.5570504590868950,
3144391.1395506658591330 10081700.2500000000000000,
3144389.9466011249460280 10081701.4429495409131050,
3144361.5386967407539487 10081757.1966011244803667,
3144355.5287439506500959 10081795.1419496573507786)),
((3143226.6166262058541179 10080950.7475066352635622,
3143216.8279294651001692 10080888.9441077597439289,
3143188.4200250809080899 10080833.1904561761766672,
3143144.1736766644753516 10080788.9441077597439289,
3143088.4200250809080899 10080760.5362033769488335,
3143026.6166262058541179 10080750.7475066352635622,
3142964.8132273308001459 10080760.5362033769488335,
3142909.0595757472328842 10080788.9441077597439289,
3142864.8132273308001459 10080833.1904561761766672,
3142836.4053229466080666 10080888.9441077597439289,
3142826.6166262058541179 10080950.7475066352635622,
3142836.4053229466080666 10081012.5509055107831955,
3142864.8132273308001459 10081068.3045570943504572,
3142909.0595757472328842 10081112.5509055107831955,
3142964.8132273308001459 10081140.9588098935782909,
3143026.6166262058541179 10081150.7475066352635622,
3143088.4200250809080899 10081140.9588098935782909,
3143144.1736766644753516 10081112.5509055107831955,
3143188.4200250809080899 10081068.3045570943504572,
3143216.8279294651001692 10081012.5509055107831955,
3143226.6166262058541179 10080950.7475066352635622)),
((3142555.7500000000000000 10080107.0000000000000000,
3142545.9613032592460513 10080045.1966011244803667,
3142517.5533988750539720 10079989.4429495409131050,
3142473.3070504586212337 10079945.1966011244803667,
3142417.5533988750539720 10079916.7886967416852713,
3142355.7500000000000000 10079907.0000000000000000,
3142293.9466011249460280 10079916.7886967416852713,
3142238.1929495413787663 10079945.1966011244803667,
3142193.9466011249460280 10079989.4429495409131050,
3142165.5386967407539487 10080045.1966011244803667,
3142155.7500000000000000 10080107.0000000000000000,
3142165.5386967407539487 10080168.8033988755196333,
3142193.9466011249460280 10080224.5570504590868950,
3142238.1929495413787663 10080268.8033988755196333,
3142293.9466011249460280 10080297.2113032583147287,
3142355.7500000000000000 10080307.0000000000000000,
3142417.5533988750539720 10080297.2113032583147287,
3142473.3070504586212337 10080268.8033988755196333,
3142517.5533988750539720 10080224.5570504590868950,
3142545.9613032592460513 10080168.8033988755196333,
3142555.7500000000000000 10080107.0000000000000000)),
((3142168.5456810002215207 10079985.7807899992913008,
3142158.7569842594675720 10079923.9773911237716675,
3142130.3490798752754927 10079868.2237395402044058,
3142086.1027314588427544 10079823.9773911237716675,
3142030.3490798752754927 10079795.5694867409765720,
3141968.5456810002215207 10079785.7807899992913008,
3141906.7422821251675487 10079795.5694867409765720,
3141850.9886305416002870 10079823.9773911237716675,
3141806.7422821251675487 10079868.2237395402044058,
3141778.3343777409754694 10079923.9773911237716675,
3141768.5456810002215207 10079985.7807899992913008,
3141778.3343777409754694 10080047.5841888748109341,
3141806.7422821251675487 10080103.3378404583781958,
3141850.9886305416002870 10080147.5841888748109341,
3141906.7422821251675487 10080175.9920932576060295,
3141968.5456810002215207 10080185.7807899992913008,
3142030.3490798752754927 10080175.9920932576060295,
3142086.1027314588427544 10080147.5841888748109341,
3142130.3490798752754927 10080103.3378404583781958,
3142158.7569842594675720 10080047.5841888748109341,
3142168.5456810002215207 10079985.7807899992913008)),
((3140758.7500000000000000 10079094.0000000000000000,
3140748.9613032592460513 10079032.1966011244803667,
3140720.5533988750539720 10078976.4429495409131050,
3140676.3070504586212337 10078932.1966011244803667,
3140620.5533988750539720 10078903.7886967416852713,
3140558.7500000000000000 10078894.0000000000000000,
3140496.9466011249460280 10078903.7886967416852713,
3140441.1929495413787663 10078932.1966011244803667,
3140396.9466011249460280 10078976.4429495409131050,
3140368.5386967407539487 10079032.1966011244803667,
3140358.7500000000000000 10079094.0000000000000000,
3140368.5386967407539487 10079155.8033988755196333,
3140396.9466011249460280 10079211.5570504590868950,
3140441.1929495413787663 10079255.8033988755196333,
3140496.9466011249460280 10079284.2113032583147287,
3140558.7500000000000000 10079294.0000000000000000,
3140620.5533988750539720 10079284.2113032583147287,
3140676.3070504586212337 10079255.8033988755196333,
3140720.5533988750539720 10079211.5570504590868950,
3140748.9613032592460513 10079155.8033988755196333,
3140758.7500000000000000 10079094.0000000000000000)),
((3139987.2500000000000000 10079912.0000000000000000,
3139977.4613032592460513 10079850.1966011244803667,
3139949.0533988750539720 10079794.4429495409131050,
3139904.8070504586212337 10079750.1966011244803667,
3139849.0533988750539720 10079721.7886967416852713,
3139787.2500000000000000 10079712.0000000000000000,
3139725.4466011249460280 10079721.7886967416852713,
3139669.6929495413787663 10079750.1966011244803667,
3139625.4466011249460280 10079794.4429495409131050,
3139597.0386967407539487 10079850.1966011244803667,
3139587.2500000000000000 10079912.0000000000000000,
3139597.0386967407539487 10079973.8033988755196333,
3139625.4466011249460280 10080029.5570504590868950,
3139669.6929495413787663 10080073.8033988755196333,
3139725.4466011249460280 10080102.2113032583147287,
3139787.2500000000000000 10080112.0000000000000000,
3139849.0533988750539720 10080102.2113032583147287,
3139904.8070504586212337 10080073.8033988755196333,
3139949.0533988750539720 10080029.5570504590868950,
3139977.4613032592460513 10079973.8033988755196333,
3139987.2500000000000000 10079912.0000000000000000)),
((3138644.4854970001615584 10080523.2817800007760525,
3138634.6968002594076097 10080461.4783811252564192,
3138606.2888958752155304 10080405.7247295416891575,
3138562.0425474587827921 10080361.4783811252564192,
3138506.2888958752155304 10080333.0704767424613237,
3138444.4854970001615584 10080323.2817800007760525,
3138382.6820981251075864 10080333.0704767424613237,
3138326.9284465415403247 10080361.4783811252564192,
3138282.6820981251075864 10080405.7247295416891575,
3138254.2741937409155071 10080461.4783811252564192,
3138244.4854970001615584 10080523.2817800007760525,
3138254.2741937409155071 10080585.0851788762956858,
3138282.6820981251075864 10080640.8388304598629475,
3138326.9284465415403247 10080685.0851788762956858,
3138382.6820981251075864 10080713.4930832590907812,
3138444.4854970001615584 10080723.2817800007760525,
3138506.2888958752155304 10080713.4930832590907812,
3138562.0425474587827921 10080685.0851788762956858,
3138606.2888958752155304 10080640.8388304598629475,
3138634.6968002594076097 10080585.0851788762956858,
3138644.4854970001615584 10080523.2817800007760525)),
((3137662.8895506658591330 10084932.0000000000000000,
3137629.4466011249460280 10084965.4429495409131050,
3137601.0386967407539487 10085021.1966011244803667,
3137591.2500000000000000 10085083.0000000000000000,
3137601.0386967407539487 10085144.8033988755196333,
3137629.4466011249460280 10085200.5570504590868950,
3137673.6929495413787663 10085244.8033988755196333,
3137722.1154415430501103 10085269.4758908767253160,
3137730.4429495413787663 10085277.8033988755196333,
3137786.1966011249460280 10085306.2113032583147287,
3137848.0000000000000000 10085316.0000000000000000,
3137909.8033988750539720 10085306.2113032583147287,
3137965.5570504586212337 10085277.8033988755196333,
3138009.8033988750539720 10085233.5570504590868950,
3138038.2113032592460513 10085177.8033988755196333,
3138048.0000000000000000 10085116.0000000000000000,
3138045.6135819763876498 10085100.9327495880424976,
3138081.7420749431475997 10085064.8042566217482090,
3138110.1499793273396790 10085009.0506050381809473,
3138119.9386760680936277 10084947.2472061626613140,
3138110.1499793273396790 10084885.4438072871416807,
3138081.7420749431475997 10084829.6901557035744190,
3138037.4957265267148614 10084785.4438072871416807,
3137998.0263899806886911 10084765.3331758435815573,
3137992.4613032592460513 10084730.1966011244803667,
3137964.0533988750539720 10084674.4429495409131050,
3137919.8070504586212337 10084630.1966011244803667,
3137864.0533988750539720 10084601.7886967416852713,
3137802.2500000000000000 10084592.0000000000000000,
3137740.4466011249460280 10084601.7886967416852713,
3137684.6929495413787663 10084630.1966011244803667,
3137640.4466011249460280 10084674.4429495409131050,
3137612.0386967407539487 10084730.1966011244803667,
3137602.2500000000000000 10084792.0000000000000000,
3137612.0386967407539487 10084853.8033988755196333,
3137640.4466011249460280 10084909.5570504590868950,
3137662.8895506658591330 10084932.0000000000000000)),
((3136096.2448901482857764 10088943.4383649379014969,
3136104.5386967407539487 10088995.8033988755196333,
3136132.9466011249460280 10089051.5570504590868950,
3136175.7516472581773996 10089094.3620965927839279,
3136173.7500000000000000 10089107.0000000000000000,
3136183.4084564736112952 10089167.9810941927134991,
3136168.9466011249460280 10089182.4429495409131050,
3136151.5460015009157360 10089216.5935491640120745,
3136132.6966011249460280 10089235.4429495409131050,
3136104.2886967407539487 10089291.1966011244803667,
3136094.5000000000000000 10089353.0000000000000000,
3136104.2886967407539487 10089414.8033988755196333,
3136132.6966011249460280 10089470.5570504590868950,
3136176.9429495413787663 10089514.8033988755196333,
3136232.6966011249460280 10089543.2113032583147287,
3136294.5000000000000000 10089553.0000000000000000,
3136356.3033988750539720 10089543.2113032583147287,
3136412.0570504586212337 10089514.8033988755196333,
3136456.3033988750539720 10089470.5570504590868950,
3136473.7039984990842640 10089436.4064508359879255,
3136492.5533988750539720 10089417.5570504590868950,
3136520.9613032592460513 10089361.8033988755196333,
3136530.2258268320001662 10089303.3094991333782673,
3136547.6966011249460280 10089312.2113032583147287,
3136609.5000000000000000 10089322.0000000000000000,
3136636.1373706669546664 10089317.7810549549758434,
3136678.1966011249460280 10089339.2113032583147287,
3136740.0000000000000000 10089349.0000000000000000,
3136781.2902805083431304 10089342.4602620303630829,
3136788.7886967407539487 10089389.8033988755196333,
3136813.1412944286130369 10089437.5980629343539476,
3136810.2886967407539487 10089443.1966011244803667,
3136803.4164477470330894 10089486.5862736199051142,
3136790.4429495413787663 10089493.1966011244803667,
3136746.1966011249460280 10089537.4429495409131050,
3136734.4187443377450109 10089560.5582950040698051,
3136708.0570504586212337 10089534.1966011244803667,
3136652.3033988750539720 10089505.7886967416852713,
3136590.5000000000000000 10089496.0000000000000000,
3136528.6966011249460280 10089505.7886967416852713,
3136472.9429495413787663 10089534.1966011244803667,
3136428.6966011249460280 10089578.4429495409131050,
3136400.2886967407539487 10089634.1966011244803667,
3136390.5000000000000000 10089696.0000000000000000,
3136400.2886967407539487 10089757.8033988755196333,
3136428.6966011249460280 10089813.5570504590868950,
3136472.9429495413787663 10089857.8033988755196333,
3136528.6966011249460280 10089886.2113032583147287,
3136538.3519245618954301 10089887.7405562568455935,
3136511.9429495413787663 10089901.1966011244803667,
3136467.6966011249460280 10089945.4429495409131050,
3136457.9740605228580534 10089964.5245098676532507,
3136429.0533988750539720 10089949.7886967416852713,
3136367.2500000000000000 10089940.0000000000000000,
3136305.4466011249460280 10089949.7886967416852713,
3136249.6929495413787663 10089978.1966011244803667,
3136219.0000000000000000 10090008.8895506653934717,
3136181.3070504586212337 10089971.1966011244803667,
3136125.5533988750539720 10089942.7886967416852713,
3136063.7500000000000000 10089933.0000000000000000,
3136001.9466011249460280 10089942.7886967416852713,
3135946.1929495413787663 10089971.1966011244803667,
3135901.9466011249460280 10090015.4429495409131050,
3135873.5386967407539487 10090071.1966011244803667,
3135863.7500000000000000 10090133.0000000000000000,
3135873.5386967407539487 10090194.8033988755196333,
3135901.9466011249460280 10090250.5570504590868950,
3135946.1929495413787663 10090294.8033988755196333,
3136001.9466011249460280 10090323.2113032583147287,
3136063.7500000000000000 10090333.0000000000000000,
3136125.5533988750539720 10090323.2113032583147287,
3136181.3070504586212337 10090294.8033988755196333,
3136212.0000000000000000 10090264.1104493346065283,
3136249.6929495413787663 10090301.8033988755196333,
3136305.4466011249460280 10090330.2113032583147287,
3136367.2500000000000000 10090340.0000000000000000,
3136429.0533988750539720 10090330.2113032583147287,
3136483.8469625851139426 10090302.2925880812108517,
3136440.6966011249460280 10090345.4429495409131050,
3136412.2886967407539487 10090401.1966011244803667,
3136402.5000000000000000 10090463.0000000000000000,
3136412.2886967407539487 10090524.8033988755196333,
3136440.6966011249460280 10090580.5570504590868950,
3136484.9429495413787663 10090624.8033988755196333,
3136540.6966011249460280 10090653.2113032583147287,
3136602.5000000000000000 10090663.0000000000000000,
3136652.1576877986080945 10090655.1349949091672897,
3136669.6966011249460280 10090689.5570504590868950,
3136713.9429495413787663 10090733.8033988755196333,
3136769.6966011249460280 10090762.2113032583147287,
3136831.5000000000000000 10090772.0000000000000000,
3136893.3033988750539720 10090762.2113032583147287,
3136940.2699933997355402 10090738.2806280739605427,
3136955.6966011249460280 10090768.5570504590868950,
3136999.9429495413787663 10090812.8033988755196333,
3137055.6966011249460280 10090841.2113032583147287,
3137117.5000000000000000 10090851.0000000000000000,
3137179.3033988750539720 10090841.2113032583147287,
3137235.0570504586212337 10090812.8033988755196333,
3137279.3033988750539720 10090768.5570504590868950,
3137307.7113032592460513 10090712.8033988755196333,
3137317.5000000000000000 10090651.0000000000000000,
3137307.7113032592460513 10090589.1966011244803667,
3137279.3033988750539720 10090533.4429495409131050,
3137235.0570504586212337 10090489.1966011244803667,
3137179.3033988750539720 10090460.7886967416852713,
3137117.5000000000000000 10090451.0000000000000000,
3137055.6966011249460280 10090460.7886967416852713,
3137008.7300066002644598 10090484.7193719260394573,
3136993.3033988750539720 10090454.4429495409131050,
3136967.5657823677174747 10090428.7053330335766077,
3137026.2500000000000000 10090438.0000000000000000,
3137088.0533988750539720 10090428.2113032583147287,
3137143.8070504586212337 10090399.8033988755196333,
3137188.0533988750539720 10090355.5570504590868950,
3137216.4613032592460513 10090299.8033988755196333,
3137226.2500000000000000 10090238.0000000000000000,
3137216.4613032592460513 10090176.1966011244803667,
3137188.0533988750539720 10090120.4429495409131050,
3137143.8070504586212337 10090076.1966011244803667,
3137088.0533988750539720 10090047.7886967416852713,
3137026.2500000000000000 10090038.0000000000000000,
3137008.4605209683068097 10090040.8175766803324223,
3137000.5533988750539720 10090036.7886967416852713,
3136975.0375925395637751 10090032.7473900355398655,
3136926.0533988750539720 10090007.7886967416852713,
3136864.2500000000000000 10089998.0000000000000000,
3136820.3073407127521932 10090004.9598334990441799,
3136819.7113032592460513 10090001.1966011244803667,
3136791.3033988750539720 10089945.4429495409131050,
3136747.0570504586212337 10089901.1966011244803667,
3136691.3033988750539720 10089872.7886967416852713,
3136681.6480754381045699 10089871.2594437431544065,
3136708.0570504586212337 10089857.8033988755196333,
3136752.3033988750539720 10089813.5570504590868950,
3136764.0812556622549891 10089790.4417049959301949,
3136790.4429495413787663 10089816.8033988755196333,
3136846.1966011249460280 10089845.2113032583147287,
3136908.0000000000000000 10089855.0000000000000000,
3136969.8033988750539720 10089845.2113032583147287,
3137017.3170666922815144 10089821.0018803086131811,
3137026.7886967407539487 10089880.8033988755196333,
3137055.1966011249460280 10089936.5570504590868950,
3137099.4429495413787663 10089980.8033988755196333,
3137155.1966011249460280 10090009.2113032583147287,
3137206.3767160717397928 10090017.3174371197819710,
3137200.2500000000000000 10090056.0000000000000000,
3137210.0386967407539487 10090117.8033988755196333,
3137238.4466011249460280 10090173.5570504590868950,
3137282.6929495413787663 10090217.8033988755196333,
3137338.4466011249460280 10090246.2113032583147287,
3137400.2500000000000000 10090256.0000000000000000,
3137462.0533988750539720 10090246.2113032583147287,
3137517.8070504586212337 10090217.8033988755196333,
3137562.0533988750539720 10090173.5570504590868950,
3137580.8352138139307499 10090136.6956631485372782,
3137613.9429495413787663 10090169.8033988755196333,
3137663.0366533049382269 10090194.8178903516381979,
3137654.4429495413787663 10090199.1966011244803667,
3137610.1966011249460280 10090243.4429495409131050,
3137581.7886967407539487 10090299.1966011244803667,
3137572.0000000000000000 10090361.0000000000000000,
3137581.7886967407539487 10090422.8033988755196333,
3137610.1966011249460280 10090478.5570504590868950,
3137654.4429495413787663 10090522.8033988755196333,
3137710.1966011249460280 10090551.2113032583147287,
3137772.0000000000000000 10090561.0000000000000000,
3137833.8033988750539720 10090551.2113032583147287,
3137889.5570504586212337 10090522.8033988755196333,
3137933.8033988750539720 10090478.5570504590868950,
3137962.2113032592460513 10090422.8033988755196333,
3137972.0000000000000000 10090361.0000000000000000,
3137962.2113032592460513 10090299.1966011244803667,
3137933.8033988750539720 10090243.4429495409131050,
3137889.5570504586212337 10090199.1966011244803667,
3137840.4633466950617731 10090174.1821096483618021,
3137849.0570504586212337 10090169.8033988755196333,
3137893.3033988750539720 10090125.5570504590868950,
3137921.7113032592460513 10090069.8033988755196333,
3137931.5000000000000000 10090008.0000000000000000,
3137921.7113032592460513 10089946.1966011244803667,
3137893.3033988750539720 10089890.4429495409131050,
3137849.0570504586212337 10089846.1966011244803667,
3137825.6397438584826887 10089834.2648874539881945,
3137830.7500000000000000 10089802.0000000000000000,
3137824.8015710324980319 10089764.4430975951254368,
3137826.0570504586212337 10089763.8033988755196333,
3137870.3033988750539720 10089719.5570504590868950,
3137898.7113032592460513 10089663.8033988755196333,
3137908.5000000000000000 10089602.0000000000000000,
3137898.7113032592460513 10089540.1966011244803667,
3137870.3033988750539720 10089484.4429495409131050,
3137826.0570504586212337 10089440.1966011244803667,
3137770.3033988750539720 10089411.7886967416852713,
3137708.5000000000000000 10089402.0000000000000000,
3137646.6966011249460280 10089411.7886967416852713,
3137590.9429495413787663 10089440.1966011244803667,
3137590.3007821356877685 10089440.8387685306370258,
3137566.7515178481116891 10089437.1089314855635166,
3137599.3033988750539720 10089404.5570504590868950,
3137627.7113032592460513 10089348.8033988755196333,
3137637.5000000000000000 10089287.0000000000000000,
3137627.7113032592460513 10089225.1966011244803667,
3137599.3033988750539720 10089169.4429495409131050,
3137555.0570504586212337 10089125.1966011244803667,
3137501.4194367048330605 10089097.8668718673288822,
3137501.9613032592460513 10089096.8033988755196333,
3137511.7500000000000000 10089035.0000000000000000,
3137510.0772214639000595 10089024.4384919833391905,
3137519.0987199507653713 10089029.0351750552654266,
3137524.2886967407539487 10089061.8033988755196333,
3137552.6966011249460280 10089117.5570504590868950,
3137596.9429495413787663 10089161.8033988755196333,
3137652.6966011249460280 10089190.2113032583147287,
3137714.5000000000000000 10089200.0000000000000000,
3137776.3033988750539720 10089190.2113032583147287,
3137832.0570504586212337 10089161.8033988755196333,
3137876.3033988750539720 10089117.5570504590868950,
3137904.7113032592460513 10089061.8033988755196333,
3137914.5000000000000000 10089000.0000000000000000,
3137904.7113032592460513 10088938.1966011244803667,
3137876.3033988750539720 10088882.4429495409131050,
3137832.0570504586212337 10088838.1966011244803667,
3137817.1764938882552087 10088830.6145788487046957,
3137820.5336688482202590 10088824.0257520042359829,
3137838.3033988750539720 10088821.2113032583147287,
3137894.0570504586212337 10088792.8033988755196333,
3137938.3033988750539720 10088748.5570504590868950,
3137966.7113032592460513 10088692.8033988755196333,
3137976.5000000000000000 10088631.0000000000000000,
3137966.7113032592460513 10088569.1966011244803667,
3137938.3033988750539720 10088513.4429495409131050,
3137894.0570504586212337 10088469.1966011244803667,
3137880.5553911239840090 10088462.3171620834618807,
3137889.0000000000000000 10088409.0000000000000000,
3137879.2113032592460513 10088347.1966011244803667,
3137850.8033988750539720 10088291.4429495409131050,
3137806.5570504586212337 10088247.1966011244803667,
3137758.0059733032248914 10088222.4585917145013809,
3137778.2113032592460513 10088182.8033988755196333,
3137787.7919601043686271 10088122.3135122060775757,
3137814.3070504586212337 10088108.8033988755196333,
3137858.5533988750539720 10088064.5570504590868950,
3137886.9613032592460513 10088008.8033988755196333,
3137896.7500000000000000 10087947.0000000000000000,
3137886.9613032592460513 10087885.1966011244803667,
3137858.5533988750539720 10087829.4429495409131050,
3137814.3070504586212337 10087785.1966011244803667,
3137758.5533988750539720 10087756.7886967416852713,
3137734.2991007561795413 10087752.9471933078020811,
3137727.2113032592460513 10087708.1966011244803667,
3137698.8033988750539720 10087652.4429495409131050,
3137662.8106929659843445 10087616.4502436313778162,
3137667.0000000000000000 10087590.0000000000000000,
3137663.7677941177971661 10087569.5926552154123783,
3137674.8033988750539720 10087558.5570504590868950,
3137703.2113032592460513 10087502.8033988755196333,
3137706.6277695260941982 10087481.2326798085123301,
3137737.3033988750539720 10087450.5570504590868950,
3137765.7113032592460513 10087394.8033988755196333,
3137775.5000000000000000 10087333.0000000000000000,
3137765.7113032592460513 10087271.1966011244803667,
3137740.2491629021242261 10087221.2243369668722153,
3137753.7113032592460513 10087194.8033988755196333,
3137763.5000000000000000 10087133.0000000000000000,
3137763.2174330898560584 10087131.2159427441656590,
3137776.9466011249460280 10087138.2113032583147287,
3137838.7500000000000000 10087148.0000000000000000,
3137900.5533988750539720 10087138.2113032583147287,
3137956.3070504586212337 10087109.8033988755196333,
3138000.5533988750539720 10087065.5570504590868950,
3138028.9613032592460513 10087009.8033988755196333,
3138038.7500000000000000 10086948.0000000000000000,
3138028.9613032592460513 10086886.1966011244803667,
3138000.5533988750539720 10086830.4429495409131050,
3137956.3070504586212337 10086786.1966011244803667,
3137900.5533988750539720 10086757.7886967416852713,
3137838.7500000000000000 10086748.0000000000000000,
3137776.9466011249460280 10086757.7886967416852713,
3137721.1929495413787663 10086786.1966011244803667,
3137676.9466011249460280 10086830.4429495409131050,
3137648.5386967407539487 10086886.1966011244803667,
3137638.7500000000000000 10086948.0000000000000000,
3137639.0325669101439416 10086949.7840572558343410,
3137625.3033988750539720 10086942.7886967416852713,
3137563.5000000000000000 10086933.0000000000000000,
3137501.6966011249460280 10086942.7886967416852713,
3137445.9429495413787663 10086971.1966011244803667,
3137401.6966011249460280 10087015.4429495409131050,
3137373.2886967407539487 10087071.1966011244803667,
3137367.2409596536308527 10087109.3805103190243244,
3137337.0570504586212337 10087079.1966011244803667,
3137281.3033988750539720 10087050.7886967416852713,
3137219.5000000000000000 10087041.0000000000000000,
3137157.6966011249460280 10087050.7886967416852713,
3137101.9429495413787663 10087079.1966011244803667,
3137057.6966011249460280 10087123.4429495409131050,
3137029.2886967407539487 10087179.1966011244803667,
3137019.5000000000000000 10087241.0000000000000000,
3137029.2886967407539487 10087302.8033988755196333,
3137057.6966011249460280 10087358.5570504590868950,
3137101.9429495413787663 10087402.8033988755196333,
3137120.3657741928473115 10087412.1902968864887953,
3137103.0386967407539487 10087446.1966011244803667,
3137093.2500000000000000 10087508.0000000000000000,
3137099.6742237601429224 10087548.5609524957835674,
3137058.2500000000000000 10087542.0000000000000000,
3136996.4466011249460280 10087551.7886967416852713,
3136940.6929495413787663 10087580.1966011244803667,
3136896.4466011249460280 10087624.4429495409131050,
3136868.0386967407539487 10087680.1966011244803667,
3136866.3053612671792507 10087691.1404505968093872,
3136826.9429495413787663 10087711.1966011244803667,
3136816.0000000000000000 10087722.1395506653934717,
3136791.0570504586212337 10087697.1966011244803667,
3136735.3033988750539720 10087668.7886967416852713,
3136673.5000000000000000 10087659.0000000000000000,
3136611.6966011249460280 10087668.7886967416852713,
3136594.9562209942378104 10087677.3183464519679546,
3136548.7500000000000000 10087670.0000000000000000,
3136486.9466011249460280 10087679.7886967416852713,
3136431.1929495413787663 10087708.1966011244803667,
3136388.7981554847210646 10087750.5913951806724072,
3136366.3033988750539720 10087706.4429495409131050,
3136322.0570504586212337 10087662.1966011244803667,
3136266.3033988750539720 10087633.7886967416852713,
3136204.5000000000000000 10087624.0000000000000000,
3136142.6966011249460280 10087633.7886967416852713,
3136086.9429495413787663 10087662.1966011244803667,
3136042.6966011249460280 10087706.4429495409131050,
3136014.2886967407539487 10087762.1966011244803667,
3136004.5000000000000000 10087824.0000000000000000,
3136014.2886967407539487 10087885.8033988755196333,
3136042.6966011249460280 10087941.5570504590868950,
3136086.9429495413787663 10087985.8033988755196333,
3136142.6966011249460280 10088014.2113032583147287,
3136204.5000000000000000 10088024.0000000000000000,
3136266.3033988750539720 10088014.2113032583147287,
3136322.0570504586212337 10087985.8033988755196333,
3136364.4518445152789354 10087943.4086048193275928,
3136386.9466011249460280 10087987.5570504590868950,
3136431.1929495413787663 10088031.8033988755196333,
3136486.9466011249460280 10088060.2113032583147287,
3136548.7500000000000000 10088070.0000000000000000,
3136610.5533988750539720 10088060.2113032583147287,
3136627.2937790057621896 10088051.6816535480320454,
3136673.5000000000000000 10088059.0000000000000000,
3136735.3033988750539720 10088049.2113032583147287,
3136791.0570504586212337 10088020.8033988755196333,
3136802.0000000000000000 10088009.8604493346065283,
3136826.9429495413787663 10088034.8033988755196333,
3136882.6966011249460280 10088063.2113032583147287,
3136944.5000000000000000 10088073.0000000000000000,
3137006.3033988750539720 10088063.2113032583147287,
3137015.6092738136649132 10088058.4697231482714415,
3137015.9429495413787663 10088058.8033988755196333,
3137071.6966011249460280 10088087.2113032583147287,
3137133.0717173595912755 10088096.9321666937321424,
3137155.9429495413787663 10088119.8033988755196333,
3137192.0762896002270281 10088138.2142552100121975,
3137187.8859159690327942 10088164.6712330710142851,
3137178.3033988750539720 10088159.7886967416852713,
3137120.7526336428709328 10088150.6735509987920523,
3137117.0533988750539720 10088148.7886967416852713,
3137055.2500000000000000 10088139.0000000000000000,
3137015.3569972878322005 10088145.3184309080243111,
3136988.8033988750539720 10088131.7886967416852713,
3136927.0000000000000000 10088122.0000000000000000,
3136923.0050060567446053 10088122.6327448803931475,
3136868.5000000000000000 10088114.0000000000000000,
3136806.6966011249460280 10088123.7886967416852713,
3136750.9429495413787663 10088152.1966011244803667,
3136706.6966011249460280 10088196.4429495409131050,
3136678.2886967407539487 10088252.1966011244803667,
3136668.5000000000000000 10088314.0000000000000000,
3136678.2886967407539487 10088375.8033988755196333,
3136706.6966011249460280 10088431.5570504590868950,
3136750.9429495413787663 10088475.8033988755196333,
3136806.6966011249460280 10088504.2113032583147287,
3136868.5000000000000000 10088514.0000000000000000,
3136872.4949939432553947 10088513.3672551196068525,
3136927.0000000000000000 10088522.0000000000000000,
3136966.8930027121677995 10088515.6815690919756889,
3136993.4466011249460280 10088529.2113032583147287,
3137025.0086239972151816 10088534.2102365866303444,
3137024.2500000000000000 10088539.0000000000000000,
3137034.0386967407539487 10088600.8033988755196333,
3137062.4466011249460280 10088656.5570504590868950,
3137106.6929495413787663 10088700.8033988755196333,
3137162.4466011249460280 10088729.2113032583147287,
3137206.4558888385072351 10088736.1816896628588438,
3137184.5386967407539487 10088779.1966011244803667,
3137174.7500000000000000 10088841.0000000000000000,
3137181.8106104899197817 10088885.5789401754736900,
3137149.9466011249460280 10088917.4429495409131050,
3137121.5386967407539487 10088973.1966011244803667,
3137111.7500000000000000 10089035.0000000000000000,
3137121.5386967407539487 10089096.8033988755196333,
3137125.6895815860480070 10089104.9499690793454647,
3137098.1966011249460280 10089132.4429495409131050,
3137084.2050387659110129 10089159.9029368143528700,
3137040.8033988750539720 10089137.7886967416852713,
3136979.0000000000000000 10089128.0000000000000000,
3136937.7097194916568696 10089134.5397379696369171,
3136930.2113032592460513 10089087.1966011244803667,
3136927.2413936620578170 10089081.3678253479301929,
3136985.0533988750539720 10089072.2113032583147287,
3137040.8070504586212337 10089043.8033988755196333,
3137085.0533988750539720 10088999.5570504590868950,
3137113.4613032592460513 10088943.8033988755196333,
3137123.2500000000000000 10088882.0000000000000000,
3137113.4613032592460513 10088820.1966011244803667,
3137085.0533988750539720 10088764.4429495409131050,
3137040.8070504586212337 10088720.1966011244803667,
3136985.0533988750539720 10088691.7886967416852713,
3136923.2500000000000000 10088682.0000000000000000,
3136861.4466011249460280 10088691.7886967416852713,
3136805.6929495413787663 10088720.1966011244803667,
3136761.4466011249460280 10088764.4429495409131050,
3136733.0386967407539487 10088820.1966011244803667,
3136723.2500000000000000 10088882.0000000000000000,
3136733.0386967407539487 10088943.8033988755196333,
3136736.0086063379421830 10088949.6321746520698071,
3136713.3626293330453336 10088953.2189450450241566,
3136671.3033988750539720 10088931.7886967416852713,
3136609.5000000000000000 10088922.0000000000000000,
3136547.6966011249460280 10088931.7886967416852713,
3136501.4585896534845233 10088955.3481403198093176,
3136492.7483527418226004 10088946.6379034072160721,
3136494.7500000000000000 10088934.0000000000000000,
3136484.9613032592460513 10088872.1966011244803667,
3136456.5533988750539720 10088816.4429495409131050,
3136412.3070504586212337 10088772.1966011244803667,
3136356.5533988750539720 10088743.7886967416852713,
3136294.7500000000000000 10088734.0000000000000000,
3136232.9466011249460280 10088743.7886967416852713,
3136177.1929495413787663 10088772.1966011244803667,
3136132.9466011249460280 10088816.4429495409131050,
3136112.5051098517142236 10088856.5616350620985031,
3136104.2113032592460513 10088804.1966011244803667,
3136075.8033988750539720 10088748.4429495409131050,
3136031.5570504586212337 10088704.1966011244803667,
3135975.8033988750539720 10088675.7886967416852713,
3135914.0000000000000000 10088666.0000000000000000,
3135852.1966011249460280 10088675.7886967416852713,
3135796.4429495413787663 10088704.1966011244803667,
3135752.1966011249460280 10088748.4429495409131050,
3135723.7886967407539487 10088804.1966011244803667,
3135714.0000000000000000 10088866.0000000000000000,
3135723.7886967407539487 10088927.8033988755196333,
3135752.1966011249460280 10088983.5570504590868950,
3135796.4429495413787663 10089027.8033988755196333,
3135852.1966011249460280 10089056.2113032583147287,
3135914.0000000000000000 10089066.0000000000000000,
3135975.8033988750539720 10089056.2113032583147287,
3136031.5570504586212337 10089027.8033988755196333,
3136075.8033988750539720 10088983.5570504590868950,
3136096.2448901482857764 10088943.4383649379014969),
(3136485.9030374148860574 10090300.7074119187891483,
3136529.0533988750539720 10090257.5570504590868950,
3136538.7759394771419466 10090238.4754901323467493,
3136567.6966011249460280 10090253.2113032583147287,
3136629.5000000000000000 10090263.0000000000000000,
3136673.4426592872478068 10090256.0401665009558201,
3136674.0386967407539487 10090259.8033988755196333,
3136686.3887514141388237 10090284.0417459215968847,
3136664.3033988750539720 10090272.7886967416852713,
3136602.5000000000000000 10090263.0000000000000000,
3136540.6966011249460280 10090272.7886967416852713,
3136485.9030374148860574 10090300.7074119187891483),
(3136780.3612485853955150 10090376.9582540784031153,
3136785.0644705197773874 10090379.3546653483062983,
3136781.8423122013919055 10090379.8650050908327103,
3136780.3612485853955150 10090376.9582540784031153),
(3137440.3076307177543640 10089862.3445054218173027,
3137410.8732839282602072 10089857.6825628802180290,
3137417.0000000000000000 10089819.0000000000000000,
3137408.2699059154838324 10089763.8803552500903606,
3137432.8883759942837059 10089788.4988253284245729,
3137430.7500000000000000 10089802.0000000000000000,
3137440.3076307177543640 10089862.3445054218173027),
(3137367.2201010216958821 10089689.8596516866236925,
3137368.2013436243869364 10089689.3596836086362600,
3137368.4800940845161676 10089691.1196447499096394,
3137367.2201010216958821 10089689.8596516866236925)),
((3136231.0303096468560398 10085856.1326221227645874,
3136237.7886967407539487 10085898.8033988755196333,
3136266.1966011249460280 10085954.5570504590868950,
3136310.4429495413787663 10085998.8033988755196333,
3136324.5768199875019491 10086006.0049655679613352,
3136316.5000000000000000 10086057.0000000000000000,
3136326.2886967407539487 10086118.8033988755196333,
3136354.6966011249460280 10086174.5570504590868950,
3136398.9429495413787663 10086218.8033988755196333,
3136454.6966011249460280 10086247.2113032583147287,
3136515.4759944668039680 10086256.8378134574741125,
3136514.5000000000000000 10086263.0000000000000000,
3136524.2886967407539487 10086324.8033988755196333,
3136552.6966011249460280 10086380.5570504590868950,
3136581.6139158890582621 10086409.4743652231991291,
3136556.7886967407539487 10086458.1966011244803667,
3136552.8244831729680300 10086483.2256605438888073,
3136534.3033988750539720 10086473.7886967416852713,
3136472.5000000000000000 10086464.0000000000000000,
3136410.6966011249460280 10086473.7886967416852713,
3136354.9429495413787663 10086502.1966011244803667,
3136310.6966011249460280 10086546.4429495409131050,
3136282.2886967407539487 10086602.1966011244803667,
3136272.5000000000000000 10086664.0000000000000000,
3136282.2886967407539487 10086725.8033988755196333,
3136310.6966011249460280 10086781.5570504590868950,
3136354.9429495413787663 10086825.8033988755196333,
3136410.6966011249460280 10086854.2113032583147287,
3136472.5000000000000000 10086864.0000000000000000,
3136534.3033988750539720 10086854.2113032583147287,
3136588.3526731925085187 10086826.6718224678188562,
3136596.4466011249460280 10086842.5570504590868950,
3136640.6929495413787663 10086886.8033988755196333,
3136696.4466011249460280 10086915.2113032583147287,
3136758.2500000000000000 10086925.0000000000000000,
3136820.0533988750539720 10086915.2113032583147287,
3136875.8070504586212337 10086886.8033988755196333,
3136898.3848411221988499 10086864.2256082110106945,
3136906.1966011249460280 10086879.5570504590868950,
3136950.4429495413787663 10086923.8033988755196333,
3137006.1966011249460280 10086952.2113032583147287,
3137068.0000000000000000 10086962.0000000000000000,
3137129.8033988750539720 10086952.2113032583147287,
3137185.5570504586212337 10086923.8033988755196333,
3137229.8033988750539720 10086879.5570504590868950,
3137258.2113032592460513 10086823.8033988755196333,
3137264.1893821405246854 10086786.0592942833900452,
3137320.0533988750539720 10086777.2113032583147287,
3137375.8070504586212337 10086748.8033988755196333,
3137420.0533988750539720 10086704.5570504590868950,
3137426.3809318812564015 10086692.1385677065700293,
3137445.4466011249460280 10086729.5570504590868950,
3137489.6929495413787663 10086773.8033988755196333,
3137545.4466011249460280 10086802.2113032583147287,
3137607.2500000000000000 10086812.0000000000000000,
3137669.0533988750539720 10086802.2113032583147287,
3137724.8070504586212337 10086773.8033988755196333,
3137769.0533988750539720 10086729.5570504590868950,
3137797.4613032592460513 10086673.8033988755196333,
3137807.2500000000000000 10086612.0000000000000000,
3137797.4613032592460513 10086550.1966011244803667,
3137769.0533988750539720 10086494.4429495409131050,
3137724.8070504586212337 10086450.1966011244803667,
3137669.0533988750539720 10086421.7886967416852713,
3137607.2500000000000000 10086412.0000000000000000,
3137545.4466011249460280 10086421.7886967416852713,
3137489.6929495413787663 10086450.1966011244803667,
3137445.4466011249460280 10086494.4429495409131050,
3137439.1190681187435985 10086506.8614322934299707,
3137420.0533988750539720 10086469.4429495409131050,
3137375.8070504586212337 10086425.1966011244803667,
3137320.0533988750539720 10086396.7886967416852713,
3137258.2500000000000000 10086387.0000000000000000,
3137196.4466011249460280 10086396.7886967416852713,
3137140.6929495413787663 10086425.1966011244803667,
3137096.4466011249460280 10086469.4429495409131050,
3137068.0386967407539487 10086525.1966011244803667,
3137062.0606178594753146 10086562.9407057166099548,
3137006.1966011249460280 10086571.7886967416852713,
3136987.8706386149860919 10086581.1262410264462233,
3136975.8033988750539720 10086557.4429495409131050,
3136955.2863845042884350 10086536.9259351696819067,
3136985.0533988750539720 10086532.2113032583147287,
3137040.8070504586212337 10086503.8033988755196333,
3137085.0533988750539720 10086459.5570504590868950,
3137113.4613032592460513 10086403.8033988755196333,
3137115.9443011921830475 10086388.1263669151812792,
3137134.9613032592460513 10086350.8033988755196333,
3137144.7500000000000000 10086289.0000000000000000,
3137134.9613032592460513 10086227.1966011244803667,
3137106.5533988750539720 10086171.4429495409131050,
3137062.3070504586212337 10086127.1966011244803667,
3137006.5533988750539720 10086098.7886967416852713,
3136944.7500000000000000 10086089.0000000000000000,
3136922.5149732907302678 10086092.5216822605580091,
3136913.3033988750539720 10086074.4429495409131050,
3136869.0570504586212337 10086030.1966011244803667,
3136813.3033988750539720 10086001.7886967416852713,
3136751.5000000000000000 10085992.0000000000000000,
3136707.3134586480446160 10085998.9984606225043535,
3136706.7113032592460513 10085995.1966011244803667,
3136678.3033988750539720 10085939.4429495409131050,
3136634.0570504586212337 10085895.1966011244803667,
3136619.9231800124980509 10085887.9950344320386648,
3136628.0000000000000000 10085837.0000000000000000,
3136618.2113032592460513 10085775.1966011244803667,
3136601.0651225661858916 10085741.5453267674893141,
3136611.0533988750539720 10085731.5570504590868950,
3136639.4613032592460513 10085675.8033988755196333,
3136649.2500000000000000 10085614.0000000000000000,
3136639.4613032592460513 10085552.1966011244803667,
3136611.0533988750539720 10085496.4429495409131050,
3136566.8070504586212337 10085452.1966011244803667,
3136511.0533988750539720 10085423.7886967416852713,
3136449.2500000000000000 10085414.0000000000000000,
3136387.4466011249460280 10085423.7886967416852713,
3136331.6929495413787663 10085452.1966011244803667,
3136287.4466011249460280 10085496.4429495409131050,
3136259.0386967407539487 10085552.1966011244803667,
3136249.2500000000000000 10085614.0000000000000000,
3136252.1403840421698987 10085632.2491666246205568,
3136241.9466011249460280 10085642.4429495409131050,
3136213.5386967407539487 10085698.1966011244803667,
3136203.7500000000000000 10085760.0000000000000000,
3136213.5386967407539487 10085821.8033988755196333,
3136231.0303096468560398 10085856.1326221227645874)),
((3134593.6112348921597004 10079947.4177208933979273,
3134621.1966011249460280 10080001.5570504590868950,
3134646.5253711529076099 10080026.8858204875141382,
3134650.7886967407539487 10080053.8033988755196333,
3134679.1966011249460280 10080109.5570504590868950,
3134723.4429495413787663 10080153.8033988755196333,
3134779.1966011249460280 10080182.2113032583147287,
3134839.4884620043449104 10080191.7605959009379148,
3134845.0386967407539487 10080226.8033988755196333,
3134873.4466011249460280 10080282.5570504590868950,
3134917.6929495413787663 10080326.8033988755196333,
3134973.4466011249460280 10080355.2113032583147287,
3135035.2500000000000000 10080365.0000000000000000,
3135097.0533988750539720 10080355.2113032583147287,
3135152.8070504586212337 10080326.8033988755196333,
3135197.0533988750539720 10080282.5570504590868950,
3135199.4076970289461315 10080277.9364801682531834,
3135218.7500000000000000 10080281.0000000000000000,
3135280.5533988750539720 10080271.2113032583147287,
3135336.3070504586212337 10080242.8033988755196333,
3135380.5533988750539720 10080198.5570504590868950,
3135408.9613032592460513 10080142.8033988755196333,
3135418.7500000000000000 10080081.0000000000000000,
3135408.9613032592460513 10080019.1966011244803667,
3135398.9626085888594389 10079999.5730579234659672,
3135410.1929495413787663 10080010.8033988755196333,
3135465.9466011249460280 10080039.2113032583147287,
3135527.7500000000000000 10080049.0000000000000000,
3135589.5533988750539720 10080039.2113032583147287,
3135645.3070504586212337 10080010.8033988755196333,
3135689.5533988750539720 10079966.5570504590868950,
3135717.9613032592460513 10079910.8033988755196333,
3135727.7500000000000000 10079849.0000000000000000,
3135718.7410050220787525 10079792.1194443125277758,
3135738.3033988750539720 10079772.5570504590868950,
3135756.1570575837977231 10079737.5172723159193993,
3135800.6966011249460280 10079760.2113032583147287,
3135862.5000000000000000 10079770.0000000000000000,
3135924.3033988750539720 10079760.2113032583147287,
3135972.0387383080087602 10079735.8889329787343740,
3136023.2500000000000000 10079744.0000000000000000,
3136085.0533988750539720 10079734.2113032583147287,
3136140.8070504586212337 10079705.8033988755196333,
3136185.0533988750539720 10079661.5570504590868950,
3136188.0552117130719125 10079655.6656610481441021,
3136198.1929495413787663 10079665.8033988755196333,
3136253.9466011249460280 10079694.2113032583147287,
3136315.7500000000000000 10079704.0000000000000000,
3136377.5533988750539720 10079694.2113032583147287,
3136433.3070504586212337 10079665.8033988755196333,
3136477.5533988750539720 10079621.5570504590868950,
3136505.9613032592460513 10079565.8033988755196333,
3136510.9105303632095456 10079534.5552087500691414,
3136557.4883951130323112 10079541.9324177913367748,
3136619.2917939880862832 10079532.1437210496515036,
3136675.0454455716535449 10079503.7358166668564081,
3136675.7737206560559571 10079503.0075415819883347,
3136686.2954455716535449 10079497.6464549656957388,
3136730.5417939880862832 10079453.4001065492630005,
3136758.9496983722783625 10079397.6464549656957388,
3136768.7383951130323112 10079335.8430560901761055,
3136764.6933787846937776 10079310.3038281183689833,
3136784.1929495413787663 10079329.8033988755196333,
3136839.9466011249460280 10079358.2113032583147287,
3136901.7500000000000000 10079368.0000000000000000,
3136963.5533988750539720 10079358.2113032583147287,
3137019.3070504586212337 10079329.8033988755196333,
3137063.5533988750539720 10079285.5570504590868950,
3137091.9613032592460513 10079229.8033988755196333,
3137101.7500000000000000 10079168.0000000000000000,
3137094.7447667019441724 10079123.7706976532936096,
3137108.0605429499410093 10079097.6370152998715639,
3137117.8492396906949580 10079035.8336164243519306,
3137113.3613052102737129 10079007.4979132991284132,
3137153.0533988750539720 10079001.2113032583147287,
3137208.8070504586212337 10078972.8033988755196333,
3137253.0533988750539720 10078928.5570504590868950,
3137281.4613032592460513 10078872.8033988755196333,
3137291.2500000000000000 10078811.0000000000000000,
3137286.0401947828941047 10078778.1065844167023897,
3137301.9466011249460280 10078786.2113032583147287,
3137336.4518119087442756 10078791.6763917561620474,
3137336.7886967407539487 10078793.8033988755196333,
3137365.1966011249460280 10078849.5570504590868950,
3137409.4429495413787663 10078893.8033988755196333,
3137465.1966011249460280 10078922.2113032583147287,
3137527.0000000000000000 10078932.0000000000000000,
3137588.8033988750539720 10078922.2113032583147287,
3137644.5570504586212337 10078893.8033988755196333,
3137688.8033988750539720 10078849.5570504590868950,
3137717.2113032592460513 10078793.8033988755196333,
3137727.0000000000000000 10078732.0000000000000000,
3137717.2113032592460513 10078670.1966011244803667,
3137688.8033988750539720 10078614.4429495409131050,
3137644.5570504586212337 10078570.1966011244803667,
3137588.8033988750539720 10078541.7886967416852713,
3137554.2981880912557244 10078536.3236082438379526,
3137553.9613032592460513 10078534.1966011244803667,
3137525.5533988750539720 10078478.4429495409131050,
3137481.3070504586212337 10078434.1966011244803667,
3137446.1522091790102422 10078416.2843148205429316,
3137454.7500000000000000 10078362.0000000000000000,
3137444.9613032592460513 10078300.1966011244803667,
3137416.5533988750539720 10078244.4429495409131050,
3137372.3070504586212337 10078200.1966011244803667,
3137316.5533988750539720 10078171.7886967416852713,
3137254.7500000000000000 10078162.0000000000000000,
3137195.1560419476591051 10078171.4387556929141283,
3137189.5533988750539720 10078160.4429495409131050,
3137145.3070504586212337 10078116.1966011244803667,
3137089.5533988750539720 10078087.7886967416852713,
3137027.7500000000000000 10078078.0000000000000000,
3136965.9466011249460280 10078087.7886967416852713,
3136965.7782769156619906 10078087.8744622096419334,
3136961.7113032592460513 10078062.1966011244803667,
3136933.3033988750539720 10078006.4429495409131050,
3136889.0570504586212337 10077962.1966011244803667,
3136833.3033988750539720 10077933.7886967416852713,
3136771.5000000000000000 10077924.0000000000000000,
3136709.6966011249460280 10077933.7886967416852713,
3136653.9429495413787663 10077962.1966011244803667,
3136609.6966011249460280 10078006.4429495409131050,
3136591.7586365658789873 10078041.6481872312724590,
3136563.3070504586212337 10078013.1966011244803667,
3136507.5533988750539720 10077984.7886967416852713,
3136445.7500000000000000 10077975.0000000000000000,
3136383.9466011249460280 10077984.7886967416852713,
3136328.1929495413787663 10078013.1966011244803667,
3136327.2860413272865117 10078014.1035093385726213,
3136288.7500000000000000 10078008.0000000000000000,
3136226.9466011249460280 10078017.7886967416852713,
3136171.1929495413787663 10078046.1966011244803667,
3136126.9466011249460280 10078090.4429495409131050,
3136098.5386967407539487 10078146.1966011244803667,
3136088.7500000000000000 10078208.0000000000000000,
3136090.5227636806666851 10078219.1927893739193678,
3136080.4466011249460280 10078220.7886967416852713,
3136024.6929495413787663 10078249.1966011244803667,
3135980.4466011249460280 10078293.4429495409131050,
3135952.0386967407539487 10078349.1966011244803667,
3135942.2500000000000000 10078411.0000000000000000,
3135952.0386967407539487 10078472.8033988755196333,
3135980.4466011249460280 10078528.5570504590868950,
3136024.6929495413787663 10078572.8033988755196333,
3136080.4466011249460280 10078601.2113032583147287,
3136142.2500000000000000 10078611.0000000000000000,
3136204.0533988750539720 10078601.2113032583147287,
3136222.6337116872891784 10078591.7441610209643841,
3136263.6929495413787663 10078632.8033988755196333,
3136319.4466011249460280 10078661.2113032583147287,
3136381.2500000000000000 10078671.0000000000000000,
3136443.0533988750539720 10078661.2113032583147287,
3136451.8624289273284376 10078656.7228782624006271,
3136474.9429495413787663 10078679.8033988755196333,
3136530.6966011249460280 10078708.2113032583147287,
3136592.5000000000000000 10078718.0000000000000000,
3136654.3033988750539720 10078708.2113032583147287,
3136710.0570504586212337 10078679.8033988755196333,
3136754.3033988750539720 10078635.5570504590868950,
3136759.6214724010787904 10078625.1197434868663549,
3136809.5533988750539720 10078617.2113032583147287,
3136865.3070504586212337 10078588.8033988755196333,
3136909.5533988750539720 10078544.5570504590868950,
3136929.6009893831796944 10078505.2114387173205614,
3136968.1929495413787663 10078543.8033988755196333,
3136996.3310110857710242 10078558.1404573302716017,
3136945.1929495413787663 10078584.1966011244803667,
3136900.9466011249460280 10078628.4429495409131050,
3136872.5386967407539487 10078684.1966011244803667,
3136869.4293080358766019 10078703.8285087700933218,
3136843.1929495413787663 10078717.1966011244803667,
3136798.9466011249460280 10078761.4429495409131050,
3136770.5386967407539487 10078817.1966011244803667,
3136760.7500000000000000 10078879.0000000000000000,
3136765.4770414792001247 10078908.8453653007745743,
3136756.0458408156409860 10078918.2765659652650356,
3136727.6379364314489067 10078974.0302175488322973,
3136717.8492396906949580 10079035.8336164243519306,
3136724.8544729887507856 10079080.0629187710583210,
3136711.5386967407539487 10079106.1966011244803667,
3136701.7500000000000000 10079168.0000000000000000,
3136705.7950163283385336 10079193.5392279718071222,
3136686.2954455716535449 10079174.0396572146564722,
3136630.5417939880862832 10079145.6317528318613768,
3136568.7383951130323112 10079135.8430560901761055,
3136506.9349962379783392 10079145.6317528318613768,
3136451.1813446544110775 10079174.0396572146564722,
3136450.4530695700086653 10079174.7679322995245457,
3136439.9313446544110775 10079180.1290189158171415,
3136402.7769338502548635 10079217.2834297195076942,
3136386.5533988750539720 10079185.4429495409131050,
3136342.3070504586212337 10079141.1966011244803667,
3136286.5533988750539720 10079112.7886967416852713,
3136224.7500000000000000 10079103.0000000000000000,
3136162.9466011249460280 10079112.7886967416852713,
3136107.1929495413787663 10079141.1966011244803667,
3136062.9466011249460280 10079185.4429495409131050,
3136036.6522077289409935 10079237.0486022550612688,
3136014.5533988750539720 10079225.7886967416852713,
3135952.7500000000000000 10079216.0000000000000000,
3135890.9466011249460280 10079225.7886967416852713,
3135889.9214742882177234 10079226.3110249545425177,
3135884.8070504586212337 10079221.1966011244803667,
3135829.0533988750539720 10079192.7886967416852713,
3135767.2500000000000000 10079183.0000000000000000,
3135705.4466011249460280 10079192.7886967416852713,
3135649.6929495413787663 10079221.1966011244803667,
3135605.4466011249460280 10079265.4429495409131050,
3135577.0386967407539487 10079321.1966011244803667,
3135567.2500000000000000 10079383.0000000000000000,
3135568.2905984548851848 10079389.5700800716876984,
3135545.7500000000000000 10079386.0000000000000000,
3135483.9466011249460280 10079395.7886967416852713,
3135461.6323744524270296 10079407.1583631169050932,
3135422.7500000000000000 10079401.0000000000000000,
3135360.9466011249460280 10079410.7886967416852713,
3135305.1929495413787663 10079439.1966011244803667,
3135260.9466011249460280 10079483.4429495409131050,
3135247.8723987876437604 10079509.1025163996964693,
3135192.3033988750539720 10079480.7886967416852713,
3135179.3794527510181069 10079478.7417447678744793,
3135189.0000000000000000 10079418.0000000000000000,
3135179.2113032592460513 10079356.1966011244803667,
3135150.8033988750539720 10079300.4429495409131050,
3135106.5570504586212337 10079256.1966011244803667,
3135050.8033988750539720 10079227.7886967416852713,
3134989.0000000000000000 10079218.0000000000000000,
3134927.1966011249460280 10079227.7886967416852713,
3134871.4429495413787663 10079256.1966011244803667,
3134827.1966011249460280 10079300.4429495409131050,
3134798.7886967407539487 10079356.1966011244803667,
3134789.0000000000000000 10079418.0000000000000000,
3134798.7886967407539487 10079479.8033988755196333,
3134827.1966011249460280 10079535.5570504590868950,
3134832.7565143438987434 10079541.1169636771082878,
3134796.9466011249460280 10079546.7886967416852713,
3134741.1929495413787663 10079575.1966011244803667,
3134729.0547982314601541 10079587.3347524348646402,
3134708.0000000000000000 10079584.0000000000000000,
3134646.1966011249460280 10079593.7886967416852713,
3134590.4429495413787663 10079622.1966011244803667,
3134546.1966011249460280 10079666.4429495409131050,
3134517.7886967407539487 10079722.1966011244803667,
3134508.0000000000000000 10079784.0000000000000000,
3134517.7886967407539487 10079845.8033988755196333,
3134546.1966011249460280 10079901.5570504590868950,
3134590.4429495413787663 10079945.8033988755196333,
3134593.6112348921597004 10079947.4177208933979273),
(3137169.2703358461149037 10078561.1459711864590645,
3137166.7162635060958564 10078577.2717492934316397,
3137152.1689889146946371 10078569.8595426678657532,
3137169.2703358461149037 10078561.1459711864590645)),
((3137593.5000000000000000 10092988.0000000000000000,
3137583.7113032592460513 10092926.1966011244803667,
3137555.3033988750539720 10092870.4429495409131050,
3137511.0570504586212337 10092826.1966011244803667,
3137455.3033988750539720 10092797.7886967416852713,
3137393.5000000000000000 10092788.0000000000000000,
3137331.6966011249460280 10092797.7886967416852713,
3137275.9429495413787663 10092826.1966011244803667,
3137231.6966011249460280 10092870.4429495409131050,
3137203.2886967407539487 10092926.1966011244803667,
3137193.5000000000000000 10092988.0000000000000000,
3137203.2886967407539487 10093049.8033988755196333,
3137231.6966011249460280 10093105.5570504590868950,
3137275.9429495413787663 10093149.8033988755196333,
3137331.6966011249460280 10093178.2113032583147287,
3137393.5000000000000000 10093188.0000000000000000,
3137455.3033988750539720 10093178.2113032583147287,
3137511.0570504586212337 10093149.8033988755196333,
3137555.3033988750539720 10093105.5570504590868950,
3137583.7113032592460513 10093049.8033988755196333,
3137593.5000000000000000 10092988.0000000000000000)),
((3137360.2500000000000000 10094928.0000000000000000,
3137350.4613032592460513 10094866.1966011244803667,
3137322.0533988750539720 10094810.4429495409131050,
3137277.8070504586212337 10094766.1966011244803667,
3137222.0533988750539720 10094737.7886967416852713,
3137160.2500000000000000 10094728.0000000000000000,
3137098.4466011249460280 10094737.7886967416852713,
3137042.6929495413787663 10094766.1966011244803667,
3136998.4466011249460280 10094810.4429495409131050,
3136970.0386967407539487 10094866.1966011244803667,
3136960.2500000000000000 10094928.0000000000000000,
3136970.0386967407539487 10094989.8033988755196333,
3136998.4466011249460280 10095045.5570504590868950,
3137042.6929495413787663 10095089.8033988755196333,
3137098.4466011249460280 10095118.2113032583147287,
3137160.2500000000000000 10095128.0000000000000000,
3137222.0533988750539720 10095118.2113032583147287,
3137277.8070504586212337 10095089.8033988755196333,
3137322.0533988750539720 10095045.5570504590868950,
3137350.4613032592460513 10094989.8033988755196333,
3137360.2500000000000000 10094928.0000000000000000)),
((3137340.0000000000000000 10085508.0000000000000000,
3137330.2113032592460513 10085446.1966011244803667,
3137301.8033988750539720 10085390.4429495409131050,
3137257.5570504586212337 10085346.1966011244803667,
3137201.8033988750539720 10085317.7886967416852713,
3137140.0000000000000000 10085308.0000000000000000,
3137078.1966011249460280 10085317.7886967416852713,
3137022.4429495413787663 10085346.1966011244803667,
3136978.1966011249460280 10085390.4429495409131050,
3136949.7886967407539487 10085446.1966011244803667,
3136940.0000000000000000 10085508.0000000000000000,
3136949.7886967407539487 10085569.8033988755196333,
3136978.1966011249460280 10085625.5570504590868950,
3137022.4429495413787663 10085669.8033988755196333,
3137078.1966011249460280 10085698.2113032583147287,
3137140.0000000000000000 10085708.0000000000000000,
3137201.8033988750539720 10085698.2113032583147287,
3137257.5570504586212337 10085669.8033988755196333,
3137301.8033988750539720 10085625.5570504590868950,
3137330.2113032592460513 10085569.8033988755196333,
3137340.0000000000000000 10085508.0000000000000000)),
((3137315.5000000000000000 10093795.0000000000000000,
3137305.7113032592460513 10093733.1966011244803667,
3137277.3033988750539720 10093677.4429495409131050,
3137233.0570504586212337 10093633.1966011244803667,
3137177.3033988750539720 10093604.7886967416852713,
3137115.5000000000000000 10093595.0000000000000000,
3137053.6966011249460280 10093604.7886967416852713,
3136997.9429495413787663 10093633.1966011244803667,
3136953.6966011249460280 10093677.4429495409131050,
3136925.2886967407539487 10093733.1966011244803667,
3136915.5000000000000000 10093795.0000000000000000,
3136925.2886967407539487 10093856.8033988755196333,
3136953.6966011249460280 10093912.5570504590868950,
3136997.9429495413787663 10093956.8033988755196333,
3137053.6966011249460280 10093985.2113032583147287,
3137115.5000000000000000 10093995.0000000000000000,
3137177.3033988750539720 10093985.2113032583147287,
3137233.0570504586212337 10093956.8033988755196333,
3137277.3033988750539720 10093912.5570504590868950,
3137305.7113032592460513 10093856.8033988755196333,
3137315.5000000000000000 10093795.0000000000000000)),
((3136983.7500000000000000 10093007.0000000000000000,
3136973.9613032592460513 10092945.1966011244803667,
3136945.5533988750539720 10092889.4429495409131050,
3136901.3070504586212337 10092845.1966011244803667,
3136845.5533988750539720 10092816.7886967416852713,
3136783.7500000000000000 10092807.0000000000000000,
3136721.9466011249460280 10092816.7886967416852713,
3136666.1929495413787663 10092845.1966011244803667,
3136621.9466011249460280 10092889.4429495409131050,
3136593.5386967407539487 10092945.1966011244803667,
3136583.7500000000000000 10093007.0000000000000000,
3136593.5386967407539487 10093068.8033988755196333,
3136621.9466011249460280 10093124.5570504590868950,
3136666.1929495413787663 10093168.8033988755196333,
3136721.9466011249460280 10093197.2113032583147287,
3136783.7500000000000000 10093207.0000000000000000,
3136845.5533988750539720 10093197.2113032583147287,
3136901.3070504586212337 10093168.8033988755196333,
3136945.5533988750539720 10093124.5570504590868950,
3136973.9613032592460513 10093068.8033988755196333,
3136983.7500000000000000 10093007.0000000000000000)),
((3136980.2500000000000000 10098846.0000000000000000,
3136970.4613032592460513 10098784.1966011244803667,
3136942.0533988750539720 10098728.4429495409131050,
3136897.8070504586212337 10098684.1966011244803667,
3136842.0533988750539720 10098655.7886967416852713,
3136780.2500000000000000 10098646.0000000000000000,
3136718.4466011249460280 10098655.7886967416852713,
3136662.6929495413787663 10098684.1966011244803667,
3136618.4466011249460280 10098728.4429495409131050,
3136590.0386967407539487 10098784.1966011244803667,
3136580.2500000000000000 10098846.0000000000000000,
3136590.0386967407539487 10098907.8033988755196333,
3136618.4466011249460280 10098963.5570504590868950,
3136662.6929495413787663 10099007.8033988755196333,
3136718.4466011249460280 10099036.2113032583147287,
3136780.2500000000000000 10099046.0000000000000000,
3136842.0533988750539720 10099036.2113032583147287,
3136897.8070504586212337 10099007.8033988755196333,
3136942.0533988750539720 10098963.5570504590868950,
3136970.4613032592460513 10098907.8033988755196333,
3136980.2500000000000000 10098846.0000000000000000)),
((3136479.0811529960483313 10095137.0213648565113544,
3136434.7500000000000000 10095130.0000000000000000,
3136372.9466011249460280 10095139.7886967416852713,
3136317.1929495413787663 10095168.1966011244803667,
3136272.9466011249460280 10095212.4429495409131050,
3136244.5386967407539487 10095268.1966011244803667,
3136234.7500000000000000 10095330.0000000000000000,
3136244.5386967407539487 10095391.8033988755196333,
3136272.9466011249460280 10095447.5570504590868950,
3136317.1929495413787663 10095491.8033988755196333,
3136372.9466011249460280 10095520.2113032583147287,
3136434.7500000000000000 10095530.0000000000000000,
3136496.5533988750539720 10095520.2113032583147287,
3136552.3070504586212337 10095491.8033988755196333,
3136596.5533988750539720 10095447.5570504590868950,
3136624.9613032592460513 10095391.8033988755196333,
3136626.3029040037654340 10095383.3328651431947947,
3136670.6340569998137653 10095390.3542299997061491,
3136732.4374558748677373 10095380.5655332580208778,
3136788.1911074584349990 10095352.1576288752257824,
3136832.4374558748677373 10095307.9112804587930441,
3136860.8453602590598166 10095252.1576288752257824,
3136870.6340569998137653 10095190.3542299997061491,
3136860.8453602590598166 10095128.5508311241865158,
3136832.4374558748677373 10095072.7971795406192541,
3136788.1911074584349990 10095028.5508311241865158,
3136732.4374558748677373 10095000.1429267413914204,
3136670.6340569998137653 10094990.3542299997061491,
3136608.8306581247597933 10095000.1429267413914204,
3136553.0770065411925316 10095028.5508311241865158,
3136508.8306581247597933 10095072.7971795406192541,
3136480.4227537405677140 10095128.5508311241865158,
3136479.0811529960483313 10095137.0213648565113544)),
((3136783.2760279998183250 10091497.3104800004512072,
3136773.4873312590643764 10091435.5070811249315739,
3136745.0794268748722970 10091379.7534295413643122,
3136700.8330784584395587 10091335.5070811249315739,
3136645.0794268748722970 10091307.0991767421364784,
3136583.2760279998183250 10091297.3104800004512072,
3136521.4726291247643530 10091307.0991767421364784,
3136465.7189775411970913 10091335.5070811249315739,
3136421.4726291247643530 10091379.7534295413643122,
3136393.0647247405722737 10091435.5070811249315739,
3136383.2760279998183250 10091497.3104800004512072,
3136393.0647247405722737 10091559.1138788759708405,
3136421.4726291247643530 10091614.8675304595381021,
3136465.7189775411970913 10091659.1138788759708405,
3136521.4726291247643530 10091687.5217832587659359,
3136583.2760279998183250 10091697.3104800004512072,
3136645.0794268748722970 10091687.5217832587659359,
3136700.8330784584395587 10091659.1138788759708405,
3136745.0794268748722970 10091614.8675304595381021,
3136773.4873312590643764 10091559.1138788759708405,
3136783.2760279998183250 10091497.3104800004512072)),
((3135965.9308513822034001 10095193.7913007158786058,
3135934.6161211249418557 10095198.7510667424649000,
3135878.8624695413745940 10095227.1589711252599955,
3135834.6161211249418557 10095271.4053195416927338,
3135806.2082167407497764 10095327.1589711252599955,
3135796.4195199999958277 10095388.9623700007796288,
3135806.2082167407497764 10095450.7657688762992620,
3135834.6161211249418557 10095506.5194204598665237,
3135878.8624695413745940 10095550.7657688762992620,
3135934.6161211249418557 10095579.1736732590943575,
3135996.4195199999958277 10095588.9623700007796288,
3136058.2229188750497997 10095579.1736732590943575,
3136113.9765704586170614 10095550.7657688762992620,
3136158.2229188750497997 10095506.5194204598665237,
3136186.6308232592418790 10095450.7657688762992620,
3136196.4195199999958277 10095388.9623700007796288,
3136186.6308232592418790 10095327.1589711252599955,
3136158.2229188750497997 10095271.4053195416927338,
3136136.9886686177924275 10095250.1710692849010229,
3136168.3033988750539720 10095245.2113032583147287,
3136224.0570504586212337 10095216.8033988755196333,
3136268.3033988750539720 10095172.5570504590868950,
3136296.7113032592460513 10095116.8033988755196333,
3136306.5000000000000000 10095055.0000000000000000,
3136296.7113032592460513 10094993.1966011244803667,
3136268.3033988750539720 10094937.4429495409131050,
3136224.0570504586212337 10094893.1966011244803667,
3136168.3033988750539720 10094864.7886967416852713,
3136106.5000000000000000 10094855.0000000000000000,
3136044.6966011249460280 10094864.7886967416852713,
3135988.9429495413787663 10094893.1966011244803667,
3135944.6966011249460280 10094937.4429495409131050,
3135916.2886967407539487 10094993.1966011244803667,
3135906.5000000000000000 10095055.0000000000000000,
3135916.2886967407539487 10095116.8033988755196333,
3135944.6966011249460280 10095172.5570504590868950,
3135965.9308513822034001 10095193.7913007158786058)),
((3135011.9192220158874989 10083217.3137515150010586,
3135005.0000000000000000 10083261.0000000000000000,
3135014.7886967407539487 10083322.8033988755196333,
3135036.3676004856824875 10083365.1543820630759001,
3135041.5386967407539487 10083397.8033988755196333,
3135069.9466011249460280 10083453.5570504590868950,
3135114.1929495413787663 10083497.8033988755196333,
3135169.9466011249460280 10083526.2113032583147287,
3135231.7500000000000000 10083536.0000000000000000,
3135293.5533988750539720 10083526.2113032583147287,
3135349.3070504586212337 10083497.8033988755196333,
3135393.5533988750539720 10083453.5570504590868950,
3135421.9613032592460513 10083397.8033988755196333,
3135431.7500000000000000 10083336.0000000000000000,
3135426.3700395757332444 10083302.0322667192667723,
3135431.5533988750539720 10083301.2113032583147287,
3135487.3070504586212337 10083272.8033988755196333,
3135493.0000000000000000 10083267.1104493346065283,
3135529.6929495413787663 10083303.8033988755196333,
3135585.4466011249460280 10083332.2113032583147287,
3135647.2500000000000000 10083342.0000000000000000,
3135709.0533988750539720 10083332.2113032583147287,
3135764.8070504586212337 10083303.8033988755196333,
3135769.0346932280808687 10083299.5757561065256596,
3135777.6444400870241225 10083316.4733357410877943,
3135821.8907885034568608 10083360.7196841575205326,
3135877.6444400870241225 10083389.1275885403156281,
3135939.4478389620780945 10083398.9162852820008993,
3136001.2512378371320665 10083389.1275885403156281,
3136057.0048894206993282 10083360.7196841575205326,
3136101.2512378371320665 10083316.4733357410877943,
3136129.6591422213241458 10083260.7196841575205326,
3136139.4478389620780945 10083198.9162852820008993,
3136129.6591422213241458 10083137.1128864064812660,
3136109.9735063440166414 10083098.4776506256312132,
3136114.0825064848177135 10083072.5344447623938322,
3136104.2938097440637648 10083010.7310458868741989,
3136075.8859053598716855 10082954.9773943033069372,
3136031.6395569434389472 10082910.7310458868741989,
3135975.8859053598716855 10082882.3231415040791035,
3135914.0825064848177135 10082872.5344447623938322,
3135852.2791076097637415 10082882.3231415040791035,
3135796.5254560261964798 10082910.7310458868741989,
3135752.2791076097637415 10082954.9773943033069372,
3135744.6598255583085120 10082969.9310773015022278,
3135709.0533988750539720 10082951.7886967416852713,
3135647.2500000000000000 10082942.0000000000000000,
3135585.4466011249460280 10082951.7886967416852713,
3135583.7451542899943888 10082952.6556272059679031,
3135565.8033988750539720 10082917.4429495409131050,
3135521.5570504586212337 10082873.1966011244803667,
3135465.8033988750539720 10082844.7886967416852713,
3135404.0000000000000000 10082835.0000000000000000,
3135342.1966011249460280 10082844.7886967416852713,
3135286.4429495413787663 10082873.1966011244803667,
3135242.1966011249460280 10082917.4429495409131050,
3135218.7334701595827937 10082963.4919368661940098,
3135203.0000000000000000 10082961.0000000000000000,
3135141.1966011249460280 10082970.7886967416852713,
3135085.4429495413787663 10082999.1966011244803667,
3135041.1966011249460280 10083043.4429495409131050,
3135012.7886967407539487 10083099.1966011244803667,
3135003.0000000000000000 10083161.0000000000000000,
3135011.9192220158874989 10083217.3137515150010586)),
((3136071.7500000000000000 10100522.0000000000000000,
3136061.9613032592460513 10100460.1966011244803667,
3136033.5533988750539720 10100404.4429495409131050,
3135989.3070504586212337 10100360.1966011244803667,
3135933.5533988750539720 10100331.7886967416852713,
3135871.7500000000000000 10100322.0000000000000000,
3135809.9466011249460280 10100331.7886967416852713,
3135754.1929495413787663 10100360.1966011244803667,
3135709.9466011249460280 10100404.4429495409131050,
3135681.5386967407539487 10100460.1966011244803667,
3135671.7500000000000000 10100522.0000000000000000,
3135681.5386967407539487 10100583.8033988755196333,
3135709.9466011249460280 10100639.5570504590868950,
3135754.1929495413787663 10100683.8033988755196333,
3135809.9466011249460280 10100712.2113032583147287,
3135871.7500000000000000 10100722.0000000000000000,
3135933.5533988750539720 10100712.2113032583147287,
3135989.3070504586212337 10100683.8033988755196333,
3136033.5533988750539720 10100639.5570504590868950,
3136061.9613032592460513 10100583.8033988755196333,
3136071.7500000000000000 10100522.0000000000000000)),
((3136068.0000000000000000 10099066.0000000000000000,
3136058.2113032592460513 10099004.1966011244803667,
3136029.8033988750539720 10098948.4429495409131050,
3135985.5570504586212337 10098904.1966011244803667,
3135929.8033988750539720 10098875.7886967416852713,
3135868.0000000000000000 10098866.0000000000000000,
3135806.1966011249460280 10098875.7886967416852713,
3135750.4429495413787663 10098904.1966011244803667,
3135706.1966011249460280 10098948.4429495409131050,
3135677.7886967407539487 10099004.1966011244803667,
3135668.0000000000000000 10099066.0000000000000000,
3135677.7886967407539487 10099127.8033988755196333,
3135706.1966011249460280 10099183.5570504590868950,
3135750.4429495413787663 10099227.8033988755196333,
3135806.1966011249460280 10099256.2113032583147287,
3135868.0000000000000000 10099266.0000000000000000,
3135929.8033988750539720 10099256.2113032583147287,
3135985.5570504586212337 10099227.8033988755196333,
3136029.8033988750539720 10099183.5570504590868950,
3136058.2113032592460513 10099127.8033988755196333,
3136068.0000000000000000 10099066.0000000000000000)),
((3135644.7533988519571722 10084983.6157238278537989,
3135625.3033988750539720 10084945.4429495409131050,
3135581.0570504586212337 10084901.1966011244803667,
3135525.3033988750539720 10084872.7886967416852713,
3135463.5000000000000000 10084863.0000000000000000,
3135401.6966011249460280 10084872.7886967416852713,
3135345.9429495413787663 10084901.1966011244803667,
3135301.6966011249460280 10084945.4429495409131050,
3135273.2886967407539487 10085001.1966011244803667,
3135263.5000000000000000 10085063.0000000000000000,
3135273.2886967407539487 10085124.8033988755196333,
3135301.6966011249460280 10085180.5570504590868950,
3135345.9429495413787663 10085224.8033988755196333,
3135401.6966011249460280 10085253.2113032583147287,
3135463.5000000000000000 10085263.0000000000000000,
3135525.3033988750539720 10085253.2113032583147287,
3135581.0570504586212337 10085224.8033988755196333,
3135625.3033988750539720 10085180.5570504590868950,
3135653.7113032592460513 10085124.8033988755196333,
3135660.7466011480428278 10085080.3842761721462011,
3135680.1966011249460280 10085118.5570504590868950,
3135724.4429495413787663 10085162.8033988755196333,
3135780.1966011249460280 10085191.2113032583147287,
3135842.0000000000000000 10085201.0000000000000000,
3135903.8033988750539720 10085191.2113032583147287,
3135959.5570504586212337 10085162.8033988755196333,
3136003.8033988750539720 10085118.5570504590868950,
3136032.2113032592460513 10085062.8033988755196333,
3136042.0000000000000000 10085001.0000000000000000,
3136032.2113032592460513 10084939.1966011244803667,
3136003.8033988750539720 10084883.4429495409131050,
3135959.5570504586212337 10084839.1966011244803667,
3135903.8033988750539720 10084810.7886967416852713,
3135842.0000000000000000 10084801.0000000000000000,
3135780.1966011249460280 10084810.7886967416852713,
3135724.4429495413787663 10084839.1966011244803667,
3135680.1966011249460280 10084883.4429495409131050,
3135651.7886967407539487 10084939.1966011244803667,
3135644.7533988519571722 10084983.6157238278537989)),
((3135363.1430372083559632 10093168.4519253540784121,
3135336.5701712640002370 10093195.0247912984341383,
3135308.1622668798081577 10093250.7784428820014000,
3135298.3735701390542090 10093312.5818417575210333,
3135308.1622668798081577 10093374.3852406330406666,
3135336.5701712640002370 10093430.1388922166079283,
3135380.8165196804329753 10093474.3852406330406666,
3135436.5701712640002370 10093502.7931450158357620,
3135498.3735701390542090 10093512.5818417575210333,
3135558.7226356337778270 10093503.0234887935221195,
3135561.5386967407539487 10093520.8033988755196333,
3135589.9466011249460280 10093576.5570504590868950,
3135634.1929495413787663 10093620.8033988755196333,
3135689.9466011249460280 10093649.2113032583147287,
3135751.7500000000000000 10093659.0000000000000000,
3135813.5533988750539720 10093649.2113032583147287,
3135869.3070504586212337 10093620.8033988755196333,
3135913.5533988750539720 10093576.5570504590868950,
3135941.9613032592460513 10093520.8033988755196333,
3135951.7500000000000000 10093459.0000000000000000,
3135941.9613032592460513 10093397.1966011244803667,
3135913.5533988750539720 10093341.4429495409131050,
3135869.3070504586212337 10093297.1966011244803667,
3135813.5533988750539720 10093268.7886967416852713,
3135751.7500000000000000 10093259.0000000000000000,
3135691.4009345052763820 10093268.5583529639989138,
3135688.5848733983002603 10093250.7784428820014000,
3135660.2305329306982458 10093195.1299164034426212,
3135686.8033988750539720 10093168.5570504590868950,
3135715.2113032592460513 10093112.8033988755196333,
3135725.0000000000000000 10093051.0000000000000000,
3135715.2113032592460513 10092989.1966011244803667,
3135686.8033988750539720 10092933.4429495409131050,
3135642.5570504586212337 10092889.1966011244803667,
3135586.8033988750539720 10092860.7886967416852713,
3135525.0000000000000000 10092851.0000000000000000,
3135463.1966011249460280 10092860.7886967416852713,
3135407.4429495413787663 10092889.1966011244803667,
3135363.1966011249460280 10092933.4429495409131050,
3135334.7886967407539487 10092989.1966011244803667,
3135325.0000000000000000 10093051.0000000000000000,
3135334.7886967407539487 10093112.8033988755196333,
3135363.1430372083559632 10093168.4519253540784121)),
((3135214.6455022036097944 10095839.0197838973253965,
3135200.2886967407539487 10095867.1966011244803667,
3135190.5000000000000000 10095929.0000000000000000,
3135200.2886967407539487 10095990.8033988755196333,
3135228.6966011249460280 10096046.5570504590868950,
3135272.9429495413787663 10096090.8033988755196333,
3135328.6966011249460280 10096119.2113032583147287,
3135390.5000000000000000 10096129.0000000000000000,
3135452.3033988750539720 10096119.2113032583147287,
3135508.0570504586212337 10096090.8033988755196333,
3135511.7199808158911765 10096087.1404685191810131,
3135510.0000000000000000 10096098.0000000000000000,
3135519.7886967407539487 10096159.8033988755196333,
3135548.1966011249460280 10096215.5570504590868950,
3135592.4429495413787663 10096259.8033988755196333,
3135648.1966011249460280 10096288.2113032583147287,
3135710.0000000000000000 10096298.0000000000000000,
3135771.8033988750539720 10096288.2113032583147287,
3135827.5570504586212337 10096259.8033988755196333,
3135871.8033988750539720 10096215.5570504590868950,
3135900.2113032592460513 10096159.8033988755196333,
3135910.0000000000000000 10096098.0000000000000000,
3135900.2113032592460513 10096036.1966011244803667,
3135871.8033988750539720 10095980.4429495409131050,
3135827.5570504586212337 10095936.1966011244803667,
3135771.8033988750539720 10095907.7886967416852713,
3135751.3347590342164040 10095904.5467826761305332,
3135752.4613032592460513 10095902.3358151447027922,
3135762.2500000000000000 10095840.5324162691831589,
3135752.4613032592460513 10095778.7290173936635256,
3135724.0533988750539720 10095722.9753658100962639,
3135679.8070504586212337 10095678.7290173936635256,
3135624.0533988750539720 10095650.3211130108684301,
3135562.2500000000000000 10095640.5324162691831589,
3135500.4466011249460280 10095650.3211130108684301,
3135479.1378931580111384 10095661.1784420162439346,
3135480.7500000000000000 10095651.0000000000000000,
3135470.9613032592460513 10095589.1966011244803667,
3135442.5533988750539720 10095533.4429495409131050,
3135398.3070504586212337 10095489.1966011244803667,
3135342.5533988750539720 10095460.7886967416852713,
3135280.7500000000000000 10095451.0000000000000000,
3135218.9466011249460280 10095460.7886967416852713,
3135163.1929495413787663 10095489.1966011244803667,
3135118.9466011249460280 10095533.4429495409131050,
3135090.5386967407539487 10095589.1966011244803667,
3135080.7500000000000000 10095651.0000000000000000,
3135090.5386967407539487 10095712.8033988755196333,
3135118.9466011249460280 10095768.5570504590868950,
3135163.1929495413787663 10095812.8033988755196333,
3135214.6455022036097944 10095839.0197838973253965)),
((3135890.7500000000000000 10094022.0000000000000000,
3135880.9613032592460513 10093960.1966011244803667,
3135852.5533988750539720 10093904.4429495409131050,
3135808.3070504586212337 10093860.1966011244803667,
3135752.5533988750539720 10093831.7886967416852713,
3135690.7500000000000000 10093822.0000000000000000,
3135628.9466011249460280 10093831.7886967416852713,
3135573.1929495413787663 10093860.1966011244803667,
3135528.9466011249460280 10093904.4429495409131050,
3135500.5386967407539487 10093960.1966011244803667,
3135490.7500000000000000 10094022.0000000000000000,
3135500.5386967407539487 10094083.8033988755196333,
3135528.9466011249460280 10094139.5570504590868950,
3135573.1929495413787663 10094183.8033988755196333,
3135628.9466011249460280 10094212.2113032583147287,
3135690.7500000000000000 10094222.0000000000000000,
3135752.5533988750539720 10094212.2113032583147287,
3135808.3070504586212337 10094183.8033988755196333,
3135852.5533988750539720 10094139.5570504590868950,
3135880.9613032592460513 10094083.8033988755196333,
3135890.7500000000000000 10094022.0000000000000000)),
((3135840.7500000000000000 10098400.0000000000000000,
3135830.9613032592460513 10098338.1966011244803667,
3135802.5533988750539720 10098282.4429495409131050,
3135758.3070504586212337 10098238.1966011244803667,
3135702.5533988750539720 10098209.7886967416852713,
3135640.7500000000000000 10098200.0000000000000000,
3135578.9466011249460280 10098209.7886967416852713,
3135523.1929495413787663 10098238.1966011244803667,
3135478.9466011249460280 10098282.4429495409131050,
3135450.5386967407539487 10098338.1966011244803667,
3135440.7500000000000000 10098400.0000000000000000,
3135450.5386967407539487 10098461.8033988755196333,
3135478.9466011249460280 10098517.5570504590868950,
3135523.1929495413787663 10098561.8033988755196333,
3135578.9466011249460280 10098590.2113032583147287,
3135640.7500000000000000 10098600.0000000000000000,
3135702.5533988750539720 10098590.2113032583147287,
3135758.3070504586212337 10098561.8033988755196333,
3135802.5533988750539720 10098517.5570504590868950,
3135830.9613032592460513 10098461.8033988755196333,
3135840.7500000000000000 10098400.0000000000000000)),
((3135716.5000000000000000 10099410.0000000000000000,
3135706.7113032592460513 10099348.1966011244803667,
3135678.3033988750539720 10099292.4429495409131050,
3135634.0570504586212337 10099248.1966011244803667,
3135578.3033988750539720 10099219.7886967416852713,
3135516.5000000000000000 10099210.0000000000000000,
3135454.6966011249460280 10099219.7886967416852713,
3135398.9429495413787663 10099248.1966011244803667,
3135354.6966011249460280 10099292.4429495409131050,
3135326.2886967407539487 10099348.1966011244803667,
3135316.5000000000000000 10099410.0000000000000000,
3135326.2886967407539487 10099471.8033988755196333,
3135354.6966011249460280 10099527.5570504590868950,
3135398.9429495413787663 10099571.8033988755196333,
3135454.6966011249460280 10099600.2113032583147287,
3135516.5000000000000000 10099610.0000000000000000,
3135578.3033988750539720 10099600.2113032583147287,
3135634.0570504586212337 10099571.8033988755196333,
3135678.3033988750539720 10099527.5570504590868950,
3135706.7113032592460513 10099471.8033988755196333,
3135716.5000000000000000 10099410.0000000000000000)),
((3135702.1557247699238360 10094411.7714265864342451,
3135692.3670280291698873 10094349.9680277109146118,
3135663.9591236449778080 10094294.2143761273473501,
3135619.7127752285450697 10094249.9680277109146118,
3135563.9591236449778080 10094221.5601233281195164,
3135502.1557247699238360 10094211.7714265864342451,
3135440.3523258948698640 10094221.5601233281195164,
3135384.5986743113026023 10094249.9680277109146118,
3135340.3523258948698640 10094294.2143761273473501,
3135311.9444215106777847 10094349.9680277109146118,
3135302.1557247699238360 10094411.7714265864342451,
3135311.9444215106777847 10094473.5748254619538784,
3135340.3523258948698640 10094529.3284770455211401,
3135384.5986743113026023 10094573.5748254619538784,
3135440.3523258948698640 10094601.9827298447489738,
3135502.1557247699238360 10094611.7714265864342451,
3135563.9591236449778080 10094601.9827298447489738,
3135619.7127752285450697 10094573.5748254619538784,
3135663.9591236449778080 10094529.3284770455211401,
3135692.3670280291698873 10094473.5748254619538784,
3135702.1557247699238360 10094411.7714265864342451)),
((3135264.6535237450152636 10096725.2069255895912647,
3135255.5000000000000000 10096783.0000000000000000,
3135265.2886967407539487 10096844.8033988755196333,
3135293.6966011249460280 10096900.5570504590868950,
3135337.9429495413787663 10096944.8033988755196333,
3135393.6966011249460280 10096973.2113032583147287,
3135455.5000000000000000 10096983.0000000000000000,
3135517.3033988750539720 10096973.2113032583147287,
3135573.0570504586212337 10096944.8033988755196333,
3135617.3033988750539720 10096900.5570504590868950,
3135645.7113032592460513 10096844.8033988755196333,
3135655.5000000000000000 10096783.0000000000000000,
3135645.7113032592460513 10096721.1966011244803667,
3135617.3033988750539720 10096665.4429495409131050,
3135573.0570504586212337 10096621.1966011244803667,
3135517.3033988750539720 10096592.7886967416852713,
3135455.5000000000000000 10096583.0000000000000000,
3135393.6966011249460280 10096592.7886967416852713,
3135337.9429495413787663 10096621.1966011244803667,
3135334.3464762549847364 10096624.7930744104087353,
3135343.5000000000000000 10096567.0000000000000000,
3135333.7113032592460513 10096505.1966011244803667,
3135305.3033988750539720 10096449.4429495409131050,
3135261.0570504586212337 10096405.1966011244803667,
3135205.3033988750539720 10096376.7886967416852713,
3135143.5000000000000000 10096367.0000000000000000,
3135081.6966011249460280 10096376.7886967416852713,
3135025.9429495413787663 10096405.1966011244803667,
3134981.6966011249460280 10096449.4429495409131050,
3134953.2886967407539487 10096505.1966011244803667,
3134943.5000000000000000 10096567.0000000000000000,
3134953.2886967407539487 10096628.8033988755196333,
3134981.6966011249460280 10096684.5570504590868950,
3135025.9429495413787663 10096728.8033988755196333,
3135081.6966011249460280 10096757.2113032583147287,
3135143.5000000000000000 10096767.0000000000000000,
3135205.3033988750539720 10096757.2113032583147287,
3135261.0570504586212337 10096728.8033988755196333,
3135264.6535237450152636 10096725.2069255895912647)),
((3135642.5000000000000000 10091602.0000000000000000,
3135632.7113032592460513 10091540.1966011244803667,
3135604.3033988750539720 10091484.4429495409131050,
3135560.0570504586212337 10091440.1966011244803667,
3135504.3033988750539720 10091411.7886967416852713,
3135442.5000000000000000 10091402.0000000000000000,
3135380.6966011249460280 10091411.7886967416852713,
3135324.9429495413787663 10091440.1966011244803667,
3135280.6966011249460280 10091484.4429495409131050,
3135252.2886967407539487 10091540.1966011244803667,
3135242.5000000000000000 10091602.0000000000000000,
3135252.2886967407539487 10091663.8033988755196333,
3135280.6966011249460280 10091719.5570504590868950,
3135324.9429495413787663 10091763.8033988755196333,
3135380.6966011249460280 10091792.2113032583147287,
3135442.5000000000000000 10091802.0000000000000000,
3135504.3033988750539720 10091792.2113032583147287,
3135560.0570504586212337 10091763.8033988755196333,
3135604.3033988750539720 10091719.5570504590868950,
3135632.7113032592460513 10091663.8033988755196333,
3135642.5000000000000000 10091602.0000000000000000)),
((3134815.3865317041054368 10082639.9065262638032436,
3134804.5386967407539487 10082661.1966011244803667,
3134794.7500000000000000 10082723.0000000000000000,
3134804.5386967407539487 10082784.8033988755196333,
3134832.9466011249460280 10082840.5570504590868950,
3134877.1929495413787663 10082884.8033988755196333,
3134932.9466011249460280 10082913.2113032583147287,
3134994.7500000000000000 10082923.0000000000000000,
3135056.5533988750539720 10082913.2113032583147287,
3135112.3070504586212337 10082884.8033988755196333,
3135156.5533988750539720 10082840.5570504590868950,
3135184.9613032592460513 10082784.8033988755196333,
3135194.7500000000000000 10082723.0000000000000000,
3135184.9613032592460513 10082661.1966011244803667,
3135169.1134682958945632 10082630.0934737361967564,
3135179.9613032592460513 10082608.8033988755196333,
3135185.1949502024799585 10082575.7594525609165430,
3135190.6966011249460280 10082586.5570504590868950,
3135234.9429495413787663 10082630.8033988755196333,
3135290.6966011249460280 10082659.2113032583147287,
3135352.5000000000000000 10082669.0000000000000000,
3135414.3033988750539720 10082659.2113032583147287,
3135470.0570504586212337 10082630.8033988755196333,
3135514.3033988750539720 10082586.5570504590868950,
3135542.7113032592460513 10082530.8033988755196333,
3135552.5000000000000000 10082469.0000000000000000,
3135542.7113032592460513 10082407.1966011244803667,
3135514.3033988750539720 10082351.4429495409131050,
3135470.0570504586212337 10082307.1966011244803667,
3135414.3033988750539720 10082278.7886967416852713,
3135352.5000000000000000 10082269.0000000000000000,
3135290.6966011249460280 10082278.7886967416852713,
3135234.9429495413787663 10082307.1966011244803667,
3135190.6966011249460280 10082351.4429495409131050,
3135162.2886967407539487 10082407.1966011244803667,
3135157.0550497975200415 10082440.2405474390834570,
3135151.5533988750539720 10082429.4429495409131050,
3135107.3070504586212337 10082385.1966011244803667,
3135051.5533988750539720 10082356.7886967416852713,
3134989.7500000000000000 10082347.0000000000000000,
3134927.9466011249460280 10082356.7886967416852713,
3134872.1929495413787663 10082385.1966011244803667,
3134827.9466011249460280 10082429.4429495409131050,
3134799.5386967407539487 10082485.1966011244803667,
3134789.7500000000000000 10082547.0000000000000000,
3134799.5386967407539487 10082608.8033988755196333,
3134815.3865317041054368 10082639.9065262638032436)),
((3135130.2020069337449968 10098124.1098076272755861,
3135108.4429495413787663 10098135.1966011244803667,
3135064.1966011249460280 10098179.4429495409131050,
3135035.7886967407539487 10098235.1966011244803667,
3135026.0000000000000000 10098297.0000000000000000,
3135035.7886967407539487 10098358.8033988755196333,
3135064.1966011249460280 10098414.5570504590868950,
3135108.4429495413787663 10098458.8033988755196333,
3135164.1966011249460280 10098487.2113032583147287,
3135226.0000000000000000 10098497.0000000000000000,
3135287.8033988750539720 10098487.2113032583147287,
3135343.5570504586212337 10098458.8033988755196333,
3135387.8033988750539720 10098414.5570504590868950,
3135416.2113032592460513 10098358.8033988755196333,
3135426.0000000000000000 10098297.0000000000000000,
3135416.2113032592460513 10098235.1966011244803667,
3135402.2979930662550032 10098207.8901923727244139,
3135424.0570504586212337 10098196.8033988755196333,
3135468.3033988750539720 10098152.5570504590868950,
3135496.7113032592460513 10098096.8033988755196333,
3135506.5000000000000000 10098035.0000000000000000,
3135496.7113032592460513 10097973.1966011244803667,
3135468.3033988750539720 10097917.4429495409131050,
3135424.0570504586212337 10097873.1966011244803667,
3135368.3033988750539720 10097844.7886967416852713,
3135306.5000000000000000 10097835.0000000000000000,
3135244.6966011249460280 10097844.7886967416852713,
3135188.9429495413787663 10097873.1966011244803667,
3135144.6966011249460280 10097917.4429495409131050,
3135116.2886967407539487 10097973.1966011244803667,
3135106.5000000000000000 10098035.0000000000000000,
3135116.2886967407539487 10098096.8033988755196333,
3135130.2020069337449968 10098124.1098076272755861)),
((3134366.2467432995326817 10082526.6154448390007019,
3134357.2886967407539487 10082544.1966011244803667,
3134347.5000000000000000 10082606.0000000000000000,
3134357.2886967407539487 10082667.8033988755196333,
3134382.7287078369408846 10082717.7322319131344557,
3134373.5000000000000000 10082776.0000000000000000,
3134383.2886967407539487 10082837.8033988755196333,
3134411.6966011249460280 10082893.5570504590868950,
3134455.9429495413787663 10082937.8033988755196333,
3134511.6966011249460280 10082966.2113032583147287,
3134573.5000000000000000 10082976.0000000000000000,
3134635.3033988750539720 10082966.2113032583147287,
3134691.0570504586212337 10082937.8033988755196333,
3134735.3033988750539720 10082893.5570504590868950,
3134763.7113032592460513 10082837.8033988755196333,
3134773.5000000000000000 10082776.0000000000000000,
3134763.7113032592460513 10082714.1966011244803667,
3134738.2712921630591154 10082664.2677680868655443,
3134747.5000000000000000 10082606.0000000000000000,
3134737.7113032592460513 10082544.1966011244803667,
3134709.3033988750539720 10082488.4429495409131050,
3134665.0570504586212337 10082444.1966011244803667,
3134609.3033988750539720 10082415.7886967416852713,
3134547.5000000000000000 10082406.0000000000000000,
3134513.5032567004673183 10082411.3845551609992981,
3134522.4613032592460513 10082393.8033988755196333,
3134523.9621308338828385 10082384.3275465033948421,
3134525.6966011249460280 10082385.2113032583147287,
3134587.5000000000000000 10082395.0000000000000000,
3134649.3033988750539720 10082385.2113032583147287,
3134659.9085188228636980 10082379.8077247496694326,
3134673.7500000000000000 10082382.0000000000000000,
3134735.5533988750539720 10082372.2113032583147287,
3134791.3070504586212337 10082343.8033988755196333,
3134835.5533988750539720 10082299.5570504590868950,
3134863.9613032592460513 10082243.8033988755196333,
3134873.7500000000000000 10082182.0000000000000000,
3134863.9613032592460513 10082120.1966011244803667,
3134857.7301959642209113 10082107.9673644863069057,
3134864.2500000000000000 10082109.0000000000000000,
3134926.0533988750539720 10082099.2113032583147287,
3134962.8130525280721486 10082080.4813242089003325,
3134979.9466011249460280 10082089.2113032583147287,
3135041.7500000000000000 10082099.0000000000000000,
3135085.4563582055270672 10082092.0775929167866707,
3135087.7886967407539487 10082106.8033988755196333,
3135116.1966011249460280 10082162.5570504590868950,
3135160.4429495413787663 10082206.8033988755196333,
3135216.1966011249460280 10082235.2113032583147287,
3135278.0000000000000000 10082245.0000000000000000,
3135339.8033988750539720 10082235.2113032583147287,
3135395.5570504586212337 10082206.8033988755196333,
3135439.8033988750539720 10082162.5570504590868950,
3135468.2113032592460513 10082106.8033988755196333,
3135478.0000000000000000 10082045.0000000000000000,
3135468.2113032592460513 10081983.1966011244803667,
3135439.8033988750539720 10081927.4429495409131050,
3135395.5570504586212337 10081883.1966011244803667,
3135339.8033988750539720 10081854.7886967416852713,
3135295.6156646530143917 10081847.7900471873581409,
3135314.4613032592460513 10081810.8033988755196333,
3135324.2500000000000000 10081749.0000000000000000,
3135314.4613032592460513 10081687.1966011244803667,
3135286.0533988750539720 10081631.4429495409131050,
3135241.8070504586212337 10081587.1966011244803667,
3135194.4146388368681073 10081563.0489612910896540,
3135202.5000000000000000 10081512.0000000000000000,
3135192.7113032592460513 10081450.1966011244803667,
3135164.3033988750539720 10081394.4429495409131050,
3135151.0996551313437521 10081381.2392057962715626,
3135129.8033988750539720 10081339.4429495409131050,
3135085.5570504586212337 10081295.1966011244803667,
3135029.8033988750539720 10081266.7886967416852713,
3134968.0000000000000000 10081257.0000000000000000,
3134906.1966011249460280 10081266.7886967416852713,
3134850.4429495413787663 10081295.1966011244803667,
3134806.1966011249460280 10081339.4429495409131050,
3134777.7886967407539487 10081395.1966011244803667,
3134768.0000000000000000 10081457.0000000000000000,
3134777.7886967407539487 10081518.8033988755196333,
3134806.1966011249460280 10081574.5570504590868950,
3134819.4003448686562479 10081587.7607942037284374,
3134840.6966011249460280 10081629.5570504590868950,
3134884.9429495413787663 10081673.8033988755196333,
3134932.3353611631318927 10081697.9510387089103460,
3134928.8123504724353552 10081720.1944527942687273,
3134926.0533988750539720 10081718.7886967416852713,
3134864.2500000000000000 10081709.0000000000000000,
3134802.4466011249460280 10081718.7886967416852713,
3134746.6929495413787663 10081747.1966011244803667,
3134702.4466011249460280 10081791.4429495409131050,
3134674.0386967407539487 10081847.1966011244803667,
3134664.2500000000000000 10081909.0000000000000000,
3134674.0386967407539487 10081970.8033988755196333,
3134680.2698040357790887 10081983.0326355136930943,
3134673.7500000000000000 10081982.0000000000000000,
3134611.9466011249460280 10081991.7886967416852713,
3134601.3414811771363020 10081997.1922752503305674,
3134587.5000000000000000 10081995.0000000000000000,
3134525.6966011249460280 10082004.7886967416852713,
3134469.9429495413787663 10082033.1966011244803667,
3134425.6966011249460280 10082077.4429495409131050,
3134397.2886967407539487 10082133.1966011244803667,
3134395.7878691661171615 10082142.6724534966051579,
3134394.0533988750539720 10082141.7886967416852713,
3134332.2500000000000000 10082132.0000000000000000,
3134270.4466011249460280 10082141.7886967416852713,
3134214.6929495413787663 10082170.1966011244803667,
3134170.4466011249460280 10082214.4429495409131050,
3134142.0386967407539487 10082270.1966011244803667,
3134132.2500000000000000 10082332.0000000000000000,
3134142.0386967407539487 10082393.8033988755196333,
3134170.4466011249460280 10082449.5570504590868950,
3134214.6929495413787663 10082493.8033988755196333,
3134270.4466011249460280 10082522.2113032583147287,
3134332.2500000000000000 10082532.0000000000000000,
3134366.2467432995326817 10082526.6154448390007019)),
((3135272.4621080001816154 10092544.9000000003725290,
3135262.6734112594276667 10092483.0966011248528957,
3135234.2655068752355874 10092427.3429495412856340,
3135190.0191584588028491 10092383.0966011248528957,
3135134.2655068752355874 10092354.6886967420578003,
3135072.4621080001816154 10092344.9000000003725290,
3135010.6587091251276433 10092354.6886967420578003,
3134954.9050575415603817 10092383.0966011248528957,
3134910.6587091251276433 10092427.3429495412856340,
3134882.2508047409355640 10092483.0966011248528957,
3134872.4621080001816154 10092544.9000000003725290,
3134882.2508047409355640 10092606.7033988758921623,
3134910.6587091251276433 10092662.4570504594594240,
3134954.9050575415603817 10092706.7033988758921623,
3135010.6587091251276433 10092735.1113032586872578,
3135072.4621080001816154 10092744.9000000003725290,
3135134.2655068752355874 10092735.1113032586872578,
3135190.0191584588028491 10092706.7033988758921623,
3135234.2655068752355874 10092662.4570504594594240,
3135262.6734112594276667 10092606.7033988758921623,
3135272.4621080001816154 10092544.9000000003725290)),
((3133364.6880845781415701 10083690.0637887176126242,
3133378.6966011249460280 10083717.5570504590868950,
3133422.9429495413787663 10083761.8033988755196333,
3133478.6966011249460280 10083790.2113032583147287,
3133540.5000000000000000 10083800.0000000000000000,
3133602.3033988750539720 10083790.2113032583147287,
3133630.9650898934341967 10083775.6074422597885132,
3133644.6966011249460280 10083802.5570504590868950,
3133688.9429495413787663 10083846.8033988755196333,
3133744.6966011249460280 10083875.2113032583147287,
3133806.5000000000000000 10083885.0000000000000000,
3133808.8448109654709697 10083884.6286184266209602,
3133794.2886967407539487 10083913.1966011244803667,
3133784.5000000000000000 10083975.0000000000000000,
3133794.2886967407539487 10084036.8033988755196333,
3133822.6966011249460280 10084092.5570504590868950,
3133831.0161375352181494 10084100.8765868693590164,
3133833.5386967407539487 10084116.8033988755196333,
3133861.9466011249460280 10084172.5570504590868950,
3133876.1832828898914158 10084186.7937322240322828,
3133874.2500000000000000 10084199.0000000000000000,
3133884.0386967407539487 10084260.8033988755196333,
3133912.4466011249460280 10084316.5570504590868950,
3133915.1725581781938672 10084319.2830075118690729,
3133913.0000000000000000 10084333.0000000000000000,
3133922.7886967407539487 10084394.8033988755196333,
3133951.1966011249460280 10084450.5570504590868950,
3133976.5418535857461393 10084475.9023029208183289,
3133972.2500000000000000 10084503.0000000000000000,
3133982.0386967407539487 10084564.8033988755196333,
3134010.4466011249460280 10084620.5570504590868950,
3134054.6929495413787663 10084664.8033988755196333,
3134110.4466011249460280 10084693.2113032583147287,
3134172.2500000000000000 10084703.0000000000000000,
3134234.0533988750539720 10084693.2113032583147287,
3134289.8070504586212337 10084664.8033988755196333,
3134311.0350583884865046 10084643.5753909461200237,
3134329.9466011249460280 10084653.2113032583147287,
3134391.7500000000000000 10084663.0000000000000000,
3134453.5533988750539720 10084653.2113032583147287,
3134509.3070504586212337 10084624.8033988755196333,
3134553.5533988750539720 10084580.5570504590868950,
3134581.9613032592460513 10084524.8033988755196333,
3134591.7500000000000000 10084463.0000000000000000,
3134581.9613032592460513 10084401.1966011244803667,
3134553.5533988750539720 10084345.4429495409131050,
3134509.3070504586212337 10084301.1966011244803667,
3134453.5533988750539720 10084272.7886967416852713,
3134391.7500000000000000 10084263.0000000000000000,
3134358.9089357536286116 10084268.2015135809779167,
3134400.5533988750539720 10084226.5570504590868950,
3134428.9613032592460513 10084170.8033988755196333,
3134438.7500000000000000 10084109.0000000000000000,
3134428.9613032592460513 10084047.1966011244803667,
3134400.5533988750539720 10083991.4429495409131050,
3134356.3070504586212337 10083947.1966011244803667,
3134319.1072711292654276 10083928.2423668410629034,
3134319.3033988750539720 10083928.2113032583147287,
3134357.0950472829863429 10083908.9554966166615486,
3134393.9429495413787663 10083945.8033988755196333,
3134449.6966011249460280 10083974.2113032583147287,
3134511.5000000000000000 10083984.0000000000000000,
3134573.3033988750539720 10083974.2113032583147287,
3134629.0570504586212337 10083945.8033988755196333,
3134673.3033988750539720 10083901.5570504590868950,
3134675.4102439740672708 10083897.4221341349184513,
3134698.0000000000000000 10083901.0000000000000000,
3134759.8033988750539720 10083891.2113032583147287,
3134787.2913546473719180 10083877.2054902389645576,
3134773.5386967407539487 10083904.1966011244803667,
3134763.7500000000000000 10083966.0000000000000000,
3134773.5386967407539487 10084027.8033988755196333,
3134801.9466011249460280 10084083.5570504590868950,
3134810.1259183725342155 10084091.7363677062094212,
3134806.3033988750539720 10084089.7886967416852713,
3134744.5000000000000000 10084080.0000000000000000,
3134682.6966011249460280 10084089.7886967416852713,
3134626.9429495413787663 10084118.1966011244803667,
3134582.6966011249460280 10084162.4429495409131050,
3134554.2886967407539487 10084218.1966011244803667,
3134544.5000000000000000 10084280.0000000000000000,
3134554.2886967407539487 10084341.8033988755196333,
3134582.6966011249460280 10084397.5570504590868950,
3134626.9429495413787663 10084441.8033988755196333,
3134682.6966011249460280 10084470.2113032583147287,
3134744.5000000000000000 10084480.0000000000000000,
3134806.3033988750539720 10084470.2113032583147287,
3134862.0570504586212337 10084441.8033988755196333,
3134906.3033988750539720 10084397.5570504590868950,
3134934.7113032592460513 10084341.8033988755196333,
3134944.5000000000000000 10084280.0000000000000000,
3134934.7113032592460513 10084218.1966011244803667,
3134906.3033988750539720 10084162.4429495409131050,
3134898.1240816274657845 10084154.2636322937905788,
3134901.9466011249460280 10084156.2113032583147287,
3134963.7500000000000000 10084166.0000000000000000,
3135025.5533988750539720 10084156.2113032583147287,
3135081.3070504586212337 10084127.8033988755196333,
3135125.5533988750539720 10084083.5570504590868950,
3135153.9613032592460513 10084027.8033988755196333,
3135163.7500000000000000 10083966.0000000000000000,
3135153.9613032592460513 10083904.1966011244803667,
3135125.5533988750539720 10083848.4429495409131050,
3135081.3070504586212337 10083804.1966011244803667,
3135025.5533988750539720 10083775.7886967416852713,
3134963.7500000000000000 10083766.0000000000000000,
3134901.9466011249460280 10083775.7886967416852713,
3134874.4586453526280820 10083789.7945097610354424,
3134888.2113032592460513 10083762.8033988755196333,
3134898.0000000000000000 10083701.0000000000000000,
3134888.2113032592460513 10083639.1966011244803667,
3134859.8033988750539720 10083583.4429495409131050,
3134815.5570504586212337 10083539.1966011244803667,
3134759.8033988750539720 10083510.7886967416852713,
3134698.0000000000000000 10083501.0000000000000000,
3134688.8257904704660177 10083502.4530520420521498,
3134696.5000000000000000 10083454.0000000000000000,
3134686.7113032592460513 10083392.1966011244803667,
3134658.3033988750539720 10083336.4429495409131050,
3134614.0570504586212337 10083292.1966011244803667,
3134558.3033988750539720 10083263.7886967416852713,
3134496.5000000000000000 10083254.0000000000000000,
3134434.6966011249460280 10083263.7886967416852713,
3134378.9429495413787663 10083292.1966011244803667,
3134334.6966011249460280 10083336.4429495409131050,
3134333.6356441602110863 10083338.5251948256045580,
3134323.3070504586212337 10083328.1966011244803667,
3134267.5533988750539720 10083299.7886967416852713,
3134205.7500000000000000 10083290.0000000000000000,
3134160.9552420084364712 10083297.0947926752269268,
3134120.0570504586212337 10083256.1966011244803667,
3134064.3033988750539720 10083227.7886967416852713,
3134002.5000000000000000 10083218.0000000000000000,
3133940.6966011249460280 10083227.7886967416852713,
3133884.9429495413787663 10083256.1966011244803667,
3133880.8872446748428047 10083260.2523059900850058,
3133871.3033988750539720 10083241.4429495409131050,
3133827.0570504586212337 10083197.1966011244803667,
3133771.3033988750539720 10083168.7886967416852713,
3133709.5000000000000000 10083159.0000000000000000,
3133647.6966011249460280 10083168.7886967416852713,
3133591.9429495413787663 10083197.1966011244803667,
3133547.6966011249460280 10083241.4429495409131050,
3133519.2886967407539487 10083297.1966011244803667,
3133509.5000000000000000 10083359.0000000000000000,
3133513.7934554112143815 10083386.1078106071799994,
3133510.8493433394469321 10083404.6962026599794626,
3133478.6966011249460280 10083409.7886967416852713,
3133422.9429495413787663 10083438.1966011244803667,
3133378.6966011249460280 10083482.4429495409131050,
3133371.3119154218584299 10083496.9362112823873758,
3133357.3033988750539720 10083469.4429495409131050,
3133313.0570504586212337 10083425.1966011244803667,
3133257.3033988750539720 10083396.7886967416852713,
3133195.5000000000000000 10083387.0000000000000000,
3133133.6966011249460280 10083396.7886967416852713,
3133077.9429495413787663 10083425.1966011244803667,
3133033.6966011249460280 10083469.4429495409131050,
3133005.2886967407539487 10083525.1966011244803667,
3132995.5000000000000000 10083587.0000000000000000,
3133005.2886967407539487 10083648.8033988755196333,
3133033.6966011249460280 10083704.5570504590868950,
3133077.9429495413787663 10083748.8033988755196333,
3133133.6966011249460280 10083777.2113032583147287,
3133195.5000000000000000 10083787.0000000000000000,
3133257.3033988750539720 10083777.2113032583147287,
3133313.0570504586212337 10083748.8033988755196333,
3133357.3033988750539720 10083704.5570504590868950,
3133364.6880845781415701 10083690.0637887176126242),
(3134177.1427288707345724 10083918.7576331589370966,
3134176.9466011249460280 10083918.7886967416852713,
3134175.6977847991511226 10083919.4250004421919584,
3134175.4559604721143842 10083917.8981817327439785,
3134177.1427288707345724 10083918.7576331589370966)),
((3134679.3885878794826567 10085414.9990372136235237,
3134700.1929495413787663 10085435.8033988755196333,
3134755.9466011249460280 10085464.2113032583147287,
3134817.7500000000000000 10085474.0000000000000000,
3134879.5533988750539720 10085464.2113032583147287,
3134935.3070504586212337 10085435.8033988755196333,
3134979.5533988750539720 10085391.5570504590868950,
3135007.9613032592460513 10085335.8033988755196333,
3135017.7500000000000000 10085274.0000000000000000,
3135007.9613032592460513 10085212.1966011244803667,
3134979.5533988750539720 10085156.4429495409131050,
3134935.3070504586212337 10085112.1966011244803667,
3134879.5533988750539720 10085083.7886967416852713,
3134817.7500000000000000 10085074.0000000000000000,
3134779.8614121205173433 10085080.0009627863764763,
3134759.0570504586212337 10085059.1966011244803667,
3134703.3033988750539720 10085030.7886967416852713,
3134641.5000000000000000 10085021.0000000000000000,
3134579.6966011249460280 10085030.7886967416852713,
3134523.9429495413787663 10085059.1966011244803667,
3134479.6966011249460280 10085103.4429495409131050,
3134451.2886967407539487 10085159.1966011244803667,
3134441.5000000000000000 10085221.0000000000000000,
3134451.2886967407539487 10085282.8033988755196333,
3134479.6966011249460280 10085338.5570504590868950,
3134523.9429495413787663 10085382.8033988755196333,
3134579.6966011249460280 10085411.2113032583147287,
3134641.5000000000000000 10085421.0000000000000000,
3134679.3885878794826567 10085414.9990372136235237)),
((3134170.1185878752730787 10099314.2118700668215752,
3134147.7970292652025819 10099336.5334286764264107,
3134119.3891248810105026 10099392.2870802599936724,
3134109.6004281402565539 10099454.0904791355133057,
3134119.3891248810105026 10099515.8938780110329390,
3134147.7970292652025819 10099571.6475295946002007,
3134192.0433776816353202 10099615.8938780110329390,
3134247.7970292652025819 10099644.3017823938280344,
3134309.6004281402565539 10099654.0904791355133057,
3134340.2697111465968192 10099649.2329419106245041,
3134358.8748106677085161 10099685.7475056871771812,
3134403.1211590841412544 10099729.9938541036099195,
3134458.8748106677085161 10099758.4017584864050150,
3134520.6782095427624881 10099768.1904552280902863,
3134582.4816084178164601 10099758.4017584864050150,
3134638.2352600013837218 10099729.9938541036099195,
3134682.4816084178164601 10099685.7475056871771812,
3134710.8895128020085394 10099629.9938541036099195,
3134720.6782095427624881 10099568.1904552280902863,
3134710.8895128020085394 10099506.3870563525706530,
3134682.4816084178164601 10099450.6334047690033913,
3134638.2352600013837218 10099406.3870563525706530,
3134582.4816084178164601 10099377.9791519697755575,
3134520.6782095427624881 10099368.1904552280902863,
3134490.0089265364222229 10099373.0479924529790878,
3134471.4038270153105259 10099336.5334286764264107,
3134427.1574785988777876 10099292.2870802599936724,
3134371.4038270153105259 10099263.8791758771985769,
3134369.9434359590522945 10099263.6478726565837860,
3134392.2649945691227913 10099241.3263140469789505,
3134420.6728989533148706 10099185.5726624634116888,
3134430.4615956940688193 10099123.7692635878920555,
3134420.6728989533148706 10099061.9658647123724222,
3134392.2649945691227913 10099006.2122131288051605,
3134348.0186461526900530 10098961.9658647123724222,
3134292.2649945691227913 10098933.5579603295773268,
3134230.4615956940688193 10098923.7692635878920555,
3134168.6581968190148473 10098933.5579603295773268,
3134112.9045452354475856 10098961.9658647123724222,
3134068.6581968190148473 10099006.2122131288051605,
3134040.2502924348227680 10099061.9658647123724222,
3134030.4615956940688193 10099123.7692635878920555,
3134040.2502924348227680 10099185.5726624634116888,
3134068.6581968190148473 10099241.3263140469789505,
3134112.9045452354475856 10099285.5726624634116888,
3134168.6581968190148473 10099313.9805668462067842,
3134170.1185878752730787 10099314.2118700668215752)),
((3134561.0000000000000000 10089266.0000000000000000,
3134551.2113032592460513 10089204.1966011244803667,
3134522.8033988750539720 10089148.4429495409131050,
3134478.5570504586212337 10089104.1966011244803667,
3134422.8033988750539720 10089075.7886967416852713,
3134361.0000000000000000 10089066.0000000000000000,
3134299.1966011249460280 10089075.7886967416852713,
3134243.4429495413787663 10089104.1966011244803667,
3134199.1966011249460280 10089148.4429495409131050,
3134170.7886967407539487 10089204.1966011244803667,
3134161.0000000000000000 10089266.0000000000000000,
3134170.7886967407539487 10089327.8033988755196333,
3134199.1966011249460280 10089383.5570504590868950,
3134243.4429495413787663 10089427.8033988755196333,
3134299.1966011249460280 10089456.2113032583147287,
3134361.0000000000000000 10089466.0000000000000000,
3134422.8033988750539720 10089456.2113032583147287,
3134478.5570504586212337 10089427.8033988755196333,
3134522.8033988750539720 10089383.5570504590868950,
3134551.2113032592460513 10089327.8033988755196333,
3134561.0000000000000000 10089266.0000000000000000)),
((3134022.8502189335413277 10098672.3431504927575588,
3134036.0433317031711340 10098685.5362632628530264,
3134091.7969832867383957 10098713.9441676456481218,
3134153.6003821617923677 10098723.7328643873333931,
3134215.4037810368463397 10098713.9441676456481218,
3134271.1574326204136014 10098685.5362632628530264,
3134315.4037810368463397 10098641.2899148464202881,
3134343.8116854210384190 10098585.5362632628530264,
3134353.6003821617923677 10098523.7328643873333931,
3134343.8116854210384190 10098461.9294655118137598,
3134315.4037810368463397 10098406.1758139282464981,
3134271.1574326204136014 10098361.9294655118137598,
3134215.4037810368463397 10098333.5215611290186644,
3134153.6003821617923677 10098323.7328643873333931,
3134144.2519922284409404 10098325.2135038953274488,
3134131.0588794588111341 10098312.0203911252319813,
3134075.3052278752438724 10098283.6124867424368858,
3134013.5018290001899004 10098273.8237900007516146,
3133951.6984301251359284 10098283.6124867424368858,
3133895.9447785415686667 10098312.0203911252319813,
3133851.6984301251359284 10098356.2667395416647196,
3133823.2905257409438491 10098412.0203911252319813,
3133813.5018290001899004 10098473.8237900007516146,
3133823.2905257409438491 10098535.6271888762712479,
3133851.6984301251359284 10098591.3808404598385096,
3133895.9447785415686667 10098635.6271888762712479,
3133951.6984301251359284 10098664.0350932590663433,
3134013.5018290001899004 10098673.8237900007516146,
3134022.8502189335413277 10098672.3431504927575588)),
((3133467.9607481672428548 10094549.1640554983168840,
3133447.3233241247944534 10094569.8014795407652855,
3133418.9154197406023741 10094625.5551311243325472,
3133409.1267229998484254 10094687.3585299998521805,
3133418.9154197406023741 10094749.1619288753718138,
3133447.3233241247944534 10094804.9155804589390755,
3133491.5696725412271917 10094849.1619288753718138,
3133547.3233241247944534 10094877.5698332581669092,
3133609.1267229998484254 10094887.3585299998521805,
3133670.9301218749023974 10094877.5698332581669092,
3133726.6837734584696591 10094849.1619288753718138,
3133770.9301218749023974 10094804.9155804589390755,
3133799.3380262590944767 10094749.1619288753718138,
3133809.1267229998484254 10094687.3585299998521805,
3133804.6659748326055706 10094659.1944745015352964,
3133825.3033988750539720 10094638.5570504590868950,
3133853.7113032592460513 10094582.8033988755196333,
3133863.5000000000000000 10094521.0000000000000000,
3133853.7113032592460513 10094459.1966011244803667,
3133825.3033988750539720 10094403.4429495409131050,
3133781.0570504586212337 10094359.1966011244803667,
3133725.3033988750539720 10094330.7886967416852713,
3133663.5000000000000000 10094321.0000000000000000,
3133601.6966011249460280 10094330.7886967416852713,
3133545.9429495413787663 10094359.1966011244803667,
3133501.6966011249460280 10094403.4429495409131050,
3133473.2886967407539487 10094459.1966011244803667,
3133463.5000000000000000 10094521.0000000000000000,
3133467.9607481672428548 10094549.1640554983168840)),
((3132445.6047048824839294 10091656.2848457824438810,
3132416.0116486768238246 10091671.3632610477507114,
3132371.7653002603910863 10091715.6096094641834497,
3132343.3573958761990070 10091771.3632610477507114,
3132333.5686991354450583 10091833.1666599232703447,
3132343.3573958761990070 10091894.9700587987899780,
3132371.7653002603910863 10091950.7237103823572397,
3132416.0116486768238246 10091994.9700587987899780,
3132471.7653002603910863 10092023.3779631815850735,
3132497.6058698575943708 10092027.4707073345780373,
3132482.4429495413787663 10092035.1966011244803667,
3132438.1966011249460280 10092079.4429495409131050,
3132409.7886967407539487 10092135.1966011244803667,
3132400.0000000000000000 10092197.0000000000000000,
3132409.7886967407539487 10092258.8033988755196333,
3132438.1966011249460280 10092314.5570504590868950,
3132482.4429495413787663 10092358.8033988755196333,
3132538.1966011249460280 10092387.2113032583147287,
3132566.1558842123486102 10092391.6396186631172895,
3132555.7589660258963704 10092412.0447195190936327,
3132500.3033988750539720 10092383.7886967416852713,
3132438.5000000000000000 10092374.0000000000000000,
3132376.6966011249460280 10092383.7886967416852713,
3132320.9429495413787663 10092412.1966011244803667,
3132276.6966011249460280 10092456.4429495409131050,
3132248.2886967407539487 10092512.1966011244803667,
3132238.5000000000000000 10092574.0000000000000000,
3132248.2886967407539487 10092635.8033988755196333,
3132276.6966011249460280 10092691.5570504590868950,
3132320.9429495413787663 10092735.8033988755196333,
3132376.6966011249460280 10092764.2113032583147287,
3132438.5000000000000000 10092774.0000000000000000,
3132500.3033988750539720 10092764.2113032583147287,
3132556.0570504586212337 10092735.8033988755196333,
3132600.3033988750539720 10092691.5570504590868950,
3132620.9910339741036296 10092650.9552804809063673,
3132676.4466011249460280 10092679.2113032583147287,
3132738.2500000000000000 10092689.0000000000000000,
3132800.0533988750539720 10092679.2113032583147287,
3132855.8070504586212337 10092650.8033988755196333,
3132900.0533988750539720 10092606.5570504590868950,
3132928.4613032592460513 10092550.8033988755196333,
3132938.2500000000000000 10092489.0000000000000000,
3132928.4613032592460513 10092427.1966011244803667,
3132902.3194882278330624 10092375.8904003109782934,
3132950.8033988750539720 10092368.2113032583147287,
3132962.3604438798502088 10092362.3226947076618671,
3132987.4466011249460280 10092411.5570504590868950,
3133018.0046882363967597 10092442.1151375714689493,
3133043.1966011249460280 10092491.5570504590868950,
3133046.0145506658591330 10092494.3750000000000000,
3133010.9466011249460280 10092529.4429495409131050,
3132982.5386967407539487 10092585.1966011244803667,
3132972.7500000000000000 10092647.0000000000000000,
3132982.5386967407539487 10092708.8033988755196333,
3133010.9466011249460280 10092764.5570504590868950,
3133023.8521857620216906 10092777.4626350961625576,
3133022.5000000000000000 10092786.0000000000000000,
3133032.2886967407539487 10092847.8033988755196333,
3133060.6966011249460280 10092903.5570504590868950,
3133065.7518137758597732 10092908.6122631095349789,
3133045.6966011249460280 10092911.7886967416852713,
3132989.9429495413787663 10092940.1966011244803667,
3132986.9509281031787395 10092943.1886225622147322,
3132935.2500000000000000 10092935.0000000000000000,
3132873.4466011249460280 10092944.7886967416852713,
3132817.6929495413787663 10092973.1966011244803667,
3132773.4466011249460280 10093017.4429495409131050,
3132745.0386967407539487 10093073.1966011244803667,
3132735.2500000000000000 10093135.0000000000000000,
3132745.0386967407539487 10093196.8033988755196333,
3132773.4466011249460280 10093252.5570504590868950,
3132817.6929495413787663 10093296.8033988755196333,
3132873.4466011249460280 10093325.2113032583147287,
3132935.2500000000000000 10093335.0000000000000000,
3132997.0533988750539720 10093325.2113032583147287,
3133052.8070504586212337 10093296.8033988755196333,
3133055.7990718968212605 10093293.8113774377852678,
3133107.5000000000000000 10093302.0000000000000000,
3133169.3033988750539720 10093292.2113032583147287,
3133225.0570504586212337 10093263.8033988755196333,
3133269.3033988750539720 10093219.5570504590868950,
3133297.7113032592460513 10093163.8033988755196333,
3133307.5000000000000000 10093102.0000000000000000,
3133297.7113032592460513 10093040.1966011244803667,
3133269.3033988750539720 10092984.4429495409131050,
3133264.2481862241402268 10092979.3877368904650211,
3133284.3033988750539720 10092976.2113032583147287,
3133340.0570504586212337 10092947.8033988755196333,
3133384.3033988750539720 10092903.5570504590868950,
3133396.2826939551159739 10092880.0463600866496563,
3133446.5000000000000000 10092888.0000000000000000,
3133508.3033988750539720 10092878.2113032583147287,
3133516.3995579774491489 10092874.0861041527241468,
3133540.1966011249460280 10092886.2113032583147287,
3133602.0000000000000000 10092896.0000000000000000,
3133663.8033988750539720 10092886.2113032583147287,
3133719.5570504586212337 10092857.8033988755196333,
3133763.8033988750539720 10092813.5570504590868950,
3133792.2113032592460513 10092757.8033988755196333,
3133802.0000000000000000 10092696.0000000000000000,
3133792.2113032592460513 10092634.1966011244803667,
3133763.8033988750539720 10092578.4429495409131050,
3133719.5570504586212337 10092534.1966011244803667,
3133663.8033988750539720 10092505.7886967416852713,
3133602.0000000000000000 10092496.0000000000000000,
3133554.7194883953779936 10092503.4884973689913750,
3133553.4038793691433966 10092500.9064692724496126,
3133569.3070504586212337 10092492.8033988755196333,
3133613.5533988750539720 10092448.5570504590868950,
3133641.9613032592460513 10092392.8033988755196333,
3133651.7500000000000000 10092331.0000000000000000,
3133641.9613032592460513 10092269.1966011244803667,
3133613.5533988750539720 10092213.4429495409131050,
3133569.3070504586212337 10092169.1966011244803667,
3133525.1424776059575379 10092146.6936272904276848,
3133517.4613032592460513 10092098.1966011244803667,
3133489.0533988750539720 10092042.4429495409131050,
3133444.8070504586212337 10091998.1966011244803667,
3133389.0533988750539720 10091969.7886967416852713,
3133331.9065021742135286 10091960.7375174909830093,
3133337.2500000000000000 10091927.0000000000000000,
3133327.4613032592460513 10091865.1966011244803667,
3133309.5078160311095417 10091829.9608984794467688,
3133307.9613032592460513 10091820.1966011244803667,
3133294.1942170630209148 10091793.1771731264889240,
3133285.9613032592460513 10091741.1966011244803667,
3133257.5533988750539720 10091685.4429495409131050,
3133213.3070504586212337 10091641.1966011244803667,
3133157.5533988750539720 10091612.7886967416852713,
3133095.7500000000000000 10091603.0000000000000000,
3133033.9466011249460280 10091612.7886967416852713,
3132978.1929495413787663 10091641.1966011244803667,
3132960.4700184348039329 10091658.9195322301238775,
3132958.1720980103127658 10091654.4096094649285078,
3132913.9257495938800275 10091610.1632610484957695,
3132858.1720980103127658 10091581.7553566657006741,
3132796.3686991352587938 10091571.9666599240154028,
3132734.5653002602048218 10091581.7553566657006741,
3132726.9628497404046357 10091585.6289986837655306,
3132698.7289366237819195 10091590.1008112113922834,
3132651.0663365302607417 10091614.3861189465969801,
3132629.1323354989290237 10091610.9121144693344831,
3132577.4724695058539510 10091619.0942334327846766,
3132564.2500000000000000 10091617.0000000000000000,
3132502.4466011249460280 10091626.7886967416852713,
3132446.6929495413787663 10091655.1966011244803667,
3132445.6047048824839294 10091656.2848457824438810),
(3132812.9415557892061770 10091995.0520051233470440,
3132771.4429495413787663 10092016.1966011244803667,
3132735.0000000000000000 10092052.6395506653934717,
3132717.5570504586212337 10092035.1966011244803667,
3132661.8033988750539720 10092006.7886967416852713,
3132658.4849846488796175 10092006.2631115615367889,
3132690.9357343739829957 10092001.1234177276492119,
3132738.5983344675041735 10091976.8381099924445152,
3132760.5323354988358915 10091980.3121144697070122,
3132798.2229783865623176 10091974.3425030894577503,
3132804.4466011249460280 10091986.5570504590868950,
3132812.9415557892061770 10091995.0520051233470440)),
((3133693.2500000000000000 10089628.0000000000000000,
3133683.4613032592460513 10089566.1966011244803667,
3133655.0533988750539720 10089510.4429495409131050,
3133610.8070504586212337 10089466.1966011244803667,
3133555.0533988750539720 10089437.7886967416852713,
3133493.2500000000000000 10089428.0000000000000000,
3133431.4466011249460280 10089437.7886967416852713,
3133375.6929495413787663 10089466.1966011244803667,
3133331.4466011249460280 10089510.4429495409131050,
3133303.0386967407539487 10089566.1966011244803667,
3133293.2500000000000000 10089628.0000000000000000,
3133303.0386967407539487 10089689.8033988755196333,
3133331.4466011249460280 10089745.5570504590868950,
3133375.6929495413787663 10089789.8033988755196333,
3133431.4466011249460280 10089818.2113032583147287,
3133493.2500000000000000 10089828.0000000000000000,
3133555.0533988750539720 10089818.2113032583147287,
3133610.8070504586212337 10089789.8033988755196333,
3133655.0533988750539720 10089745.5570504590868950,
3133683.4613032592460513 10089689.8033988755196333,
3133693.2500000000000000 10089628.0000000000000000)),
((3133683.5000000000000000 10095547.0000000000000000,
3133673.7113032592460513 10095485.1966011244803667,
3133645.3033988750539720 10095429.4429495409131050,
3133601.0570504586212337 10095385.1966011244803667,
3133545.3033988750539720 10095356.7886967416852713,
3133483.5000000000000000 10095347.0000000000000000,
3133421.6966011249460280 10095356.7886967416852713,
3133365.9429495413787663 10095385.1966011244803667,
3133321.6966011249460280 10095429.4429495409131050,
3133293.2886967407539487 10095485.1966011244803667,
3133283.5000000000000000 10095547.0000000000000000,
3133293.2886967407539487 10095608.8033988755196333,
3133321.6966011249460280 10095664.5570504590868950,
3133365.9429495413787663 10095708.8033988755196333,
3133421.6966011249460280 10095737.2113032583147287,
3133483.5000000000000000 10095747.0000000000000000,
3133545.3033988750539720 10095737.2113032583147287,
3133601.0570504586212337 10095708.8033988755196333,
3133645.3033988750539720 10095664.5570504590868950,
3133673.7113032592460513 10095608.8033988755196333,
3133683.5000000000000000 10095547.0000000000000000)),
((3133077.1441452940925956 10093829.9436381515115499,
3133073.4043901977129281 10093853.5555225554853678,
3133083.1930869384668767 10093915.3589214310050011,
3133111.6009913226589561 10093971.1125730145722628,
3133155.8473397390916944 10094015.3589214310050011,
3133211.6009913226589561 10094043.7668258138000965,
3133240.6602328498847783 10094048.3693575188517570,
3133229.5386967407539487 10094070.1966011244803667,
3133219.7500000000000000 10094132.0000000000000000,
3133229.5386967407539487 10094193.8033988755196333,
3133257.9466011249460280 10094249.5570504590868950,
3133302.1929495413787663 10094293.8033988755196333,
3133357.9466011249460280 10094322.2113032583147287,
3133419.7500000000000000 10094332.0000000000000000,
3133481.5533988750539720 10094322.2113032583147287,
3133537.3070504586212337 10094293.8033988755196333,
3133581.5533988750539720 10094249.5570504590868950,
3133609.9613032592460513 10094193.8033988755196333,
3133619.7500000000000000 10094132.0000000000000000,
3133609.9613032592460513 10094070.1966011244803667,
3133581.5533988750539720 10094014.4429495409131050,
3133537.3070504586212337 10093970.1966011244803667,
3133481.5533988750539720 10093941.7886967416852713,
3133452.4941573478281498 10093937.1861650366336107,
3133463.6156934569589794 10093915.3589214310050011,
3133473.4043901977129281 10093853.5555225554853678,
3133463.6156934569589794 10093791.7521236799657345,
3133435.2077890727669001 10093735.9984720963984728,
3133390.9614406563341618 10093691.7521236799657345,
3133335.2077890727669001 10093663.3442192971706390,
3133273.7602449036203325 10093653.6118844039738178,
3133277.5000000000000000 10093630.0000000000000000,
3133267.7113032592460513 10093568.1966011244803667,
3133239.3033988750539720 10093512.4429495409131050,
3133195.0570504586212337 10093468.1966011244803667,
3133139.3033988750539720 10093439.7886967416852713,
3133077.5000000000000000 10093430.0000000000000000,
3133015.6966011249460280 10093439.7886967416852713,
3132959.9429495413787663 10093468.1966011244803667,
3132915.6966011249460280 10093512.4429495409131050,
3132887.2886967407539487 10093568.1966011244803667,
3132877.5000000000000000 10093630.0000000000000000,
3132887.2886967407539487 10093691.8033988755196333,
3132915.6966011249460280 10093747.5570504590868950,
3132959.9429495413787663 10093791.8033988755196333,
3133015.6966011249460280 10093820.2113032583147287,
3133077.1441452940925956 10093829.9436381515115499)),
((3133296.2701623719185591 10097325.6403034031391144,
3133286.4814656311646104 10097263.8369045276194811,
3133258.0735612469725311 10097208.0832529440522194,
3133213.8272128305397928 10097163.8369045276194811,
3133158.0735612469725311 10097135.4290001448243856,
3133096.2701623719185591 10097125.6403034031391144,
3133034.4667634968645871 10097135.4290001448243856,
3132978.7131119132973254 10097163.8369045276194811,
3132934.4667634968645871 10097208.0832529440522194,
3132906.0588591126725078 10097263.8369045276194811,
3132896.2701623719185591 10097325.6403034031391144,
3132906.0588591126725078 10097387.4437022786587477,
3132934.4667634968645871 10097443.1973538622260094,
3132978.7131119132973254 10097487.4437022786587477,
3133034.4667634968645871 10097515.8516066614538431,
3133096.2701623719185591 10097525.6403034031391144,
3133158.0735612469725311 10097515.8516066614538431,
3133213.8272128305397928 10097487.4437022786587477,
3133258.0735612469725311 10097443.1973538622260094,
3133286.4814656311646104 10097387.4437022786587477,
3133296.2701623719185591 10097325.6403034031391144)),
((3133268.2677942002192140 10080255.8193339351564646,
3133258.4790974594652653 10080194.0159350596368313,
3133230.0711930752731860 10080138.2622834760695696,
3133185.8248446588404477 10080094.0159350596368313,
3133130.0711930752731860 10080065.6080306768417358,
3133068.2677942002192140 10080055.8193339351564646,
3133006.4643953251652420 10080065.6080306768417358,
3132950.7107437415979803 10080094.0159350596368313,
3132906.4643953251652420 10080138.2622834760695696,
3132878.0564909409731627 10080194.0159350596368313,
3132868.2677942002192140 10080255.8193339351564646,
3132878.0564909409731627 10080317.6227328106760979,
3132906.4643953251652420 10080373.3763843942433596,
3132950.7107437415979803 10080417.6227328106760979,
3133006.4643953251652420 10080446.0306371934711933,
3133068.2677942002192140 10080455.8193339351564646,
3133130.0711930752731860 10080446.0306371934711933,
3133185.8248446588404477 10080417.6227328106760979,
3133230.0711930752731860 10080373.3763843942433596,
3133258.4790974594652653 10080317.6227328106760979,
3133268.2677942002192140 10080255.8193339351564646)),
((3133249.5000000000000000 10082806.0000000000000000,
3133239.7113032592460513 10082744.1966011244803667,
3133211.3033988750539720 10082688.4429495409131050,
3133167.0570504586212337 10082644.1966011244803667,
3133111.3033988750539720 10082615.7886967416852713,
3133049.5000000000000000 10082606.0000000000000000,
3132987.6966011249460280 10082615.7886967416852713,
3132931.9429495413787663 10082644.1966011244803667,
3132887.6966011249460280 10082688.4429495409131050,
3132859.2886967407539487 10082744.1966011244803667,
3132849.5000000000000000 10082806.0000000000000000,
3132859.2886967407539487 10082867.8033988755196333,
3132887.6966011249460280 10082923.5570504590868950,
3132931.9429495413787663 10082967.8033988755196333,
3132987.6966011249460280 10082996.2113032583147287,
3133049.5000000000000000 10083006.0000000000000000,
3133111.3033988750539720 10082996.2113032583147287,
3133167.0570504586212337 10082967.8033988755196333,
3133211.3033988750539720 10082923.5570504590868950,
3133239.7113032592460513 10082867.8033988755196333,
3133249.5000000000000000 10082806.0000000000000000)),
((3133193.5000000000000000 10085288.0000000000000000,
3133183.7113032592460513 10085226.1966011244803667,
3133155.3033988750539720 10085170.4429495409131050,
3133111.0570504586212337 10085126.1966011244803667,
3133055.3033988750539720 10085097.7886967416852713,
3132993.5000000000000000 10085088.0000000000000000,
3132931.6966011249460280 10085097.7886967416852713,
3132875.9429495413787663 10085126.1966011244803667,
3132831.6966011249460280 10085170.4429495409131050,
3132803.2886967407539487 10085226.1966011244803667,
3132793.5000000000000000 10085288.0000000000000000,
3132803.2886967407539487 10085349.8033988755196333,
3132831.6966011249460280 10085405.5570504590868950,
3132875.9429495413787663 10085449.8033988755196333,
3132931.6966011249460280 10085478.2113032583147287,
3132993.5000000000000000 10085488.0000000000000000,
3133055.3033988750539720 10085478.2113032583147287,
3133111.0570504586212337 10085449.8033988755196333,
3133155.3033988750539720 10085405.5570504590868950,
3133183.7113032592460513 10085349.8033988755196333,
3133193.5000000000000000 10085288.0000000000000000)),
((3132801.3738949438557029 10084397.9198707770556211,
3132791.3033988750539720 10084392.7886967416852713,
3132729.5000000000000000 10084383.0000000000000000,
3132667.6966011249460280 10084392.7886967416852713,
3132611.9429495413787663 10084421.1966011244803667,
3132567.6966011249460280 10084465.4429495409131050,
3132539.2886967407539487 10084521.1966011244803667,
3132529.5000000000000000 10084583.0000000000000000,
3132539.2886967407539487 10084644.8033988755196333,
3132567.6966011249460280 10084700.5570504590868950,
3132611.9429495413787663 10084744.8033988755196333,
3132667.6966011249460280 10084773.2113032583147287,
3132729.5000000000000000 10084783.0000000000000000,
3132791.3033988750539720 10084773.2113032583147287,
3132840.6261050561442971 10084748.0801292229443789,
3132850.6966011249460280 10084753.2113032583147287,
3132912.5000000000000000 10084763.0000000000000000,
3132974.3033988750539720 10084753.2113032583147287,
3133030.0570504586212337 10084724.8033988755196333,
3133074.3033988750539720 10084680.5570504590868950,
3133102.7113032592460513 10084624.8033988755196333,
3133112.5000000000000000 10084563.0000000000000000,
3133102.7113032592460513 10084501.1966011244803667,
3133074.3033988750539720 10084445.4429495409131050,
3133030.0570504586212337 10084401.1966011244803667,
3132974.3033988750539720 10084372.7886967416852713,
3132912.5000000000000000 10084363.0000000000000000,
3132850.6966011249460280 10084372.7886967416852713,
3132801.3738949438557029 10084397.9198707770556211)),
((3132594.2500000000000000 10095096.0000000000000000,
3132584.4613032592460513 10095034.1966011244803667,
3132556.0533988750539720 10094978.4429495409131050,
3132511.8070504586212337 10094934.1966011244803667,
3132456.0533988750539720 10094905.7886967416852713,
3132394.2500000000000000 10094896.0000000000000000,
3132332.4466011249460280 10094905.7886967416852713,
3132276.6929495413787663 10094934.1966011244803667,
3132232.4466011249460280 10094978.4429495409131050,
3132204.0386967407539487 10095034.1966011244803667,
3132194.2500000000000000 10095096.0000000000000000,
3132204.0386967407539487 10095157.8033988755196333,
3132232.4466011249460280 10095213.5570504590868950,
3132276.6929495413787663 10095257.8033988755196333,
3132332.4466011249460280 10095286.2113032583147287,
3132394.2500000000000000 10095296.0000000000000000,
3132456.0533988750539720 10095286.2113032583147287,
3132511.8070504586212337 10095257.8033988755196333,
3132556.0533988750539720 10095213.5570504590868950,
3132584.4613032592460513 10095157.8033988755196333,
3132594.2500000000000000 10095096.0000000000000000)),
((3131287.5587792061269283 10093137.7733188141137362,
3131288.0386967407539487 10093140.8033988755196333,
3131316.4466011249460280 10093196.5570504590868950,
3131360.6929495413787663 10093240.8033988755196333,
3131416.4466011249460280 10093269.2113032583147287,
3131478.2500000000000000 10093279.0000000000000000,
3131540.0533988750539720 10093269.2113032583147287,
3131595.8070504586212337 10093240.8033988755196333,
3131640.0533988750539720 10093196.5570504590868950,
3131668.4613032592460513 10093140.8033988755196333,
3131675.8495450923219323 10093094.1558758094906807,
3131689.6966011249460280 10093101.2113032583147287,
3131751.5000000000000000 10093111.0000000000000000,
3131757.8193978900089860 10093109.9991057012230158,
3131776.4466011249460280 10093146.5570504590868950,
3131820.6929495413787663 10093190.8033988755196333,
3131856.8636625604704022 10093209.2332976851612329,
3131855.0000000000000000 10093221.0000000000000000,
3131864.7886967407539487 10093282.8033988755196333,
3131893.1966011249460280 10093338.5570504590868950,
3131937.4429495413787663 10093382.8033988755196333,
3131993.1966011249460280 10093411.2113032583147287,
3132055.0000000000000000 10093421.0000000000000000,
3132116.8033988750539720 10093411.2113032583147287,
3132172.5570504586212337 10093382.8033988755196333,
3132211.4806754509918392 10093343.8797738831490278,
3132261.1966011249460280 10093369.2113032583147287,
3132323.0000000000000000 10093379.0000000000000000,
3132384.8033988750539720 10093369.2113032583147287,
3132440.5570504586212337 10093340.8033988755196333,
3132484.8033988750539720 10093296.5570504590868950,
3132513.2113032592460513 10093240.8033988755196333,
3132523.0000000000000000 10093179.0000000000000000,
3132513.2113032592460513 10093117.1966011244803667,
3132484.8033988750539720 10093061.4429495409131050,
3132440.5570504586212337 10093017.1966011244803667,
3132384.8033988750539720 10092988.7886967416852713,
3132323.0000000000000000 10092979.0000000000000000,
3132261.1966011249460280 10092988.7886967416852713,
3132205.4429495413787663 10093017.1966011244803667,
3132202.6250000000000000 10093020.0145506653934717,
3132172.8070504586212337 10092990.1966011244803667,
3132128.5310305962339044 10092967.6368422023952007,
3132128.4613032592460513 10092967.1966011244803667,
3132100.0533988750539720 10092911.4429495409131050,
3132055.8070504586212337 10092867.1966011244803667,
3132000.0533988750539720 10092838.7886967416852713,
3131938.2500000000000000 10092829.0000000000000000,
3131931.9306021099910140 10092830.0008942987769842,
3131913.3033988750539720 10092793.4429495409131050,
3131869.0570504586212337 10092749.1966011244803667,
3131813.3033988750539720 10092720.7886967416852713,
3131751.5000000000000000 10092711.0000000000000000,
3131732.5964318099431694 10092713.9940310679376125,
3131687.0533988750539720 10092690.7886967416852713,
3131625.2500000000000000 10092681.0000000000000000,
3131563.4466011249460280 10092690.7886967416852713,
3131507.6929495413787663 10092719.1966011244803667,
3131463.4466011249460280 10092763.4429495409131050,
3131453.7346392036415637 10092782.5037480369210243,
3131401.3033988750539720 10092755.7886967416852713,
3131339.5000000000000000 10092746.0000000000000000,
3131277.6966011249460280 10092755.7886967416852713,
3131221.9429495413787663 10092784.1966011244803667,
3131177.6966011249460280 10092828.4429495409131050,
3131149.2886967407539487 10092884.1966011244803667,
3131139.5000000000000000 10092946.0000000000000000,
3131149.2886967407539487 10093007.8033988755196333,
3131177.6966011249460280 10093063.5570504590868950,
3131221.9429495413787663 10093107.8033988755196333,
3131277.6966011249460280 10093136.2113032583147287,
3131287.5587792061269283 10093137.7733188141137362)),
((3132519.8371540000662208 10093968.6206899993121624,
3132510.0484572593122721 10093906.8172911237925291,
3132481.6405528751201928 10093851.0636395402252674,
3132437.3942044586874545 10093806.8172911237925291,
3132381.6405528751201928 10093778.4093867409974337,
3132319.8371540000662208 10093768.6206899993121624,
3132258.0337551250122488 10093778.4093867409974337,
3132202.2801035414449871 10093806.8172911237925291,
3132158.0337551250122488 10093851.0636395402252674,
3132129.6258507408201694 10093906.8172911237925291,
3132119.8371540000662208 10093968.6206899993121624,
3132129.6258507408201694 10094030.4240888748317957,
3132158.0337551250122488 10094086.1777404583990574,
3132202.2801035414449871 10094130.4240888748317957,
3132258.0337551250122488 10094158.8319932576268911,
3132319.8371540000662208 10094168.6206899993121624,
3132381.6405528751201928 10094158.8319932576268911,
3132437.3942044586874545 10094130.4240888748317957,
3132481.6405528751201928 10094086.1777404583990574,
3132510.0484572593122721 10094030.4240888748317957,
3132519.8371540000662208 10093968.6206899993121624)),
((3132489.5000000000000000 10085291.0000000000000000,
3132479.7113032592460513 10085229.1966011244803667,
3132451.3033988750539720 10085173.4429495409131050,
3132407.0570504586212337 10085129.1966011244803667,
3132351.3033988750539720 10085100.7886967416852713,
3132289.5000000000000000 10085091.0000000000000000,
3132227.6966011249460280 10085100.7886967416852713,
3132171.9429495413787663 10085129.1966011244803667,
3132127.6966011249460280 10085173.4429495409131050,
3132099.2886967407539487 10085229.1966011244803667,
3132089.5000000000000000 10085291.0000000000000000,
3132099.2886967407539487 10085352.8033988755196333,
3132127.6966011249460280 10085408.5570504590868950,
3132171.9429495413787663 10085452.8033988755196333,
3132227.6966011249460280 10085481.2113032583147287,
3132289.5000000000000000 10085491.0000000000000000,
3132351.3033988750539720 10085481.2113032583147287,
3132407.0570504586212337 10085452.8033988755196333,
3132451.3033988750539720 10085408.5570504590868950,
3132479.7113032592460513 10085352.8033988755196333,
3132489.5000000000000000 10085291.0000000000000000)),
((3132399.0405893186107278 10096330.6733119841665030,
3132389.2518925778567791 10096268.8699131086468697,
3132360.8439881936646998 10096213.1162615250796080,
3132316.5976397772319615 10096168.8699131086468697,
3132260.8439881936646998 10096140.4620087258517742,
3132199.0405893186107278 10096130.6733119841665030,
3132137.2371904435567558 10096140.4620087258517742,
3132081.4835388599894941 10096168.8699131086468697,
3132037.2371904435567558 10096213.1162615250796080,
3132008.8292860593646765 10096268.8699131086468697,
3131999.0405893186107278 10096330.6733119841665030,
3132008.8292860593646765 10096392.4767108596861362,
3132037.2371904435567558 10096448.2303624432533979,
3132081.4835388599894941 10096492.4767108596861362,
3132137.2371904435567558 10096520.8846152424812317,
3132199.0405893186107278 10096530.6733119841665030,
3132260.8439881936646998 10096520.8846152424812317,
3132316.5976397772319615 10096492.4767108596861362,
3132360.8439881936646998 10096448.2303624432533979,
3132389.2518925778567791 10096392.4767108596861362,
3132399.0405893186107278 10096330.6733119841665030)),
((3131400.7255569100379944 10084323.4139937553554773,
3131395.6966011249460280 10084328.4429495409131050,
3131367.2886967407539487 10084384.1966011244803667,
3131357.5000000000000000 10084446.0000000000000000,
3131367.2886967407539487 10084507.8033988755196333,
3131395.6966011249460280 10084563.5570504590868950,
3131439.9429495413787663 10084607.8033988755196333,
3131495.6966011249460280 10084636.2113032583147287,
3131557.5000000000000000 10084646.0000000000000000,
3131619.3033988750539720 10084636.2113032583147287,
3131675.0570504586212337 10084607.8033988755196333,
3131686.4033466423861682 10084596.4571026917546988,
3131697.6966011249460280 10084602.2113032583147287,
3131759.5000000000000000 10084612.0000000000000000,
3131821.3033988750539720 10084602.2113032583147287,
3131877.0570504586212337 10084573.8033988755196333,
3131921.3033988750539720 10084529.5570504590868950,
3131949.7113032592460513 10084473.8033988755196333,
3131959.5000000000000000 10084412.0000000000000000,
3131949.7113032592460513 10084350.1966011244803667,
3131921.3033988750539720 10084294.4429495409131050,
3131877.0570504586212337 10084250.1966011244803667,
3131821.3033988750539720 10084221.7886967416852713,
3131759.5000000000000000 10084212.0000000000000000,
3131697.6966011249460280 10084221.7886967416852713,
3131695.5887155616655946 10084222.8627180811017752,
3131650.3033988750539720 10084199.7886967416852713,
3131588.5000000000000000 10084190.0000000000000000,
3131526.6966011249460280 10084199.7886967416852713,
3131470.9429495413787663 10084228.1966011244803667,
3131426.6966011249460280 10084272.4429495409131050,
3131400.7255569100379944 10084323.4139937553554773)),
((3131467.7318061250261962 10092120.2226822115480900,
3131466.5000000000000000 10092128.0000000000000000,
3131476.2886967407539487 10092189.8033988755196333,
3131504.6966011249460280 10092245.5570504590868950,
3131548.9429495413787663 10092289.8033988755196333,
3131604.6966011249460280 10092318.2113032583147287,
3131666.5000000000000000 10092328.0000000000000000,
3131728.3033988750539720 10092318.2113032583147287,
3131782.4194894204847515 10092290.6377779003232718,
3131804.0533988750539720 10092287.2113032583147287,
3131859.8070504586212337 10092258.8033988755196333,
3131904.0533988750539720 10092214.5570504590868950,
3131932.4613032592460513 10092158.8033988755196333,
3131942.2500000000000000 10092097.0000000000000000,
3131932.4613032592460513 10092035.1966011244803667,
3131904.0533988750539720 10091979.4429495409131050,
3131859.8070504586212337 10091935.1966011244803667,
3131804.0533988750539720 10091906.7886967416852713,
3131742.2500000000000000 10091897.0000000000000000,
3131680.4466011249460280 10091906.7886967416852713,
3131658.0100431735627353 10091918.2206940166652203,
3131605.3811745895072818 10091926.5562879126518965,
3131549.6275230059400201 10091954.9641922954469919,
3131505.3811745895072818 10091999.2105407118797302,
3131476.9732702053152025 10092054.9641922954469919,
3131467.1845734645612538 10092116.7675911709666252,
3131467.7318061250261962 10092120.2226822115480900)),
((3131842.7500000000000000 10085312.0000000000000000,
3131832.9613032592460513 10085250.1966011244803667,
3131804.5533988750539720 10085194.4429495409131050,
3131760.3070504586212337 10085150.1966011244803667,
3131704.5533988750539720 10085121.7886967416852713,
3131642.7500000000000000 10085112.0000000000000000,
3131580.9466011249460280 10085121.7886967416852713,
3131525.1929495413787663 10085150.1966011244803667,
3131480.9466011249460280 10085194.4429495409131050,
3131452.5386967407539487 10085250.1966011244803667,
3131442.7500000000000000 10085312.0000000000000000,
3131452.5386967407539487 10085373.8033988755196333,
3131480.9466011249460280 10085429.5570504590868950,
3131525.1929495413787663 10085473.8033988755196333,
3131580.9466011249460280 10085502.2113032583147287,
3131642.7500000000000000 10085512.0000000000000000,
3131704.5533988750539720 10085502.2113032583147287,
3131760.3070504586212337 10085473.8033988755196333,
3131804.5533988750539720 10085429.5570504590868950,
3131832.9613032592460513 10085373.8033988755196333,
3131842.7500000000000000 10085312.0000000000000000)),
((3131380.6685430491343141 10096818.7210076171904802,
3131336.5690999175421894 10096825.7056732363998890,
3131280.8154483339749277 10096854.1135776191949844,
3131236.5690999175421894 10096898.3599260356277227,
3131208.1611955333501101 10096954.1135776191949844,
3131198.3724987925961614 10097015.9169764947146177,
3131208.1611955333501101 10097077.7203753702342510,
3131236.5690999175421894 10097133.4740269538015127,
3131280.8154483339749277 10097177.7203753702342510,
3131336.5690999175421894 10097206.1282797530293465,
3131398.3724987925961614 10097215.9169764947146177,
3131460.1758976676501334 10097206.1282797530293465,
3131515.9295492512173951 10097177.7203753702342510,
3131528.4539557434618473 10097165.1959688775241375,
3131572.5533988750539720 10097158.2113032583147287,
3131628.3070504586212337 10097129.8033988755196333,
3131672.5533988750539720 10097085.5570504590868950,
3131700.9613032592460513 10097029.8033988755196333,
3131710.7500000000000000 10096968.0000000000000000,
3131700.9613032592460513 10096906.1966011244803667,
3131672.5533988750539720 10096850.4429495409131050,
3131628.3070504586212337 10096806.1966011244803667,
3131572.5533988750539720 10096777.7886967416852713,
3131510.7500000000000000 10096768.0000000000000000,
3131448.9466011249460280 10096777.7886967416852713,
3131393.1929495413787663 10096806.1966011244803667,
3131380.6685430491343141 10096818.7210076171904802)),
((3131009.9058093223720789 10100104.0162586569786072,
3131009.7500000000000000 10100105.0000000000000000,
3131019.5386967407539487 10100166.8033988755196333,
3131047.9466011249460280 10100222.5570504590868950,
3131092.1929495413787663 10100266.8033988755196333,
3131147.9466011249460280 10100295.2113032583147287,
3131209.7500000000000000 10100305.0000000000000000,
3131250.2408929169178009 10100298.5868725869804621,
3131248.7500000000000000 10100308.0000000000000000,
3131258.5386967407539487 10100369.8033988755196333,
3131286.9466011249460280 10100425.5570504590868950,
3131331.1929495413787663 10100469.8033988755196333,
3131386.9466011249460280 10100498.2113032583147287,
3131448.7500000000000000 10100508.0000000000000000,
3131510.5533988750539720 10100498.2113032583147287,
3131566.3070504586212337 10100469.8033988755196333,
3131610.5533988750539720 10100425.5570504590868950,
3131638.9613032592460513 10100369.8033988755196333,
3131648.7500000000000000 10100308.0000000000000000,
3131638.9613032592460513 10100246.1966011244803667,
3131610.5533988750539720 10100190.4429495409131050,
3131566.3070504586212337 10100146.1966011244803667,
3131510.5533988750539720 10100117.7886967416852713,
3131448.7500000000000000 10100108.0000000000000000,
3131408.2591070830821991 10100114.4131274130195379,
3131409.7500000000000000 10100105.0000000000000000,
3131408.3885755990631878 10100096.4043046254664660,
3131453.8033988750539720 10100089.2113032583147287,
3131509.5570504586212337 10100060.8033988755196333,
3131553.8033988750539720 10100016.5570504590868950,
3131582.2113032592460513 10099960.8033988755196333,
3131592.0000000000000000 10099899.0000000000000000,
3131582.2113032592460513 10099837.1966011244803667,
3131553.8033988750539720 10099781.4429495409131050,
3131509.5570504586212337 10099737.1966011244803667,
3131453.8033988750539720 10099708.7886967416852713,
3131392.0000000000000000 10099699.0000000000000000,
3131382.2480521067045629 10099700.5445568095892668,
3131374.5533988750539720 10099685.4429495409131050,
3131330.3070504586212337 10099641.1966011244803667,
3131274.5533988750539720 10099612.7886967416852713,
3131212.7500000000000000 10099603.0000000000000000,
3131150.9466011249460280 10099612.7886967416852713,
3131095.1929495413787663 10099641.1966011244803667,
3131050.9466011249460280 10099685.4429495409131050,
3131022.5386967407539487 10099741.1966011244803667,
3131016.6870483122766018 10099778.1424552537500858,
3131010.6929495413787663 10099781.1966011244803667,
3130966.4466011249460280 10099825.4429495409131050,
3130938.0386967407539487 10099881.1966011244803667,
3130928.2500000000000000 10099943.0000000000000000,
3130938.0386967407539487 10100004.8033988755196333,
3130966.4466011249460280 10100060.5570504590868950,
3131009.9058093223720789 10100104.0162586569786072)),
((3127277.2500000000000000 10098867.0000000000000000,
3127267.4613032592460513 10098805.1966011244803667,
3127239.0533988750539720 10098749.4429495409131050,
3127194.8070504586212337 10098705.1966011244803667,
3127139.0533988750539720 10098676.7886967416852713,
3127077.2500000000000000 10098667.0000000000000000,
3127015.4466011249460280 10098676.7886967416852713,
3126959.6929495413787663 10098705.1966011244803667,
3126915.4466011249460280 10098749.4429495409131050,
3126887.0386967407539487 10098805.1966011244803667,
3126877.2500000000000000 10098867.0000000000000000,
3126887.0386967407539487 10098928.8033988755196333,
3126915.4466011249460280 10098984.5570504590868950,
3126959.6929495413787663 10099028.8033988755196333,
3127015.4466011249460280 10099057.2113032583147287,
3127077.2500000000000000 10099067.0000000000000000,
3127139.0533988750539720 10099057.2113032583147287,
3127194.8070504586212337 10099028.8033988755196333,
3127239.0533988750539720 10098984.5570504590868950,
3127267.4613032592460513 10098928.8033988755196333,
3127277.2500000000000000 10098867.0000000000000000))),
MULTIPOLYGON (((3132347.2500000000000000 10081181.0000000000000000,
3132337.4613032592460513 10081119.1966011244803667,
3132309.0533988750539720 10081063.4429495409131050,
3132264.8070504586212337 10081019.1966011244803667,
3132209.0533988750539720 10080990.7886967416852713,
3132147.2500000000000000 10080981.0000000000000000,
3132085.4466011249460280 10080990.7886967416852713,
3132029.6929495413787663 10081019.1966011244803667,
3131985.4466011249460280 10081063.4429495409131050,
3131957.0386967407539487 10081119.1966011244803667,
3131947.2500000000000000 10081181.0000000000000000,
3131957.0386967407539487 10081242.8033988755196333,
3131985.4466011249460280 10081298.5570504590868950,
3132029.6929495413787663 10081342.8033988755196333,
3132085.4466011249460280 10081371.2113032583147287,
3132147.2500000000000000 10081381.0000000000000000,
3132209.0533988750539720 10081371.2113032583147287,
3132264.8070504586212337 10081342.8033988755196333,
3132309.0533988750539720 10081298.5570504590868950,
3132337.4613032592460513 10081242.8033988755196333,
3132347.2500000000000000 10081181.0000000000000000)),
((3131169.2105593103915453 10081549.7880717460066080,
3131118.6966011249460280 10081557.7886967416852713,
3131062.9429495413787663 10081586.1966011244803667,
3131018.6966011249460280 10081630.4429495409131050,
3130990.2886967407539487 10081686.1966011244803667,
3130980.5000000000000000 10081748.0000000000000000,
3130990.2886967407539487 10081809.8033988755196333,
3131018.6966011249460280 10081865.5570504590868950,
3131062.9429495413787663 10081909.8033988755196333,
3131118.6966011249460280 10081938.2113032583147287,
3131180.5000000000000000 10081948.0000000000000000,
3131242.3033988750539720 10081938.2113032583147287,
3131298.0570504586212337 10081909.8033988755196333,
3131342.3033988750539720 10081865.5570504590868950,
3131370.7113032592460513 10081809.8033988755196333,
3131374.2894406896084547 10081787.2119282539933920,
3131424.8033988750539720 10081779.2113032583147287,
3131480.5570504586212337 10081750.8033988755196333,
3131524.8033988750539720 10081706.5570504590868950,
3131553.2113032592460513 10081650.8033988755196333,
3131563.0000000000000000 10081589.0000000000000000,
3131556.7027526847086847 10081549.2407452240586281,
3131593.3230797019787133 10081512.6204182058572769,
3131621.7309840861707926 10081456.8667666222900152,
3131631.5196808269247413 10081395.0633677467703819,
3131621.7309840861707926 10081333.2599688712507486,
3131593.3230797019787133 10081277.5063172876834869,
3131549.0767312855459750 10081233.2599688712507486,
3131493.3230797019787133 10081204.8520644884556532,
3131431.5196808269247413 10081195.0633677467703819,
3131369.7162819518707693 10081204.8520644884556532,
3131313.9626303683035076 10081233.2599688712507486,
3131269.7162819518707693 10081277.5063172876834869,
3131241.3083775676786900 10081333.2599688712507486,
3131231.5196808269247413 10081395.0633677467703819,
3131237.8169281422160566 10081434.8226225227117538,
3131201.1966011249460280 10081471.4429495409131050,
3131172.7886967407539487 10081527.1966011244803667,
3131169.2105593103915453 10081549.7880717460066080)),
((3130865.5657762284390628 10079938.0688744615763426,
3130827.6437804959714413 10079957.3910963814705610,
3130783.3974320795387030 10080001.6374447979032993,
3130754.9895276953466237 10080057.3910963814705610,
3130745.2008309545926750 10080119.1944952569901943,
3130754.9895276953466237 10080180.9978941325098276,
3130783.3974320795387030 10080236.7515457160770893,
3130827.6437804959714413 10080280.9978941325098276,
3130883.3974320795387030 10080309.4057985153049231,
3130943.8375088651664555 10080318.9785662516951561,
3130960.9466011249460280 10080352.5570504590868950,
3131005.1929495413787663 10080396.8033988755196333,
3131060.9466011249460280 10080425.2113032583147287,
3131122.7500000000000000 10080435.0000000000000000,
3131184.5533988750539720 10080425.2113032583147287,
3131240.3070504586212337 10080396.8033988755196333,
3131284.5533988750539720 10080352.5570504590868950,
3131312.9613032592460513 10080296.8033988755196333,
3131322.7500000000000000 10080235.0000000000000000,
3131322.7219715188257396 10080234.8230351340025663,
3131325.4466011249460280 10080236.2113032583147287,
3131387.2500000000000000 10080246.0000000000000000,
3131449.0533988750539720 10080236.2113032583147287,
3131504.8070504586212337 10080207.8033988755196333,
3131549.0533988750539720 10080163.5570504590868950,
3131577.4613032592460513 10080107.8033988755196333,
3131587.2500000000000000 10080046.0000000000000000,
3131577.4613032592460513 10079984.1966011244803667,
3131549.0533988750539720 10079928.4429495409131050,
3131526.0568381357006729 10079905.4463888015598059,
3131541.0570504586212337 10079897.8033988755196333,
3131585.3033988750539720 10079853.5570504590868950,
3131613.7113032592460513 10079797.8033988755196333,
3131623.5000000000000000 10079736.0000000000000000,
3131613.7113032592460513 10079674.1966011244803667,
3131585.3033988750539720 10079618.4429495409131050,
3131541.0570504586212337 10079574.1966011244803667,
3131485.3033988750539720 10079545.7886967416852713,
3131423.5000000000000000 10079536.0000000000000000,
3131361.6966011249460280 10079545.7886967416852713,
3131305.9429495413787663 10079574.1966011244803667,
3131261.6966011249460280 10079618.4429495409131050,
3131233.2886967407539487 10079674.1966011244803667,
3131223.5000000000000000 10079736.0000000000000000,
3131229.7963356473483145 10079775.7534987311810255,
3131226.5290500517003238 10079776.2709859311580658,
3131208.5636688028462231 10079741.0119399577379227,
3131164.3173203864134848 10079696.7655915413051844,
3131108.5636688028462231 10079668.3576871585100889,
3131046.7602699277922511 10079658.5689904168248177,
3130984.9568710527382791 10079668.3576871585100889,
3130929.2032194691710174 10079696.7655915413051844,
3130884.9568710527382791 10079741.0119399577379227,
3130856.5489666685461998 10079796.7655915413051844,
3130846.7602699277922511 10079858.5689904168248177,
3130856.5489666685461998 10079920.3723892923444510,
3130865.5657762284390628 10079938.0688744615763426)),
((3129970.2669724728912115 10084143.6225781925022602,
3129933.3033988750539720 10084124.7886967416852713,
3129871.5000000000000000 10084115.0000000000000000,
3129809.6966011249460280 10084124.7886967416852713,
3129753.9429495413787663 10084153.1966011244803667,
3129709.6966011249460280 10084197.4429495409131050,
3129681.2886967407539487 10084253.1966011244803667,
3129671.5000000000000000 10084315.0000000000000000,
3129681.2886967407539487 10084376.8033988755196333,
3129709.6966011249460280 10084432.5570504590868950,
3129753.9429495413787663 10084476.8033988755196333,
3129809.6966011249460280 10084505.2113032583147287,
3129871.5000000000000000 10084515.0000000000000000,
3129933.3033988750539720 10084505.2113032583147287,
3129989.0570504586212337 10084476.8033988755196333,
3130002.4830275271087885 10084463.3774218074977398,
3130008.8090698570013046 10084466.6007013693451881,
3129983.5386967407539487 10084516.1966011244803667,
3129973.7500000000000000 10084578.0000000000000000,
3129983.5386967407539487 10084639.8033988755196333,
3130011.9466011249460280 10084695.5570504590868950,
3130056.1929495413787663 10084739.8033988755196333,
3130111.9466011249460280 10084768.2113032583147287,
3130173.7500000000000000 10084778.0000000000000000,
3130235.5533988750539720 10084768.2113032583147287,
3130291.3070504586212337 10084739.8033988755196333,
3130335.5533988750539720 10084695.5570504590868950,
3130363.9613032592460513 10084639.8033988755196333,
3130366.8183174086734653 10084621.7649214621633291,
3130406.9466011249460280 10084642.2113032583147287,
3130468.7500000000000000 10084652.0000000000000000,
3130518.2927499432116747 10084644.1531992778182030,
3130555.9429495413787663 10084681.8033988755196333,
3130611.6966011249460280 10084710.2113032583147287,
3130673.5000000000000000 10084720.0000000000000000,
3130735.3033988750539720 10084710.2113032583147287,
3130791.0570504586212337 10084681.8033988755196333,
3130835.3033988750539720 10084637.5570504590868950,
3130836.3461241577751935 10084635.5105868652462959,
3130830.2500000000000000 10084674.0000000000000000,
3130832.3541938099078834 10084687.2853568568825722,
3130807.5736015490256250 10084712.0659491177648306,
3130796.6966011249460280 10084713.7886967416852713,
3130740.9429495413787663 10084742.1966011244803667,
3130696.6966011249460280 10084786.4429495409131050,
3130668.2886967407539487 10084842.1966011244803667,
3130658.5000000000000000 10084904.0000000000000000,
3130668.2886967407539487 10084965.8033988755196333,
3130696.6966011249460280 10085021.5570504590868950,
3130700.3895506658591330 10085025.2500000000000000,
3130680.1966011249460280 10085045.4429495409131050,
3130651.7886967407539487 10085101.1966011244803667,
3130642.0000000000000000 10085163.0000000000000000,
3130651.7886967407539487 10085224.8033988755196333,
3130680.1966011249460280 10085280.5570504590868950,
3130724.4429495413787663 10085324.8033988755196333,
3130780.1966011249460280 10085353.2113032583147287,
3130842.0000000000000000 10085363.0000000000000000,
3130903.8033988750539720 10085353.2113032583147287,
3130943.0998419085517526 10085333.1887654587626457,
3130940.0386967407539487 10085339.1966011244803667,
3130930.2500000000000000 10085401.0000000000000000,
3130940.0386967407539487 10085462.8033988755196333,
3130968.4466011249460280 10085518.5570504590868950,
3131012.6929495413787663 10085562.8033988755196333,
3131068.4466011249460280 10085591.2113032583147287,
3131130.2500000000000000 10085601.0000000000000000,
3131192.0533988750539720 10085591.2113032583147287,
3131247.8070504586212337 10085562.8033988755196333,
3131292.0533988750539720 10085518.5570504590868950,
3131295.8825202966108918 10085511.0419765301048756,
3131333.5000000000000000 10085517.0000000000000000,
3131395.3033988750539720 10085507.2113032583147287,
3131451.0570504586212337 10085478.8033988755196333,
3131495.3033988750539720 10085434.5570504590868950,
3131523.7113032592460513 10085378.8033988755196333,
3131533.5000000000000000 10085317.0000000000000000,
3131523.7113032592460513 10085255.1966011244803667,
3131495.3033988750539720 10085199.4429495409131050,
3131483.1773386686109006 10085187.3168893344700336,
3131466.4529372137039900 10085154.4934033416211605,
3131473.5000000000000000 10085110.0000000000000000,
3131463.7113032592460513 10085048.1966011244803667,
3131435.3033988750539720 10084992.4429495409131050,
3131423.6104493341408670 10084980.7500000000000000,
3131429.8033988750539720 10084974.5570504590868950,
3131458.2113032592460513 10084918.8033988755196333,
3131468.0000000000000000 10084857.0000000000000000,
3131458.2113032592460513 10084795.1966011244803667,
3131429.8033988750539720 10084739.4429495409131050,
3131385.5570504586212337 10084695.1966011244803667,
3131329.8033988750539720 10084666.7886967416852713,
3131268.0000000000000000 10084657.0000000000000000,
3131228.5471638026647270 10084663.2487153802067041,
3131220.4613032592460513 10084612.1966011244803667,
3131192.0533988750539720 10084556.4429495409131050,
3131147.8070504586212337 10084512.1966011244803667,
3131092.0533988750539720 10084483.7886967416852713,
3131030.2500000000000000 10084474.0000000000000000,
3130968.4466011249460280 10084483.7886967416852713,
3130912.6929495413787663 10084512.1966011244803667,
3130868.4466011249460280 10084556.4429495409131050,
3130867.4038758422248065 10084558.4894131347537041,
3130873.5000000000000000 10084520.0000000000000000,
3130868.2168630780652165 10084486.6435862556099892,
3130874.3033988750539720 10084480.5570504590868950,
3130884.2142877345904708 10084461.1058358643203974,
3130908.8033988750539720 10084457.2113032583147287,
3130964.5570504586212337 10084428.8033988755196333,
3131008.8033988750539720 10084384.5570504590868950,
3131037.2113032592460513 10084328.8033988755196333,
3131044.2598674744367599 10084284.3005158845335245,
3131105.5000000000000000 10084294.0000000000000000,
3131139.7196850073523819 10084288.5801343414932489,
3131142.9429495413787663 10084291.8033988755196333,
3131198.6966011249460280 10084320.2113032583147287,
3131260.5000000000000000 10084330.0000000000000000,
3131322.3033988750539720 10084320.2113032583147287,
3131378.0570504586212337 10084291.8033988755196333,
3131422.3033988750539720 10084247.5570504590868950,
3131450.7113032592460513 10084191.8033988755196333,
3131460.5000000000000000 10084130.0000000000000000,
3131450.7113032592460513 10084068.1966011244803667,
3131422.3033988750539720 10084012.4429495409131050,
3131392.4854493341408670 10083982.6250000000000000,
3131426.5533988750539720 10083948.5570504590868950,
3131454.9613032592460513 10083892.8033988755196333,
3131464.7500000000000000 10083831.0000000000000000,
3131458.8857659501954913 10083793.9746833834797144,
3131460.3033988750539720 10083792.5570504590868950,
3131488.7113032592460513 10083736.8033988755196333,
3131498.5000000000000000 10083675.0000000000000000,
3131488.7113032592460513 10083613.1966011244803667,
3131460.3033988750539720 10083557.4429495409131050,
3131440.8656401019543409 10083538.0051907673478127,
3131441.5000000000000000 10083534.0000000000000000,
3131431.7113032592460513 10083472.1966011244803667,
3131403.3033988750539720 10083416.4429495409131050,
3131360.3604493341408670 10083373.5000000000000000,
3131379.3033988750539720 10083354.5570504590868950,
3131406.6380189950577915 10083300.9098378475755453,
3131436.3033988750539720 10083296.2113032583147287,
3131492.0570504586212337 10083267.8033988755196333,
3131536.3033988750539720 10083223.5570504590868950,
3131564.7113032592460513 10083167.8033988755196333,
3131574.5000000000000000 10083106.0000000000000000,
3131564.7113032592460513 10083044.1966011244803667,
3131536.3033988750539720 10082988.4429495409131050,
3131500.2354493341408670 10082952.3750000000000000,
3131526.0533988750539720 10082926.5570504590868950,
3131554.4613032592460513 10082870.8033988755196333,
3131564.2500000000000000 10082809.0000000000000000,
3131554.4613032592460513 10082747.1966011244803667,
3131526.0533988750539720 10082691.4429495409131050,
3131481.8070504586212337 10082647.1966011244803667,
3131426.0533988750539720 10082618.7886967416852713,
3131364.2500000000000000 10082609.0000000000000000,
3131302.4466011249460280 10082618.7886967416852713,
3131246.6929495413787663 10082647.1966011244803667,
3131240.0899179661646485 10082653.7996327001601458,
3131234.3033988750539720 10082642.4429495409131050,
3131190.0570504586212337 10082598.1966011244803667,
3131134.3033988750539720 10082569.7886967416852713,
3131072.5000000000000000 10082560.0000000000000000,
3131010.6966011249460280 10082569.7886967416852713,
3130954.9429495413787663 10082598.1966011244803667,
3130910.6966011249460280 10082642.4429495409131050,
3130882.2886967407539487 10082698.1966011244803667,
3130872.5000000000000000 10082760.0000000000000000,
3130882.0369744473136961 10082820.2140868641436100,
3130868.2886967407539487 10082847.1966011244803667,
3130866.6180999884381890 10082857.7443339023739100,
3130835.3033988750539720 10082841.7886967416852713,
3130773.5000000000000000 10082832.0000000000000000,
3130731.9425092483870685 10082838.5820599142462015,
3130707.5570504586212337 10082814.1966011244803667,
3130651.8033988750539720 10082785.7886967416852713,
3130590.0000000000000000 10082776.0000000000000000,
3130528.1966011249460280 10082785.7886967416852713,
3130472.4429495413787663 10082814.1966011244803667,
3130428.1966011249460280 10082858.4429495409131050,
3130399.7886967407539487 10082914.1966011244803667,
3130390.0000000000000000 10082976.0000000000000000,
3130399.7886967407539487 10083037.8033988755196333,
3130428.1966011249460280 10083093.5570504590868950,
3130472.4429495413787663 10083137.8033988755196333,
3130528.1966011249460280 10083166.2113032583147287,
3130590.0000000000000000 10083176.0000000000000000,
3130631.5574907516129315 10083169.4179400857537985,
3130655.9429495413787663 10083193.8033988755196333,
3130668.7234854153357446 10083200.3154071606695652,
3130642.2886967407539487 10083252.1966011244803667,
3130632.5000000000000000 10083314.0000000000000000,
3130642.2886967407539487 10083375.8033988755196333,
3130655.9441332137212157 10083402.6037019547075033,
3130614.2500000000000000 10083396.0000000000000000,
3130552.4466011249460280 10083405.7886967416852713,
3130496.6929495413787663 10083434.1966011244803667,
3130452.4466011249460280 10083478.4429495409131050,
3130424.0386967407539487 10083534.1966011244803667,
3130414.2500000000000000 10083596.0000000000000000,
3130424.0386967407539487 10083657.8033988755196333,
3130452.4466011249460280 10083713.5570504590868950,
3130496.6929495413787663 10083757.8033988755196333,
3130552.4466011249460280 10083786.2113032583147287,
3130614.2500000000000000 10083796.0000000000000000,
3130640.3780604191124439 10083791.8617217727005482,
3130588.6929495413787663 10083818.1966011244803667,
3130544.4466011249460280 10083862.4429495409131050,
3130543.7507692789658904 10083863.8085964322090149,
3130540.9613032592460513 10083846.1966011244803667,
3130512.5533988750539720 10083790.4429495409131050,
3130468.3070504586212337 10083746.1966011244803667,
3130412.5533988750539720 10083717.7886967416852713,
3130350.7500000000000000 10083708.0000000000000000,
3130288.9466011249460280 10083717.7886967416852713,
3130270.5835135458037257 10083727.1451571937650442,
3130209.6966011249460280 10083736.7886967416852713,
3130167.9047404709272087 10083758.0827133264392614,
3130129.5000000000000000 10083752.0000000000000000,
3130067.6966011249460280 10083761.7886967416852713,
3130011.9429495413787663 10083790.1966011244803667,
3129967.6966011249460280 10083834.4429495409131050,
3129939.2886967407539487 10083890.1966011244803667,
3129929.5000000000000000 10083952.0000000000000000,
3129939.2886967407539487 10084013.8033988755196333,
3129967.6966011249460280 10084069.5570504590868950,
3130011.9429495413787663 10084113.8033988755196333,
3130013.9046850185841322 10084114.8029530253261328,
3129983.6929495413787663 10084130.1966011244803667,
3129970.2669724728912115 10084143.6225781925022602),
(3131100.5610343911685050 10085205.7022702023386955,
3131068.4466011249460280 10085210.7886967416852713,
3131029.1501580914482474 10085230.8112345412373543,
3131032.2113032592460513 10085224.8033988755196333,
3131042.0000000000000000 10085163.0000000000000000,
3131032.2113032592460513 10085101.1966011244803667,
3131003.8033988750539720 10085045.4429495409131050,
3131000.1104493341408670 10085041.7500000000000000,
3131016.9263984509743750 10085024.9340508822351694,
3131027.8033988750539720 10085023.2113032583147287,
3131083.5570504586212337 10084994.8033988755196333,
3131083.8867625822313130 10084994.4736867509782314,
3131114.5172577477060258 10084989.6222929190844297,
3131111.6966011249460280 10084992.4429495409131050,
3131083.2886967407539487 10085048.1966011244803667,
3131073.5000000000000000 10085110.0000000000000000,
3131083.2886967407539487 10085171.8033988755196333,
3131100.5610343911685050 10085205.7022702023386955),
(3130680.1219395808875561 10083784.1382782272994518,
3130729.2874125088565052 10083759.0872185342013836,
3130725.5000000000000000 10083783.0000000000000000,
3130725.5079443641006947 10083783.0501587409526110,
3130706.2500000000000000 10083780.0000000000000000,
3130680.1219395808875561 10083784.1382782272994518),
(3130216.8453149809502065 10084129.1970469728112221,
3130233.0952595290727913 10084120.9172866735607386,
3130271.5000000000000000 10084127.0000000000000000,
3130333.3033988750539720 10084117.2113032583147287,
3130351.6664864541962743 10084107.8548428062349558,
3130412.5533988750539720 10084098.2113032583147287,
3130468.3070504586212337 10084069.8033988755196333,
3130512.5533988750539720 10084025.5570504590868950,
3130513.2492307210341096 10084024.1914035677909851,
3130516.0386967407539487 10084041.8033988755196333,
3130529.6407058387994766 10084068.4988448265939951,
3130488.6966011249460280 10084109.4429495409131050,
3130472.9680830687284470 10084140.3119043130427599,
3130466.0533988750539720 10084136.7886967416852713,
3130404.2500000000000000 10084127.0000000000000000,
3130342.4466011249460280 10084136.7886967416852713,
3130286.6929495413787663 10084165.1966011244803667,
3130267.9116825484670699 10084183.9778681173920631,
3130263.0533988750539720 10084174.4429495409131050,
3130218.8070504586212337 10084130.1966011244803667,
3130216.8453149809502065 10084129.1970469728112221)),
((3129577.5385824376717210 10085577.1357893180102110,
3129586.0386967407539487 10085630.8033988755196333,
3129614.4466011249460280 10085686.5570504590868950,
3129658.6929495413787663 10085730.8033988755196333,
3129714.4466011249460280 10085759.2113032583147287,
3129776.2500000000000000 10085769.0000000000000000,
3129781.1184620317071676 10085768.2289113663136959,
3129814.6929495413787663 10085801.8033988755196333,
3129870.4466011249460280 10085830.2113032583147287,
3129932.2500000000000000 10085840.0000000000000000,
3129979.6345717832446098 10085832.4950211178511381,
3129980.9429495413787663 10085833.8033988755196333,
3129993.6005668840371072 10085840.2527770418673754,
3129996.5386967407539487 10085858.8033988755196333,
3130024.9466011249460280 10085914.5570504590868950,
3130069.1929495413787663 10085958.8033988755196333,
3130124.9466011249460280 10085987.2113032583147287,
3130186.7500000000000000 10085997.0000000000000000,
3130248.5533988750539720 10085987.2113032583147287,
3130304.3070504586212337 10085958.8033988755196333,
3130348.5533988750539720 10085914.5570504590868950,
3130361.0557899512350559 10085890.0197263900190592,
3130392.5000000000000000 10085895.0000000000000000,
3130454.3033988750539720 10085885.2113032583147287,
3130510.0570504586212337 10085856.8033988755196333,
3130554.3033988750539720 10085812.5570504590868950,
3130567.3519583083689213 10085786.9478106331080198,
3130571.1584564736112952 10085810.9810941927134991,
3130565.6966011249460280 10085816.4429495409131050,
3130537.2886967407539487 10085872.1966011244803667,
3130527.5000000000000000 10085934.0000000000000000,
3130530.6924782493151724 10085954.1565143819898367,
3130523.5386967407539487 10085968.1966011244803667,
3130513.7500000000000000 10086030.0000000000000000,
3130523.5386967407539487 10086091.8033988755196333,
3130551.9466011249460280 10086147.5570504590868950,
3130596.1929495413787663 10086191.8033988755196333,
3130651.9466011249460280 10086220.2113032583147287,
3130713.7500000000000000 10086230.0000000000000000,
3130775.5533988750539720 10086220.2113032583147287,
3130831.3070504586212337 10086191.8033988755196333,
3130875.5533988750539720 10086147.5570504590868950,
3130876.3963892119936645 10086145.9025887679308653,
3130901.6966011249460280 10086195.5570504590868950,
3130917.7898455378599465 10086211.6502948720008135,
3130914.2500000000000000 10086234.0000000000000000,
3130924.0386967407539487 10086295.8033988755196333,
3130952.4466011249460280 10086351.5570504590868950,
3130996.6929495413787663 10086395.8033988755196333,
3131052.4466011249460280 10086424.2113032583147287,
3131114.2500000000000000 10086434.0000000000000000,
3131114.5173625005409122 10086433.9576539397239685,
3131121.4466011249460280 10086447.5570504590868950,
3131165.6929495413787663 10086491.8033988755196333,
3131221.4466011249460280 10086520.2113032583147287,
3131283.2500000000000000 10086530.0000000000000000,
3131345.0533988750539720 10086520.2113032583147287,
3131400.8070504586212337 10086491.8033988755196333,
3131445.0533988750539720 10086447.5570504590868950,
3131473.4613032592460513 10086391.8033988755196333,
3131483.2500000000000000 10086330.0000000000000000,
3131473.4613032592460513 10086268.1966011244803667,
3131445.0533988750539720 10086212.4429495409131050,
3131400.8070504586212337 10086168.1966011244803667,
3131345.0533988750539720 10086139.7886967416852713,
3131283.2500000000000000 10086130.0000000000000000,
3131282.9826374994590878 10086130.0423460602760315,
3131276.0533988750539720 10086116.4429495409131050,
3131259.9601544621400535 10086100.3497051279991865,
3131263.5000000000000000 10086078.0000000000000000,
3131253.7113032592460513 10086016.1966011244803667,
3131231.6707903640344739 10085972.9396589696407318,
3131248.0533988750539720 10085956.5570504590868950,
3131276.4613032592460513 10085900.8033988755196333,
3131286.2500000000000000 10085839.0000000000000000,
3131276.4613032592460513 10085777.1966011244803667,
3131248.0533988750539720 10085721.4429495409131050,
3131203.8070504586212337 10085677.1966011244803667,
3131148.0533988750539720 10085648.7886967416852713,
3131086.2500000000000000 10085639.0000000000000000,
3131084.4338311650790274 10085639.2876528836786747,
3131073.3033988750539720 10085617.4429495409131050,
3131029.0570504586212337 10085573.1966011244803667,
3130973.3033988750539720 10085544.7886967416852713,
3130911.5000000000000000 10085535.0000000000000000,
3130849.6966011249460280 10085544.7886967416852713,
3130820.9797444655559957 10085559.4206660389900208,
3130761.5000000000000000 10085550.0000000000000000,
3130699.6966011249460280 10085559.7886967416852713,
3130643.9429495413787663 10085588.1966011244803667,
3130599.6966011249460280 10085632.4429495409131050,
3130586.6480416916310787 10085658.0521893668919802,
3130582.7113032592460513 10085633.1966011244803667,
3130554.3033988750539720 10085577.4429495409131050,
3130510.0570504586212337 10085533.1966011244803667,
3130454.3033988750539720 10085504.7886967416852713,
3130392.5000000000000000 10085495.0000000000000000,
3130330.6966011249460280 10085504.7886967416852713,
3130301.2258931123651564 10085519.8047724887728691,
3130288.3033988750539720 10085494.4429495409131050,
3130244.0570504586212337 10085450.1966011244803667,
3130188.3033988750539720 10085421.7886967416852713,
3130126.5000000000000000 10085412.0000000000000000,
3130064.6966011249460280 10085421.7886967416852713,
3130008.9429495413787663 10085450.1966011244803667,
3130004.1873486237600446 10085454.9522020425647497,
3129994.0533988750539720 10085449.7886967416852713,
3129932.2500000000000000 10085440.0000000000000000,
3129927.3815379682928324 10085440.7710886336863041,
3129893.8070504586212337 10085407.1966011244803667,
3129838.0533988750539720 10085378.7886967416852713,
3129806.9614175623282790 10085373.8642106819897890,
3129798.4613032592460513 10085320.1966011244803667,
3129770.0533988750539720 10085264.4429495409131050,
3129725.8070504586212337 10085220.1966011244803667,
3129670.0533988750539720 10085191.7886967416852713,
3129608.2500000000000000 10085182.0000000000000000,
3129546.4466011249460280 10085191.7886967416852713,
3129490.6929495413787663 10085220.1966011244803667,
3129446.4466011249460280 10085264.4429495409131050,
3129418.0386967407539487 10085320.1966011244803667,
3129408.2500000000000000 10085382.0000000000000000,
3129418.0386967407539487 10085443.8033988755196333,
3129446.4466011249460280 10085499.5570504590868950,
3129490.6929495413787663 10085543.8033988755196333,
3129546.4466011249460280 10085572.2113032583147287,
3129577.5385824376717210 10085577.1357893180102110)),
((3131076.6083601950667799 10087178.0020891390740871,
3131075.5000000000000000 10087185.0000000000000000,
3131085.2886967407539487 10087246.8033988755196333,
3131113.6966011249460280 10087302.5570504590868950,
3131157.9429495413787663 10087346.8033988755196333,
3131213.6966011249460280 10087375.2113032583147287,
3131275.5000000000000000 10087385.0000000000000000,
3131337.3033988750539720 10087375.2113032583147287,
3131393.0570504586212337 10087346.8033988755196333,
3131437.3033988750539720 10087302.5570504590868950,
3131465.7113032592460513 10087246.8033988755196333,
3131475.5000000000000000 10087185.0000000000000000,
3131465.7113032592460513 10087123.1966011244803667,
3131437.3033988750539720 10087067.4429495409131050,
3131393.0570504586212337 10087023.1966011244803667,
3131337.3033988750539720 10086994.7886967416852713,
3131275.5000000000000000 10086985.0000000000000000,
3131213.6966011249460280 10086994.7886967416852713,
3131157.9429495413787663 10087023.1966011244803667,
3131134.1416398049332201 10087046.9979108609259129,
3131135.2500000000000000 10087040.0000000000000000,
3131125.4613032592460513 10086978.1966011244803667,
3131097.0533988750539720 10086922.4429495409131050,
3131052.8070504586212337 10086878.1966011244803667,
3130997.0533988750539720 10086849.7886967416852713,
3130935.2500000000000000 10086840.0000000000000000,
3130873.4466011249460280 10086849.7886967416852713,
3130817.6929495413787663 10086878.1966011244803667,
3130773.4466011249460280 10086922.4429495409131050,
3130745.0386967407539487 10086978.1966011244803667,
3130735.2500000000000000 10087040.0000000000000000,
3130745.0386967407539487 10087101.8033988755196333,
3130773.4466011249460280 10087157.5570504590868950,
3130817.6929495413787663 10087201.8033988755196333,
3130873.4466011249460280 10087230.2113032583147287,
3130935.2500000000000000 10087240.0000000000000000,
3130997.0533988750539720 10087230.2113032583147287,
3131052.8070504586212337 10087201.8033988755196333,
3131076.6083601950667799 10087178.0020891390740871)),
((3130400.8352307076565921 10088149.5493578072637320,
3130386.6966011249460280 10088151.7886967416852713,
3130330.9429495413787663 10088180.1966011244803667,
3130286.6966011249460280 10088224.4429495409131050,
3130258.2886967407539487 10088280.1966011244803667,
3130248.5000000000000000 10088342.0000000000000000,
3130258.2886967407539487 10088403.8033988755196333,
3130286.6966011249460280 10088459.5570504590868950,
3130330.9429495413787663 10088503.8033988755196333,
3130386.6966011249460280 10088532.2113032583147287,
3130448.5000000000000000 10088542.0000000000000000,
3130474.0869723674841225 10088537.9474217016249895,
3130508.9429495413787663 10088572.8033988755196333,
3130564.6966011249460280 10088601.2113032583147287,
3130626.5000000000000000 10088611.0000000000000000,
3130688.3033988750539720 10088601.2113032583147287,
3130696.4499690793454647 10088597.0604184139519930,
3130716.1929495413787663 10088616.8033988755196333,
3130771.9466011249460280 10088645.2113032583147287,
3130824.1586683597415686 10088653.4808823056519032,
3130821.1966011249460280 10088656.4429495409131050,
3130792.7886967407539487 10088712.1966011244803667,
3130783.0000000000000000 10088774.0000000000000000,
3130792.7886967407539487 10088835.8033988755196333,
3130821.1966011249460280 10088891.5570504590868950,
3130852.1692782142199576 10088922.5297275483608246,
3130855.5386967407539487 10088943.8033988755196333,
3130883.9466011249460280 10088999.5570504590868950,
3130897.2550821714103222 10089012.8655315060168505,
3130898.2524744179099798 10089019.1628183126449585,
3130856.3033988750539720 10088997.7886967416852713,
3130794.5000000000000000 10088988.0000000000000000,
3130732.6966011249460280 10088997.7886967416852713,
3130676.9429495413787663 10089026.1966011244803667,
3130632.6966011249460280 10089070.4429495409131050,
3130604.2886967407539487 10089126.1966011244803667,
3130594.5000000000000000 10089188.0000000000000000,
3130604.2886967407539487 10089249.8033988755196333,
3130632.6966011249460280 10089305.5570504590868950,
3130676.9429495413787663 10089349.8033988755196333,
3130732.6966011249460280 10089378.2113032583147287,
3130794.5000000000000000 10089388.0000000000000000,
3130808.3300088825635612 10089385.8095417823642492,
3130789.6966011249460280 10089404.4429495409131050,
3130776.8255976885557175 10089429.7037161011248827,
3130734.5000000000000000 10089423.0000000000000000,
3130672.6966011249460280 10089432.7886967416852713,
3130616.9429495413787663 10089461.1966011244803667,
3130572.6966011249460280 10089505.4429495409131050,
3130545.6752652889117599 10089558.4753071255981922,
3130543.6966011249460280 10089558.7886967416852713,
3130487.9429495413787663 10089587.1966011244803667,
3130443.6966011249460280 10089631.4429495409131050,
3130415.2886967407539487 10089687.1966011244803667,
3130405.5000000000000000 10089749.0000000000000000,
3130415.2886967407539487 10089810.8033988755196333,
3130443.6966011249460280 10089866.5570504590868950,
3130487.9429495413787663 10089910.8033988755196333,
3130543.6966011249460280 10089939.2113032583147287,
3130605.5000000000000000 10089949.0000000000000000,
3130667.3033988750539720 10089939.2113032583147287,
3130723.0570504586212337 10089910.8033988755196333,
3130767.3033988750539720 10089866.5570504590868950,
3130794.3247347110882401 10089813.5246928744018078,
3130796.3033988750539720 10089813.2113032583147287,
3130852.0570504586212337 10089784.8033988755196333,
3130864.0000000000000000 10089772.8604493346065283,
3130904.9429495413787663 10089813.8033988755196333,
3130960.6966011249460280 10089842.2113032583147287,
3131022.5000000000000000 10089852.0000000000000000,
3131084.3033988750539720 10089842.2113032583147287,
3131140.0570504586212337 10089813.8033988755196333,
3131184.3033988750539720 10089769.5570504590868950,
3131204.1219468093477190 10089730.6609600801020861,
3131216.1958529474213719 10089728.7486412134021521,
3131271.9495045309886336 10089700.3407368306070566,
3131316.1958529474213719 10089656.0943884141743183,
3131344.6037573316134512 10089600.3407368306070566,
3131354.3924540723673999 10089538.5373379550874233,
3131344.6037573316134512 10089476.7339390795677900,
3131316.1958529474213719 10089420.9802874960005283,
3131300.2429878064431250 10089405.0274223554879427,
3131297.6188491866923869 10089388.4592631701380014,
3131269.2109448025003076 10089332.7056115865707397,
3131224.9645963860675693 10089288.4592631701380014,
3131205.1332889441400766 10089278.3547073323279619,
3131212.0000000000000000 10089235.0000000000000000,
3131202.2113032592460513 10089173.1966011244803667,
3131193.6596572166308761 10089156.4130507614463568,
3131210.5570504586212337 10089147.8033988755196333,
3131254.8033988750539720 10089103.5570504590868950,
3131283.2113032592460513 10089047.8033988755196333,
3131293.0000000000000000 10088986.0000000000000000,
3131283.2113032592460513 10088924.1966011244803667,
3131254.8033988750539720 10088868.4429495409131050,
3131241.4949178285896778 10088855.1344684939831495,
3131239.2028289986774325 10088840.6627891734242439,
3131242.0533988750539720 10088840.2113032583147287,
3131297.8070504586212337 10088811.8033988755196333,
3131342.0533988750539720 10088767.5570504590868950,
3131370.4613032592460513 10088711.8033988755196333,
3131380.2500000000000000 10088650.0000000000000000,
3131370.4613032592460513 10088588.1966011244803667,
3131342.0533988750539720 10088532.4429495409131050,
3131303.3488912461325526 10088493.7384419124573469,
3131303.4386364710517228 10088493.1718128640204668,
3131322.0533988750539720 10088474.5570504590868950,
3131350.4613032592460513 10088418.8033988755196333,
3131360.2500000000000000 10088357.0000000000000000,
3131350.4613032592460513 10088295.1966011244803667,
3131322.0533988750539720 10088239.4429495409131050,
3131288.8019763021729887 10088206.1915269680321217,
3131292.0000000000000000 10088186.0000000000000000,
3131282.2113032592460513 10088124.1966011244803667,
3131253.8033988750539720 10088068.4429495409131050,
3131209.5570504586212337 10088024.1966011244803667,
3131153.8033988750539720 10087995.7886967416852713,
3131092.0000000000000000 10087986.0000000000000000,
3131030.1966011249460280 10087995.7886967416852713,
3130974.4429495413787663 10088024.1966011244803667,
3130930.1966011249460280 10088068.4429495409131050,
3130901.7886967407539487 10088124.1966011244803667,
3130892.5760556622408330 10088182.3629276901483536,
3130870.9466011249460280 10088185.7886967416852713,
3130815.1929495413787663 10088214.1966011244803667,
3130770.9466011249460280 10088258.4429495409131050,
3130766.2288644574582577 10088267.7020290866494179,
3130764.5532818441279233 10088268.5557810701429844,
3130765.7500000000000000 10088261.0000000000000000,
3130755.9613032592460513 10088199.1966011244803667,
3130727.5533988750539720 10088143.4429495409131050,
3130683.3070504586212337 10088099.1966011244803667,
3130627.5533988750539720 10088070.7886967416852713,
3130565.7500000000000000 10088061.0000000000000000,
3130503.9466011249460280 10088070.7886967416852713,
3130448.1929495413787663 10088099.1966011244803667,
3130403.9466011249460280 10088143.4429495409131050,
3130400.8352307076565921 10088149.5493578072637320)),
((3129224.0991266998462379 10100137.3611749876290560,
3129190.2500000000000000 10100132.0000000000000000,
3129128.4466011249460280 10100141.7886967416852713,
3129072.6929495413787663 10100170.1966011244803667,
3129028.4466011249460280 10100214.4429495409131050,
3129000.0386967407539487 10100270.1966011244803667,
3128990.2500000000000000 10100332.0000000000000000,
3129000.0386967407539487 10100393.8033988755196333,
3129028.4466011249460280 10100449.5570504590868950,
3129072.6929495413787663 10100493.8033988755196333,
3129128.4466011249460280 10100522.2113032583147287,
3129190.2500000000000000 10100532.0000000000000000,
3129252.0533988750539720 10100522.2113032583147287,
3129294.4078813251107931 10100500.6306165512651205,
3129298.4466011249460280 10100508.5570504590868950,
3129342.6929495413787663 10100552.8033988755196333,
3129398.4466011249460280 10100581.2113032583147287,
3129460.2500000000000000 10100591.0000000000000000,
3129474.0391611629165709 10100588.8160114269703627,
3129478.7886967407539487 10100618.8033988755196333,
3129507.1966011249460280 10100674.5570504590868950,
3129551.4429495413787663 10100718.8033988755196333,
3129607.1966011249460280 10100747.2113032583147287,
3129669.0000000000000000 10100757.0000000000000000,
3129706.3566433405503631 10100751.0832889508455992,
3129728.1966011249460280 10100762.2113032583147287,
3129790.0000000000000000 10100772.0000000000000000,
3129851.8033988750539720 10100762.2113032583147287,
3129907.5570504586212337 10100733.8033988755196333,
3129912.2500000000000000 10100729.1104493346065283,
3129929.2006530030630529 10100746.0611023381352425,
3129910.7886967407539487 10100782.1966011244803667,
3129901.0000000000000000 10100844.0000000000000000,
3129910.7886967407539487 10100905.8033988755196333,
3129939.1966011249460280 10100961.5570504590868950,
3129983.4429495413787663 10101005.8033988755196333,
3130039.1966011249460280 10101034.2113032583147287,
3130101.0000000000000000 10101044.0000000000000000,
3130162.8033988750539720 10101034.2113032583147287,
3130218.5570504586212337 10101005.8033988755196333,
3130262.8033988750539720 10100961.5570504590868950,
3130291.2113032592460513 10100905.8033988755196333,
3130301.0000000000000000 10100844.0000000000000000,
3130291.2113032592460513 10100782.1966011244803667,
3130262.8033988750539720 10100726.4429495409131050,
3130230.2993469969369471 10100693.9388976618647575,
3130248.7113032592460513 10100657.8033988755196333,
3130258.5000000000000000 10100596.0000000000000000,
3130248.7113032592460513 10100534.1966011244803667,
3130220.3033988750539720 10100478.4429495409131050,
3130176.0570504586212337 10100434.1966011244803667,
3130149.4693299010396004 10100420.6494808569550514,
3130149.2411786951124668 10100419.2089908346533775,
3130164.9466011249460280 10100427.2113032583147287,
3130226.7500000000000000 10100437.0000000000000000,
3130288.5533988750539720 10100427.2113032583147287,
3130331.3089149850420654 10100405.4262796957045794,
3130366.5000000000000000 10100411.0000000000000000,
3130428.3033988750539720 10100401.2113032583147287,
3130457.9743705498985946 10100386.0931880790740252,
3130463.7886967407539487 10100422.8033988755196333,
3130492.1966011249460280 10100478.5570504590868950,
3130536.4429495413787663 10100522.8033988755196333,
3130592.1966011249460280 10100551.2113032583147287,
3130654.0000000000000000 10100561.0000000000000000,
3130715.8033988750539720 10100551.2113032583147287,
3130771.5570504586212337 10100522.8033988755196333,
3130815.8033988750539720 10100478.5570504590868950,
3130844.2113032592460513 10100422.8033988755196333,
3130854.0000000000000000 10100361.0000000000000000,
3130844.2113032592460513 10100299.1966011244803667,
3130815.8033988750539720 10100243.4429495409131050,
3130771.5570504586212337 10100199.1966011244803667,
3130715.8033988750539720 10100170.7886967416852713,
3130654.0000000000000000 10100161.0000000000000000,
3130592.1966011249460280 10100170.7886967416852713,
3130562.5256294501014054 10100185.9068119209259748,
3130556.7113032592460513 10100149.1966011244803667,
3130537.2023415034636855 10100110.9081078302115202,
3130558.5533988750539720 10100089.5570504590868950,
3130586.9613032592460513 10100033.8033988755196333,
3130596.7500000000000000 10099972.0000000000000000,
3130586.9613032592460513 10099910.1966011244803667,
3130565.0622474802657962 10099867.2172841913998127,
3130568.3024348914623260 10099860.8580583389848471,
3130584.6966011249460280 10099869.2113032583147287,
3130646.5000000000000000 10099879.0000000000000000,
3130708.3033988750539720 10099869.2113032583147287,
3130764.0570504586212337 10099840.8033988755196333,
3130785.3334659659303725 10099819.5269833691418171,
3130795.0386967407539487 10099880.8033988755196333,
3130823.4466011249460280 10099936.5570504590868950,
3130867.6929495413787663 10099980.8033988755196333,
3130923.4466011249460280 10100009.2113032583147287,
3130985.2500000000000000 10100019.0000000000000000,
3131047.0533988750539720 10100009.2113032583147287,
3131102.8070504586212337 10099980.8033988755196333,
3131147.0533988750539720 10099936.5570504590868950,
3131175.4613032592460513 10099880.8033988755196333,
3131185.2500000000000000 10099819.0000000000000000,
3131175.4613032592460513 10099757.1966011244803667,
3131147.0533988750539720 10099701.4429495409131050,
3131143.3711115792393684 10099697.7606622446328402,
3131162.7113032592460513 10099659.8033988755196333,
3131172.5000000000000000 10099598.0000000000000000,
3131162.7113032592460513 10099536.1966011244803667,
3131136.2827683896757662 10099484.3276809453964233,
3131162.0533988750539720 10099458.5570504590868950,
3131190.4613032592460513 10099402.8033988755196333,
3131200.2500000000000000 10099341.0000000000000000,
3131190.4613032592460513 10099279.1966011244803667,
3131162.0533988750539720 10099223.4429495409131050,
3131150.3604493346065283 10099211.7500000000000000,
3131166.5533988750539720 10099195.5570504590868950,
3131194.9613032592460513 10099139.8033988755196333,
3131204.7500000000000000 10099078.0000000000000000,
3131194.9613032592460513 10099016.1966011244803667,
3131166.5533988750539720 10098960.4429495409131050,
3131166.1250056852586567 10098960.0145563501864672,
3131163.4613032592460513 10098943.1966011244803667,
3131135.0533988750539720 10098887.4429495409131050,
3131090.8070504586212337 10098843.1966011244803667,
3131035.0533988750539720 10098814.7886967416852713,
3130973.2500000000000000 10098805.0000000000000000,
3130911.4466011249460280 10098814.7886967416852713,
3130855.6929495413787663 10098843.1966011244803667,
3130811.4466011249460280 10098887.4429495409131050,
3130786.4712038175202906 10098936.4599266760051250,
3130777.3033988750539720 10098931.7886967416852713,
3130715.5000000000000000 10098922.0000000000000000,
3130653.6966011249460280 10098931.7886967416852713,
3130597.9429495413787663 10098960.1966011244803667,
3130553.6966011249460280 10099004.4429495409131050,
3130525.2886967407539487 10099060.1966011244803667,
3130516.2329274616204202 10099117.3724781274795532,
3130503.0570504586212337 10099104.1966011244803667,
3130447.3033988750539720 10099075.7886967416852713,
3130385.5000000000000000 10099066.0000000000000000,
3130323.6966011249460280 10099075.7886967416852713,
3130267.9429495413787663 10099104.1966011244803667,
3130223.6966011249460280 10099148.4429495409131050,
3130195.2886967407539487 10099204.1966011244803667,
3130185.5000000000000000 10099266.0000000000000000,
3130195.2886967407539487 10099327.8033988755196333,
3130197.4987257127650082 10099332.1408249530941248,
3130160.1966011249460280 10099369.4429495409131050,
3130131.7886967407539487 10099425.1966011244803667,
3130122.0000000000000000 10099487.0000000000000000,
3130131.7886967407539487 10099548.8033988755196333,
3130160.1966011249460280 10099604.5570504590868950,
3130204.4429495413787663 10099648.8033988755196333,
3130227.0715214009396732 10099660.3332321234047413,
3130208.2886967407539487 10099697.1966011244803667,
3130198.5000000000000000 10099759.0000000000000000,
3130199.9439552761614323 10099768.1167748123407364,
3130170.4466011249460280 10099772.7886967416852713,
3130164.3570455596782267 10099775.8914802782237530,
3130156.9613032592460513 10099729.1966011244803667,
3130128.5533988750539720 10099673.4429495409131050,
3130084.3070504586212337 10099629.1966011244803667,
3130028.5533988750539720 10099600.7886967416852713,
3129966.7500000000000000 10099591.0000000000000000,
3129904.9466011249460280 10099600.7886967416852713,
3129849.1929495413787663 10099629.1966011244803667,
3129804.9466011249460280 10099673.4429495409131050,
3129776.5386967407539487 10099729.1966011244803667,
3129766.7500000000000000 10099791.0000000000000000,
3129776.5386967407539487 10099852.8033988755196333,
3129804.9466011249460280 10099908.5570504590868950,
3129849.1929495413787663 10099952.8033988755196333,
3129875.2893643202260137 10099966.1001863460987806,
3129838.9466011249460280 10100002.4429495409131050,
3129810.5386967407539487 10100058.1966011244803667,
3129800.7500000000000000 10100120.0000000000000000,
3129810.5386967407539487 10100181.8033988755196333,
3129827.2618995173834264 10100214.6245323307812214,
3129791.7500000000000000 10100209.0000000000000000,
3129729.9466011249460280 10100218.7886967416852713,
3129674.1929495413787663 10100247.1966011244803667,
3129630.7933942950330675 10100290.5961563698947430,
3129622.0533988750539720 10100273.4429495409131050,
3129589.4799344907514751 10100240.8694851566106081,
3129613.4613032592460513 10100193.8033988755196333,
3129623.2500000000000000 10100132.0000000000000000,
3129613.4613032592460513 10100070.1966011244803667,
3129585.0533988750539720 10100014.4429495409131050,
3129540.8070504586212337 10099970.1966011244803667,
3129485.0533988750539720 10099941.7886967416852713,
3129423.2500000000000000 10099932.0000000000000000,
3129361.4466011249460280 10099941.7886967416852713,
3129305.6929495413787663 10099970.1966011244803667,
3129261.4466011249460280 10100014.4429495409131050,
3129233.0386967407539487 10100070.1966011244803667,
3129223.2500000000000000 10100132.0000000000000000,
3129224.0991266998462379 10100137.3611749876290560)),
((3131102.0000000000000000 10093941.0000000000000000,
3131092.2113032592460513 10093879.1966011244803667,
3131063.8033988750539720 10093823.4429495409131050,
3131019.5570504586212337 10093779.1966011244803667,
3130963.8033988750539720 10093750.7886967416852713,
3130902.0000000000000000 10093741.0000000000000000,
3130840.1966011249460280 10093750.7886967416852713,
3130784.4429495413787663 10093779.1966011244803667,
3130740.1966011249460280 10093823.4429495409131050,
3130711.7886967407539487 10093879.1966011244803667,
3130702.0000000000000000 10093941.0000000000000000,
3130711.7886967407539487 10094002.8033988755196333,
3130740.1966011249460280 10094058.5570504590868950,
3130784.4429495413787663 10094102.8033988755196333,
3130840.1966011249460280 10094131.2113032583147287,
3130902.0000000000000000 10094141.0000000000000000,
3130963.8033988750539720 10094131.2113032583147287,
3131019.5570504586212337 10094102.8033988755196333,
3131063.8033988750539720 10094058.5570504590868950,
3131092.2113032592460513 10094002.8033988755196333,
3131102.0000000000000000 10093941.0000000000000000)),
((3130313.7642070837318897 10092392.1233179029077291,
3130270.4429495413787663 10092414.1966011244803667,
3130226.1966011249460280 10092458.4429495409131050,
3130197.7886967407539487 10092514.1966011244803667,
3130188.0000000000000000 10092576.0000000000000000,
3130197.7886967407539487 10092637.8033988755196333,
3130226.1966011249460280 10092693.5570504590868950,
3130270.4429495413787663 10092737.8033988755196333,
3130326.1966011249460280 10092766.2113032583147287,
3130388.0000000000000000 10092776.0000000000000000,
3130449.8033988750539720 10092766.2113032583147287,
3130505.5570504586212337 10092737.8033988755196333,
3130549.8033988750539720 10092693.5570504590868950,
3130554.7357929162681103 10092683.8766820970922709,
3130598.0570504586212337 10092661.8033988755196333,
3130642.3033988750539720 10092617.5570504590868950,
3130652.1314125317148864 10092598.2684876080602407,
3130656.7500000000000000 10092599.0000000000000000,
3130718.5533988750539720 10092589.2113032583147287,
3130757.3555493559688330 10092569.4406200945377350,
3130758.8033988750539720 10092569.2113032583147287,
3130814.5570504586212337 10092540.8033988755196333,
3130817.5915365885011852 10092537.7689127456396818,
3130840.0533988750539720 10092534.2113032583147287,
3130895.8070504586212337 10092505.8033988755196333,
3130904.7438448155298829 10092496.8666045181453228,
3130934.3070504586212337 10092481.8033988755196333,
3130978.5533988750539720 10092437.5570504590868950,
3131006.9613032592460513 10092381.8033988755196333,
3131016.7500000000000000 10092320.0000000000000000,
3131006.9613032592460513 10092258.1966011244803667,
3130978.5533988750539720 10092202.4429495409131050,
3130934.3070504586212337 10092158.1966011244803667,
3130878.5533988750539720 10092129.7886967416852713,
3130816.7500000000000000 10092120.0000000000000000,
3130754.9466011249460280 10092129.7886967416852713,
3130699.1929495413787663 10092158.1966011244803667,
3130690.2561551844701171 10092167.1333954818546772,
3130660.6929495413787663 10092182.1966011244803667,
3130657.6584634114988148 10092185.2310872543603182,
3130635.1966011249460280 10092188.7886967416852713,
3130596.3944506440311670 10092208.5593799054622650,
3130594.9466011249460280 10092208.7886967416852713,
3130539.1929495413787663 10092237.1966011244803667,
3130494.9466011249460280 10092281.4429495409131050,
3130485.1185874682851136 10092300.7315123919397593,
3130480.5000000000000000 10092300.0000000000000000,
3130418.6966011249460280 10092309.7886967416852713,
3130362.9429495413787663 10092338.1966011244803667,
3130318.6966011249460280 10092382.4429495409131050,
3130313.7642070837318897 10092392.1233179029077291)),
((3130961.5852671060711145 10079102.8850269354879856,
3130951.7965703653171659 10079041.0816280599683523,
3130923.3886659811250865 10078985.3279764764010906,
3130879.1423175646923482 10078941.0816280599683523,
3130823.3886659811250865 10078912.6737236771732569,
3130761.5852671060711145 10078902.8850269354879856,
3130699.7818682310171425 10078912.6737236771732569,
3130644.0282166474498808 10078941.0816280599683523,
3130599.7818682310171425 10078985.3279764764010906,
3130571.3739638468250632 10079041.0816280599683523,
3130561.5852671060711145 10079102.8850269354879856,
3130571.3739638468250632 10079164.6884258110076189,
3130599.7818682310171425 10079220.4420773945748806,
3130644.0282166474498808 10079264.6884258110076189,
3130699.7818682310171425 10079293.0963301938027143,
3130761.5852671060711145 10079302.8850269354879856,
3130823.3886659811250865 10079293.0963301938027143,
3130879.1423175646923482 10079264.6884258110076189,
3130923.3886659811250865 10079220.4420773945748806,
3130951.7965703653171659 10079164.6884258110076189,
3130961.5852671060711145 10079102.8850269354879856)),
((3129684.2828150158748031 10093576.1067356504499912,
3129666.4429495413787663 10093585.1966011244803667,
3129622.1966011249460280 10093629.4429495409131050,
3129593.7886967407539487 10093685.1966011244803667,
3129584.0000000000000000 10093747.0000000000000000,
3129593.7886967407539487 10093808.8033988755196333,
3129622.1966011249460280 10093864.5570504590868950,
3129666.4429495413787663 10093908.8033988755196333,
3129722.1966011249460280 10093937.2113032583147287,
3129784.0000000000000000 10093947.0000000000000000,
3129845.8033988750539720 10093937.2113032583147287,
3129901.5570504586212337 10093908.8033988755196333,
3129912.2874540355987847 10093898.0729952976107597,
3129965.8070504586212337 10093870.8033988755196333,
3130010.0533988750539720 10093826.5570504590868950,
3130038.4613032592460513 10093770.8033988755196333,
3130038.5524002788588405 10093770.2282349299639463,
3130081.6966011249460280 10093792.2113032583147287,
3130143.5000000000000000 10093802.0000000000000000,
3130173.8349643195979297 10093797.1954136528074741,
3130194.4429495413787663 10093817.8033988755196333,
3130250.1966011249460280 10093846.2113032583147287,
3130312.0000000000000000 10093856.0000000000000000,
3130373.8033988750539720 10093846.2113032583147287,
3130429.5570504586212337 10093817.8033988755196333,
3130473.8033988750539720 10093773.5570504590868950,
3130502.2113032592460513 10093717.8033988755196333,
3130512.0000000000000000 10093656.0000000000000000,
3130502.2113032592460513 10093594.1966011244803667,
3130487.8020730633288622 10093565.9168945662677288,
3130482.4613032592460513 10093532.1966011244803667,
3130454.0533988750539720 10093476.4429495409131050,
3130409.8070504586212337 10093432.1966011244803667,
3130354.0533988750539720 10093403.7886967416852713,
3130292.2500000000000000 10093394.0000000000000000,
3130283.2696569599211216 10093395.4223466068506241,
3130281.2586681870743632 10093382.7254631966352463,
3130252.8507638028822839 10093326.9718116130679846,
3130208.6044153864495456 10093282.7254631966352463,
3130152.8507638028822839 10093254.3175588138401508,
3130091.0473649278283119 10093244.5288620721548796,
3130044.9417270566336811 10093251.8312777224928141,
3130040.3070504586212337 10093247.1966011244803667,
3129984.5533988750539720 10093218.7886967416852713,
3129950.0195365841500461 10093213.3190702907741070,
3129945.0533988750539720 10093210.7886967416852713,
3129883.2500000000000000 10093201.0000000000000000,
3129850.5948085612617433 10093206.1720742192119360,
3129873.7113032592460513 10093160.8033988755196333,
3129883.5000000000000000 10093099.0000000000000000,
3129878.4789042291231453 10093067.2980489693582058,
3129883.1966011249460280 10093076.5570504590868950,
3129927.4429495413787663 10093120.8033988755196333,
3129983.1966011249460280 10093149.2113032583147287,
3130045.0000000000000000 10093159.0000000000000000,
3130106.8033988750539720 10093149.2113032583147287,
3130162.5570504586212337 10093120.8033988755196333,
3130206.8033988750539720 10093076.5570504590868950,
3130208.2052322500385344 10093073.8057975508272648,
3130209.7886967407539487 10093083.8033988755196333,
3130238.1966011249460280 10093139.5570504590868950,
3130282.4429495413787663 10093183.8033988755196333,
3130338.1966011249460280 10093212.2113032583147287,
3130400.0000000000000000 10093222.0000000000000000,
3130461.8033988750539720 10093212.2113032583147287,
3130507.3664181958884001 10093188.9957853592932224,
3130510.8366529545746744 10093210.9059853255748749,
3130539.2445573387667537 10093266.6596369091421366,
3130583.4909057551994920 10093310.9059853255748749,
3130639.2445573387667537 10093339.3138897083699703,
3130701.0479562138207257 10093349.1025864500552416,
3130762.8513550888746977 10093339.3138897083699703,
3130818.6050066724419594 10093310.9059853255748749,
3130862.8513550888746977 10093266.6596369091421366,
3130891.2592594730667770 10093210.9059853255748749,
3130901.0479562138207257 10093149.1025864500552416,
3130891.2592594730667770 10093087.2991875745356083,
3130870.7712481059134007 10093047.0892012286931276,
3130912.3033988750539720 10093005.5570504590868950,
3130940.7113032592460513 10092949.8033988755196333,
3130950.5000000000000000 10092888.0000000000000000,
3130940.7113032592460513 10092826.1966011244803667,
3130912.3033988750539720 10092770.4429495409131050,
3130868.0570504586212337 10092726.1966011244803667,
3130812.3033988750539720 10092697.7886967416852713,
3130750.5000000000000000 10092688.0000000000000000,
3130688.6966011249460280 10092697.7886967416852713,
3130632.9429495413787663 10092726.1966011244803667,
3130588.6966011249460280 10092770.4429495409131050,
3130560.2886967407539487 10092826.1966011244803667,
3130550.5000000000000000 10092888.0000000000000000,
3130551.4672169750556350 10092894.1067676413804293,
3130517.5570504586212337 10092860.1966011244803667,
3130461.8033988750539720 10092831.7886967416852713,
3130400.0000000000000000 10092822.0000000000000000,
3130338.1966011249460280 10092831.7886967416852713,
3130282.4429495413787663 10092860.1966011244803667,
3130238.1966011249460280 10092904.4429495409131050,
3130236.7947677499614656 10092907.1942024491727352,
3130235.2113032592460513 10092897.1966011244803667,
3130206.8033988750539720 10092841.4429495409131050,
3130162.5570504586212337 10092797.1966011244803667,
3130106.8033988750539720 10092768.7886967416852713,
3130045.0000000000000000 10092759.0000000000000000,
3130026.5368399820290506 10092761.9242772664874792,
3130027.0000000000000000 10092759.0000000000000000,
3130017.2113032592460513 10092697.1966011244803667,
3129988.8033988750539720 10092641.4429495409131050,
3129944.5570504586212337 10092597.1966011244803667,
3129888.8033988750539720 10092568.7886967416852713,
3129827.0000000000000000 10092559.0000000000000000,
3129765.1966011249460280 10092568.7886967416852713,
3129709.4429495413787663 10092597.1966011244803667,
3129665.1966011249460280 10092641.4429495409131050,
3129636.7886967407539487 10092697.1966011244803667,
3129627.0000000000000000 10092759.0000000000000000,
3129636.7886967407539487 10092820.8033988755196333,
3129665.1966011249460280 10092876.5570504590868950,
3129688.4185766805894673 10092899.7790260147303343,
3129683.5000000000000000 10092899.0000000000000000,
3129621.6966011249460280 10092908.7886967416852713,
3129565.9429495413787663 10092937.1966011244803667,
3129521.6966011249460280 10092981.4429495409131050,
3129493.2886967407539487 10093037.1966011244803667,
3129483.5000000000000000 10093099.0000000000000000,
3129493.2886967407539487 10093160.8033988755196333,
3129521.6966011249460280 10093216.5570504590868950,
3129565.9429495413787663 10093260.8033988755196333,
3129621.6966011249460280 10093289.2113032583147287,
3129683.5000000000000000 10093299.0000000000000000,
3129716.1551914387382567 10093293.8279257807880640,
3129693.0386967407539487 10093339.1966011244803667,
3129683.2500000000000000 10093401.0000000000000000,
3129693.0386967407539487 10093462.8033988755196333,
3129721.4466011249460280 10093518.5570504590868950,
3129743.1568495365791023 10093540.2672988697886467,
3129696.1929495413787663 10093564.1966011244803667,
3129684.2828150158748031 10093576.1067356504499912),
(3129822.0814233194105327 10092958.2209739852696657,
3129827.0000000000000000 10092959.0000000000000000,
3129845.4631600179709494 10092956.0757227335125208,
3129845.0000000000000000 10092959.0000000000000000,
3129850.0210957708768547 10092990.7019510306417942,
3129845.3033988750539720 10092981.4429495409131050,
3129822.0814233194105327 10092958.2209739852696657)),
((3129799.1884902273304760 10086391.8373522162437439,
3129761.8033988750539720 10086372.7886967416852713,
3129700.0000000000000000 10086363.0000000000000000,
3129638.1966011249460280 10086372.7886967416852713,
3129582.4429495413787663 10086401.1966011244803667,
3129538.1966011249460280 10086445.4429495409131050,
3129509.7886967407539487 10086501.1966011244803667,
3129500.0000000000000000 10086563.0000000000000000,
3129509.7886967407539487 10086624.8033988755196333,
3129538.1966011249460280 10086680.5570504590868950,
3129582.4429495413787663 10086724.8033988755196333,
3129638.1966011249460280 10086753.2113032583147287,
3129700.0000000000000000 10086763.0000000000000000,
3129761.8033988750539720 10086753.2113032583147287,
3129817.5570504586212337 10086724.8033988755196333,
3129861.8033988750539720 10086680.5570504590868950,
3129865.0615097726695240 10086674.1626477837562561,
3129902.4466011249460280 10086693.2113032583147287,
3129915.4249139511957765 10086695.2668660711497068,
3129922.1966011249460280 10086708.5570504590868950,
3129966.4429495413787663 10086752.8033988755196333,
3130022.1966011249460280 10086781.2113032583147287,
3130084.0000000000000000 10086791.0000000000000000,
3130145.8033988750539720 10086781.2113032583147287,
3130201.5570504586212337 10086752.8033988755196333,
3130245.8033988750539720 10086708.5570504590868950,
3130274.2113032592460513 10086652.8033988755196333,
3130281.8281431971117854 10086604.7125641796737909,
3130305.6966011249460280 10086651.5570504590868950,
3130349.9429495413787663 10086695.8033988755196333,
3130405.6966011249460280 10086724.2113032583147287,
3130447.4047161578200758 10086730.8172197155654430,
3130445.0000000000000000 10086746.0000000000000000,
3130454.7886967407539487 10086807.8033988755196333,
3130483.1966011249460280 10086863.5570504590868950,
3130527.4429495413787663 10086907.8033988755196333,
3130583.1966011249460280 10086936.2113032583147287,
3130645.0000000000000000 10086946.0000000000000000,
3130706.8033988750539720 10086936.2113032583147287,
3130762.5570504586212337 10086907.8033988755196333,
3130806.8033988750539720 10086863.5570504590868950,
3130835.2113032592460513 10086807.8033988755196333,
3130845.0000000000000000 10086746.0000000000000000,
3130836.1960981264710426 10086690.4143512081354856,
3130837.0533988750539720 10086689.5570504590868950,
3130865.4613032592460513 10086633.8033988755196333,
3130875.2500000000000000 10086572.0000000000000000,
3130874.5814579180441797 10086567.7789914160966873,
3130888.8033988750539720 10086553.5570504590868950,
3130917.2113032592460513 10086497.8033988755196333,
3130927.0000000000000000 10086436.0000000000000000,
3130917.2113032592460513 10086374.1966011244803667,
3130888.8033988750539720 10086318.4429495409131050,
3130844.5570504586212337 10086274.1966011244803667,
3130788.8033988750539720 10086245.7886967416852713,
3130727.0000000000000000 10086236.0000000000000000,
3130665.1966011249460280 10086245.7886967416852713,
3130609.4429495413787663 10086274.1966011244803667,
3130603.5846569128334522 10086280.0548937525600195,
3130573.6966011249460280 10086284.7886967416852713,
3130517.9429495413787663 10086313.1966011244803667,
3130493.0869723674841225 10086338.0525782983750105,
3130467.5000000000000000 10086334.0000000000000000,
3130405.6966011249460280 10086343.7886967416852713,
3130349.9429495413787663 10086372.1966011244803667,
3130305.6966011249460280 10086416.4429495409131050,
3130277.2886967407539487 10086472.1966011244803667,
3130269.6718568028882146 10086520.2874358203262091,
3130245.8033988750539720 10086473.4429495409131050,
3130201.5570504586212337 10086429.1966011244803667,
3130145.8033988750539720 10086400.7886967416852713,
3130132.8250860488042235 10086398.7331339288502932,
3130126.0533988750539720 10086385.4429495409131050,
3130081.8070504586212337 10086341.1966011244803667,
3130026.0533988750539720 10086312.7886967416852713,
3129964.2500000000000000 10086303.0000000000000000,
3129902.4466011249460280 10086312.7886967416852713,
3129846.6929495413787663 10086341.1966011244803667,
3129802.4466011249460280 10086385.4429495409131050,
3129799.1884902273304760 10086391.8373522162437439)),
((3130887.0000000000000000 10091780.0000000000000000,
3130877.2113032592460513 10091718.1966011244803667,
3130848.8033988750539720 10091662.4429495409131050,
3130804.5570504586212337 10091618.1966011244803667,
3130748.8033988750539720 10091589.7886967416852713,
3130687.0000000000000000 10091580.0000000000000000,
3130625.1966011249460280 10091589.7886967416852713,
3130569.4429495413787663 10091618.1966011244803667,
3130525.1966011249460280 10091662.4429495409131050,
3130496.7886967407539487 10091718.1966011244803667,
3130487.0000000000000000 10091780.0000000000000000,
3130496.7886967407539487 10091841.8033988755196333,
3130525.1966011249460280 10091897.5570504590868950,
3130569.4429495413787663 10091941.8033988755196333,
3130625.1966011249460280 10091970.2113032583147287,
3130687.0000000000000000 10091980.0000000000000000,
3130748.8033988750539720 10091970.2113032583147287,
3130804.5570504586212337 10091941.8033988755196333,
3130848.8033988750539720 10091897.5570504590868950,
3130877.2113032592460513 10091841.8033988755196333,
3130887.0000000000000000 10091780.0000000000000000)),
((3129627.9146926272660494 10098250.2248580381274223,
3129626.6966011249460280 10098251.4429495409131050,
3129598.2886967407539487 10098307.1966011244803667,
3129588.5000000000000000 10098369.0000000000000000,
3129598.2886967407539487 10098430.8033988755196333,
3129626.6966011249460280 10098486.5570504590868950,
3129670.9429495413787663 10098530.8033988755196333,
3129726.6966011249460280 10098559.2113032583147287,
3129788.5000000000000000 10098569.0000000000000000,
3129810.4193903957493603 10098565.5283096209168434,
3129801.0000000000000000 10098625.0000000000000000,
3129810.7886967407539487 10098686.8033988755196333,
3129839.1966011249460280 10098742.5570504590868950,
3129883.4429495413787663 10098786.8033988755196333,
3129919.8051041448488832 10098805.3308420442044735,
3129934.6966011249460280 10098834.5570504590868950,
3129978.9429495413787663 10098878.8033988755196333,
3130034.6966011249460280 10098907.2113032583147287,
3130096.5000000000000000 10098917.0000000000000000,
3130158.3033988750539720 10098907.2113032583147287,
3130214.0570504586212337 10098878.8033988755196333,
3130258.3033988750539720 10098834.5570504590868950,
3130266.1088675879873335 10098819.2379555627703667,
3130311.1966011249460280 10098842.2113032583147287,
3130373.0000000000000000 10098852.0000000000000000,
3130434.8033988750539720 10098842.2113032583147287,
3130490.5570504586212337 10098813.8033988755196333,
3130534.8033988750539720 10098769.5570504590868950,
3130563.2113032592460513 10098713.8033988755196333,
3130573.0000000000000000 10098652.0000000000000000,
3130563.2113032592460513 10098590.1966011244803667,
3130544.9027392505668104 10098554.2640210613608360,
3130562.4613032592460513 10098519.8033988755196333,
3130567.3577539417892694 10098488.8884259629994631,
3130580.5993604143150151 10098482.1414904724806547,
3130624.8457088307477534 10098437.8951420560479164,
3130653.2536132149398327 10098382.1414904724806547,
3130663.0423099556937814 10098320.3380915969610214,
3130653.2536132149398327 10098258.5346927214413881,
3130624.8457088307477534 10098202.7810411378741264,
3130580.5993604143150151 10098158.5346927214413881,
3130524.8457088307477534 10098130.1267883386462927,
3130463.0423099556937814 10098120.3380915969610214,
3130401.2389110806398094 10098130.1267883386462927,
3130390.1874418696388602 10098135.7577931564301252,
3130393.0000000000000000 10098118.0000000000000000,
3130383.2113032592460513 10098056.1966011244803667,
3130354.8033988750539720 10098000.4429495409131050,
3130344.4854493341408670 10097990.1250000000000000,
3130369.0533988750539720 10097965.5570504590868950,
3130397.4613032592460513 10097909.8033988755196333,
3130407.2500000000000000 10097848.0000000000000000,
3130398.3777337581850588 10097791.9827155750244856,
3130424.8033988750539720 10097765.5570504590868950,
3130453.2113032592460513 10097709.8033988755196333,
3130463.0000000000000000 10097648.0000000000000000,
3130453.2113032592460513 10097586.1966011244803667,
3130424.8033988750539720 10097530.4429495409131050,
3130380.5570504586212337 10097486.1966011244803667,
3130324.8033988750539720 10097457.7886967416852713,
3130263.0000000000000000 10097448.0000000000000000,
3130201.1966011249460280 10097457.7886967416852713,
3130145.4429495413787663 10097486.1966011244803667,
3130101.1966011249460280 10097530.4429495409131050,
3130072.7886967407539487 10097586.1966011244803667,
3130069.4873263002373278 10097607.0406337436288595,
3130055.4429495413787663 10097614.1966011244803667,
3130011.1966011249460280 10097658.4429495409131050,
3129982.7886967407539487 10097714.1966011244803667,
3129973.0000000000000000 10097776.0000000000000000,
3129982.7886967407539487 10097837.8033988755196333,
3130000.7008544025011361 10097872.9579876791685820,
3129962.9429495413787663 10097892.1966011244803667,
3129918.6966011249460280 10097936.4429495409131050,
3129890.2886967407539487 10097992.1966011244803667,
3129887.4701451878063381 10098009.9922352619469166,
3129867.4429495413787663 10098020.1966011244803667,
3129831.0051907678134739 10098056.6343598980456591,
3129827.0000000000000000 10098056.0000000000000000,
3129765.1966011249460280 10098065.7886967416852713,
3129709.4429495413787663 10098094.1966011244803667,
3129665.1966011249460280 10098138.4429495409131050,
3129636.7886967407539487 10098194.1966011244803667,
3129627.9146926272660494 10098250.2248580381274223),
(3130240.3964035096578300 10098310.4931471552699804,
3130210.4466011249460280 10098340.4429495409131050,
3130206.7504836763255298 10098347.6969884745776653,
3130170.4429495413787663 10098366.1966011244803667,
3130160.7358562438748777 10098375.9036944210529327,
3130136.5533988750539720 10098328.4429495409131050,
3130127.2354493341408670 10098319.1250000000000000,
3130137.1985333925113082 10098309.1619159411638975,
3130193.0000000000000000 10098318.0000000000000000,
3130240.3964035096578300 10098310.4931471552699804)),
((3130658.1561590000055730 10082496.2404999993741512,
3130648.3674622592516243 10082434.4371011238545179,
3130619.9595578750595450 10082378.6834495402872562,
3130575.7132094586268067 10082334.4371011238545179,
3130519.9595578750595450 10082306.0291967410594225,
3130458.1561590000055730 10082296.2404999993741512,
3130396.3527601249516010 10082306.0291967410594225,
3130340.5991085413843393 10082334.4371011238545179,
3130296.3527601249516010 10082378.6834495402872562,
3130267.9448557407595217 10082434.4371011238545179,
3130258.1561590000055730 10082496.2404999993741512,
3130267.9448557407595217 10082558.0438988748937845,
3130296.3527601249516010 10082613.7975504584610462,
3130340.5991085413843393 10082658.0438988748937845,
3130396.3527601249516010 10082686.4518032576888800,
3130458.1561590000055730 10082696.2404999993741512,
3130519.9595578750595450 10082686.4518032576888800,
3130575.7132094586268067 10082658.0438988748937845,
3130619.9595578750595450 10082613.7975504584610462,
3130648.3674622592516243 10082558.0438988748937845,
3130658.1561590000055730 10082496.2404999993741512)),
((3130338.5000000000000000 10088914.0000000000000000,
3130328.7113032592460513 10088852.1966011244803667,
3130300.3033988750539720 10088796.4429495409131050,
3130256.0570504586212337 10088752.1966011244803667,
3130200.3033988750539720 10088723.7886967416852713,
3130138.5000000000000000 10088714.0000000000000000,
3130076.6966011249460280 10088723.7886967416852713,
3130020.9429495413787663 10088752.1966011244803667,
3129976.6966011249460280 10088796.4429495409131050,
3129948.2886967407539487 10088852.1966011244803667,
3129938.5000000000000000 10088914.0000000000000000,
3129948.2886967407539487 10088975.8033988755196333,
3129976.6966011249460280 10089031.5570504590868950,
3130020.9429495413787663 10089075.8033988755196333,
3130076.6966011249460280 10089104.2113032583147287,
3130138.5000000000000000 10089114.0000000000000000,
3130200.3033988750539720 10089104.2113032583147287,
3130256.0570504586212337 10089075.8033988755196333,
3130300.3033988750539720 10089031.5570504590868950,
3130328.7113032592460513 10088975.8033988755196333,
3130338.5000000000000000 10088914.0000000000000000)),
((3130296.9657731303013861 10087784.7674239557236433,
3130287.1770763895474374 10087722.9640250802040100,
3130258.7691720053553581 10087667.2103734966367483,
3130214.5228235889226198 10087622.9640250802040100,
3130158.7691720053553581 10087594.5561206974089146,
3130096.9657731303013861 10087584.7674239557236433,
3130035.1623742552474141 10087594.5561206974089146,
3129979.4087226716801524 10087622.9640250802040100,
3129935.1623742552474141 10087667.2103734966367483,
3129906.7544698710553348 10087722.9640250802040100,
3129896.9657731303013861 10087784.7674239557236433,
3129906.7544698710553348 10087846.5708228312432766,
3129935.1623742552474141 10087902.3244744148105383,
3129979.4087226716801524 10087946.5708228312432766,
3130035.1623742552474141 10087974.9787272140383720,
3130096.9657731303013861 10087984.7674239557236433,
3130158.7691720053553581 10087974.9787272140383720,
3130214.5228235889226198 10087946.5708228312432766,
3130258.7691720053553581 10087902.3244744148105383,
3130287.1770763895474374 10087846.5708228312432766,
3130296.9657731303013861 10087784.7674239557236433)),
((3130189.6287270002067089 10082107.2066200003027916,
3130179.8400302594527602 10082045.4032211247831583,
3130151.4321258752606809 10081989.6495695412158966,
3130107.1857774588279426 10081945.4032211247831583,
3130051.4321258752606809 10081916.9953167419880629,
3129989.6287270002067089 10081907.2066200003027916,
3129927.8253281251527369 10081916.9953167419880629,
3129872.0716765415854752 10081945.4032211247831583,
3129827.8253281251527369 10081989.6495695412158966,
3129799.4174237409606576 10082045.4032211247831583,
3129789.6287270002067089 10082107.2066200003027916,
3129799.4174237409606576 10082169.0100188758224249,
3129827.8253281251527369 10082224.7636704593896866,
3129872.0716765415854752 10082269.0100188758224249,
3129927.8253281251527369 10082297.4179232586175203,
3129989.6287270002067089 10082307.2066200003027916,
3130051.4321258752606809 10082297.4179232586175203,
3130107.1857774588279426 10082269.0100188758224249,
3130151.4321258752606809 10082224.7636704593896866,
3130179.8400302594527602 10082169.0100188758224249,
3130189.6287270002067089 10082107.2066200003027916)),
((3129363.7478430476039648 10089914.3582923822104931,
3129368.1929495413787663 10089918.8033988755196333,
3129423.9466011249460280 10089947.2113032583147287,
3129485.7500000000000000 10089957.0000000000000000,
3129547.5533988750539720 10089947.2113032583147287,
3129584.7813968434929848 10089928.2426908612251282,
3129575.0000000000000000 10089990.0000000000000000,
3129584.7886967407539487 10090051.8033988755196333,
3129613.1966011249460280 10090107.5570504590868950,
3129657.4429495413787663 10090151.8033988755196333,
3129713.1966011249460280 10090180.2113032583147287,
3129775.0000000000000000 10090190.0000000000000000,
3129836.8033988750539720 10090180.2113032583147287,
3129892.5570504586212337 10090151.8033988755196333,
3129936.8033988750539720 10090107.5570504590868950,
3129950.2813203153200448 10090081.1051402483135462,
3129987.5000000000000000 10090087.0000000000000000,
3130049.3033988750539720 10090077.2113032583147287,
3130105.0570504586212337 10090048.8033988755196333,
3130149.3033988750539720 10090004.5570504590868950,
3130177.7113032592460513 10089948.8033988755196333,
3130187.5000000000000000 10089887.0000000000000000,
3130177.7113032592460513 10089825.1966011244803667,
3130149.3033988750539720 10089769.4429495409131050,
3130105.0570504586212337 10089725.1966011244803667,
3130049.3033988750539720 10089696.7886967416852713,
3129987.5000000000000000 10089687.0000000000000000,
3129925.6966011249460280 10089696.7886967416852713,
3129869.9429495413787663 10089725.1966011244803667,
3129825.6966011249460280 10089769.4429495409131050,
3129812.2186796846799552 10089795.8948597516864538,
3129775.0000000000000000 10089790.0000000000000000,
3129713.1966011249460280 10089799.7886967416852713,
3129675.9686031565070152 10089818.7573091387748718,
3129685.7500000000000000 10089757.0000000000000000,
3129675.9613032592460513 10089695.1966011244803667,
3129647.5533988750539720 10089639.4429495409131050,
3129603.3070504586212337 10089595.1966011244803667,
3129547.5533988750539720 10089566.7886967416852713,
3129485.7500000000000000 10089557.0000000000000000,
3129437.5021569523960352 10089564.6417076177895069,
3129433.0570504586212337 10089560.1966011244803667,
3129377.3033988750539720 10089531.7886967416852713,
3129315.5000000000000000 10089522.0000000000000000,
3129253.6966011249460280 10089531.7886967416852713,
3129197.9429495413787663 10089560.1966011244803667,
3129153.6966011249460280 10089604.4429495409131050,
3129125.2886967407539487 10089660.1966011244803667,
3129115.5000000000000000 10089722.0000000000000000,
3129125.2886967407539487 10089783.8033988755196333,
3129153.6966011249460280 10089839.5570504590868950,
3129197.9429495413787663 10089883.8033988755196333,
3129253.6966011249460280 10089912.2113032583147287,
3129315.5000000000000000 10089922.0000000000000000,
3129363.7478430476039648 10089914.3582923822104931)),
((3128637.4251130041666329 10095779.0990040097385645,
3128636.1387796052731574 10095778.8952688146382570,
3128574.3353807302191854 10095788.6839655563235283,
3128518.5817291466519237 10095817.0918699391186237,
3128474.3353807302191854 10095861.3382183555513620,
3128445.9274763460271060 10095917.0918699391186237,
3128436.1387796052731574 10095978.8952688146382570,
3128445.9274763460271060 10096040.6986676901578903,
3128474.3353807302191854 10096096.4523192737251520,
3128518.5817291466519237 10096140.6986676901578903,
3128574.3353807302191854 10096169.1065720729529858,
3128636.1387796052731574 10096178.8952688146382570,
3128697.9421784803271294 10096169.1065720729529858,
3128753.6958300638943911 10096140.6986676901578903,
3128797.9421784803271294 10096096.4523192737251520,
3128826.3500828645192087 10096040.6986676901578903,
3128836.1387796052731574 10095978.8952688146382570,
3128826.3500828645192087 10095917.0918699391186237,
3128800.2136666011065245 10095865.7962648048996925,
3128801.5000000000000000 10095866.0000000000000000,
3128863.3033988750539720 10095856.2113032583147287,
3128919.0570504586212337 10095827.8033988755196333,
3128963.3033988750539720 10095783.5570504590868950,
3128991.7113032592460513 10095727.8033988755196333,
3128999.7416070182807744 10095677.1020563524216413,
3129019.4429495413787663 10095696.8033988755196333,
3129075.1966011249460280 10095725.2113032583147287,
3129137.0000000000000000 10095735.0000000000000000,
3129198.8033988750539720 10095725.2113032583147287,
3129254.5570504586212337 10095696.8033988755196333,
3129284.6164736007340252 10095666.7439757343381643,
3129344.8033988750539720 10095657.2113032583147287,
3129400.5570504586212337 10095628.8033988755196333,
3129444.8033988750539720 10095584.5570504590868950,
3129473.2113032592460513 10095528.8033988755196333,
3129483.0000000000000000 10095467.0000000000000000,
3129479.1323246159590781 10095442.5804586857557297,
3129483.1966011249460280 10095450.5570504590868950,
3129527.4429495413787663 10095494.8033988755196333,
3129583.1966011249460280 10095523.2113032583147287,
3129645.0000000000000000 10095533.0000000000000000,
3129706.8033988750539720 10095523.2113032583147287,
3129762.5570504586212337 10095494.8033988755196333,
3129773.4757858519442379 10095483.8846634831279516,
3129775.5584920085966587 10095487.9722044654190540,
3129819.8048404250293970 10095532.2185528818517923,
3129875.5584920085966587 10095560.6264572646468878,
3129937.3618908836506307 10095570.4151540063321590,
3129999.1652897587046027 10095560.6264572646468878,
3130054.9189413422718644 10095532.2185528818517923,
3130099.1652897587046027 10095487.9722044654190540,
3130127.5731941428966820 10095432.2185528818517923,
3130137.3618908836506307 10095370.4151540063321590,
3130127.5731941428966820 10095308.6117551308125257,
3130099.1652897587046027 10095252.8581035472452641,
3130054.9189413422718644 10095208.6117551308125257,
3130015.4069930864498019 10095188.4794119354337454,
3130016.7500000000000000 10095180.0000000000000000,
3130006.9613032592460513 10095118.1966011244803667,
3130006.2494436735287309 10095116.7994980234652758,
3130055.3070504586212337 10095091.8033988755196333,
3130099.5533988750539720 10095047.5570504590868950,
3130127.9613032592460513 10094991.8033988755196333,
3130137.7500000000000000 10094930.0000000000000000,
3130127.9613032592460513 10094868.1966011244803667,
3130099.5533988750539720 10094812.4429495409131050,
3130055.3070504586212337 10094768.1966011244803667,
3129999.5533988750539720 10094739.7886967416852713,
3129937.7500000000000000 10094730.0000000000000000,
3129875.9466011249460280 10094739.7886967416852713,
3129841.5800286391749978 10094757.2993400339037180,
3129833.9613032592460513 10094709.1966011244803667,
3129805.5533988750539720 10094653.4429495409131050,
3129761.3070504586212337 10094609.1966011244803667,
3129716.1087480555288494 10094586.1669157780706882,
3129709.4613032592460513 10094544.1966011244803667,
3129681.0533988750539720 10094488.4429495409131050,
3129662.7836740459315479 10094470.1732247117906809,
3129662.7687156940810382 10094470.0787813961505890,
3129701.8546046526171267 10094450.1635262556374073,
3129746.1009530690498650 10094405.9171778392046690,
3129774.5088574532419443 10094350.1635262556374073,
3129784.2975541939958930 10094288.3601273801177740,
3129774.5088574532419443 10094226.5567285045981407,
3129746.1009530690498650 10094170.8030769210308790,
3129701.8546046526171267 10094126.5567285045981407,
3129655.9011703184805810 10094103.1422842200845480,
3129650.6456778752617538 10094092.8277995400130749,
3129606.3993294588290155 10094048.5814511235803366,
3129550.6456778752617538 10094020.1735467407852411,
3129488.8422790002077818 10094010.3848499990999699,
3129427.0388801251538098 10094020.1735467407852411,
3129371.2852285415865481 10094048.5814511235803366,
3129327.0388801251538098 10094092.8277995400130749,
3129298.6309757409617305 10094148.5814511235803366,
3129288.8422790002077818 10094210.3848499990999699,
3129298.6309757409617305 10094272.1882488746196032,
3129327.0388801251538098 10094327.9419004581868649,
3129349.9932651664130390 10094350.8962854985147715,
3129345.6250000000000000 10094355.2645506653934717,
3129318.5570504586212337 10094328.1966011244803667,
3129262.8033988750539720 10094299.7886967416852713,
3129201.0000000000000000 10094290.0000000000000000,
3129139.1966011249460280 10094299.7886967416852713,
3129083.4429495413787663 10094328.1966011244803667,
3129039.1966011249460280 10094372.4429495409131050,
3129010.7886967407539487 10094428.1966011244803667,
3129001.0000000000000000 10094490.0000000000000000,
3129010.7886967407539487 10094551.8033988755196333,
3129039.1966011249460280 10094607.5570504590868950,
3129083.4429495413787663 10094651.8033988755196333,
3129139.1966011249460280 10094680.2113032583147287,
3129201.0000000000000000 10094690.0000000000000000,
3129262.8033988750539720 10094680.2113032583147287,
3129318.5570504586212337 10094651.8033988755196333,
3129324.6250000000000000 10094645.7354493346065283,
3129325.7163259540684521 10094646.8267752882093191,
3129329.0386967407539487 10094667.8033988755196333,
3129357.4466011249460280 10094723.5570504590868950,
3129401.6929495413787663 10094767.8033988755196333,
3129446.8912519444711506 10094790.8330842219293118,
3129453.5386967407539487 10094832.8033988755196333,
3129464.4120326512493193 10094854.1435221638530493,
3129462.3261577207595110 10094867.3132181670516729,
3129446.6966011249460280 10094869.7886967416852713,
3129390.9429495413787663 10094898.1966011244803667,
3129346.6966011249460280 10094942.4429495409131050,
3129318.2886967407539487 10094998.1966011244803667,
3129308.5000000000000000 10095060.0000000000000000,
3129318.2886967407539487 10095121.8033988755196333,
3129346.6966011249460280 10095177.5570504590868950,
3129349.9780284059233963 10095180.8384777400642633,
3129369.1966011249460280 10095218.5570504590868950,
3129413.4429495413787663 10095262.8033988755196333,
3129452.9313035495579243 10095282.9237201996147633,
3129445.0000000000000000 10095333.0000000000000000,
3129448.8676753840409219 10095357.4195413142442703,
3129444.8033988750539720 10095349.4429495409131050,
3129400.5570504586212337 10095305.1966011244803667,
3129344.8033988750539720 10095276.7886967416852713,
3129283.0000000000000000 10095267.0000000000000000,
3129221.1966011249460280 10095276.7886967416852713,
3129165.4429495413787663 10095305.1966011244803667,
3129135.3835263992659748 10095335.2560242656618357,
3129075.1966011249460280 10095344.7886967416852713,
3129019.4429495413787663 10095373.1966011244803667,
3128975.1966011249460280 10095417.4429495409131050,
3128946.7886967407539487 10095473.1966011244803667,
3128938.7583929817192256 10095523.8979436475783587,
3128919.0570504586212337 10095504.1966011244803667,
3128863.3033988750539720 10095475.7886967416852713,
3128801.5000000000000000 10095466.0000000000000000,
3128739.6966011249460280 10095475.7886967416852713,
3128683.9429495413787663 10095504.1966011244803667,
3128639.6966011249460280 10095548.4429495409131050,
3128611.2886967407539487 10095604.1966011244803667,
3128601.5000000000000000 10095666.0000000000000000,
3128611.2886967407539487 10095727.8033988755196333,
3128637.4251130041666329 10095779.0990040097385645)),
((3127634.5866099777631462 10087922.4293429665267467,
3127627.1929495413787663 10087926.1966011244803667,
3127582.9466011249460280 10087970.4429495409131050,
3127554.5386967407539487 10088026.1966011244803667,
3127544.7500000000000000 10088088.0000000000000000,
3127554.5386967407539487 10088149.8033988755196333,
3127582.9466011249460280 10088205.5570504590868950,
3127627.1929495413787663 10088249.8033988755196333,
3127682.9466011249460280 10088278.2113032583147287,
3127744.7500000000000000 10088288.0000000000000000,
3127806.5533988750539720 10088278.2113032583147287,
3127862.3070504586212337 10088249.8033988755196333,
3127903.3689717254601419 10088208.7414776086807251,
3127908.2886967407539487 10088239.8033988755196333,
3127936.6966011249460280 10088295.5570504590868950,
3127980.9429495413787663 10088339.8033988755196333,
3128036.6966011249460280 10088368.2113032583147287,
3128098.5000000000000000 10088378.0000000000000000,
3128160.3033988750539720 10088368.2113032583147287,
3128195.6108228522352874 10088350.2212721873074770,
3128206.1929495413787663 10088360.8033988755196333,
3128261.9466011249460280 10088389.2113032583147287,
3128323.7500000000000000 10088399.0000000000000000,
3128385.5533988750539720 10088389.2113032583147287,
3128441.3070504586212337 10088360.8033988755196333,
3128485.5533988750539720 10088316.5570504590868950,
3128513.9613032592460513 10088260.8033988755196333,
3128523.7500000000000000 10088199.0000000000000000,
3128513.9613032592460513 10088137.1966011244803667,
3128485.5533988750539720 10088081.4429495409131050,
3128441.3070504586212337 10088037.1966011244803667,
3128385.5533988750539720 10088008.7886967416852713,
3128323.7500000000000000 10087999.0000000000000000,
3128261.9466011249460280 10088008.7886967416852713,
3128226.6391771477647126 10088026.7787278126925230,
3128223.9949640599079430 10088024.1345147248357534,
3128226.7113032592460513 10088018.8033988755196333,
3128236.5000000000000000 10087957.0000000000000000,
3128226.7113032592460513 10087895.1966011244803667,
3128225.8024740638211370 10087893.4129233974963427,
3128258.1929495413787663 10087925.8033988755196333,
3128313.9466011249460280 10087954.2113032583147287,
3128375.7500000000000000 10087964.0000000000000000,
3128437.5533988750539720 10087954.2113032583147287,
3128493.3070504586212337 10087925.8033988755196333,
3128526.7500000000000000 10087892.3604493346065283,
3128541.1929495413787663 10087906.8033988755196333,
3128596.9466011249460280 10087935.2113032583147287,
3128658.7500000000000000 10087945.0000000000000000,
3128676.3110043359920382 10087942.2186101563274860,
3128681.7886967407539487 10087976.8033988755196333,
3128710.1966011249460280 10088032.5570504590868950,
3128754.4429495413787663 10088076.8033988755196333,
3128810.1966011249460280 10088105.2113032583147287,
3128872.0000000000000000 10088115.0000000000000000,
3128933.8033988750539720 10088105.2113032583147287,
3128989.5570504586212337 10088076.8033988755196333,
3129033.8033988750539720 10088032.5570504590868950,
3129053.0915240417234600 10087994.7019733749330044,
3129077.1929495413787663 10088018.8033988755196333,
3129132.9466011249460280 10088047.2113032583147287,
3129194.7500000000000000 10088057.0000000000000000,
3129256.5533988750539720 10088047.2113032583147287,
3129266.9988949438557029 10088041.8890571780502796,
3129311.8743052189238369 10088064.7542207688093185,
3129305.5000000000000000 10088105.0000000000000000,
3129315.2886967407539487 10088166.8033988755196333,
3129343.6966011249460280 10088222.5570504590868950,
3129387.9429495413787663 10088266.8033988755196333,
3129443.6966011249460280 10088295.2113032583147287,
3129505.5000000000000000 10088305.0000000000000000,
3129554.6111143114976585 10088297.2215636447072029,
3129585.1929495413787663 10088327.8033988755196333,
3129640.9466011249460280 10088356.2113032583147287,
3129702.7500000000000000 10088366.0000000000000000,
3129764.5533988750539720 10088356.2113032583147287,
3129820.3070504586212337 10088327.8033988755196333,
3129864.5533988750539720 10088283.5570504590868950,
3129892.9613032592460513 10088227.8033988755196333,
3129902.7500000000000000 10088166.0000000000000000,
3129892.9613032592460513 10088104.1966011244803667,
3129864.5533988750539720 10088048.4429495409131050,
3129820.3070504586212337 10088004.1966011244803667,
3129764.5533988750539720 10087975.7886967416852713,
3129702.7500000000000000 10087966.0000000000000000,
3129653.6388856885023415 10087973.7784363552927971,
3129623.0570504586212337 10087943.1966011244803667,
3129572.1256947810761631 10087917.2457792311906815,
3129578.5000000000000000 10087877.0000000000000000,
3129568.7113032592460513 10087815.1966011244803667,
3129540.3033988750539720 10087759.4429495409131050,
3129537.6021808958612382 10087756.7417315617203712,
3129558.4613032592460513 10087715.8033988755196333,
3129568.2500000000000000 10087654.0000000000000000,
3129558.8168283980339766 10087594.4412985090166330,
3129573.8070504586212337 10087586.8033988755196333,
3129618.0533988750539720 10087542.5570504590868950,
3129646.4613032592460513 10087486.8033988755196333,
3129656.2500000000000000 10087425.0000000000000000,
3129646.4613032592460513 10087363.1966011244803667,
3129618.0533988750539720 10087307.4429495409131050,
3129580.0714881680905819 10087269.4610388334840536,
3129574.9613032592460513 10087237.1966011244803667,
3129546.5533988750539720 10087181.4429495409131050,
3129502.3070504586212337 10087137.1966011244803667,
3129446.5533988750539720 10087108.7886967416852713,
3129384.7500000000000000 10087099.0000000000000000,
3129322.9466011249460280 10087108.7886967416852713,
3129267.1929495413787663 10087137.1966011244803667,
3129222.9466011249460280 10087181.4429495409131050,
3129194.5386967407539487 10087237.1966011244803667,
3129184.7500000000000000 10087299.0000000000000000,
3129194.5386967407539487 10087360.8033988755196333,
3129222.9466011249460280 10087416.5570504590868950,
3129260.9285118319094181 10087454.5389611665159464,
3129265.2158056474290788 10087481.6078689899295568,
3129251.4466011249460280 10087483.7886967416852713,
3129195.6929495413787663 10087512.1966011244803667,
3129162.6849395111203194 10087545.2046111542731524,
3129112.8033988750539720 10087519.7886967416852713,
3129051.0000000000000000 10087510.0000000000000000,
3128989.1966011249460280 10087519.7886967416852713,
3128984.3024939931929111 10087522.2823688779026270,
3128976.2113032592460513 10087471.1966011244803667,
3128947.8033988750539720 10087415.4429495409131050,
3128903.5570504586212337 10087371.1966011244803667,
3128847.8033988750539720 10087342.7886967416852713,
3128786.0000000000000000 10087333.0000000000000000,
3128724.1966011249460280 10087342.7886967416852713,
3128668.4429495413787663 10087371.1966011244803667,
3128624.1966011249460280 10087415.4429495409131050,
3128595.7886967407539487 10087471.1966011244803667,
3128586.0000000000000000 10087533.0000000000000000,
3128590.0107222297228873 10087558.3227035533636808,
3128541.1929495413787663 10087583.1966011244803667,
3128507.7500000000000000 10087616.6395506653934717,
3128493.3070504586212337 10087602.1966011244803667,
3128437.5533988750539720 10087573.7886967416852713,
3128425.3841829407028854 10087571.8612822871655226,
3128427.9613032592460513 10087566.8033988755196333,
3128437.7500000000000000 10087505.0000000000000000,
3128427.9613032592460513 10087443.1966011244803667,
3128399.5533988750539720 10087387.4429495409131050,
3128357.4829203695990145 10087345.3724710363894701,
3128350.9613032592460513 10087304.1966011244803667,
3128322.5533988750539720 10087248.4429495409131050,
3128278.3070504586212337 10087204.1966011244803667,
3128222.5533988750539720 10087175.7886967416852713,
3128160.7500000000000000 10087166.0000000000000000,
3128156.7729329494759440 10087166.6299055386334658,
3128164.0000000000000000 10087121.0000000000000000,
3128154.2113032592460513 10087059.1966011244803667,
3128125.8033988750539720 10087003.4429495409131050,
3128081.5570504586212337 10086959.1966011244803667,
3128025.8033988750539720 10086930.7886967416852713,
3127964.0000000000000000 10086921.0000000000000000,
3127902.1966011249460280 10086930.7886967416852713,
3127846.4429495413787663 10086959.1966011244803667,
3127802.1966011249460280 10087003.4429495409131050,
3127773.7886967407539487 10087059.1966011244803667,
3127764.0000000000000000 10087121.0000000000000000,
3127773.7886967407539487 10087182.8033988755196333,
3127802.1966011249460280 10087238.5570504590868950,
3127846.4429495413787663 10087282.8033988755196333,
3127892.9100046502426267 10087306.4795460160821676,
3127877.9466011249460280 10087321.4429495409131050,
3127849.5386967407539487 10087377.1966011244803667,
3127839.7500000000000000 10087439.0000000000000000,
3127849.5386967407539487 10087500.8033988755196333,
3127877.9466011249460280 10087556.5570504590868950,
3127922.1929495413787663 10087600.8033988755196333,
3127977.9466011249460280 10087629.2113032583147287,
3128039.7500000000000000 10087639.0000000000000000,
3128085.1922114393673837 10087631.8026607744395733,
3128120.1929495413787663 10087666.8033988755196333,
3128175.9466011249460280 10087695.2113032583147287,
3128188.1158170592971146 10087697.1387177128344774,
3128185.5386967407539487 10087702.1966011244803667,
3128175.7500000000000000 10087764.0000000000000000,
3128185.5386967407539487 10087825.8033988755196333,
3128186.4475259361788630 10087827.5870766025036573,
3128154.0570504586212337 10087795.1966011244803667,
3128098.3033988750539720 10087766.7886967416852713,
3128036.5000000000000000 10087757.0000000000000000,
3127988.4679747684858739 10087764.6075254343450069,
3127946.0570504586212337 10087722.1966011244803667,
3127890.3033988750539720 10087693.7886967416852713,
3127828.5000000000000000 10087684.0000000000000000,
3127766.6966011249460280 10087693.7886967416852713,
3127710.9429495413787663 10087722.1966011244803667,
3127666.6966011249460280 10087766.4429495409131050,
3127638.2886967407539487 10087822.1966011244803667,
3127628.5000000000000000 10087884.0000000000000000,
3127634.5866099777631462 10087922.4293429665267467)),
((3129896.2152143297716975 10096449.9256476629525423,
3129886.4265175890177488 10096388.1222487874329090,
3129858.0186132048256695 10096332.3685972038656473,
3129813.7722647883929312 10096288.1222487874329090,
3129758.0186132048256695 10096259.7143444046378136,
3129696.2152143297716975 10096249.9256476629525423,
3129634.4118154547177255 10096259.7143444046378136,
3129578.6581638711504638 10096288.1222487874329090,
3129534.4118154547177255 10096332.3685972038656473,
3129506.0039110705256462 10096388.1222487874329090,
3129496.2152143297716975 10096449.9256476629525423,
3129506.0039110705256462 10096511.7290465384721756,
3129534.4118154547177255 10096567.4826981220394373,
3129578.6581638711504638 10096611.7290465384721756,
3129634.4118154547177255 10096640.1369509212672710,
3129696.2152143297716975 10096649.9256476629525423,
3129758.0186132048256695 10096640.1369509212672710,
3129813.7722647883929312 10096611.7290465384721756,
3129858.0186132048256695 10096567.4826981220394373,
3129886.4265175890177488 10096511.7290465384721756,
3129896.2152143297716975 10096449.9256476629525423)),
((3129346.0313772074878216 10096842.3807362671941519,
3129331.0000000000000000 10096840.0000000000000000,
3129269.1966011249460280 10096849.7886967416852713,
3129213.4429495413787663 10096878.1966011244803667,
3129169.1966011249460280 10096922.4429495409131050,
3129140.7886967407539487 10096978.1966011244803667,
3129131.0000000000000000 10097040.0000000000000000,
3129140.7886967407539487 10097101.8033988755196333,
3129169.1966011249460280 10097157.5570504590868950,
3129213.4429495413787663 10097201.8033988755196333,
3129269.1966011249460280 10097230.2113032583147287,
3129331.0000000000000000 10097240.0000000000000000,
3129392.8033988750539720 10097230.2113032583147287,
3129448.5570504586212337 10097201.8033988755196333,
3129466.4584804745391011 10097183.9019688591361046,
3129481.4898576820269227 10097186.2827051263302565,
3129543.2932565570808947 10097176.4940083846449852,
3129599.0469081406481564 10097148.0861040018498898,
3129643.2932565570808947 10097103.8397555854171515,
3129671.7011609412729740 10097048.0861040018498898,
3129681.4898576820269227 10096986.2827051263302565,
3129671.7011609412729740 10096924.4793062508106232,
3129643.2932565570808947 10096868.7256546672433615,
3129599.0469081406481564 10096824.4793062508106232,
3129543.2932565570808947 10096796.0714018680155277,
3129481.4898576820269227 10096786.2827051263302565,
3129419.6864588069729507 10096796.0714018680155277,
3129363.9328072234056890 10096824.4793062508106232,
3129346.0313772074878216 10096842.3807362671941519)),
((3129641.5000000000000000 10091931.0000000000000000,
3129631.7113032592460513 10091869.1966011244803667,
3129603.3033988750539720 10091813.4429495409131050,
3129559.0570504586212337 10091769.1966011244803667,
3129503.3033988750539720 10091740.7886967416852713,
3129441.5000000000000000 10091731.0000000000000000,
3129379.6966011249460280 10091740.7886967416852713,
3129323.9429495413787663 10091769.1966011244803667,
3129279.6966011249460280 10091813.4429495409131050,
3129251.2886967407539487 10091869.1966011244803667,
3129241.5000000000000000 10091931.0000000000000000,
3129251.2886967407539487 10091992.8033988755196333,
3129279.6966011249460280 10092048.5570504590868950,
3129323.9429495413787663 10092092.8033988755196333,
3129379.6966011249460280 10092121.2113032583147287,
3129441.5000000000000000 10092131.0000000000000000,
3129503.3033988750539720 10092121.2113032583147287,
3129559.0570504586212337 10092092.8033988755196333,
3129603.3033988750539720 10092048.5570504590868950,
3129631.7113032592460513 10091992.8033988755196333,
3129641.5000000000000000 10091931.0000000000000000)),
((3129406.2500000000000000 10084733.0000000000000000,
3129396.4613032592460513 10084671.1966011244803667,
3129368.0533988750539720 10084615.4429495409131050,
3129323.8070504586212337 10084571.1966011244803667,
3129268.0533988750539720 10084542.7886967416852713,
3129206.2500000000000000 10084533.0000000000000000,
3129144.4466011249460280 10084542.7886967416852713,
3129088.6929495413787663 10084571.1966011244803667,
3129044.4466011249460280 10084615.4429495409131050,
3129016.0386967407539487 10084671.1966011244803667,
3129006.2500000000000000 10084733.0000000000000000,
3129016.0386967407539487 10084794.8033988755196333,
3129044.4466011249460280 10084850.5570504590868950,
3129088.6929495413787663 10084894.8033988755196333,
3129144.4466011249460280 10084923.2113032583147287,
3129206.2500000000000000 10084933.0000000000000000,
3129268.0533988750539720 10084923.2113032583147287,
3129323.8070504586212337 10084894.8033988755196333,
3129368.0533988750539720 10084850.5570504590868950,
3129396.4613032592460513 10084794.8033988755196333,
3129406.2500000000000000 10084733.0000000000000000)),
((3129356.1899470235221088 10079212.8888563159853220,
3129346.4012502827681601 10079151.0854574404656887,
3129317.9933458985760808 10079095.3318058568984270,
3129273.7469974821433425 10079051.0854574404656887,
3129217.9933458985760808 10079022.6775530576705933,
3129156.1899470235221088 10079012.8888563159853220,
3129094.3865481484681368 10079022.6775530576705933,
3129038.6328965649008751 10079051.0854574404656887,
3128994.3865481484681368 10079095.3318058568984270,
3128965.9786437642760575 10079151.0854574404656887,
3128956.1899470235221088 10079212.8888563159853220,
3128965.9786437642760575 10079274.6922551915049553,
3128994.3865481484681368 10079330.4459067750722170,
3129038.6328965649008751 10079374.6922551915049553,
3129094.3865481484681368 10079403.1001595743000507,
3129156.1899470235221088 10079412.8888563159853220,
3129217.9933458985760808 10079403.1001595743000507,
3129273.7469974821433425 10079374.6922551915049553,
3129317.9933458985760808 10079330.4459067750722170,
3129346.4012502827681601 10079274.6922551915049553,
3129356.1899470235221088 10079212.8888563159853220)),
((3128898.8215470877476037 10096102.3180035781115294,
3128890.5000000000000000 10096101.0000000000000000,
3128828.6966011249460280 10096110.7886967416852713,
3128772.9429495413787663 10096139.1966011244803667,
3128728.6966011249460280 10096183.4429495409131050,
3128700.2886967407539487 10096239.1966011244803667,
3128690.5000000000000000 10096301.0000000000000000,
3128700.2886967407539487 10096362.8033988755196333,
3128728.6966011249460280 10096418.5570504590868950,
3128772.9429495413787663 10096462.8033988755196333,
3128828.6966011249460280 10096491.2113032583147287,
3128890.5000000000000000 10096501.0000000000000000,
3128952.3033988750539720 10096491.2113032583147287,
3129008.0570504586212337 10096462.8033988755196333,
3129029.1784529122523963 10096441.6819964218884706,
3129037.5000000000000000 10096443.0000000000000000,
3129099.3033988750539720 10096433.2113032583147287,
3129155.0570504586212337 10096404.8033988755196333,
3129199.3033988750539720 10096360.5570504590868950,
3129227.7113032592460513 10096304.8033988755196333,
3129237.5000000000000000 10096243.0000000000000000,
3129227.7113032592460513 10096181.1966011244803667,
3129199.3033988750539720 10096125.4429495409131050,
3129155.0570504586212337 10096081.1966011244803667,
3129099.3033988750539720 10096052.7886967416852713,
3129037.5000000000000000 10096043.0000000000000000,
3128975.6966011249460280 10096052.7886967416852713,
3128919.9429495413787663 10096081.1966011244803667,
3128898.8215470877476037 10096102.3180035781115294)),
((3128589.2331022392027080 10089964.0935515742748976,
3128624.9429495413787663 10089999.8033988755196333,
3128680.6966011249460280 10090028.2113032583147287,
3128742.5000000000000000 10090038.0000000000000000,
3128804.3033988750539720 10090028.2113032583147287,
3128860.0534402849152684 10089999.8052383512258530,
3128863.8033988750539720 10089999.2113032583147287,
3128919.5570504586212337 10089970.8033988755196333,
3128963.8033988750539720 10089926.5570504590868950,
3128992.2113032592460513 10089870.8033988755196333,
3129002.0000000000000000 10089809.0000000000000000,
3128992.2113032592460513 10089747.1966011244803667,
3128963.8033988750539720 10089691.4429495409131050,
3128919.5570504586212337 10089647.1966011244803667,
3128863.8033988750539720 10089618.7886967416852713,
3128802.0000000000000000 10089609.0000000000000000,
3128740.1966011249460280 10089618.7886967416852713,
3128685.8434565137140453 10089646.4830071795731783,
3128650.5570504586212337 10089611.1966011244803667,
3128594.8033988750539720 10089582.7886967416852713,
3128533.0000000000000000 10089573.0000000000000000,
3128471.1966011249460280 10089582.7886967416852713,
3128415.4429495413787663 10089611.1966011244803667,
3128371.1966011249460280 10089655.4429495409131050,
3128342.7886967407539487 10089711.1966011244803667,
3128333.0000000000000000 10089773.0000000000000000,
3128342.7886967407539487 10089834.8033988755196333,
3128371.1966011249460280 10089890.5570504590868950,
3128415.4429495413787663 10089934.8033988755196333,
3128471.1966011249460280 10089963.2113032583147287,
3128533.0000000000000000 10089973.0000000000000000,
3128589.2331022392027080 10089964.0935515742748976)),
((3128901.7500000000000000 10090796.0000000000000000,
3128891.9613032592460513 10090734.1966011244803667,
3128863.5533988750539720 10090678.4429495409131050,
3128819.3070504586212337 10090634.1966011244803667,
3128763.5533988750539720 10090605.7886967416852713,
3128701.7500000000000000 10090596.0000000000000000,
3128639.9466011249460280 10090605.7886967416852713,
3128584.1929495413787663 10090634.1966011244803667,
3128539.9466011249460280 10090678.4429495409131050,
3128511.5386967407539487 10090734.1966011244803667,
3128501.7500000000000000 10090796.0000000000000000,
3128511.5386967407539487 10090857.8033988755196333,
3128539.9466011249460280 10090913.5570504590868950,
3128584.1929495413787663 10090957.8033988755196333,
3128639.9466011249460280 10090986.2113032583147287,
3128701.7500000000000000 10090996.0000000000000000,
3128763.5533988750539720 10090986.2113032583147287,
3128819.3070504586212337 10090957.8033988755196333,
3128863.5533988750539720 10090913.5570504590868950,
3128891.9613032592460513 10090857.8033988755196333,
3128901.7500000000000000 10090796.0000000000000000)),
((3128893.5000000000000000 10084691.0000000000000000,
3128883.7113032592460513 10084629.1966011244803667,
3128855.3033988750539720 10084573.4429495409131050,
3128811.0570504586212337 10084529.1966011244803667,
3128755.3033988750539720 10084500.7886967416852713,
3128693.5000000000000000 10084491.0000000000000000,
3128631.6966011249460280 10084500.7886967416852713,
3128575.9429495413787663 10084529.1966011244803667,
3128531.6966011249460280 10084573.4429495409131050,
3128503.2886967407539487 10084629.1966011244803667,
3128493.5000000000000000 10084691.0000000000000000,
3128503.2886967407539487 10084752.8033988755196333,
3128531.6966011249460280 10084808.5570504590868950,
3128575.9429495413787663 10084852.8033988755196333,
3128631.6966011249460280 10084881.2113032583147287,
3128693.5000000000000000 10084891.0000000000000000,
3128755.3033988750539720 10084881.2113032583147287,
3128811.0570504586212337 10084852.8033988755196333,
3128855.3033988750539720 10084808.5570504590868950,
3128883.7113032592460513 10084752.8033988755196333,
3128893.5000000000000000 10084691.0000000000000000)),
((3128892.2500000000000000 10091470.0000000000000000,
3128882.4613032592460513 10091408.1966011244803667,
3128854.0533988750539720 10091352.4429495409131050,
3128809.8070504586212337 10091308.1966011244803667,
3128754.0533988750539720 10091279.7886967416852713,
3128692.2500000000000000 10091270.0000000000000000,
3128630.4466011249460280 10091279.7886967416852713,
3128574.6929495413787663 10091308.1966011244803667,
3128530.4466011249460280 10091352.4429495409131050,
3128502.0386967407539487 10091408.1966011244803667,
3128492.2500000000000000 10091470.0000000000000000,
3128502.0386967407539487 10091531.8033988755196333,
3128530.4466011249460280 10091587.5570504590868950,
3128574.6929495413787663 10091631.8033988755196333,
3128630.4466011249460280 10091660.2113032583147287,
3128692.2500000000000000 10091670.0000000000000000,
3128754.0533988750539720 10091660.2113032583147287,
3128809.8070504586212337 10091631.8033988755196333,
3128854.0533988750539720 10091587.5570504590868950,
3128882.4613032592460513 10091531.8033988755196333,
3128892.2500000000000000 10091470.0000000000000000)),
((3128619.2500000000000000 10078747.0000000000000000,
3128609.4613032592460513 10078685.1966011244803667,
3128581.0533988750539720 10078629.4429495409131050,
3128536.8070504586212337 10078585.1966011244803667,
3128481.0533988750539720 10078556.7886967416852713,
3128419.2500000000000000 10078547.0000000000000000,
3128357.4466011249460280 10078556.7886967416852713,
3128301.6929495413787663 10078585.1966011244803667,
3128257.4466011249460280 10078629.4429495409131050,
3128229.0386967407539487 10078685.1966011244803667,
3128219.2500000000000000 10078747.0000000000000000,
3128229.0386967407539487 10078808.8033988755196333,
3128257.4466011249460280 10078864.5570504590868950,
3128301.6929495413787663 10078908.8033988755196333,
3128357.4466011249460280 10078937.2113032583147287,
3128419.2500000000000000 10078947.0000000000000000,
3128481.0533988750539720 10078937.2113032583147287,
3128536.8070504586212337 10078908.8033988755196333,
3128581.0533988750539720 10078864.5570504590868950,
3128609.4613032592460513 10078808.8033988755196333,
3128619.2500000000000000 10078747.0000000000000000)),
((3128230.1898077568039298 10090293.0502570904791355,
3128258.9429495413787663 10090321.8033988755196333,
3128314.6966011249460280 10090350.2113032583147287,
3128376.5000000000000000 10090360.0000000000000000,
3128438.3033988750539720 10090350.2113032583147287,
3128494.0570504586212337 10090321.8033988755196333,
3128538.3033988750539720 10090277.5570504590868950,
3128566.7113032592460513 10090221.8033988755196333,
3128576.5000000000000000 10090160.0000000000000000,
3128566.7113032592460513 10090098.1966011244803667,
3128538.3033988750539720 10090042.4429495409131050,
3128494.0570504586212337 10089998.1966011244803667,
3128438.3033988750539720 10089969.7886967416852713,
3128388.8101922431960702 10089961.9497429095208645,
3128360.0570504586212337 10089933.1966011244803667,
3128304.3033988750539720 10089904.7886967416852713,
3128242.5000000000000000 10089895.0000000000000000,
3128180.6966011249460280 10089904.7886967416852713,
3128124.9429495413787663 10089933.1966011244803667,
3128080.6966011249460280 10089977.4429495409131050,
3128052.2886967407539487 10090033.1966011244803667,
3128042.5000000000000000 10090095.0000000000000000,
3128052.2886967407539487 10090156.8033988755196333,
3128080.6966011249460280 10090212.5570504590868950,
3128124.9429495413787663 10090256.8033988755196333,
3128180.6966011249460280 10090285.2113032583147287,
3128230.1898077568039298 10090293.0502570904791355)),
((3128254.2500000000000000 10095879.0000000000000000,
3128244.4613032592460513 10095817.1966011244803667,
3128216.0533988750539720 10095761.4429495409131050,
3128171.8070504586212337 10095717.1966011244803667,
3128116.0533988750539720 10095688.7886967416852713,
3128054.2500000000000000 10095679.0000000000000000,
3127992.4466011249460280 10095688.7886967416852713,
3127936.6929495413787663 10095717.1966011244803667,
3127892.4466011249460280 10095761.4429495409131050,
3127864.0386967407539487 10095817.1966011244803667,
3127854.2500000000000000 10095879.0000000000000000,
3127864.0386967407539487 10095940.8033988755196333,
3127892.4466011249460280 10095996.5570504590868950,
3127936.6929495413787663 10096040.8033988755196333,
3127992.4466011249460280 10096069.2113032583147287,
3128054.2500000000000000 10096079.0000000000000000,
3128116.0533988750539720 10096069.2113032583147287,
3128171.8070504586212337 10096040.8033988755196333,
3128216.0533988750539720 10095996.5570504590868950,
3128244.4613032592460513 10095940.8033988755196333,
3128254.2500000000000000 10095879.0000000000000000)),
((3128060.7500000000000000 10100865.0000000000000000,
3128050.9613032592460513 10100803.1966011244803667,
3128022.5533988750539720 10100747.4429495409131050,
3127978.3070504586212337 10100703.1966011244803667,
3127922.5533988750539720 10100674.7886967416852713,
3127860.7500000000000000 10100665.0000000000000000,
3127798.9466011249460280 10100674.7886967416852713,
3127743.1929495413787663 10100703.1966011244803667,
3127698.9466011249460280 10100747.4429495409131050,
3127670.5386967407539487 10100803.1966011244803667,
3127660.7500000000000000 10100865.0000000000000000,
3127670.5386967407539487 10100926.8033988755196333,
3127698.9466011249460280 10100982.5570504590868950,
3127743.1929495413787663 10101026.8033988755196333,
3127798.9466011249460280 10101055.2113032583147287,
3127860.7500000000000000 10101065.0000000000000000,
3127922.5533988750539720 10101055.2113032583147287,
3127978.3070504586212337 10101026.8033988755196333,
3128022.5533988750539720 10100982.5570504590868950,
3128050.9613032592460513 10100926.8033988755196333,
3128060.7500000000000000 10100865.0000000000000000)),
((3127974.1829699999652803 10098482.1327199991792440,
3127964.3942732592113316 10098420.3293211236596107,
3127935.9863688750192523 10098364.5756695400923491,
3127891.7400204585865140 10098320.3293211236596107,
3127835.9863688750192523 10098291.9214167408645153,
3127774.1829699999652803 10098282.1327199991792440,
3127712.3795711249113083 10098291.9214167408645153,
3127656.6259195413440466 10098320.3293211236596107,
3127612.3795711249113083 10098364.5756695400923491,
3127583.9716667407192290 10098420.3293211236596107,
3127574.1829699999652803 10098482.1327199991792440,
3127583.9716667407192290 10098543.9361188746988773,
3127612.3795711249113083 10098599.6897704582661390,
3127656.6259195413440466 10098643.9361188746988773,
3127712.3795711249113083 10098672.3440232574939728,
3127774.1829699999652803 10098682.1327199991792440,
3127835.9863688750192523 10098672.3440232574939728,
3127891.7400204585865140 10098643.9361188746988773,
3127935.9863688750192523 10098599.6897704582661390,
3127964.3942732592113316 10098543.9361188746988773,
3127974.1829699999652803 10098482.1327199991792440)),
((3127859.7500000000000000 10097109.0000000000000000,
3127849.9613032592460513 10097047.1966011244803667,
3127821.5533988750539720 10096991.4429495409131050,
3127777.3070504586212337 10096947.1966011244803667,
3127721.5533988750539720 10096918.7886967416852713,
3127659.7500000000000000 10096909.0000000000000000,
3127597.9466011249460280 10096918.7886967416852713,
3127542.1929495413787663 10096947.1966011244803667,
3127497.9466011249460280 10096991.4429495409131050,
3127469.5386967407539487 10097047.1966011244803667,
3127459.7500000000000000 10097109.0000000000000000,
3127469.5386967407539487 10097170.8033988755196333,
3127497.9466011249460280 10097226.5570504590868950,
3127542.1929495413787663 10097270.8033988755196333,
3127597.9466011249460280 10097299.2113032583147287,
3127659.7500000000000000 10097309.0000000000000000,
3127721.5533988750539720 10097299.2113032583147287,
3127777.3070504586212337 10097270.8033988755196333,
3127821.5533988750539720 10097226.5570504590868950,
3127849.9613032592460513 10097170.8033988755196333,
3127859.7500000000000000 10097109.0000000000000000)),
((3127849.7500000000000000 10091011.0000000000000000,
3127839.9613032592460513 10090949.1966011244803667,
3127811.5533988750539720 10090893.4429495409131050,
3127767.3070504586212337 10090849.1966011244803667,
3127711.5533988750539720 10090820.7886967416852713,
3127649.7500000000000000 10090811.0000000000000000,
3127587.9466011249460280 10090820.7886967416852713,
3127532.1929495413787663 10090849.1966011244803667,
3127487.9466011249460280 10090893.4429495409131050,
3127459.5386967407539487 10090949.1966011244803667,
3127449.7500000000000000 10091011.0000000000000000,
3127459.5386967407539487 10091072.8033988755196333,
3127487.9466011249460280 10091128.5570504590868950,
3127532.1929495413787663 10091172.8033988755196333,
3127587.9466011249460280 10091201.2113032583147287,
3127649.7500000000000000 10091211.0000000000000000,
3127711.5533988750539720 10091201.2113032583147287,
3127767.3070504586212337 10091172.8033988755196333,
3127811.5533988750539720 10091128.5570504590868950,
3127839.9613032592460513 10091072.8033988755196333,
3127849.7500000000000000 10091011.0000000000000000)),
((3127815.7500000000000000 10078364.0000000000000000,
3127805.9613032592460513 10078302.1966011244803667,
3127777.5533988750539720 10078246.4429495409131050,
3127733.3070504586212337 10078202.1966011244803667,
3127677.5533988750539720 10078173.7886967416852713,
3127615.7500000000000000 10078164.0000000000000000,
3127553.9466011249460280 10078173.7886967416852713,
3127498.1929495413787663 10078202.1966011244803667,
3127453.9466011249460280 10078246.4429495409131050,
3127425.5386967407539487 10078302.1966011244803667,
3127415.7500000000000000 10078364.0000000000000000,
3127425.5386967407539487 10078425.8033988755196333,
3127453.9466011249460280 10078481.5570504590868950,
3127498.1929495413787663 10078525.8033988755196333,
3127553.9466011249460280 10078554.2113032583147287,
3127615.7500000000000000 10078564.0000000000000000,
3127677.5533988750539720 10078554.2113032583147287,
3127733.3070504586212337 10078525.8033988755196333,
3127777.5533988750539720 10078481.5570504590868950,
3127805.9613032592460513 10078425.8033988755196333,
3127815.7500000000000000 10078364.0000000000000000)),
((3127168.3778342278674245 10096621.4947336185723543,
3127158.7341544735245407 10096640.4215208161622286,
3127148.9454577327705920 10096702.2249196916818619,
3127158.7341544735245407 10096764.0283185672014952,
3127187.1420588577166200 10096819.7819701507687569,
3127231.3884072741493583 10096864.0283185672014952,
3127287.1420588577166200 10096892.4362229499965906,
3127348.9454577327705920 10096902.2249196916818619,
3127410.7488566078245640 10096892.4362229499965906,
3127466.5025081913918257 10096864.0283185672014952,
3127510.7488566078245640 10096819.7819701507687569,
3127539.1567609920166433 10096764.0283185672014952,
3127548.9454577327705920 10096702.2249196916818619,
3127539.1567609920166433 10096640.4215208161622286,
3127510.7488566078245640 10096584.6678692325949669,
3127466.5025081913918257 10096540.4215208161622286,
3127410.7488566078245640 10096512.0136164333671331,
3127385.0842595351859927 10096507.9487435892224312,
3127394.7279392895288765 10096489.0219563916325569,
3127404.5166360302828252 10096427.2185575161129236,
3127394.7279392895288765 10096365.4151586405932903,
3127366.3200349053367972 10096309.6615070570260286,
3127322.0736864889040589 10096265.4151586405932903,
3127266.3200349053367972 10096237.0072542577981949,
3127204.5166360302828252 10096227.2185575161129236,
3127142.7132371552288532 10096237.0072542577981949,
3127086.9595855716615915 10096265.4151586405932903,
3127042.7132371552288532 10096309.6615070570260286,
3127014.3053327710367739 10096365.4151586405932903,
3127004.5166360302828252 10096427.2185575161129236,
3127014.3053327710367739 10096489.0219563916325569,
3127042.7132371552288532 10096544.7756079751998186,
3127086.9595855716615915 10096589.0219563916325569,
3127142.7132371552288532 10096617.4298607744276524,
3127168.3778342278674245 10096621.4947336185723543)),
((3127033.3846382289193571 10078327.4382845386862755,
3127021.7886967407539487 10078350.1966011244803667,
3127012.0000000000000000 10078412.0000000000000000,
3127021.7886967407539487 10078473.8033988755196333,
3127050.1966011249460280 10078529.5570504590868950,
3127094.4429495413787663 10078573.8033988755196333,
3127150.1966011249460280 10078602.2113032583147287,
3127212.0000000000000000 10078612.0000000000000000,
3127273.8033988750539720 10078602.2113032583147287,
3127329.5570504586212337 10078573.8033988755196333,
3127373.8033988750539720 10078529.5570504590868950,
3127402.2113032592460513 10078473.8033988755196333,
3127412.0000000000000000 10078412.0000000000000000,
3127402.2113032592460513 10078350.1966011244803667,
3127377.8143849014304578 10078302.3149528540670872,
3127389.4103263895958662 10078279.5566362682729959,
3127399.1990231303498149 10078217.7532373927533627,
3127389.4103263895958662 10078155.9498385172337294,
3127361.0024220054037869 10078100.1961869336664677,
3127316.7560735889710486 10078055.9498385172337294,
3127261.0024220054037869 10078027.5419341344386339,
3127199.1990231303498149 10078017.7532373927533627,
3127137.3956242552958429 10078027.5419341344386339,
3127081.6419726717285812 10078055.9498385172337294,
3127037.3956242552958429 10078100.1961869336664677,
3127008.9877198711037636 10078155.9498385172337294,
3126999.1990231303498149 10078217.7532373927533627,
3127008.9877198711037636 10078279.5566362682729959,
3127033.3846382289193571 10078327.4382845386862755)),
((3126545.6749690365977585 10097505.6390845030546188,
3126538.6929495413787663 10097509.1966011244803667,
3126494.4466011249460280 10097553.4429495409131050,
3126466.0386967407539487 10097609.1966011244803667,
3126456.2500000000000000 10097671.0000000000000000,
3126466.0386967407539487 10097732.8033988755196333,
3126494.4466011249460280 10097788.5570504590868950,
3126538.6929495413787663 10097832.8033988755196333,
3126594.4466011249460280 10097861.2113032583147287,
3126656.2500000000000000 10097871.0000000000000000,
3126718.0533988750539720 10097861.2113032583147287,
3126773.8070504586212337 10097832.8033988755196333,
3126818.0533988750539720 10097788.5570504590868950,
3126846.4613032592460513 10097732.8033988755196333,
3126856.2500000000000000 10097671.0000000000000000,
3126846.4613032592460513 10097609.1966011244803667,
3126845.3125646901316941 10097606.9420747403055429,
3126852.2945841853506863 10097603.3845581188797951,
3126896.5409326017834246 10097559.1382097024470568,
3126924.9488369859755039 10097503.3845581188797951,
3126934.7375337267294526 10097441.5811592433601618,
3126924.9488369859755039 10097379.7777603678405285,
3126896.5409326017834246 10097324.0241087842732668,
3126852.2945841853506863 10097279.7777603678405285,
3126796.5409326017834246 10097251.3698559850454330,
3126734.7375337267294526 10097241.5811592433601618,
3126672.9341348516754806 10097251.3698559850454330,
3126617.1804832681082189 10097279.7777603678405285,
3126572.9341348516754806 10097324.0241087842732668,
3126544.5262304674834013 10097379.7777603678405285,
3126534.7375337267294526 10097441.5811592433601618,
3126544.5262304674834013 10097503.3845581188797951,
3126545.6749690365977585 10097505.6390845030546188)),
((3126627.2500000000000000 10091559.0000000000000000,
3126617.4613032592460513 10091497.1966011244803667,
3126589.0533988750539720 10091441.4429495409131050,
3126544.8070504586212337 10091397.1966011244803667,
3126489.0533988750539720 10091368.7886967416852713,
3126427.2500000000000000 10091359.0000000000000000,
3126365.4466011249460280 10091368.7886967416852713,
3126309.6929495413787663 10091397.1966011244803667,
3126265.4466011249460280 10091441.4429495409131050,
3126237.0386967407539487 10091497.1966011244803667,
3126227.2500000000000000 10091559.0000000000000000,
3126237.0386967407539487 10091620.8033988755196333,
3126265.4466011249460280 10091676.5570504590868950,
3126309.6929495413787663 10091720.8033988755196333,
3126365.4466011249460280 10091749.2113032583147287,
3126427.2500000000000000 10091759.0000000000000000,
3126489.0533988750539720 10091749.2113032583147287,
3126544.8070504586212337 10091720.8033988755196333,
3126589.0533988750539720 10091676.5570504590868950,
3126617.4613032592460513 10091620.8033988755196333,
3126627.2500000000000000 10091559.0000000000000000)),
((3126357.5000000000000000 10085181.0000000000000000,
3126347.7113032592460513 10085119.1966011244803667,
3126319.3033988750539720 10085063.4429495409131050,
3126275.0570504586212337 10085019.1966011244803667,
3126219.3033988750539720 10084990.7886967416852713,
3126157.5000000000000000 10084981.0000000000000000,
3126095.6966011249460280 10084990.7886967416852713,
3126039.9429495413787663 10085019.1966011244803667,
3125995.6966011249460280 10085063.4429495409131050,
3125967.2886967407539487 10085119.1966011244803667,
3125957.5000000000000000 10085181.0000000000000000,
3125967.2886967407539487 10085242.8033988755196333,
3125995.6966011249460280 10085298.5570504590868950,
3126039.9429495413787663 10085342.8033988755196333,
3126095.6966011249460280 10085371.2113032583147287,
3126157.5000000000000000 10085381.0000000000000000,
3126219.3033988750539720 10085371.2113032583147287,
3126275.0570504586212337 10085342.8033988755196333,
3126319.3033988750539720 10085298.5570504590868950,
3126347.7113032592460513 10085242.8033988755196333,
3126357.5000000000000000 10085181.0000000000000000)),
((3126321.5000000000000000 10096852.0000000000000000,
3126311.7113032592460513 10096790.1966011244803667,
3126283.3033988750539720 10096734.4429495409131050,
3126239.0570504586212337 10096690.1966011244803667,
3126183.3033988750539720 10096661.7886967416852713,
3126121.5000000000000000 10096652.0000000000000000,
3126059.6966011249460280 10096661.7886967416852713,
3126003.9429495413787663 10096690.1966011244803667,
3125959.6966011249460280 10096734.4429495409131050,
3125931.2886967407539487 10096790.1966011244803667,
3125921.5000000000000000 10096852.0000000000000000,
3125931.2886967407539487 10096913.8033988755196333,
3125959.6966011249460280 10096969.5570504590868950,
3126003.9429495413787663 10097013.8033988755196333,
3126059.6966011249460280 10097042.2113032583147287,
3126121.5000000000000000 10097052.0000000000000000,
3126183.3033988750539720 10097042.2113032583147287,
3126239.0570504586212337 10097013.8033988755196333,
3126283.3033988750539720 10096969.5570504590868950,
3126311.7113032592460513 10096913.8033988755196333,
3126321.5000000000000000 10096852.0000000000000000)),
((3125744.7929619303904474 10091953.4829814359545708,
3125689.2919652964919806 10091925.2038111798465252,
3125627.4885664214380085 10091915.4151144381612539,
3125565.6851675463840365 10091925.2038111798465252,
3125509.9315159628167748 10091953.6117155626416206,
3125465.6851675463840365 10091997.8580639790743589,
3125437.2772631621919572 10092053.6117155626416206,
3125427.4885664214380085 10092115.4151144381612539,
3125437.2772631621919572 10092177.2185133136808872,
3125465.6851675463840365 10092232.9721648972481489,
3125509.9315159628167748 10092277.2185133136808872,
3125565.6851675463840365 10092305.6264176964759827,
3125627.4885664214380085 10092315.4151144381612539,
3125689.2919652964919806 10092305.6264176964759827,
3125745.0456168800592422 10092277.2185133136808872,
3125789.2919652964919806 10092232.9721648972481489,
3125791.0153631931170821 10092229.5898060798645020,
3125846.5163598270155489 10092257.8689763359725475,
3125908.3197587020695210 10092267.6576730776578188,
3125970.1231575771234930 10092257.8689763359725475,
3126025.8768091606907547 10092229.4610719531774521,
3126070.1231575771234930 10092185.2147235367447138,
3126098.5310619613155723 10092129.4610719531774521,
3126108.3197587020695210 10092067.6576730776578188,
3126098.5310619613155723 10092005.8542742021381855,
3126070.1231575771234930 10091950.1006226185709238,
3126025.8768091606907547 10091905.8542742021381855,
3125970.1231575771234930 10091877.4463698193430901,
3125908.3197587020695210 10091867.6576730776578188,
3125846.5163598270155489 10091877.4463698193430901,
3125790.7627082434482872 10091905.8542742021381855,
3125746.5163598270155489 10091950.1006226185709238,
3125744.7929619303904474 10091953.4829814359545708)),
((3125978.5000000000000000 10091257.0000000000000000,
3125968.7113032592460513 10091195.1966011244803667,
3125940.3033988750539720 10091139.4429495409131050,
3125896.0570504586212337 10091095.1966011244803667,
3125840.3033988750539720 10091066.7886967416852713,
3125778.5000000000000000 10091057.0000000000000000,
3125716.6966011249460280 10091066.7886967416852713,
3125660.9429495413787663 10091095.1966011244803667,
3125616.6966011249460280 10091139.4429495409131050,
3125588.2886967407539487 10091195.1966011244803667,
3125578.5000000000000000 10091257.0000000000000000,
3125588.2886967407539487 10091318.8033988755196333,
3125616.6966011249460280 10091374.5570504590868950,
3125660.9429495413787663 10091418.8033988755196333,
3125716.6966011249460280 10091447.2113032583147287,
3125778.5000000000000000 10091457.0000000000000000,
3125840.3033988750539720 10091447.2113032583147287,
3125896.0570504586212337 10091418.8033988755196333,
3125940.3033988750539720 10091374.5570504590868950,
3125968.7113032592460513 10091318.8033988755196333,
3125978.5000000000000000 10091257.0000000000000000)),
((3125566.3644968769513071 10096010.9987329095602036,
3125569.1966011249460280 10096016.5570504590868950,
3125613.4429495413787663 10096060.8033988755196333,
3125669.1966011249460280 10096089.2113032583147287,
3125731.0000000000000000 10096099.0000000000000000,
3125792.8033988750539720 10096089.2113032583147287,
3125848.5570504586212337 10096060.8033988755196333,
3125892.8033988750539720 10096016.5570504590868950,
3125921.2113032592460513 10095960.8033988755196333,
3125931.0000000000000000 10095899.0000000000000000,
3125921.2113032592460513 10095837.1966011244803667,
3125892.8033988750539720 10095781.4429495409131050,
3125848.5570504586212337 10095737.1966011244803667,
3125792.8033988750539720 10095708.7886967416852713,
3125743.6355031230486929 10095701.0012670904397964,
3125740.8033988750539720 10095695.4429495409131050,
3125696.5570504586212337 10095651.1966011244803667,
3125640.8033988750539720 10095622.7886967416852713,
3125579.0000000000000000 10095613.0000000000000000,
3125517.1966011249460280 10095622.7886967416852713,
3125461.4429495413787663 10095651.1966011244803667,
3125417.1966011249460280 10095695.4429495409131050,
3125388.7886967407539487 10095751.1966011244803667,
3125379.0000000000000000 10095813.0000000000000000,
3125388.7886967407539487 10095874.8033988755196333,
3125417.1966011249460280 10095930.5570504590868950,
3125461.4429495413787663 10095974.8033988755196333,
3125517.1966011249460280 10096003.2113032583147287,
3125566.3644968769513071 10096010.9987329095602036)),
((3125759.2500000000000000 10078466.0000000000000000,
3125749.4613032592460513 10078404.1966011244803667,
3125721.0533988750539720 10078348.4429495409131050,
3125676.8070504586212337 10078304.1966011244803667,
3125621.0533988750539720 10078275.7886967416852713,
3125559.2500000000000000 10078266.0000000000000000,
3125497.4466011249460280 10078275.7886967416852713,
3125441.6929495413787663 10078304.1966011244803667,
3125397.4466011249460280 10078348.4429495409131050,
3125369.0386967407539487 10078404.1966011244803667,
3125359.2500000000000000 10078466.0000000000000000,
3125369.0386967407539487 10078527.8033988755196333,
3125397.4466011249460280 10078583.5570504590868950,
3125441.6929495413787663 10078627.8033988755196333,
3125497.4466011249460280 10078656.2113032583147287,
3125559.2500000000000000 10078666.0000000000000000,
3125621.0533988750539720 10078656.2113032583147287,
3125676.8070504586212337 10078627.8033988755196333,
3125721.0533988750539720 10078583.5570504590868950,
3125749.4613032592460513 10078527.8033988755196333,
3125759.2500000000000000 10078466.0000000000000000)),
((3124071.8329624687321484 10078708.1283756420016289,
3124023.6752885584719479 10078732.6659360863268375,
3123979.4289401420392096 10078776.9122845027595758,
3123951.0210357578471303 10078832.6659360863268375,
3123941.2323390170931816 10078894.4693349618464708,
3123951.0210357578471303 10078956.2727338373661041,
3123979.4289401420392096 10079012.0263854209333658,
3124023.6752885584719479 10079056.2727338373661041,
3124079.4289401420392096 10079084.6806382201611996,
3124141.2323390170931816 10079094.4693349618464708,
3124203.0357378921471536 10079084.6806382201611996,
3124258.7893894757144153 10079056.2727338373661041,
3124303.0357378921471536 10079012.0263854209333658,
3124331.4436422763392329 10078956.2727338373661041,
3124341.2323390170931816 10078894.4693349618464708,
3124339.2268648589961231 10078881.8072694595903158,
3124349.3033988750539720 10078880.2113032583147287,
3124405.0570504586212337 10078851.8033988755196333,
3124439.9393441416323185 10078816.9211051929742098,
3124444.0386967407539487 10078842.8033988755196333,
3124468.6687016207724810 10078891.1425052024424076,
3124449.7886967407539487 10078928.1966011244803667,
3124440.0000000000000000 10078990.0000000000000000,
3124449.7886967407539487 10079051.8033988755196333,
3124467.6943427752703428 10079086.9452078901231289,
3124465.1966011249460280 10079089.4429495409131050,
3124436.7886967407539487 10079145.1966011244803667,
3124427.0000000000000000 10079207.0000000000000000,
3124436.7886967407539487 10079268.8033988755196333,
3124465.1966011249460280 10079324.5570504590868950,
3124500.5145506658591330 10079359.8750000000000000,
3124478.9466011249460280 10079381.4429495409131050,
3124450.5386967407539487 10079437.1966011244803667,
3124441.2459202934987843 10079495.8688824959099293,
3124385.2500000000000000 10079487.0000000000000000,
3124323.4466011249460280 10079496.7886967416852713,
3124267.6929495413787663 10079525.1966011244803667,
3124223.4466011249460280 10079569.4429495409131050,
3124195.0386967407539487 10079625.1966011244803667,
3124188.7423885641619563 10079664.9499264117330313,
3124183.4466011249460280 10079665.7886967416852713,
3124127.6929495413787663 10079694.1966011244803667,
3124083.4466011249460280 10079738.4429495409131050,
3124055.0386967407539487 10079794.1966011244803667,
3124045.2500000000000000 10079856.0000000000000000,
3124055.0386967407539487 10079917.8033988755196333,
3124083.4466011249460280 10079973.5570504590868950,
3124127.6929495413787663 10080017.8033988755196333,
3124161.0051270406693220 10080034.7768010888248682,
3124146.4429495413787663 10080042.1966011244803667,
3124102.1966011249460280 10080086.4429495409131050,
3124073.7886967407539487 10080142.1966011244803667,
3124064.0000000000000000 10080204.0000000000000000,
3124073.7886967407539487 10080265.8033988755196333,
3124102.1966011249460280 10080321.5570504590868950,
3124107.7724122097715735 10080327.1328615434467793,
3124102.2500000000000000 10080362.0000000000000000,
3124112.0386967407539487 10080423.8033988755196333,
3124140.4466011249460280 10080479.5570504590868950,
3124184.6929495413787663 10080523.8033988755196333,
3124240.4466011249460280 10080552.2113032583147287,
3124302.2500000000000000 10080562.0000000000000000,
3124364.0533988750539720 10080552.2113032583147287,
3124419.8070504586212337 10080523.8033988755196333,
3124464.0533988750539720 10080479.5570504590868950,
3124492.4613032592460513 10080423.8033988755196333,
3124498.1353369075804949 10080387.9789603333920240,
3124512.6966011249460280 10080416.5570504590868950,
3124525.4904885729774833 10080429.3509379066526890,
3124517.9429495413787663 10080433.1966011244803667,
3124473.6966011249460280 10080477.4429495409131050,
3124445.2886967407539487 10080533.1966011244803667,
3124435.5000000000000000 10080595.0000000000000000,
3124445.2886967407539487 10080656.8033988755196333,
3124473.6966011249460280 10080712.5570504590868950,
3124517.9429495413787663 10080756.8033988755196333,
3124573.6966011249460280 10080785.2113032583147287,
3124635.5000000000000000 10080795.0000000000000000,
3124697.3033988750539720 10080785.2113032583147287,
3124753.0570504586212337 10080756.8033988755196333,
3124797.3033988750539720 10080712.5570504590868950,
3124825.7113032592460513 10080656.8033988755196333,
3124835.5000000000000000 10080595.0000000000000000,
3124825.7113032592460513 10080533.1966011244803667,
3124797.3033988750539720 10080477.4429495409131050,
3124784.5095114270225167 10080464.6490620933473110,
3124792.0570504586212337 10080460.8033988755196333,
3124836.3033988750539720 10080416.5570504590868950,
3124864.7113032592460513 10080360.8033988755196333,
3124874.5000000000000000 10080299.0000000000000000,
3124864.7113032592460513 10080237.1966011244803667,
3124836.3033988750539720 10080181.4429495409131050,
3124792.0570504586212337 10080137.1966011244803667,
3124736.3033988750539720 10080108.7886967416852713,
3124689.4252832117490470 10080101.3639326281845570,
3124690.7500000000000000 10080093.0000000000000000,
3124680.9613032592460513 10080031.1966011244803667,
3124657.6159091917797923 10079985.3786854725331068,
3124655.2113032592460513 10079970.1966011244803667,
3124626.8033988750539720 10079914.4429495409131050,
3124582.5570504586212337 10079870.1966011244803667,
3124526.8033988750539720 10079841.7886967416852713,
3124512.1436316240578890 10079839.4668177105486393,
3124547.0533988750539720 10079804.5570504590868950,
3124575.4613032592460513 10079748.8033988755196333,
3124575.5613403306342661 10079748.1717896647751331,
3124586.1929495413787663 10079758.8033988755196333,
3124641.9466011249460280 10079787.2113032583147287,
3124643.0024902792647481 10079787.3785396702587605,
3124650.0386967407539487 10079831.8033988755196333,
3124678.4466011249460280 10079887.5570504590868950,
3124679.4902380737476051 10079888.6006874088197947,
3124673.2500000000000000 10079928.0000000000000000,
3124683.0386967407539487 10079989.8033988755196333,
3124711.4466011249460280 10080045.5570504590868950,
3124755.6929495413787663 10080089.8033988755196333,
3124811.4466011249460280 10080118.2113032583147287,
3124873.2500000000000000 10080128.0000000000000000,
3124935.0533988750539720 10080118.2113032583147287,
3124990.8070504586212337 10080089.8033988755196333,
3125035.0533988750539720 10080045.5570504590868950,
3125063.4613032592460513 10079989.8033988755196333,
3125073.2500000000000000 10079928.0000000000000000,
3125063.4613032592460513 10079866.1966011244803667,
3125035.0533988750539720 10079810.4429495409131050,
3125034.0097619262523949 10079809.3993125911802053,
3125039.6633377000689507 10079773.7040399853140116,
3125061.0570504586212337 10079762.8033988755196333,
3125105.3033988750539720 10079718.5570504590868950,
3125133.7113032592460513 10079662.8033988755196333,
3125143.5000000000000000 10079601.0000000000000000,
3125133.7113032592460513 10079539.1966011244803667,
3125105.3033988750539720 10079483.4429495409131050,
3125101.8604493341408670 10079480.0000000000000000,
3125105.3033988750539720 10079476.5570504590868950,
3125133.7113032592460513 10079420.8033988755196333,
3125143.5000000000000000 10079359.0000000000000000,
3125133.7113032592460513 10079297.1966011244803667,
3125105.3033988750539720 10079241.4429495409131050,
3125089.7857000320218503 10079225.9252506978809834,
3125144.8033988750539720 10079217.2113032583147287,
3125200.5570504586212337 10079188.8033988755196333,
3125244.8033988750539720 10079144.5570504590868950,
3125273.2113032592460513 10079088.8033988755196333,
3125274.2774320123717189 10079082.0721268448978662,
3125314.0570504586212337 10079061.8033988755196333,
3125358.3033988750539720 10079017.5570504590868950,
3125377.5512208156287670 10078979.7810729108750820,
3125377.9466011249460280 10078980.5570504590868950,
3125422.1929495413787663 10079024.8033988755196333,
3125477.9466011249460280 10079053.2113032583147287,
3125539.7500000000000000 10079063.0000000000000000,
3125601.5533988750539720 10079053.2113032583147287,
3125657.3070504586212337 10079024.8033988755196333,
3125701.5533988750539720 10078980.5570504590868950,
3125729.9613032592460513 10078924.8033988755196333,
3125739.7500000000000000 10078863.0000000000000000,
3125729.9613032592460513 10078801.1966011244803667,
3125701.5533988750539720 10078745.4429495409131050,
3125657.3070504586212337 10078701.1966011244803667,
3125601.5533988750539720 10078672.7886967416852713,
3125539.7500000000000000 10078663.0000000000000000,
3125477.9466011249460280 10078672.7886967416852713,
3125422.1929495413787663 10078701.1966011244803667,
3125377.9466011249460280 10078745.4429495409131050,
3125358.6987791843712330 10078783.2189270891249180,
3125358.3033988750539720 10078782.4429495409131050,
3125314.0570504586212337 10078738.1966011244803667,
3125258.3033988750539720 10078709.7886967416852713,
3125196.5000000000000000 10078700.0000000000000000,
3125134.6966011249460280 10078709.7886967416852713,
3125078.9429495413787663 10078738.1966011244803667,
3125034.6966011249460280 10078782.4429495409131050,
3125006.2886967407539487 10078838.1966011244803667,
3125005.2225679876282811 10078844.9278731551021338,
3124965.4429495413787663 10078865.1966011244803667,
3124921.1966011249460280 10078909.4429495409131050,
3124892.7886967407539487 10078965.1966011244803667,
3124883.0000000000000000 10079027.0000000000000000,
3124892.7886967407539487 10079088.8033988755196333,
3124901.6142458040267229 10079106.1245141830295324,
3124869.5533988750539720 10079089.7886967416852713,
3124815.2399700493551791 10079081.1862947139889002,
3124830.2113032592460513 10079051.8033988755196333,
3124840.0000000000000000 10078990.0000000000000000,
3124830.2113032592460513 10078928.1966011244803667,
3124805.5812983792275190 10078879.8574947975575924,
3124824.4613032592460513 10078842.8033988755196333,
3124834.2500000000000000 10078781.0000000000000000,
3124824.4613032592460513 10078719.1966011244803667,
3124808.5944173969328403 10078688.0560842417180538,
3124821.4613032592460513 10078662.8033988755196333,
3124831.2500000000000000 10078601.0000000000000000,
3124821.4613032592460513 10078539.1966011244803667,
3124802.5210256380960345 10078502.0242132879793644,
3124850.0570504586212337 10078477.8033988755196333,
3124894.3033988750539720 10078433.5570504590868950,
3124922.7113032592460513 10078377.8033988755196333,
3124932.5000000000000000 10078316.0000000000000000,
3124922.7113032592460513 10078254.1966011244803667,
3124896.5967355137690902 10078202.9438761211931705,
3124895.2113032592460513 10078194.1966011244803667,
3124866.8033988750539720 10078138.4429495409131050,
3124822.5570504586212337 10078094.1966011244803667,
3124766.8033988750539720 10078065.7886967416852713,
3124705.0000000000000000 10078056.0000000000000000,
3124643.1966011249460280 10078065.7886967416852713,
3124620.0876814844086766 10078077.5632794089615345,
3124614.9613032592460513 10078045.1966011244803667,
3124586.5533988750539720 10077989.4429495409131050,
3124542.3070504586212337 10077945.1966011244803667,
3124486.5533988750539720 10077916.7886967416852713,
3124424.7500000000000000 10077907.0000000000000000,
3124362.9466011249460280 10077916.7886967416852713,
3124307.1929495413787663 10077945.1966011244803667,
3124262.9466011249460280 10077989.4429495409131050,
3124234.5386967407539487 10078045.1966011244803667,
3124224.7500000000000000 10078107.0000000000000000,
3124234.5386967407539487 10078168.8033988755196333,
3124262.9466011249460280 10078224.5570504590868950,
3124307.1929495413787663 10078268.8033988755196333,
3124342.6990427994169295 10078286.8946570008993149,
3124324.4429495413787663 10078296.1966011244803667,
3124280.1966011249460280 10078340.4429495409131050,
3124267.7436640341766179 10078364.8832146991044283,
3124267.0570504586212337 10078364.1966011244803667,
3124211.3033988750539720 10078335.7886967416852713,
3124149.5000000000000000 10078326.0000000000000000,
3124087.6966011249460280 10078335.7886967416852713,
3124031.9429495413787663 10078364.1966011244803667,
3123987.6966011249460280 10078408.4429495409131050,
3123959.2886967407539487 10078464.1966011244803667,
3123949.5000000000000000 10078526.0000000000000000,
3123959.2886967407539487 10078587.8033988755196333,
3123987.6966011249460280 10078643.5570504590868950,
3124031.9429495413787663 10078687.8033988755196333,
3124071.8329624687321484 10078708.1283756420016289)),
((3124013.1178170037455857 10095678.7717336621135473,
3123993.4466011249460280 10095698.4429495409131050,
3123965.0386967407539487 10095754.1966011244803667,
3123955.2500000000000000 10095816.0000000000000000,
3123965.0386967407539487 10095877.8033988755196333,
3123993.4466011249460280 10095933.5570504590868950,
3124037.6929495413787663 10095977.8033988755196333,
3124093.4466011249460280 10096006.2113032583147287,
3124104.0058298720978200 10096007.8837207946926355,
3124081.4466011249460280 10096030.4429495409131050,
3124053.0386967407539487 10096086.1966011244803667,
3124043.2500000000000000 10096148.0000000000000000,
3124053.0386967407539487 10096209.8033988755196333,
3124081.4466011249460280 10096265.5570504590868950,
3124125.6929495413787663 10096309.8033988755196333,
3124136.1749963792972267 10096315.1442685015499592,
3124139.2886967407539487 10096334.8033988755196333,
3124167.6966011249460280 10096390.5570504590868950,
3124211.9429495413787663 10096434.8033988755196333,
3124243.3902225340716541 10096450.8265847824513912,
3124249.6533728563226759 10096490.3705596160143614,
3124241.0000000000000000 10096489.0000000000000000,
3124179.1966011249460280 10096498.7886967416852713,
3124123.4429495413787663 10096527.1966011244803667,
3124079.1966011249460280 10096571.4429495409131050,
3124050.7886967407539487 10096627.1966011244803667,
3124041.0000000000000000 10096689.0000000000000000,
3124050.7886967407539487 10096750.8033988755196333,
3124079.1966011249460280 10096806.5570504590868950,
3124096.6571328979916871 10096824.0175822321325541,
3124091.7500000000000000 10096855.0000000000000000,
3124101.5386967407539487 10096916.8033988755196333,
3124129.9466011249460280 10096972.5570504590868950,
3124139.6001777141354978 10096982.2106270473450422,
3124139.0000000000000000 10096986.0000000000000000,
3124148.7886967407539487 10097047.8033988755196333,
3124177.1966011249460280 10097103.5570504590868950,
3124211.8944001379422843 10097138.2548494730144739,
3124207.5000000000000000 10097166.0000000000000000,
3124210.2878374899737537 10097183.6017131749540567,
3124185.4466011249460280 10097208.4429495409131050,
3124157.0386967407539487 10097264.1966011244803667,
3124149.1029839655384421 10097314.3007196802645922,
3124115.9429495413787663 10097331.1966011244803667,
3124071.6966011249460280 10097375.4429495409131050,
3124043.2886967407539487 10097431.1966011244803667,
3124033.5000000000000000 10097493.0000000000000000,
3124043.2886967407539487 10097554.8033988755196333,
3124071.6966011249460280 10097610.5570504590868950,
3124115.9429495413787663 10097654.8033988755196333,
3124171.6966011249460280 10097683.2113032583147287,
3124204.3083638576790690 10097688.3764990475028753,
3124200.2500000000000000 10097714.0000000000000000,
3124207.5840679616667330 10097760.3054827041924000,
3124199.4466011249460280 10097768.4429495409131050,
3124171.0386967407539487 10097824.1966011244803667,
3124161.2500000000000000 10097886.0000000000000000,
3124166.5331369219347835 10097919.3564137443900108,
3124125.4466011249460280 10097960.4429495409131050,
3124097.0386967407539487 10098016.1966011244803667,
3124087.2500000000000000 10098078.0000000000000000,
3124093.2509627859108150 10098115.8885878808796406,
3124080.6966011249460280 10098128.4429495409131050,
3124052.2886967407539487 10098184.1966011244803667,
3124042.5000000000000000 10098246.0000000000000000,
3124052.2886967407539487 10098307.8033988755196333,
3124080.6966011249460280 10098363.5570504590868950,
3124124.9429495413787663 10098407.8033988755196333,
3124180.6966011249460280 10098436.2113032583147287,
3124242.5000000000000000 10098446.0000000000000000,
3124304.3033988750539720 10098436.2113032583147287,
3124360.0570504586212337 10098407.8033988755196333,
3124404.3033988750539720 10098363.5570504590868950,
3124432.7113032592460513 10098307.8033988755196333,
3124442.5000000000000000 10098246.0000000000000000,
3124436.4990372140891850 10098208.1114121191203594,
3124449.0533988750539720 10098195.5570504590868950,
3124477.4613032592460513 10098139.8033988755196333,
3124484.1157186529599130 10098097.7890736013650894,
3124524.1966011249460280 10098118.2113032583147287,
3124586.0000000000000000 10098128.0000000000000000,
3124647.8033988750539720 10098118.2113032583147287,
3124703.5570504586212337 10098089.8033988755196333,
3124720.0000000000000000 10098073.3604493346065283,
3124740.5703653772361577 10098093.9308147113770247,
3124743.9466011249460280 10098100.5570504590868950,
3124788.1929495413787663 10098144.8033988755196333,
3124843.9466011249460280 10098173.2113032583147287,
3124905.7500000000000000 10098183.0000000000000000,
3124967.5533988750539720 10098173.2113032583147287,
3125023.3070504586212337 10098144.8033988755196333,
3125067.5533988750539720 10098100.5570504590868950,
3125095.9613032592460513 10098044.8033988755196333,
3125105.7500000000000000 10097983.0000000000000000,
3125095.9613032592460513 10097921.1966011244803667,
3125067.5533988750539720 10097865.4429495409131050,
3125033.1796346227638423 10097831.0691852886229753,
3125029.8033988750539720 10097824.4429495409131050,
3124985.5570504586212337 10097780.1966011244803667,
3124929.8033988750539720 10097751.7886967416852713,
3124868.0000000000000000 10097742.0000000000000000,
3124806.1966011249460280 10097751.7886967416852713,
3124750.4429495413787663 10097780.1966011244803667,
3124734.0000000000000000 10097796.6395506653934717,
3124703.5570504586212337 10097766.1966011244803667,
3124647.8033988750539720 10097737.7886967416852713,
3124597.7381587182171643 10097729.8591416999697685,
3124600.2500000000000000 10097714.0000000000000000,
3124590.4613032592460513 10097652.1966011244803667,
3124562.0533988750539720 10097596.4429495409131050,
3124547.7272145696915686 10097582.1167652364820242,
3124597.5000000000000000 10097590.0000000000000000,
3124659.3033988750539720 10097580.2113032583147287,
3124715.0570504586212337 10097551.8033988755196333,
3124759.3033988750539720 10097507.5570504590868950,
3124782.3345598890446126 10097462.3558518998324871,
3124782.9466011249460280 10097463.5570504590868950,
3124827.1929495413787663 10097507.8033988755196333,
3124882.9466011249460280 10097536.2113032583147287,
3124944.7500000000000000 10097546.0000000000000000,
3125006.5533988750539720 10097536.2113032583147287,
3125062.3070504586212337 10097507.8033988755196333,
3125106.5533988750539720 10097463.5570504590868950,
3125121.6602533929981291 10097433.9081790763884783,
3125172.7500000000000000 10097442.0000000000000000,
3125234.5533988750539720 10097432.2113032583147287,
3125236.2409855602309108 10097431.3514348939061165,
3125278.6929495413787663 10097473.8033988755196333,
3125334.4466011249460280 10097502.2113032583147287,
3125396.2500000000000000 10097512.0000000000000000,
3125458.0533988750539720 10097502.2113032583147287,
3125513.8070504586212337 10097473.8033988755196333,
3125516.5601922431960702 10097471.0502570904791355,
3125566.0533988750539720 10097463.2113032583147287,
3125621.8070504586212337 10097434.8033988755196333,
3125666.0533988750539720 10097390.5570504590868950,
3125694.4613032592460513 10097334.8033988755196333,
3125704.2500000000000000 10097273.0000000000000000,
3125694.4613032592460513 10097211.1966011244803667,
3125666.0533988750539720 10097155.4429495409131050,
3125621.8070504586212337 10097111.1966011244803667,
3125566.0533988750539720 10097082.7886967416852713,
3125504.2500000000000000 10097073.0000000000000000,
3125442.4466011249460280 10097082.7886967416852713,
3125386.6929495413787663 10097111.1966011244803667,
3125383.9398077568039298 10097113.9497429095208645,
3125351.5270261508412659 10097119.0834231842309237,
3125389.0533988750539720 10097081.5570504590868950,
3125417.4613032592460513 10097025.8033988755196333,
3125427.2500000000000000 10096964.0000000000000000,
3125417.4613032592460513 10096902.1966011244803667,
3125389.0533988750539720 10096846.4429495409131050,
3125344.8070504586212337 10096802.1966011244803667,
3125289.0533988750539720 10096773.7886967416852713,
3125287.2333753742277622 10096773.5004333388060331,
3125285.8803252591751516 10096764.9576111249625683,
3125257.4724208749830723 10096709.2039595413953066,
3125213.2260724585503340 10096664.9576111249625683,
3125177.0734959859400988 10096646.5369533486664295,
3125198.0533988750539720 10096625.5570504590868950,
3125226.4613032592460513 10096569.8033988755196333,
3125236.2500000000000000 10096508.0000000000000000,
3125226.4613032592460513 10096446.1966011244803667,
3125198.0533988750539720 10096390.4429495409131050,
3125153.8070504586212337 10096346.1966011244803667,
3125098.0533988750539720 10096317.7886967416852713,
3125036.2500000000000000 10096308.0000000000000000,
3124974.4466011249460280 10096317.7886967416852713,
3124918.6929495413787663 10096346.1966011244803667,
3124915.2500000000000000 10096349.6395506653934717,
3124883.8070504586212337 10096318.1966011244803667,
3124828.0533988750539720 10096289.7886967416852713,
3124766.2500000000000000 10096280.0000000000000000,
3124735.1957758292555809 10096284.9185059145092964,
3124713.5533988750539720 10096242.4429495409131050,
3124669.3070504586212337 10096198.1966011244803667,
3124613.5533988750539720 10096169.7886967416852713,
3124578.0070611163973808 10096164.1587099302560091,
3124625.8070504586212337 10096139.8033988755196333,
3124670.0533988750539720 10096095.5570504590868950,
3124698.4613032592460513 10096039.8033988755196333,
3124708.2500000000000000 10095978.0000000000000000,
3124698.4613032592460513 10095916.1966011244803667,
3124670.0533988750539720 10095860.4429495409131050,
3124625.8070504586212337 10095816.1966011244803667,
3124570.0533988750539720 10095787.7886967416852713,
3124520.8909587552770972 10095780.0021311771124601,
3124532.7113032592460513 10095756.8033988755196333,
3124542.5000000000000000 10095695.0000000000000000,
3124532.7113032592460513 10095633.1966011244803667,
3124526.1132523128762841 10095620.2471970207989216,
3124532.4743882860057056 10095613.8860610481351614,
3124568.3033988750539720 10095608.2113032583147287,
3124624.0570504586212337 10095579.8033988755196333,
3124668.3033988750539720 10095535.5570504590868950,
3124696.7113032592460513 10095479.8033988755196333,
3124706.5000000000000000 10095418.0000000000000000,
3124696.7113032592460513 10095356.1966011244803667,
3124668.3033988750539720 10095300.4429495409131050,
3124660.9299883740022779 10095293.0695390403270721,
3124663.0000000000000000 10095280.0000000000000000,
3124653.2113032592460513 10095218.1966011244803667,
3124624.8033988750539720 10095162.4429495409131050,
3124585.8307138555683196 10095123.4702645204961300,
3124615.9605916342698038 10095093.3403867427259684,
3124644.3684960184618831 10095037.5867351591587067,
3124654.1571927592158318 10094975.7833362836390734,
3124644.3684960184618831 10094913.9799374081194401,
3124615.9605916342698038 10094858.2262858245521784,
3124610.7714207405224442 10094853.0371149312704802,
3124604.4613032592460513 10094813.1966011244803667,
3124576.0533988750539720 10094757.4429495409131050,
3124531.8070504586212337 10094713.1966011244803667,
3124517.5596424136310816 10094705.9371841363608837,
3124518.5000000000000000 10094700.0000000000000000,
3124508.7113032592460513 10094638.1966011244803667,
3124493.2528233258053660 10094607.8576260078698397,
3124524.5533988750539720 10094576.5570504590868950,
3124552.9613032592460513 10094520.8033988755196333,
3124562.7500000000000000 10094459.0000000000000000,
3124552.9613032592460513 10094397.1966011244803667,
3124524.5533988750539720 10094341.4429495409131050,
3124480.3070504586212337 10094297.1966011244803667,
3124438.3976174718700349 10094275.8426784444600344,
3124445.5000000000000000 10094231.0000000000000000,
3124435.7113032592460513 10094169.1966011244803667,
3124418.3042908716015518 10094135.0334157422184944,
3124442.3070504586212337 10094122.8033988755196333,
3124486.5533988750539720 10094078.5570504590868950,
3124514.9613032592460513 10094022.8033988755196333,
3124524.7500000000000000 10093961.0000000000000000,
3124514.9613032592460513 10093899.1966011244803667,
3124486.5533988750539720 10093843.4429495409131050,
3124442.3070504586212337 10093799.1966011244803667,
3124386.5533988750539720 10093770.7886967416852713,
3124324.7500000000000000 10093761.0000000000000000,
3124262.9466011249460280 10093770.7886967416852713,
3124207.1929495413787663 10093799.1966011244803667,
3124162.9466011249460280 10093843.4429495409131050,
3124134.5386967407539487 10093899.1966011244803667,
3124124.7500000000000000 10093961.0000000000000000,
3124134.5386967407539487 10094022.8033988755196333,
3124151.9457091283984482 10094056.9665842577815056,
3124127.9429495413787663 10094069.1966011244803667,
3124083.6966011249460280 10094113.4429495409131050,
3124055.2886967407539487 10094169.1966011244803667,
3124054.3103532395325601 10094175.3736188858747482,
3124013.4429495413787663 10094196.1966011244803667,
3123969.1966011249460280 10094240.4429495409131050,
3123940.7886967407539487 10094296.1966011244803667,
3123931.0000000000000000 10094358.0000000000000000,
3123940.7886967407539487 10094419.8033988755196333,
3123969.1966011249460280 10094475.5570504590868950,
3124013.4429495413787663 10094519.8033988755196333,
3124063.0710913171060383 10094545.0902001205831766,
3124056.7500000000000000 10094585.0000000000000000,
3124066.5386967407539487 10094646.8033988755196333,
3124094.9466011249460280 10094702.5570504590868950,
3124123.4137505320832133 10094731.0241998657584190,
3124128.2886967407539487 10094761.8033988755196333,
3124156.6966011249460280 10094817.5570504590868950,
3124200.9429495413787663 10094861.8033988755196333,
3124215.1903575863689184 10094869.0628158636391163,
3124214.2500000000000000 10094875.0000000000000000,
3124215.5673367218114436 10094883.3173367213457823,
3124207.2500000000000000 10094882.0000000000000000,
3124145.4466011249460280 10094891.7886967416852713,
3124089.6929495413787663 10094920.1966011244803667,
3124045.4466011249460280 10094964.4429495409131050,
3124017.0386967407539487 10095020.1966011244803667,
3124007.2500000000000000 10095082.0000000000000000,
3124017.0386967407539487 10095143.8033988755196333,
3124045.4466011249460280 10095199.5570504590868950,
3124089.6929495413787663 10095243.8033988755196333,
3124145.4466011249460280 10095272.2113032583147287,
3124161.3852384644560516 10095274.7357354126870632,
3124169.4466011249460280 10095290.5570504590868950,
3124213.6929495413787663 10095334.8033988755196333,
3124239.6237493585795164 10095348.0158013068139553,
3124211.1966011249460280 10095376.4429495409131050,
3124195.3967460868880153 10095407.4519110247492790,
3124136.4466011249460280 10095416.7886967416852713,
3124080.6929495413787663 10095445.1966011244803667,
3124036.4466011249460280 10095489.4429495409131050,
3124008.0386967407539487 10095545.1966011244803667,
3123998.2500000000000000 10095607.0000000000000000,
3124008.0386967407539487 10095668.8033988755196333,
3124013.1178170037455857 10095678.7717336621135473),
(3124530.6842556223273277 10096933.4964563362300396,
3124564.0533988750539720 10096928.2113032583147287,
3124619.8070504586212337 10096899.8033988755196333,
3124664.0533988750539720 10096855.5570504590868950,
3124692.4613032592460513 10096799.8033988755196333,
3124702.2500000000000000 10096738.0000000000000000,
3124692.4613032592460513 10096676.1966011244803667,
3124684.1396209886297584 10096659.8643800765275955,
3124704.4466011249460280 10096670.2113032583147287,
3124766.2500000000000000 10096680.0000000000000000,
3124828.0533988750539720 10096670.2113032583147287,
3124883.8070504586212337 10096641.8033988755196333,
3124887.2500000000000000 10096638.3604493346065283,
3124918.6929495413787663 10096669.8033988755196333,
3124954.8455260139890015 10096688.2240566518157721,
3124947.3668481241911650 10096695.7027345411479473,
3124934.1966011249460280 10096697.7886967416852713,
3124878.4429495413787663 10096726.1966011244803667,
3124834.1966011249460280 10096770.4429495409131050,
3124805.7886967407539487 10096826.1966011244803667,
3124796.0000000000000000 10096888.0000000000000000,
3124805.7886967407539487 10096949.8033988755196333,
3124805.8235894739627838 10096949.8718797191977501,
3124768.7500000000000000 10096944.0000000000000000,
3124706.9466011249460280 10096953.7886967416852713,
3124651.1929495413787663 10096982.1966011244803667,
3124606.9466011249460280 10097026.4429495409131050,
3124582.5202200557105243 10097074.3824216388165951,
3124569.3033988750539720 10097048.4429495409131050,
3124534.6055998620577157 10097013.7451505269855261,
3124539.0000000000000000 10096986.0000000000000000,
3124530.6842556223273277 10096933.4964563362300396),
(3124433.7059594723396003 10097503.6501962393522263,
3124435.6966011249460280 10097507.5570504590868950,
3124450.0227854298427701 10097521.8832347635179758,
3124429.4416361427865922 10097518.6235009524971247,
3124431.6470160344615579 10097504.6992803197354078,
3124433.7059594723396003 10097503.6501962393522263)),
((3125670.0000000000000000 10096475.0000000000000000,
3125660.2113032592460513 10096413.1966011244803667,
3125631.8033988750539720 10096357.4429495409131050,
3125587.5570504586212337 10096313.1966011244803667,
3125531.8033988750539720 10096284.7886967416852713,
3125470.0000000000000000 10096275.0000000000000000,
3125408.1966011249460280 10096284.7886967416852713,
3125352.4429495413787663 10096313.1966011244803667,
3125308.1966011249460280 10096357.4429495409131050,
3125279.7886967407539487 10096413.1966011244803667,
3125270.0000000000000000 10096475.0000000000000000,
3125279.7886967407539487 10096536.8033988755196333,
3125308.1966011249460280 10096592.5570504590868950,
3125352.4429495413787663 10096636.8033988755196333,
3125408.1966011249460280 10096665.2113032583147287,
3125470.0000000000000000 10096675.0000000000000000,
3125531.8033988750539720 10096665.2113032583147287,
3125587.5570504586212337 10096636.8033988755196333,
3125631.8033988750539720 10096592.5570504590868950,
3125660.2113032592460513 10096536.8033988755196333,
3125670.0000000000000000 10096475.0000000000000000)),
((3125458.0000000000000000 10098506.0000000000000000,
3125448.2113032592460513 10098444.1966011244803667,
3125419.8033988750539720 10098388.4429495409131050,
3125375.5570504586212337 10098344.1966011244803667,
3125319.8033988750539720 10098315.7886967416852713,
3125258.0000000000000000 10098306.0000000000000000,
3125196.1966011249460280 10098315.7886967416852713,
3125140.4429495413787663 10098344.1966011244803667,
3125096.1966011249460280 10098388.4429495409131050,
3125067.7886967407539487 10098444.1966011244803667,
3125058.0000000000000000 10098506.0000000000000000,
3125067.7886967407539487 10098567.8033988755196333,
3125096.1966011249460280 10098623.5570504590868950,
3125140.4429495413787663 10098667.8033988755196333,
3125196.1966011249460280 10098696.2113032583147287,
3125258.0000000000000000 10098706.0000000000000000,
3125319.8033988750539720 10098696.2113032583147287,
3125375.5570504586212337 10098667.8033988755196333,
3125419.8033988750539720 10098623.5570504590868950,
3125448.2113032592460513 10098567.8033988755196333,
3125458.0000000000000000 10098506.0000000000000000)),
((3125404.7500000000000000 10080865.0000000000000000,
3125394.9613032592460513 10080803.1966011244803667,
3125366.5533988750539720 10080747.4429495409131050,
3125322.3070504586212337 10080703.1966011244803667,
3125266.5533988750539720 10080674.7886967416852713,
3125204.7500000000000000 10080665.0000000000000000,
3125142.9466011249460280 10080674.7886967416852713,
3125087.1929495413787663 10080703.1966011244803667,
3125042.9466011249460280 10080747.4429495409131050,
3125014.5386967407539487 10080803.1966011244803667,
3125004.7500000000000000 10080865.0000000000000000,
3125014.5386967407539487 10080926.8033988755196333,
3125042.9466011249460280 10080982.5570504590868950,
3125087.1929495413787663 10081026.8033988755196333,
3125142.9466011249460280 10081055.2113032583147287,
3125204.7500000000000000 10081065.0000000000000000,
3125266.5533988750539720 10081055.2113032583147287,
3125322.3070504586212337 10081026.8033988755196333,
3125366.5533988750539720 10080982.5570504590868950,
3125394.9613032592460513 10080926.8033988755196333,
3125404.7500000000000000 10080865.0000000000000000)),
((3124854.5201781522482634 10082086.3050167448818684,
3124877.4575720387510955 10082097.9922026749700308,
3124939.2609709138050675 10082107.7808994166553020,
3125001.0643697888590395 10082097.9922026749700308,
3125056.8180213724263012 10082069.5842982921749353,
3125101.0643697888590395 10082025.3379498757421970,
3125129.4722741730511189 10081969.5842982921749353,
3125139.2609709138050675 10081907.7808994166553020,
3125129.4722741730511189 10081845.9775005411356688,
3125101.0643697888590395 10081790.2238489575684071,
3125056.8180213724263012 10081745.9775005411356688,
3125001.0643697888590395 10081717.5695961583405733,
3124939.2609709138050675 10081707.7808994166553020,
3124877.4575720387510955 10081717.5695961583405733,
3124863.0956920166499913 10081724.8873395323753357,
3124840.1582981301471591 10081713.2001536022871733,
3124778.3548992550931871 10081703.4114568606019020,
3124716.5515003800392151 10081713.2001536022871733,
3124660.7978487964719534 10081741.6080579850822687,
3124616.5515003800392151 10081785.8544064015150070,
3124588.1435959958471358 10081841.6080579850822687,
3124578.3548992550931871 10081903.4114568606019020,
3124588.1435959958471358 10081965.2148557361215353,
3124616.5515003800392151 10082020.9685073196887970,
3124660.7978487964719534 10082065.2148557361215353,
3124716.5515003800392151 10082093.6227601189166307,
3124778.3548992550931871 10082103.4114568606019020,
3124840.1582981301471591 10082093.6227601189166307,
3124854.5201781522482634 10082086.3050167448818684)),
((3125086.7500000000000000 10089263.0000000000000000,
3125076.9613032592460513 10089201.1966011244803667,
3125048.5533988750539720 10089145.4429495409131050,
3125004.3070504586212337 10089101.1966011244803667,
3124948.5533988750539720 10089072.7886967416852713,
3124886.7500000000000000 10089063.0000000000000000,
3124824.9466011249460280 10089072.7886967416852713,
3124769.1929495413787663 10089101.1966011244803667,
3124724.9466011249460280 10089145.4429495409131050,
3124696.5386967407539487 10089201.1966011244803667,
3124686.7500000000000000 10089263.0000000000000000,
3124696.5386967407539487 10089324.8033988755196333,
3124724.9466011249460280 10089380.5570504590868950,
3124769.1929495413787663 10089424.8033988755196333,
3124824.9466011249460280 10089453.2113032583147287,
3124886.7500000000000000 10089463.0000000000000000,
3124948.5533988750539720 10089453.2113032583147287,
3125004.3070504586212337 10089424.8033988755196333,
3125048.5533988750539720 10089380.5570504590868950,
3125076.9613032592460513 10089324.8033988755196333,
3125086.7500000000000000 10089263.0000000000000000)),
((3124065.0145506658591330 10087338.8750000000000000,
3124030.4466011249460280 10087373.4429495409131050,
3124002.0386967407539487 10087429.1966011244803667,
3123992.2500000000000000 10087491.0000000000000000,
3124002.0386967407539487 10087552.8033988755196333,
3124030.4466011249460280 10087608.5570504590868950,
3124074.6929495413787663 10087652.8033988755196333,
3124130.4466011249460280 10087681.2113032583147287,
3124192.2500000000000000 10087691.0000000000000000,
3124215.2471585753373802 10087687.3576079104095697,
3124241.4174564681015909 10087713.5279058031737804,
3124249.5386967407539487 10087764.8033988755196333,
3124261.6217751554213464 10087788.5177755113691092,
3124240.6966011249460280 10087809.4429495409131050,
3124212.2886967407539487 10087865.1966011244803667,
3124202.5000000000000000 10087927.0000000000000000,
3124212.2886967407539487 10087988.8033988755196333,
3124240.6966011249460280 10088044.5570504590868950,
3124284.9429495413787663 10088088.8033988755196333,
3124320.7970870481804013 10088107.0719944033771753,
3124323.2886967407539487 10088122.8033988755196333,
3124351.6966011249460280 10088178.5570504590868950,
3124395.9429495413787663 10088222.8033988755196333,
3124451.6966011249460280 10088251.2113032583147287,
3124456.8729916857555509 10088252.0311629809439182,
3124456.7886967407539487 10088252.1966011244803667,
3124450.1406735377386212 10088294.1705676913261414,
3124442.7500000000000000 10088293.0000000000000000,
3124380.9466011249460280 10088302.7886967416852713,
3124325.1929495413787663 10088331.1966011244803667,
3124280.9466011249460280 10088375.4429495409131050,
3124252.5386967407539487 10088431.1966011244803667,
3124242.7500000000000000 10088493.0000000000000000,
3124244.8112476789392531 10088506.0142056550830603,
3124195.3033988750539720 10088480.7886967416852713,
3124133.5000000000000000 10088471.0000000000000000,
3124071.6966011249460280 10088480.7886967416852713,
3124015.9429495413787663 10088509.1966011244803667,
3123971.6966011249460280 10088553.4429495409131050,
3123943.2886967407539487 10088609.1966011244803667,
3123933.5000000000000000 10088671.0000000000000000,
3123943.2886967407539487 10088732.8033988755196333,
3123971.6966011249460280 10088788.5570504590868950,
3124015.9429495413787663 10088832.8033988755196333,
3124071.6966011249460280 10088861.2113032583147287,
3124082.0095563000068069 10088862.8447148911654949,
3124089.2886967407539487 10088908.8033988755196333,
3124117.6966011249460280 10088964.5570504590868950,
3124161.9429495413787663 10089008.8033988755196333,
3124217.6966011249460280 10089037.2113032583147287,
3124279.5000000000000000 10089047.0000000000000000,
3124341.3033988750539720 10089037.2113032583147287,
3124397.0570504586212337 10089008.8033988755196333,
3124441.3033988750539720 10088964.5570504590868950,
3124462.0310120303183794 10088923.8768191263079643,
3124481.7500000000000000 10088927.0000000000000000,
3124543.5533988750539720 10088917.2113032583147287,
3124599.3070504586212337 10088888.8033988755196333,
3124643.5533988750539720 10088844.5570504590868950,
3124671.9613032592460513 10088788.8033988755196333,
3124681.7500000000000000 10088727.0000000000000000,
3124681.6283728620037436 10088726.2320764716714621,
3124708.3033988750539720 10088699.5570504590868950,
3124736.7113032592460513 10088643.8033988755196333,
3124746.5000000000000000 10088582.0000000000000000,
3124736.7113032592460513 10088520.1966011244803667,
3124724.4930895599536598 10088496.2170065604150295,
3124764.5570504586212337 10088475.8033988755196333,
3124808.8033988750539720 10088431.5570504590868950,
3124837.2113032592460513 10088375.8033988755196333,
3124847.0000000000000000 10088314.0000000000000000,
3124837.2113032592460513 10088252.1966011244803667,
3124808.8033988750539720 10088196.4429495409131050,
3124764.5570504586212337 10088152.1966011244803667,
3124708.8033988750539720 10088123.7886967416852713,
3124703.6270083142444491 10088122.9688370190560818,
3124703.7113032592460513 10088122.8033988755196333,
3124713.5000000000000000 10088061.0000000000000000,
3124703.7113032592460513 10087999.1966011244803667,
3124675.3033988750539720 10087943.4429495409131050,
3124655.8604493341408670 10087924.0000000000000000,
3124683.3033988750539720 10087896.5570504590868950,
3124711.7113032592460513 10087840.8033988755196333,
3124721.5000000000000000 10087779.0000000000000000,
3124711.7113032592460513 10087717.1966011244803667,
3124683.3033988750539720 10087661.4429495409131050,
3124639.0570504586212337 10087617.1966011244803667,
3124610.2552891056984663 10087602.5213707257062197,
3124601.5533988750539720 10087585.4429495409131050,
3124574.5825435318984091 10087558.4720941968262196,
3124566.4613032592460513 10087507.1966011244803667,
3124538.0533988750539720 10087451.4429495409131050,
3124493.8070504586212337 10087407.1966011244803667,
3124486.3300345353782177 10087403.3868712261319160,
3124487.5000000000000000 10087396.0000000000000000,
3124477.7113032592460513 10087334.1966011244803667,
3124449.3033988750539720 10087278.4429495409131050,
3124405.0570504586212337 10087234.1966011244803667,
3124377.9456330905668437 10087220.3826440032571554,
3124384.5000000000000000 10087179.0000000000000000,
3124374.7113032592460513 10087117.1966011244803667,
3124346.3033988750539720 10087061.4429495409131050,
3124302.0570504586212337 10087017.1966011244803667,
3124246.3033988750539720 10086988.7886967416852713,
3124184.5000000000000000 10086979.0000000000000000,
3124122.6966011249460280 10086988.7886967416852713,
3124066.9429495413787663 10087017.1966011244803667,
3124022.6966011249460280 10087061.4429495409131050,
3123994.2886967407539487 10087117.1966011244803667,
3123984.5000000000000000 10087179.0000000000000000,
3123994.2886967407539487 10087240.8033988755196333,
3124022.6966011249460280 10087296.5570504590868950,
3124065.0145506658591330 10087338.8750000000000000)),
((3124392.9423482501879334 10091032.7952412497252226,
3124373.3033988750539720 10091022.7886967416852713,
3124311.5000000000000000 10091013.0000000000000000,
3124249.6966011249460280 10091022.7886967416852713,
3124193.9429495413787663 10091051.1966011244803667,
3124149.6966011249460280 10091095.4429495409131050,
3124121.2886967407539487 10091151.1966011244803667,
3124111.5000000000000000 10091213.0000000000000000,
3124121.2886967407539487 10091274.8033988755196333,
3124149.6966011249460280 10091330.5570504590868950,
3124193.9429495413787663 10091374.8033988755196333,
3124249.6966011249460280 10091403.2113032583147287,
3124311.5000000000000000 10091413.0000000000000000,
3124373.3033988750539720 10091403.2113032583147287,
3124429.0570504586212337 10091374.8033988755196333,
3124473.3033988750539720 10091330.5570504590868950,
3124501.7113032592460513 10091274.8033988755196333,
3124506.5576517498120666 10091244.2047587502747774,
3124526.1966011249460280 10091254.2113032583147287,
3124588.0000000000000000 10091264.0000000000000000,
3124649.8033988750539720 10091254.2113032583147287,
3124705.5570504586212337 10091225.8033988755196333,
3124749.8033988750539720 10091181.5570504590868950,
3124778.2113032592460513 10091125.8033988755196333,
3124788.0000000000000000 10091064.0000000000000000,
3124778.2113032592460513 10091002.1966011244803667,
3124749.8033988750539720 10090946.4429495409131050,
3124705.5570504586212337 10090902.1966011244803667,
3124649.8033988750539720 10090873.7886967416852713,
3124588.0000000000000000 10090864.0000000000000000,
3124526.1966011249460280 10090873.7886967416852713,
3124470.4429495413787663 10090902.1966011244803667,
3124426.1966011249460280 10090946.4429495409131050,
3124397.7886967407539487 10091002.1966011244803667,
3124392.9423482501879334 10091032.7952412497252226)),
((3124772.5000000000000000 10085970.0000000000000000,
3124762.7113032592460513 10085908.1966011244803667,
3124734.3033988750539720 10085852.4429495409131050,
3124690.0570504586212337 10085808.1966011244803667,
3124634.3033988750539720 10085779.7886967416852713,
3124572.5000000000000000 10085770.0000000000000000,
3124510.6966011249460280 10085779.7886967416852713,
3124454.9429495413787663 10085808.1966011244803667,
3124410.6966011249460280 10085852.4429495409131050,
3124382.2886967407539487 10085908.1966011244803667,
3124372.5000000000000000 10085970.0000000000000000,
3124382.2886967407539487 10086031.8033988755196333,
3124410.6966011249460280 10086087.5570504590868950,
3124454.9429495413787663 10086131.8033988755196333,
3124510.6966011249460280 10086160.2113032583147287,
3124572.5000000000000000 10086170.0000000000000000,
3124634.3033988750539720 10086160.2113032583147287,
3124690.0570504586212337 10086131.8033988755196333,
3124734.3033988750539720 10086087.5570504590868950,
3124762.7113032592460513 10086031.8033988755196333,
3124772.5000000000000000 10085970.0000000000000000)),
((3124606.6243613059632480 10086827.8653797619044781,
3124596.8356645652092993 10086766.0619808863848448,
3124568.4277601810172200 10086710.3083293028175831,
3124524.1814117645844817 10086666.0619808863848448,
3124468.4277601810172200 10086637.6540765035897493,
3124406.6243613059632480 10086627.8653797619044781,
3124344.8209624309092760 10086637.6540765035897493,
3124289.0673108473420143 10086666.0619808863848448,
3124244.8209624309092760 10086710.3083293028175831,
3124216.4130580467171967 10086766.0619808863848448,
3124206.6243613059632480 10086827.8653797619044781,
3124216.4130580467171967 10086889.6687786374241114,
3124244.8209624309092760 10086945.4224302209913731,
3124289.0673108473420143 10086989.6687786374241114,
3124344.8209624309092760 10087018.0766830202192068,
3124406.6243613059632480 10087027.8653797619044781,
3124468.4277601810172200 10087018.0766830202192068,
3124524.1814117645844817 10086989.6687786374241114,
3124568.4277601810172200 10086945.4224302209913731,
3124596.8356645652092993 10086889.6687786374241114,
3124606.6243613059632480 10086827.8653797619044781)),
((3124539.4284850610420108 10092394.7599573582410812,
3124529.6397883202880621 10092332.9565584827214479,
3124501.2318839360959828 10092277.2029068991541862,
3124456.9855355196632445 10092232.9565584827214479,
3124401.2318839360959828 10092204.5486540999263525,
3124339.4284850610420108 10092194.7599573582410812,
3124277.6250861859880388 10092204.5486540999263525,
3124221.8714346024207771 10092232.9565584827214479,
3124177.6250861859880388 10092277.2029068991541862,
3124149.2171818017959595 10092332.9565584827214479,
3124139.4284850610420108 10092394.7599573582410812,
3124149.2171818017959595 10092456.5633562337607145,
3124177.6250861859880388 10092512.3170078173279762,
3124221.8714346024207771 10092556.5633562337607145,
3124277.6250861859880388 10092584.9712606165558100,
3124339.4284850610420108 10092594.7599573582410812,
3124401.2318839360959828 10092584.9712606165558100,
3124456.9855355196632445 10092556.5633562337607145,
3124501.2318839360959828 10092512.3170078173279762,
3124529.6397883202880621 10092456.5633562337607145,
3124539.4284850610420108 10092394.7599573582410812)),
((3124115.0631883610039949 10089998.9897972401231527,
3124092.5386967407539487 10090043.1966011244803667,
3124082.7500000000000000 10090105.0000000000000000,
3124092.5386967407539487 10090166.8033988755196333,
3124120.9466011249460280 10090222.5570504590868950,
3124165.1929495413787663 10090266.8033988755196333,
3124220.9466011249460280 10090295.2113032583147287,
3124282.7500000000000000 10090305.0000000000000000,
3124344.5533988750539720 10090295.2113032583147287,
3124400.3070504586212337 10090266.8033988755196333,
3124444.5533988750539720 10090222.5570504590868950,
3124472.9613032592460513 10090166.8033988755196333,
3124482.7500000000000000 10090105.0000000000000000,
3124472.9613032592460513 10090043.1966011244803667,
3124444.5533988750539720 10089987.4429495409131050,
3124413.9517089775763452 10089956.8412596434354782,
3124436.4762005978263915 10089912.6344557590782642,
3124446.2648973385803401 10089850.8310568835586309,
3124436.4762005978263915 10089789.0276580080389977,
3124408.0682962136343122 10089733.2740064244717360,
3124363.8219477972015738 10089689.0276580080389977,
3124308.0682962136343122 10089660.6197536252439022,
3124246.2648973385803401 10089650.8310568835586309,
3124184.4614984635263681 10089660.6197536252439022,
3124128.7078468799591064 10089689.0276580080389977,
3124084.4614984635263681 10089733.2740064244717360,
3124056.0535940793342888 10089789.0276580080389977,
3124046.2648973385803401 10089850.8310568835586309,
3124056.0535940793342888 10089912.6344557590782642,
3124084.4614984635263681 10089968.3881073426455259,
3124115.0631883610039949 10089998.9897972401231527))))
</a>
<test>
<!--op name="buffer" arg1="a" arg3="0.000000001"-->
<op name="buffer" arg1="a" arg3="0">
MULTIPOLYGON (((3144083.7883107070811093 10078712.6012399587780237,
3144048.9466011249460280 10078747.4429495409131050,
3144020.5386967407539487 10078803.1966011244803667,
3144010.7500000000000000 10078865.0000000000000000,
3144020.5386967407539487 10078926.8033988755196333,
3144048.9466011249460280 10078982.5570504590868950,
3144093.1929495413787663 10079026.8033988755196333,
3144138.6631982573308051 10079049.9716477897018194,
3144145.2886967407539487 10079091.8033988755196333,
3144159.6389670395292342 10079119.9673901218920946,
3144163.1983127109706402 10079142.4402142446488142,
3144191.6062170951627195 10079198.1938658282160759,
3144235.8525655115954578 10079242.4402142446488142,
3144291.6062170951627195 10079270.8481186274439096,
3144300.3315549301914871 10079272.2300763763487339,
3144296.2500000000000000 10079298.0000000000000000,
3144299.1934952498413622 10079316.5844975933432579,
3144280.5386967407539487 10079353.1966011244803667,
3144270.7500000000000000 10079415.0000000000000000,
3144280.0666346335783601 10079473.8229160327464342,
3144271.4466011249460280 10079482.4429495409131050,
3144243.0386967407539487 10079538.1966011244803667,
3144236.3288886700756848 10079580.5606619957834482,
3144217.4466011249460280 10079599.4429495409131050,
3144189.0386967407539487 10079655.1966011244803667,
3144179.2500000000000000 10079717.0000000000000000,
3144189.0386967407539487 10079778.8033988755196333,
3144217.4466011249460280 10079834.5570504590868950,
3144261.6929495413787663 10079878.8033988755196333,
3144317.4466011249460280 10079907.2113032583147287,
3144379.2500000000000000 10079917.0000000000000000,
3144411.5590361021459103 10079911.8827513996511698,
3144413.2886967407539487 10079922.8033988755196333,
3144441.6966011249460280 10079978.5570504590868950,
3144485.9429495413787663 10080022.8033988755196333,
3144541.6966011249460280 10080051.2113032583147287,
3144603.5000000000000000 10080061.0000000000000000,
3144665.3033988750539720 10080051.2113032583147287,
3144721.0570504586212337 10080022.8033988755196333,
3144765.3033988750539720 10079978.5570504590868950,
3144793.7113032592460513 10079922.8033988755196333,
3144803.5000000000000000 10079861.0000000000000000,
3144793.7113032592460513 10079799.1966011244803667,
3144765.3033988750539720 10079743.4429495409131050,
3144735.0586849180981517 10079713.1982355844229460,
3144740.0000000000000000 10079682.0000000000000000,
3144730.2113032592460513 10079620.1966011244803667,
3144701.8033988750539720 10079564.4429495409131050,
3144683.2366796284914017 10079545.8762302938848734,
3144726.5570504586212337 10079523.8033988755196333,
3144770.8033988750539720 10079479.5570504590868950,
3144799.2113032592460513 10079423.8033988755196333,
3144809.0000000000000000 10079362.0000000000000000,
3144799.2113032592460513 10079300.1966011244803667,
3144770.8033988750539720 10079244.4429495409131050,
3144742.6100971987470984 10079216.2496478650718927,
3144749.4613032592460513 10079202.8033988755196333,
3144759.2500000000000000 10079141.0000000000000000,
3144749.4613032592460513 10079079.1966011244803667,
3144721.0533988750539720 10079023.4429495409131050,
3144676.8070504586212337 10078979.1966011244803667,
3144621.0533988750539720 10078950.7886967416852713,
3144592.1650020405650139 10078946.2132241781800985,
3144596.0000000000000000 10078922.0000000000000000,
3144591.6861204565502703 10078894.7632364984601736,
3144633.0533988750539720 10078888.2113032583147287,
3144688.8070504586212337 10078859.8033988755196333,
3144733.0533988750539720 10078815.5570504590868950,
3144761.4613032592460513 10078759.8033988755196333,
3144771.2500000000000000 10078698.0000000000000000,
3144761.4613032592460513 10078636.1966011244803667,
3144733.0533988750539720 10078580.4429495409131050,
3144688.8070504586212337 10078536.1966011244803667,
3144633.0533988750539720 10078507.7886967416852713,
3144619.8000165307894349 10078505.6895671971142292,
3144616.3070504586212337 10078502.1966011244803667,
3144560.5533988750539720 10078473.7886967416852713,
3144543.7354436498135328 10078471.1249943152070045,
3144539.8070504586212337 10078467.1966011244803667,
3144484.0533988750539720 10078438.7886967416852713,
3144422.2500000000000000 10078429.0000000000000000,
3144360.4466011249460280 10078438.7886967416852713,
3144304.6929495413787663 10078467.1966011244803667,
3144260.4466011249460280 10078511.4429495409131050,
3144255.9190343273803592 10078520.3287997022271156,
3144221.4466011249460280 10078525.7886967416852713,
3144165.6929495413787663 10078554.1966011244803667,
3144121.4466011249460280 10078598.4429495409131050,
3144093.0386967407539487 10078654.1966011244803667,
3144083.7883107070811093 10078712.6012399587780237)),
((3144355.5287439506500959 10081795.1419496573507786,
3144316.7500000000000000 10081789.0000000000000000,
3144254.9466011249460280 10081798.7886967416852713,
3144199.1929495413787663 10081827.1966011244803667,
3144154.9466011249460280 10081871.4429495409131050,
3144126.5386967407539487 10081927.1966011244803667,
3144116.7500000000000000 10081989.0000000000000000,
3144126.5386967407539487 10082050.8033988755196333,
3144154.9466011249460280 10082106.5570504590868950,
3144199.1929495413787663 10082150.8033988755196333,
3144254.9466011249460280 10082179.2113032583147287,
3144316.7500000000000000 10082189.0000000000000000,
3144378.5533988750539720 10082179.2113032583147287,
3144434.3070504586212337 10082150.8033988755196333,
3144478.5533988750539720 10082106.5570504590868950,
3144506.9613032592460513 10082050.8033988755196333,
3144512.9712560493499041 10082012.8580503426492214,
3144551.7500000000000000 10082019.0000000000000000,
3144613.5533988750539720 10082009.2113032583147287,
3144669.3070504586212337 10081980.8033988755196333,
3144713.5533988750539720 10081936.5570504590868950,
3144741.9613032592460513 10081880.8033988755196333,
3144751.7500000000000000 10081819.0000000000000000,
3144741.9613032592460513 10081757.1966011244803667,
3144713.5533988750539720 10081701.4429495409131050,
3144686.8604493341408670 10081674.7500000000000000,
3144688.0533988750539720 10081673.5570504590868950,
3144716.4613032592460513 10081617.8033988755196333,
3144726.2500000000000000 10081556.0000000000000000,
3144716.4613032592460513 10081494.1966011244803667,
3144688.0533988750539720 10081438.4429495409131050,
3144643.8070504586212337 10081394.1966011244803667,
3144588.0533988750539720 10081365.7886967416852713,
3144526.2500000000000000 10081356.0000000000000000,
3144464.4466011249460280 10081365.7886967416852713,
3144408.6929495413787663 10081394.1966011244803667,
3144364.4466011249460280 10081438.4429495409131050,
3144336.0386967407539487 10081494.1966011244803667,
3144326.2500000000000000 10081556.0000000000000000,
3144336.0386967407539487 10081617.8033988755196333,
3144364.4466011249460280 10081673.5570504590868950,
3144391.1395506658591330 10081700.2500000000000000,
3144389.9466011249460280 10081701.4429495409131050,
3144361.5386967407539487 10081757.1966011244803667,
3144355.5287439506500959 10081795.1419496573507786)),
((3143226.6166262058541179 10080950.7475066352635622,
3143216.8279294651001692 10080888.9441077597439289,
3143188.4200250809080899 10080833.1904561761766672,
3143144.1736766644753516 10080788.9441077597439289,
3143088.4200250809080899 10080760.5362033769488335,
3143026.6166262058541179 10080750.7475066352635622,
3142964.8132273308001459 10080760.5362033769488335,
3142909.0595757472328842 10080788.9441077597439289,
3142864.8132273308001459 10080833.1904561761766672,
3142836.4053229466080666 10080888.9441077597439289,
3142826.6166262058541179 10080950.7475066352635622,
3142836.4053229466080666 10081012.5509055107831955,
3142864.8132273308001459 10081068.3045570943504572,
3142909.0595757472328842 10081112.5509055107831955,
3142964.8132273308001459 10081140.9588098935782909,
3143026.6166262058541179 10081150.7475066352635622,
3143088.4200250809080899 10081140.9588098935782909,
3143144.1736766644753516 10081112.5509055107831955,
3143188.4200250809080899 10081068.3045570943504572,
3143216.8279294651001692 10081012.5509055107831955,
3143226.6166262058541179 10080950.7475066352635622)),
((3142555.7500000000000000 10080107.0000000000000000,
3142545.9613032592460513 10080045.1966011244803667,
3142517.5533988750539720 10079989.4429495409131050,
3142473.3070504586212337 10079945.1966011244803667,
3142417.5533988750539720 10079916.7886967416852713,
3142355.7500000000000000 10079907.0000000000000000,
3142293.9466011249460280 10079916.7886967416852713,
3142238.1929495413787663 10079945.1966011244803667,
3142193.9466011249460280 10079989.4429495409131050,
3142165.5386967407539487 10080045.1966011244803667,
3142155.7500000000000000 10080107.0000000000000000,
3142165.5386967407539487 10080168.8033988755196333,
3142193.9466011249460280 10080224.5570504590868950,
3142238.1929495413787663 10080268.8033988755196333,
3142293.9466011249460280 10080297.2113032583147287,
3142355.7500000000000000 10080307.0000000000000000,
3142417.5533988750539720 10080297.2113032583147287,
3142473.3070504586212337 10080268.8033988755196333,
3142517.5533988750539720 10080224.5570504590868950,
3142545.9613032592460513 10080168.8033988755196333,
3142555.7500000000000000 10080107.0000000000000000)),
((3142168.5456810002215207 10079985.7807899992913008,
3142158.7569842594675720 10079923.9773911237716675,
3142130.3490798752754927 10079868.2237395402044058,
3142086.1027314588427544 10079823.9773911237716675,
3142030.3490798752754927 10079795.5694867409765720,
3141968.5456810002215207 10079785.7807899992913008,
3141906.7422821251675487 10079795.5694867409765720,
3141850.9886305416002870 10079823.9773911237716675,
3141806.7422821251675487 10079868.2237395402044058,
3141778.3343777409754694 10079923.9773911237716675,
3141768.5456810002215207 10079985.7807899992913008,
3141778.3343777409754694 10080047.5841888748109341,
3141806.7422821251675487 10080103.3378404583781958,
3141850.9886305416002870 10080147.5841888748109341,
3141906.7422821251675487 10080175.9920932576060295,
3141968.5456810002215207 10080185.7807899992913008,
3142030.3490798752754927 10080175.9920932576060295,
3142086.1027314588427544 10080147.5841888748109341,
3142130.3490798752754927 10080103.3378404583781958,
3142158.7569842594675720 10080047.5841888748109341,
3142168.5456810002215207 10079985.7807899992913008)),
((3140758.7500000000000000 10079094.0000000000000000,
3140748.9613032592460513 10079032.1966011244803667,
3140720.5533988750539720 10078976.4429495409131050,
3140676.3070504586212337 10078932.1966011244803667,
3140620.5533988750539720 10078903.7886967416852713,
3140558.7500000000000000 10078894.0000000000000000,
3140496.9466011249460280 10078903.7886967416852713,
3140441.1929495413787663 10078932.1966011244803667,
3140396.9466011249460280 10078976.4429495409131050,
3140368.5386967407539487 10079032.1966011244803667,
3140358.7500000000000000 10079094.0000000000000000,
3140368.5386967407539487 10079155.8033988755196333,
3140396.9466011249460280 10079211.5570504590868950,
3140441.1929495413787663 10079255.8033988755196333,
3140496.9466011249460280 10079284.2113032583147287,
3140558.7500000000000000 10079294.0000000000000000,
3140620.5533988750539720 10079284.2113032583147287,
3140676.3070504586212337 10079255.8033988755196333,
3140720.5533988750539720 10079211.5570504590868950,
3140748.9613032592460513 10079155.8033988755196333,
3140758.7500000000000000 10079094.0000000000000000)),
((3139987.2500000000000000 10079912.0000000000000000,
3139977.4613032592460513 10079850.1966011244803667,
3139949.0533988750539720 10079794.4429495409131050,
3139904.8070504586212337 10079750.1966011244803667,
3139849.0533988750539720 10079721.7886967416852713,
3139787.2500000000000000 10079712.0000000000000000,
3139725.4466011249460280 10079721.7886967416852713,
3139669.6929495413787663 10079750.1966011244803667,
3139625.4466011249460280 10079794.4429495409131050,
3139597.0386967407539487 10079850.1966011244803667,
3139587.2500000000000000 10079912.0000000000000000,
3139597.0386967407539487 10079973.8033988755196333,
3139625.4466011249460280 10080029.5570504590868950,
3139669.6929495413787663 10080073.8033988755196333,
3139725.4466011249460280 10080102.2113032583147287,
3139787.2500000000000000 10080112.0000000000000000,
3139849.0533988750539720 10080102.2113032583147287,
3139904.8070504586212337 10080073.8033988755196333,
3139949.0533988750539720 10080029.5570504590868950,
3139977.4613032592460513 10079973.8033988755196333,
3139987.2500000000000000 10079912.0000000000000000)),
((3138644.4854970001615584 10080523.2817800007760525,
3138634.6968002594076097 10080461.4783811252564192,
3138606.2888958752155304 10080405.7247295416891575,
3138562.0425474587827921 10080361.4783811252564192,
3138506.2888958752155304 10080333.0704767424613237,
3138444.4854970001615584 10080323.2817800007760525,
3138382.6820981251075864 10080333.0704767424613237,
3138326.9284465415403247 10080361.4783811252564192,
3138282.6820981251075864 10080405.7247295416891575,
3138254.2741937409155071 10080461.4783811252564192,
3138244.4854970001615584 10080523.2817800007760525,
3138254.2741937409155071 10080585.0851788762956858,
3138282.6820981251075864 10080640.8388304598629475,
3138326.9284465415403247 10080685.0851788762956858,
3138382.6820981251075864 10080713.4930832590907812,
3138444.4854970001615584 10080723.2817800007760525,
3138506.2888958752155304 10080713.4930832590907812,
3138562.0425474587827921 10080685.0851788762956858,
3138606.2888958752155304 10080640.8388304598629475,
3138634.6968002594076097 10080585.0851788762956858,
3138644.4854970001615584 10080523.2817800007760525)),
((3137662.8895506658591330 10084932.0000000000000000,
3137629.4466011249460280 10084965.4429495409131050,
3137601.0386967407539487 10085021.1966011244803667,
3137591.2500000000000000 10085083.0000000000000000,
3137601.0386967407539487 10085144.8033988755196333,
3137629.4466011249460280 10085200.5570504590868950,
3137673.6929495413787663 10085244.8033988755196333,
3137722.1154415430501103 10085269.4758908767253160,
3137730.4429495413787663 10085277.8033988755196333,
3137786.1966011249460280 10085306.2113032583147287,
3137848.0000000000000000 10085316.0000000000000000,
3137909.8033988750539720 10085306.2113032583147287,
3137965.5570504586212337 10085277.8033988755196333,
3138009.8033988750539720 10085233.5570504590868950,
3138038.2113032592460513 10085177.8033988755196333,
3138048.0000000000000000 10085116.0000000000000000,
3138045.6135819763876498 10085100.9327495880424976,
3138081.7420749431475997 10085064.8042566217482090,
3138110.1499793273396790 10085009.0506050381809473,
3138119.9386760680936277 10084947.2472061626613140,
3138110.1499793273396790 10084885.4438072871416807,
3138081.7420749431475997 10084829.6901557035744190,
3138037.4957265267148614 10084785.4438072871416807,
3137998.0263899806886911 10084765.3331758435815573,
3137992.4613032592460513 10084730.1966011244803667,
3137964.0533988750539720 10084674.4429495409131050,
3137919.8070504586212337 10084630.1966011244803667,
3137864.0533988750539720 10084601.7886967416852713,
3137802.2500000000000000 10084592.0000000000000000,
3137740.4466011249460280 10084601.7886967416852713,
3137684.6929495413787663 10084630.1966011244803667,
3137640.4466011249460280 10084674.4429495409131050,
3137612.0386967407539487 10084730.1966011244803667,
3137602.2500000000000000 10084792.0000000000000000,
3137612.0386967407539487 10084853.8033988755196333,
3137640.4466011249460280 10084909.5570504590868950,
3137662.8895506658591330 10084932.0000000000000000)),
((3136096.2448901482857764 10088943.4383649379014969,
3136104.5386967407539487 10088995.8033988755196333,
3136132.9466011249460280 10089051.5570504590868950,
3136175.7516472581773996 10089094.3620965927839279,
3136173.7500000000000000 10089107.0000000000000000,
3136183.4084564736112952 10089167.9810941927134991,
3136168.9466011249460280 10089182.4429495409131050,
3136151.5460015009157360 10089216.5935491640120745,
3136132.6966011249460280 10089235.4429495409131050,
3136104.2886967407539487 10089291.1966011244803667,
3136094.5000000000000000 10089353.0000000000000000,
3136104.2886967407539487 10089414.8033988755196333,
3136132.6966011249460280 10089470.5570504590868950,
3136176.9429495413787663 10089514.8033988755196333,
3136232.6966011249460280 10089543.2113032583147287,
3136294.5000000000000000 10089553.0000000000000000,
3136356.3033988750539720 10089543.2113032583147287,
3136412.0570504586212337 10089514.8033988755196333,
3136456.3033988750539720 10089470.5570504590868950,
3136473.7039984990842640 10089436.4064508359879255,
3136492.5533988750539720 10089417.5570504590868950,
3136520.9613032592460513 10089361.8033988755196333,
3136530.2258268320001662 10089303.3094991333782673,
3136547.6966011249460280 10089312.2113032583147287,
3136609.5000000000000000 10089322.0000000000000000,
3136636.1373706669546664 10089317.7810549549758434,
3136678.1966011249460280 10089339.2113032583147287,
3136740.0000000000000000 10089349.0000000000000000,
3136781.2902805083431304 10089342.4602620303630829,
3136788.7886967407539487 10089389.8033988755196333,
3136813.1412944286130369 10089437.5980629343539476,
3136810.2886967407539487 10089443.1966011244803667,
3136803.4164477470330894 10089486.5862736199051142,
3136790.4429495413787663 10089493.1966011244803667,
3136746.1966011249460280 10089537.4429495409131050,
3136734.4187443377450109 10089560.5582950040698051,
3136708.0570504586212337 10089534.1966011244803667,
3136652.3033988750539720 10089505.7886967416852713,
3136590.5000000000000000 10089496.0000000000000000,
3136528.6966011249460280 10089505.7886967416852713,
3136472.9429495413787663 10089534.1966011244803667,
3136428.6966011249460280 10089578.4429495409131050,
3136400.2886967407539487 10089634.1966011244803667,
3136390.5000000000000000 10089696.0000000000000000,
3136400.2886967407539487 10089757.8033988755196333,
3136428.6966011249460280 10089813.5570504590868950,
3136472.9429495413787663 10089857.8033988755196333,
3136528.6966011249460280 10089886.2113032583147287,
3136538.3519245618954301 10089887.7405562568455935,
3136511.9429495413787663 10089901.1966011244803667,
3136467.6966011249460280 10089945.4429495409131050,
3136457.9740605228580534 10089964.5245098676532507,
3136429.0533988750539720 10089949.7886967416852713,
3136367.2500000000000000 10089940.0000000000000000,
3136305.4466011249460280 10089949.7886967416852713,
3136249.6929495413787663 10089978.1966011244803667,
3136219.0000000000000000 10090008.8895506653934717,
3136181.3070504586212337 10089971.1966011244803667,
3136125.5533988750539720 10089942.7886967416852713,
3136063.7500000000000000 10089933.0000000000000000,
3136001.9466011249460280 10089942.7886967416852713,
3135946.1929495413787663 10089971.1966011244803667,
3135901.9466011249460280 10090015.4429495409131050,
3135873.5386967407539487 10090071.1966011244803667,
3135863.7500000000000000 10090133.0000000000000000,
3135873.5386967407539487 10090194.8033988755196333,
3135901.9466011249460280 10090250.5570504590868950,
3135946.1929495413787663 10090294.8033988755196333,
3136001.9466011249460280 10090323.2113032583147287,
3136063.7500000000000000 10090333.0000000000000000,
3136125.5533988750539720 10090323.2113032583147287,
3136181.3070504586212337 10090294.8033988755196333,
3136212.0000000000000000 10090264.1104493346065283,
3136249.6929495413787663 10090301.8033988755196333,
3136305.4466011249460280 10090330.2113032583147287,
3136367.2500000000000000 10090340.0000000000000000,
3136429.0533988750539720 10090330.2113032583147287,
3136483.8469625851139426 10090302.2925880812108517,
3136440.6966011249460280 10090345.4429495409131050,
3136412.2886967407539487 10090401.1966011244803667,
3136402.5000000000000000 10090463.0000000000000000,
3136412.2886967407539487 10090524.8033988755196333,
3136440.6966011249460280 10090580.5570504590868950,
3136484.9429495413787663 10090624.8033988755196333,
3136540.6966011249460280 10090653.2113032583147287,
3136602.5000000000000000 10090663.0000000000000000,
3136652.1576877986080945 10090655.1349949091672897,
3136669.6966011249460280 10090689.5570504590868950,
3136713.9429495413787663 10090733.8033988755196333,
3136769.6966011249460280 10090762.2113032583147287,
3136831.5000000000000000 10090772.0000000000000000,
3136893.3033988750539720 10090762.2113032583147287,
3136940.2699933997355402 10090738.2806280739605427,
3136955.6966011249460280 10090768.5570504590868950,
3136999.9429495413787663 10090812.8033988755196333,
3137055.6966011249460280 10090841.2113032583147287,
3137117.5000000000000000 10090851.0000000000000000,
3137179.3033988750539720 10090841.2113032583147287,
3137235.0570504586212337 10090812.8033988755196333,
3137279.3033988750539720 10090768.5570504590868950,
3137307.7113032592460513 10090712.8033988755196333,
3137317.5000000000000000 10090651.0000000000000000,
3137307.7113032592460513 10090589.1966011244803667,
3137279.3033988750539720 10090533.4429495409131050,
3137235.0570504586212337 10090489.1966011244803667,
3137179.3033988750539720 10090460.7886967416852713,
3137117.5000000000000000 10090451.0000000000000000,
3137055.6966011249460280 10090460.7886967416852713,
3137008.7300066002644598 10090484.7193719260394573,
3136993.3033988750539720 10090454.4429495409131050,
3136967.5657823677174747 10090428.7053330335766077,
3137026.2500000000000000 10090438.0000000000000000,
3137088.0533988750539720 10090428.2113032583147287,
3137143.8070504586212337 10090399.8033988755196333,
3137188.0533988750539720 10090355.5570504590868950,
3137216.4613032592460513 10090299.8033988755196333,
3137226.2500000000000000 10090238.0000000000000000,
3137216.4613032592460513 10090176.1966011244803667,
3137188.0533988750539720 10090120.4429495409131050,
3137143.8070504586212337 10090076.1966011244803667,
3137088.0533988750539720 10090047.7886967416852713,
3137026.2500000000000000 10090038.0000000000000000,
3137008.4605209683068097 10090040.8175766803324223,
3137000.5533988750539720 10090036.7886967416852713,
3136975.0375925395637751 10090032.7473900355398655,
3136926.0533988750539720 10090007.7886967416852713,
3136864.2500000000000000 10089998.0000000000000000,
3136820.3073407127521932 10090004.9598334990441799,
3136819.7113032592460513 10090001.1966011244803667,
3136791.3033988750539720 10089945.4429495409131050,
3136747.0570504586212337 10089901.1966011244803667,
3136691.3033988750539720 10089872.7886967416852713,
3136681.6480754381045699 10089871.2594437431544065,
3136708.0570504586212337 10089857.8033988755196333,
3136752.3033988750539720 10089813.5570504590868950,
3136764.0812556622549891 10089790.4417049959301949,
3136790.4429495413787663 10089816.8033988755196333,
3136846.1966011249460280 10089845.2113032583147287,
3136908.0000000000000000 10089855.0000000000000000,
3136969.8033988750539720 10089845.2113032583147287,
3137017.3170666922815144 10089821.0018803086131811,
3137026.7886967407539487 10089880.8033988755196333,
3137055.1966011249460280 10089936.5570504590868950,
3137099.4429495413787663 10089980.8033988755196333,
3137155.1966011249460280 10090009.2113032583147287,
3137206.3767160717397928 10090017.3174371197819710,
3137200.2500000000000000 10090056.0000000000000000,
3137210.0386967407539487 10090117.8033988755196333,
3137238.4466011249460280 10090173.5570504590868950,
3137282.6929495413787663 10090217.8033988755196333,
3137338.4466011249460280 10090246.2113032583147287,
3137400.2500000000000000 10090256.0000000000000000,
3137462.0533988750539720 10090246.2113032583147287,
3137517.8070504586212337 10090217.8033988755196333,
3137562.0533988750539720 10090173.5570504590868950,
3137580.8352138139307499 10090136.6956631485372782,
3137613.9429495413787663 10090169.8033988755196333,
3137663.0366533049382269 10090194.8178903516381979,
3137654.4429495413787663 10090199.1966011244803667,
3137610.1966011249460280 10090243.4429495409131050,
3137581.7886967407539487 10090299.1966011244803667,
3137572.0000000000000000 10090361.0000000000000000,
3137581.7886967407539487 10090422.8033988755196333,
3137610.1966011249460280 10090478.5570504590868950,
3137654.4429495413787663 10090522.8033988755196333,
3137710.1966011249460280 10090551.2113032583147287,
3137772.0000000000000000 10090561.0000000000000000,
3137833.8033988750539720 10090551.2113032583147287,
3137889.5570504586212337 10090522.8033988755196333,
3137933.8033988750539720 10090478.5570504590868950,
3137962.2113032592460513 10090422.8033988755196333,
3137972.0000000000000000 10090361.0000000000000000,
3137962.2113032592460513 10090299.1966011244803667,
3137933.8033988750539720 10090243.4429495409131050,
3137889.5570504586212337 10090199.1966011244803667,
3137840.4633466950617731 10090174.1821096483618021,
3137849.0570504586212337 10090169.8033988755196333,
3137893.3033988750539720 10090125.5570504590868950,
3137921.7113032592460513 10090069.8033988755196333,
3137931.5000000000000000 10090008.0000000000000000,
3137921.7113032592460513 10089946.1966011244803667,
3137893.3033988750539720 10089890.4429495409131050,
3137849.0570504586212337 10089846.1966011244803667,
3137825.6397438584826887 10089834.2648874539881945,
3137830.7500000000000000 10089802.0000000000000000,
3137824.8015710324980319 10089764.4430975951254368,
3137826.0570504586212337 10089763.8033988755196333,
3137870.3033988750539720 10089719.5570504590868950,
3137898.7113032592460513 10089663.8033988755196333,
3137908.5000000000000000 10089602.0000000000000000,
3137898.7113032592460513 10089540.1966011244803667,
3137870.3033988750539720 10089484.4429495409131050,
3137826.0570504586212337 10089440.1966011244803667,
3137770.3033988750539720 10089411.7886967416852713,
3137708.5000000000000000 10089402.0000000000000000,
3137646.6966011249460280 10089411.7886967416852713,
3137590.9429495413787663 10089440.1966011244803667,
3137590.3007821356877685 10089440.8387685306370258,
3137566.7515178481116891 10089437.1089314855635166,
3137599.3033988750539720 10089404.5570504590868950,
3137627.7113032592460513 10089348.8033988755196333,
3137637.5000000000000000 10089287.0000000000000000,
3137627.7113032592460513 10089225.1966011244803667,
3137599.3033988750539720 10089169.4429495409131050,
3137555.0570504586212337 10089125.1966011244803667,
3137501.4194367048330605 10089097.8668718673288822,
3137501.9613032592460513 10089096.8033988755196333,
3137511.7500000000000000 10089035.0000000000000000,
3137510.0772214639000595 10089024.4384919833391905,
3137519.0987199507653713 10089029.0351750552654266,
3137524.2886967407539487 10089061.8033988755196333,
3137552.6966011249460280 10089117.5570504590868950,
3137596.9429495413787663 10089161.8033988755196333,
3137652.6966011249460280 10089190.2113032583147287,
3137714.5000000000000000 10089200.0000000000000000,
3137776.3033988750539720 10089190.2113032583147287,
3137832.0570504586212337 10089161.8033988755196333,
3137876.3033988750539720 10089117.5570504590868950,
3137904.7113032592460513 10089061.8033988755196333,
3137914.5000000000000000 10089000.0000000000000000,
3137904.7113032592460513 10088938.1966011244803667,
3137876.3033988750539720 10088882.4429495409131050,
3137832.0570504586212337 10088838.1966011244803667,
3137817.1764938882552087 10088830.6145788487046957,
3137820.5336688482202590 10088824.0257520042359829,
3137838.3033988750539720 10088821.2113032583147287,
3137894.0570504586212337 10088792.8033988755196333,
3137938.3033988750539720 10088748.5570504590868950,
3137966.7113032592460513 10088692.8033988755196333,
3137976.5000000000000000 10088631.0000000000000000,
3137966.7113032592460513 10088569.1966011244803667,
3137938.3033988750539720 10088513.4429495409131050,
3137894.0570504586212337 10088469.1966011244803667,
3137880.5553911239840090 10088462.3171620834618807,
3137889.0000000000000000 10088409.0000000000000000,
3137879.2113032592460513 10088347.1966011244803667,
3137850.8033988750539720 10088291.4429495409131050,
3137806.5570504586212337 10088247.1966011244803667,
3137758.0059733032248914 10088222.4585917145013809,
3137778.2113032592460513 10088182.8033988755196333,
3137787.7919601043686271 10088122.3135122060775757,
3137814.3070504586212337 10088108.8033988755196333,
3137858.5533988750539720 10088064.5570504590868950,
3137886.9613032592460513 10088008.8033988755196333,
3137896.7500000000000000 10087947.0000000000000000,
3137886.9613032592460513 10087885.1966011244803667,
3137858.5533988750539720 10087829.4429495409131050,
3137814.3070504586212337 10087785.1966011244803667,
3137758.5533988750539720 10087756.7886967416852713,
3137734.2991007561795413 10087752.9471933078020811,
3137727.2113032592460513 10087708.1966011244803667,
3137698.8033988750539720 10087652.4429495409131050,
3137662.8106929659843445 10087616.4502436313778162,
3137667.0000000000000000 10087590.0000000000000000,
3137663.7677941177971661 10087569.5926552154123783,
3137674.8033988750539720 10087558.5570504590868950,
3137703.2113032592460513 10087502.8033988755196333,
3137706.6277695260941982 10087481.2326798085123301,
3137737.3033988750539720 10087450.5570504590868950,
3137765.7113032592460513 10087394.8033988755196333,
3137775.5000000000000000 10087333.0000000000000000,
3137765.7113032592460513 10087271.1966011244803667,
3137740.2491629021242261 10087221.2243369668722153,
3137753.7113032592460513 10087194.8033988755196333,
3137763.5000000000000000 10087133.0000000000000000,
3137763.2174330898560584 10087131.2159427441656590,
3137776.9466011249460280 10087138.2113032583147287,
3137838.7500000000000000 10087148.0000000000000000,
3137900.5533988750539720 10087138.2113032583147287,
3137956.3070504586212337 10087109.8033988755196333,
3138000.5533988750539720 10087065.5570504590868950,
3138028.9613032592460513 10087009.8033988755196333,
3138038.7500000000000000 10086948.0000000000000000,
3138028.9613032592460513 10086886.1966011244803667,
3138000.5533988750539720 10086830.4429495409131050,
3137956.3070504586212337 10086786.1966011244803667,
3137900.5533988750539720 10086757.7886967416852713,
3137838.7500000000000000 10086748.0000000000000000,
3137776.9466011249460280 10086757.7886967416852713,
3137721.1929495413787663 10086786.1966011244803667,
3137676.9466011249460280 10086830.4429495409131050,
3137648.5386967407539487 10086886.1966011244803667,
3137638.7500000000000000 10086948.0000000000000000,
3137639.0325669101439416 10086949.7840572558343410,
3137625.3033988750539720 10086942.7886967416852713,
3137563.5000000000000000 10086933.0000000000000000,
3137501.6966011249460280 10086942.7886967416852713,
3137445.9429495413787663 10086971.1966011244803667,
3137401.6966011249460280 10087015.4429495409131050,
3137373.2886967407539487 10087071.1966011244803667,
3137367.2409596536308527 10087109.3805103190243244,
3137337.0570504586212337 10087079.1966011244803667,
3137281.3033988750539720 10087050.7886967416852713,
3137219.5000000000000000 10087041.0000000000000000,
3137157.6966011249460280 10087050.7886967416852713,
3137101.9429495413787663 10087079.1966011244803667,
3137057.6966011249460280 10087123.4429495409131050,
3137029.2886967407539487 10087179.1966011244803667,
3137019.5000000000000000 10087241.0000000000000000,
3137029.2886967407539487 10087302.8033988755196333,
3137057.6966011249460280 10087358.5570504590868950,
3137101.9429495413787663 10087402.8033988755196333,
3137120.3657741928473115 10087412.1902968864887953,
3137103.0386967407539487 10087446.1966011244803667,
3137093.2500000000000000 10087508.0000000000000000,
3137099.6742237601429224 10087548.5609524957835674,
3137058.2500000000000000 10087542.0000000000000000,
3136996.4466011249460280 10087551.7886967416852713,
3136940.6929495413787663 10087580.1966011244803667,
3136896.4466011249460280 10087624.4429495409131050,
3136868.0386967407539487 10087680.1966011244803667,
3136866.3053612671792507 10087691.1404505968093872,
3136826.9429495413787663 10087711.1966011244803667,
3136816.0000000000000000 10087722.1395506653934717,
3136791.0570504586212337 10087697.1966011244803667,
3136735.3033988750539720 10087668.7886967416852713,
3136673.5000000000000000 10087659.0000000000000000,
3136611.6966011249460280 10087668.7886967416852713,
3136594.9562209942378104 10087677.3183464519679546,
3136548.7500000000000000 10087670.0000000000000000,
3136486.9466011249460280 10087679.7886967416852713,
3136431.1929495413787663 10087708.1966011244803667,
3136388.7981554847210646 10087750.5913951806724072,
3136366.3033988750539720 10087706.4429495409131050,
3136322.0570504586212337 10087662.1966011244803667,
3136266.3033988750539720 10087633.7886967416852713,
3136204.5000000000000000 10087624.0000000000000000,
3136142.6966011249460280 10087633.7886967416852713,
3136086.9429495413787663 10087662.1966011244803667,
3136042.6966011249460280 10087706.4429495409131050,
3136014.2886967407539487 10087762.1966011244803667,
3136004.5000000000000000 10087824.0000000000000000,
3136014.2886967407539487 10087885.8033988755196333,
3136042.6966011249460280 10087941.5570504590868950,
3136086.9429495413787663 10087985.8033988755196333,
3136142.6966011249460280 10088014.2113032583147287,
3136204.5000000000000000 10088024.0000000000000000,
3136266.3033988750539720 10088014.2113032583147287,
3136322.0570504586212337 10087985.8033988755196333,
3136364.4518445152789354 10087943.4086048193275928,
3136386.9466011249460280 10087987.5570504590868950,
3136431.1929495413787663 10088031.8033988755196333,
3136486.9466011249460280 10088060.2113032583147287,
3136548.7500000000000000 10088070.0000000000000000,
3136610.5533988750539720 10088060.2113032583147287,
3136627.2937790057621896 10088051.6816535480320454,
3136673.5000000000000000 10088059.0000000000000000,
3136735.3033988750539720 10088049.2113032583147287,
3136791.0570504586212337 10088020.8033988755196333,
3136802.0000000000000000 10088009.8604493346065283,
3136826.9429495413787663 10088034.8033988755196333,
3136882.6966011249460280 10088063.2113032583147287,
3136944.5000000000000000 10088073.0000000000000000,
3137006.3033988750539720 10088063.2113032583147287,
3137015.6092738136649132 10088058.4697231482714415,
3137015.9429495413787663 10088058.8033988755196333,
3137071.6966011249460280 10088087.2113032583147287,
3137133.0717173595912755 10088096.9321666937321424,
3137155.9429495413787663 10088119.8033988755196333,
3137192.0762896002270281 10088138.2142552100121975,
3137187.8859159690327942 10088164.6712330710142851,
3137178.3033988750539720 10088159.7886967416852713,
3137120.7526336428709328 10088150.6735509987920523,
3137117.0533988750539720 10088148.7886967416852713,
3137055.2500000000000000 10088139.0000000000000000,
3137015.3569972878322005 10088145.3184309080243111,
3136988.8033988750539720 10088131.7886967416852713,
3136927.0000000000000000 10088122.0000000000000000,
3136923.0050060567446053 10088122.6327448803931475,
3136868.5000000000000000 10088114.0000000000000000,
3136806.6966011249460280 10088123.7886967416852713,
3136750.9429495413787663 10088152.1966011244803667,
3136706.6966011249460280 10088196.4429495409131050,
3136678.2886967407539487 10088252.1966011244803667,
3136668.5000000000000000 10088314.0000000000000000,
3136678.2886967407539487 10088375.8033988755196333,
3136706.6966011249460280 10088431.5570504590868950,
3136750.9429495413787663 10088475.8033988755196333,
3136806.6966011249460280 10088504.2113032583147287,
3136868.5000000000000000 10088514.0000000000000000,
3136872.4949939432553947 10088513.3672551196068525,
3136927.0000000000000000 10088522.0000000000000000,
3136966.8930027121677995 10088515.6815690919756889,
3136993.4466011249460280 10088529.2113032583147287,
3137025.0086239972151816 10088534.2102365866303444,
3137024.2500000000000000 10088539.0000000000000000,
3137034.0386967407539487 10088600.8033988755196333,
3137062.4466011249460280 10088656.5570504590868950,
3137106.6929495413787663 10088700.8033988755196333,
3137162.4466011249460280 10088729.2113032583147287,
3137206.4558888385072351 10088736.1816896628588438,
3137184.5386967407539487 10088779.1966011244803667,
3137174.7500000000000000 10088841.0000000000000000,
3137181.8106104899197817 10088885.5789401754736900,
3137149.9466011249460280 10088917.4429495409131050,
3137121.5386967407539487 10088973.1966011244803667,
3137111.7500000000000000 10089035.0000000000000000,
3137121.5386967407539487 10089096.8033988755196333,
3137125.6895815860480070 10089104.9499690793454647,
3137098.1966011249460280 10089132.4429495409131050,
3137084.2050387659110129 10089159.9029368143528700,
3137040.8033988750539720 10089137.7886967416852713,
3136979.0000000000000000 10089128.0000000000000000,
3136937.7097194916568696 10089134.5397379696369171,
3136930.2113032592460513 10089087.1966011244803667,
3136927.2413936620578170 10089081.3678253479301929,
3136985.0533988750539720 10089072.2113032583147287,
3137040.8070504586212337 10089043.8033988755196333,
3137085.0533988750539720 10088999.5570504590868950,
3137113.4613032592460513 10088943.8033988755196333,
3137123.2500000000000000 10088882.0000000000000000,
3137113.4613032592460513 10088820.1966011244803667,
3137085.0533988750539720 10088764.4429495409131050,
3137040.8070504586212337 10088720.1966011244803667,
3136985.0533988750539720 10088691.7886967416852713,
3136923.2500000000000000 10088682.0000000000000000,
3136861.4466011249460280 10088691.7886967416852713,
3136805.6929495413787663 10088720.1966011244803667,
3136761.4466011249460280 10088764.4429495409131050,
3136733.0386967407539487 10088820.1966011244803667,
3136723.2500000000000000 10088882.0000000000000000,
3136733.0386967407539487 10088943.8033988755196333,
3136736.0086063379421830 10088949.6321746520698071,
3136713.3626293330453336 10088953.2189450450241566,
3136671.3033988750539720 10088931.7886967416852713,
3136609.5000000000000000 10088922.0000000000000000,
3136547.6966011249460280 10088931.7886967416852713,
3136501.4585896534845233 10088955.3481403198093176,
3136492.7483527418226004 10088946.6379034072160721,
3136494.7500000000000000 10088934.0000000000000000,
3136484.9613032592460513 10088872.1966011244803667,
3136456.5533988750539720 10088816.4429495409131050,
3136412.3070504586212337 10088772.1966011244803667,
3136356.5533988750539720 10088743.7886967416852713,
3136294.7500000000000000 10088734.0000000000000000,
3136232.9466011249460280 10088743.7886967416852713,
3136177.1929495413787663 10088772.1966011244803667,
3136132.9466011249460280 10088816.4429495409131050,
3136112.5051098517142236 10088856.5616350620985031,
3136104.2113032592460513 10088804.1966011244803667,
3136075.8033988750539720 10088748.4429495409131050,
3136031.5570504586212337 10088704.1966011244803667,
3135975.8033988750539720 10088675.7886967416852713,
3135914.0000000000000000 10088666.0000000000000000,
3135852.1966011249460280 10088675.7886967416852713,
3135796.4429495413787663 10088704.1966011244803667,
3135752.1966011249460280 10088748.4429495409131050,
3135723.7886967407539487 10088804.1966011244803667,
3135714.0000000000000000 10088866.0000000000000000,
3135723.7886967407539487 10088927.8033988755196333,
3135752.1966011249460280 10088983.5570504590868950,
3135796.4429495413787663 10089027.8033988755196333,
3135852.1966011249460280 10089056.2113032583147287,
3135914.0000000000000000 10089066.0000000000000000,
3135975.8033988750539720 10089056.2113032583147287,
3136031.5570504586212337 10089027.8033988755196333,
3136075.8033988750539720 10088983.5570504590868950,
3136096.2448901482857764 10088943.4383649379014969),
(3136485.9030374148860574 10090300.7074119187891483,
3136529.0533988750539720 10090257.5570504590868950,
3136538.7759394771419466 10090238.4754901323467493,
3136567.6966011249460280 10090253.2113032583147287,
3136629.5000000000000000 10090263.0000000000000000,
3136673.4426592872478068 10090256.0401665009558201,
3136674.0386967407539487 10090259.8033988755196333,
3136686.3887514141388237 10090284.0417459215968847,
3136664.3033988750539720 10090272.7886967416852713,
3136602.5000000000000000 10090263.0000000000000000,
3136540.6966011249460280 10090272.7886967416852713,
3136485.9030374148860574 10090300.7074119187891483),
(3136780.3612485853955150 10090376.9582540784031153,
3136785.0644705197773874 10090379.3546653483062983,
3136781.8423122013919055 10090379.8650050908327103,
3136780.3612485853955150 10090376.9582540784031153),
(3137440.3076307177543640 10089862.3445054218173027,
3137410.8732839282602072 10089857.6825628802180290,
3137417.0000000000000000 10089819.0000000000000000,
3137408.2699059154838324 10089763.8803552500903606,
3137432.8883759942837059 10089788.4988253284245729,
3137430.7500000000000000 10089802.0000000000000000,
3137440.3076307177543640 10089862.3445054218173027),
(3137367.2201010216958821 10089689.8596516866236925,
3137368.2013436243869364 10089689.3596836086362600,
3137368.4800940845161676 10089691.1196447499096394,
3137367.2201010216958821 10089689.8596516866236925)),
((3136231.0303096468560398 10085856.1326221227645874,
3136237.7886967407539487 10085898.8033988755196333,
3136266.1966011249460280 10085954.5570504590868950,
3136310.4429495413787663 10085998.8033988755196333,
3136324.5768199875019491 10086006.0049655679613352,
3136316.5000000000000000 10086057.0000000000000000,
3136326.2886967407539487 10086118.8033988755196333,
3136354.6966011249460280 10086174.5570504590868950,
3136398.9429495413787663 10086218.8033988755196333,
3136454.6966011249460280 10086247.2113032583147287,
3136515.4759944668039680 10086256.8378134574741125,
3136514.5000000000000000 10086263.0000000000000000,
3136524.2886967407539487 10086324.8033988755196333,
3136552.6966011249460280 10086380.5570504590868950,
3136581.6139158890582621 10086409.4743652231991291,
3136556.7886967407539487 10086458.1966011244803667,
3136552.8244831729680300 10086483.2256605438888073,
3136534.3033988750539720 10086473.7886967416852713,
3136472.5000000000000000 10086464.0000000000000000,
3136410.6966011249460280 10086473.7886967416852713,
3136354.9429495413787663 10086502.1966011244803667,
3136310.6966011249460280 10086546.4429495409131050,
3136282.2886967407539487 10086602.1966011244803667,
3136272.5000000000000000 10086664.0000000000000000,
3136282.2886967407539487 10086725.8033988755196333,
3136310.6966011249460280 10086781.5570504590868950,
3136354.9429495413787663 10086825.8033988755196333,
3136410.6966011249460280 10086854.2113032583147287,
3136472.5000000000000000 10086864.0000000000000000,
3136534.3033988750539720 10086854.2113032583147287,
3136588.3526731925085187 10086826.6718224678188562,
3136596.4466011249460280 10086842.5570504590868950,
3136640.6929495413787663 10086886.8033988755196333,
3136696.4466011249460280 10086915.2113032583147287,
3136758.2500000000000000 10086925.0000000000000000,
3136820.0533988750539720 10086915.2113032583147287,
3136875.8070504586212337 10086886.8033988755196333,
3136898.3848411221988499 10086864.2256082110106945,
3136906.1966011249460280 10086879.5570504590868950,
3136950.4429495413787663 10086923.8033988755196333,
3137006.1966011249460280 10086952.2113032583147287,
3137068.0000000000000000 10086962.0000000000000000,
3137129.8033988750539720 10086952.2113032583147287,
3137185.5570504586212337 10086923.8033988755196333,
3137229.8033988750539720 10086879.5570504590868950,
3137258.2113032592460513 10086823.8033988755196333,
3137264.1893821405246854 10086786.0592942833900452,
3137320.0533988750539720 10086777.2113032583147287,
3137375.8070504586212337 10086748.8033988755196333,
3137420.0533988750539720 10086704.5570504590868950,
3137426.3809318812564015 10086692.1385677065700293,
3137445.4466011249460280 10086729.5570504590868950,
3137489.6929495413787663 10086773.8033988755196333,
3137545.4466011249460280 10086802.2113032583147287,
3137607.2500000000000000 10086812.0000000000000000,
3137669.0533988750539720 10086802.2113032583147287,
3137724.8070504586212337 10086773.8033988755196333,
3137769.0533988750539720 10086729.5570504590868950,
3137797.4613032592460513 10086673.8033988755196333,
3137807.2500000000000000 10086612.0000000000000000,
3137797.4613032592460513 10086550.1966011244803667,
3137769.0533988750539720 10086494.4429495409131050,
3137724.8070504586212337 10086450.1966011244803667,
3137669.0533988750539720 10086421.7886967416852713,
3137607.2500000000000000 10086412.0000000000000000,
3137545.4466011249460280 10086421.7886967416852713,
3137489.6929495413787663 10086450.1966011244803667,
3137445.4466011249460280 10086494.4429495409131050,
3137439.1190681187435985 10086506.8614322934299707,
3137420.0533988750539720 10086469.4429495409131050,
3137375.8070504586212337 10086425.1966011244803667,
3137320.0533988750539720 10086396.7886967416852713,
3137258.2500000000000000 10086387.0000000000000000,
3137196.4466011249460280 10086396.7886967416852713,
3137140.6929495413787663 10086425.1966011244803667,
3137096.4466011249460280 10086469.4429495409131050,
3137068.0386967407539487 10086525.1966011244803667,
3137062.0606178594753146 10086562.9407057166099548,
3137006.1966011249460280 10086571.7886967416852713,
3136987.8706386149860919 10086581.1262410264462233,
3136975.8033988750539720 10086557.4429495409131050,
3136955.2863845042884350 10086536.9259351696819067,
3136985.0533988750539720 10086532.2113032583147287,
3137040.8070504586212337 10086503.8033988755196333,
3137085.0533988750539720 10086459.5570504590868950,
3137113.4613032592460513 10086403.8033988755196333,
3137115.9443011921830475 10086388.1263669151812792,
3137134.9613032592460513 10086350.8033988755196333,
3137144.7500000000000000 10086289.0000000000000000,
3137134.9613032592460513 10086227.1966011244803667,
3137106.5533988750539720 10086171.4429495409131050,
3137062.3070504586212337 10086127.1966011244803667,
3137006.5533988750539720 10086098.7886967416852713,
3136944.7500000000000000 10086089.0000000000000000,
3136922.5149732907302678 10086092.5216822605580091,
3136913.3033988750539720 10086074.4429495409131050,
3136869.0570504586212337 10086030.1966011244803667,
3136813.3033988750539720 10086001.7886967416852713,
3136751.5000000000000000 10085992.0000000000000000,
3136707.3134586480446160 10085998.9984606225043535,
3136706.7113032592460513 10085995.1966011244803667,
3136678.3033988750539720 10085939.4429495409131050,
3136634.0570504586212337 10085895.1966011244803667,
3136619.9231800124980509 10085887.9950344320386648,
3136628.0000000000000000 10085837.0000000000000000,
3136618.2113032592460513 10085775.1966011244803667,
3136601.0651225661858916 10085741.5453267674893141,
3136611.0533988750539720 10085731.5570504590868950,
3136639.4613032592460513 10085675.8033988755196333,
3136649.2500000000000000 10085614.0000000000000000,
3136639.4613032592460513 10085552.1966011244803667,
3136611.0533988750539720 10085496.4429495409131050,
3136566.8070504586212337 10085452.1966011244803667,
3136511.0533988750539720 10085423.7886967416852713,
3136449.2500000000000000 10085414.0000000000000000,
3136387.4466011249460280 10085423.7886967416852713,
3136331.6929495413787663 10085452.1966011244803667,
3136287.4466011249460280 10085496.4429495409131050,
3136259.0386967407539487 10085552.1966011244803667,
3136249.2500000000000000 10085614.0000000000000000,
3136252.1403840421698987 10085632.2491666246205568,
3136241.9466011249460280 10085642.4429495409131050,
3136213.5386967407539487 10085698.1966011244803667,
3136203.7500000000000000 10085760.0000000000000000,
3136213.5386967407539487 10085821.8033988755196333,
3136231.0303096468560398 10085856.1326221227645874)),
((3134593.6112348921597004 10079947.4177208933979273,
3134621.1966011249460280 10080001.5570504590868950,
3134646.5253711529076099 10080026.8858204875141382,
3134650.7886967407539487 10080053.8033988755196333,
3134679.1966011249460280 10080109.5570504590868950,
3134723.4429495413787663 10080153.8033988755196333,
3134779.1966011249460280 10080182.2113032583147287,
3134839.4884620043449104 10080191.7605959009379148,
3134845.0386967407539487 10080226.8033988755196333,
3134873.4466011249460280 10080282.5570504590868950,
3134917.6929495413787663 10080326.8033988755196333,
3134973.4466011249460280 10080355.2113032583147287,
3135035.2500000000000000 10080365.0000000000000000,
3135097.0533988750539720 10080355.2113032583147287,
3135152.8070504586212337 10080326.8033988755196333,
3135197.0533988750539720 10080282.5570504590868950,
3135199.4076970289461315 10080277.9364801682531834,
3135218.7500000000000000 10080281.0000000000000000,
3135280.5533988750539720 10080271.2113032583147287,
3135336.3070504586212337 10080242.8033988755196333,
3135380.5533988750539720 10080198.5570504590868950,
3135408.9613032592460513 10080142.8033988755196333,
3135418.7500000000000000 10080081.0000000000000000,
3135408.9613032592460513 10080019.1966011244803667,
3135398.9626085888594389 10079999.5730579234659672,
3135410.1929495413787663 10080010.8033988755196333,
3135465.9466011249460280 10080039.2113032583147287,
3135527.7500000000000000 10080049.0000000000000000,
3135589.5533988750539720 10080039.2113032583147287,
3135645.3070504586212337 10080010.8033988755196333,
3135689.5533988750539720 10079966.5570504590868950,
3135717.9613032592460513 10079910.8033988755196333,
3135727.7500000000000000 10079849.0000000000000000,
3135718.7410050220787525 10079792.1194443125277758,
3135738.3033988750539720 10079772.5570504590868950,
3135756.1570575837977231 10079737.5172723159193993,
3135800.6966011249460280 10079760.2113032583147287,
3135862.5000000000000000 10079770.0000000000000000,
3135924.3033988750539720 10079760.2113032583147287,
3135972.0387383080087602 10079735.8889329787343740,
3136023.2500000000000000 10079744.0000000000000000,
3136085.0533988750539720 10079734.2113032583147287,
3136140.8070504586212337 10079705.8033988755196333,
3136185.0533988750539720 10079661.5570504590868950,
3136188.0552117130719125 10079655.6656610481441021,
3136198.1929495413787663 10079665.8033988755196333,
3136253.9466011249460280 10079694.2113032583147287,
3136315.7500000000000000 10079704.0000000000000000,
3136377.5533988750539720 10079694.2113032583147287,
3136433.3070504586212337 10079665.8033988755196333,
3136477.5533988750539720 10079621.5570504590868950,
3136505.9613032592460513 10079565.8033988755196333,
3136510.9105303632095456 10079534.5552087500691414,
3136557.4883951130323112 10079541.9324177913367748,
3136619.2917939880862832 10079532.1437210496515036,
3136675.0454455716535449 10079503.7358166668564081,
3136675.7737206560559571 10079503.0075415819883347,
3136686.2954455716535449 10079497.6464549656957388,
3136730.5417939880862832 10079453.4001065492630005,
3136758.9496983722783625 10079397.6464549656957388,
3136768.7383951130323112 10079335.8430560901761055,
3136764.6933787846937776 10079310.3038281183689833,
3136784.1929495413787663 10079329.8033988755196333,
3136839.9466011249460280 10079358.2113032583147287,
3136901.7500000000000000 10079368.0000000000000000,
3136963.5533988750539720 10079358.2113032583147287,
3137019.3070504586212337 10079329.8033988755196333,
3137063.5533988750539720 10079285.5570504590868950,
3137091.9613032592460513 10079229.8033988755196333,
3137101.7500000000000000 10079168.0000000000000000,
3137094.7447667019441724 10079123.7706976532936096,
3137108.0605429499410093 10079097.6370152998715639,
3137117.8492396906949580 10079035.8336164243519306,
3137113.3613052102737129 10079007.4979132991284132,
3137153.0533988750539720 10079001.2113032583147287,
3137208.8070504586212337 10078972.8033988755196333,
3137253.0533988750539720 10078928.5570504590868950,
3137281.4613032592460513 10078872.8033988755196333,
3137291.2500000000000000 10078811.0000000000000000,
3137286.0401947828941047 10078778.1065844167023897,
3137301.9466011249460280 10078786.2113032583147287,
3137336.4518119087442756 10078791.6763917561620474,
3137336.7886967407539487 10078793.8033988755196333,
3137365.1966011249460280 10078849.5570504590868950,
3137409.4429495413787663 10078893.8033988755196333,
3137465.1966011249460280 10078922.2113032583147287,
3137527.0000000000000000 10078932.0000000000000000,
3137588.8033988750539720 10078922.2113032583147287,
3137644.5570504586212337 10078893.8033988755196333,
3137688.8033988750539720 10078849.5570504590868950,
3137717.2113032592460513 10078793.8033988755196333,
3137727.0000000000000000 10078732.0000000000000000,
3137717.2113032592460513 10078670.1966011244803667,
3137688.8033988750539720 10078614.4429495409131050,
3137644.5570504586212337 10078570.1966011244803667,
3137588.8033988750539720 10078541.7886967416852713,
3137554.2981880912557244 10078536.3236082438379526,
3137553.9613032592460513 10078534.1966011244803667,
3137525.5533988750539720 10078478.4429495409131050,
3137481.3070504586212337 10078434.1966011244803667,
3137446.1522091790102422 10078416.2843148205429316,
3137454.7500000000000000 10078362.0000000000000000,
3137444.9613032592460513 10078300.1966011244803667,
3137416.5533988750539720 10078244.4429495409131050,
3137372.3070504586212337 10078200.1966011244803667,
3137316.5533988750539720 10078171.7886967416852713,
3137254.7500000000000000 10078162.0000000000000000,
3137195.1560419476591051 10078171.4387556929141283,
3137189.5533988750539720 10078160.4429495409131050,
3137145.3070504586212337 10078116.1966011244803667,
3137089.5533988750539720 10078087.7886967416852713,
3137027.7500000000000000 10078078.0000000000000000,
3136965.9466011249460280 10078087.7886967416852713,
3136965.7782769156619906 10078087.8744622096419334,
3136961.7113032592460513 10078062.1966011244803667,
3136933.3033988750539720 10078006.4429495409131050,
3136889.0570504586212337 10077962.1966011244803667,
3136833.3033988750539720 10077933.7886967416852713,
3136771.5000000000000000 10077924.0000000000000000,
3136709.6966011249460280 10077933.7886967416852713,
3136653.9429495413787663 10077962.1966011244803667,
3136609.6966011249460280 10078006.4429495409131050,
3136591.7586365658789873 10078041.6481872312724590,
3136563.3070504586212337 10078013.1966011244803667,
3136507.5533988750539720 10077984.7886967416852713,
3136445.7500000000000000 10077975.0000000000000000,
3136383.9466011249460280 10077984.7886967416852713,
3136328.1929495413787663 10078013.1966011244803667,
3136327.2860413272865117 10078014.1035093385726213,
3136288.7500000000000000 10078008.0000000000000000,
3136226.9466011249460280 10078017.7886967416852713,
3136171.1929495413787663 10078046.1966011244803667,
3136126.9466011249460280 10078090.4429495409131050,
3136098.5386967407539487 10078146.1966011244803667,
3136088.7500000000000000 10078208.0000000000000000,
3136090.5227636806666851 10078219.1927893739193678,
3136080.4466011249460280 10078220.7886967416852713,
3136024.6929495413787663 10078249.1966011244803667,
3135980.4466011249460280 10078293.4429495409131050,
3135952.0386967407539487 10078349.1966011244803667,
3135942.2500000000000000 10078411.0000000000000000,
3135952.0386967407539487 10078472.8033988755196333,
3135980.4466011249460280 10078528.5570504590868950,
3136024.6929495413787663 10078572.8033988755196333,
3136080.4466011249460280 10078601.2113032583147287,
3136142.2500000000000000 10078611.0000000000000000,
3136204.0533988750539720 10078601.2113032583147287,
3136222.6337116872891784 10078591.7441610209643841,
3136263.6929495413787663 10078632.8033988755196333,
3136319.4466011249460280 10078661.2113032583147287,
3136381.2500000000000000 10078671.0000000000000000,
3136443.0533988750539720 10078661.2113032583147287,
3136451.8624289273284376 10078656.7228782624006271,
3136474.9429495413787663 10078679.8033988755196333,
3136530.6966011249460280 10078708.2113032583147287,
3136592.5000000000000000 10078718.0000000000000000,
3136654.3033988750539720 10078708.2113032583147287,
3136710.0570504586212337 10078679.8033988755196333,
3136754.3033988750539720 10078635.5570504590868950,
3136759.6214724010787904 10078625.1197434868663549,
3136809.5533988750539720 10078617.2113032583147287,
3136865.3070504586212337 10078588.8033988755196333,
3136909.5533988750539720 10078544.5570504590868950,
3136929.6009893831796944 10078505.2114387173205614,
3136968.1929495413787663 10078543.8033988755196333,
3136996.3310110857710242 10078558.1404573302716017,
3136945.1929495413787663 10078584.1966011244803667,
3136900.9466011249460280 10078628.4429495409131050,
3136872.5386967407539487 10078684.1966011244803667,
3136869.4293080358766019 10078703.8285087700933218,
3136843.1929495413787663 10078717.1966011244803667,
3136798.9466011249460280 10078761.4429495409131050,
3136770.5386967407539487 10078817.1966011244803667,
3136760.7500000000000000 10078879.0000000000000000,
3136765.4770414792001247 10078908.8453653007745743,
3136756.0458408156409860 10078918.2765659652650356,
3136727.6379364314489067 10078974.0302175488322973,
3136717.8492396906949580 10079035.8336164243519306,
3136724.8544729887507856 10079080.0629187710583210,
3136711.5386967407539487 10079106.1966011244803667,
3136701.7500000000000000 10079168.0000000000000000,
3136705.7950163283385336 10079193.5392279718071222,
3136686.2954455716535449 10079174.0396572146564722,
3136630.5417939880862832 10079145.6317528318613768,
3136568.7383951130323112 10079135.8430560901761055,
3136506.9349962379783392 10079145.6317528318613768,
3136451.1813446544110775 10079174.0396572146564722,
3136450.4530695700086653 10079174.7679322995245457,
3136439.9313446544110775 10079180.1290189158171415,
3136402.7769338502548635 10079217.2834297195076942,
3136386.5533988750539720 10079185.4429495409131050,
3136342.3070504586212337 10079141.1966011244803667,
3136286.5533988750539720 10079112.7886967416852713,
3136224.7500000000000000 10079103.0000000000000000,
3136162.9466011249460280 10079112.7886967416852713,
3136107.1929495413787663 10079141.1966011244803667,
3136062.9466011249460280 10079185.4429495409131050,
3136036.6522077289409935 10079237.0486022550612688,
3136014.5533988750539720 10079225.7886967416852713,
3135952.7500000000000000 10079216.0000000000000000,
3135890.9466011249460280 10079225.7886967416852713,
3135889.9214742882177234 10079226.3110249545425177,
3135884.8070504586212337 10079221.1966011244803667,
3135829.0533988750539720 10079192.7886967416852713,
3135767.2500000000000000 10079183.0000000000000000,
3135705.4466011249460280 10079192.7886967416852713,
3135649.6929495413787663 10079221.1966011244803667,
3135605.4466011249460280 10079265.4429495409131050,
3135577.0386967407539487 10079321.1966011244803667,
3135567.2500000000000000 10079383.0000000000000000,
3135568.2905984548851848 10079389.5700800716876984,
3135545.7500000000000000 10079386.0000000000000000,
3135483.9466011249460280 10079395.7886967416852713,
3135461.6323744524270296 10079407.1583631169050932,
3135422.7500000000000000 10079401.0000000000000000,
3135360.9466011249460280 10079410.7886967416852713,
3135305.1929495413787663 10079439.1966011244803667,
3135260.9466011249460280 10079483.4429495409131050,
3135247.8723987876437604 10079509.1025163996964693,
3135192.3033988750539720 10079480.7886967416852713,
3135179.3794527510181069 10079478.7417447678744793,
3135189.0000000000000000 10079418.0000000000000000,
3135179.2113032592460513 10079356.1966011244803667,
3135150.8033988750539720 10079300.4429495409131050,
3135106.5570504586212337 10079256.1966011244803667,
3135050.8033988750539720 10079227.7886967416852713,
3134989.0000000000000000 10079218.0000000000000000,
3134927.1966011249460280 10079227.7886967416852713,
3134871.4429495413787663 10079256.1966011244803667,
3134827.1966011249460280 10079300.4429495409131050,
3134798.7886967407539487 10079356.1966011244803667,
3134789.0000000000000000 10079418.0000000000000000,
3134798.7886967407539487 10079479.8033988755196333,
3134827.1966011249460280 10079535.5570504590868950,
3134832.7565143438987434 10079541.1169636771082878,
3134796.9466011249460280 10079546.7886967416852713,
3134741.1929495413787663 10079575.1966011244803667,
3134729.0547982314601541 10079587.3347524348646402,
3134708.0000000000000000 10079584.0000000000000000,
3134646.1966011249460280 10079593.7886967416852713,
3134590.4429495413787663 10079622.1966011244803667,
3134546.1966011249460280 10079666.4429495409131050,
3134517.7886967407539487 10079722.1966011244803667,
3134508.0000000000000000 10079784.0000000000000000,
3134517.7886967407539487 10079845.8033988755196333,
3134546.1966011249460280 10079901.5570504590868950,
3134590.4429495413787663 10079945.8033988755196333,
3134593.6112348921597004 10079947.4177208933979273),
(3137169.2703358461149037 10078561.1459711864590645,
3137166.7162635060958564 10078577.2717492934316397,
3137152.1689889146946371 10078569.8595426678657532,
3137169.2703358461149037 10078561.1459711864590645)),
((3137593.5000000000000000 10092988.0000000000000000,
3137583.7113032592460513 10092926.1966011244803667,
3137555.3033988750539720 10092870.4429495409131050,
3137511.0570504586212337 10092826.1966011244803667,
3137455.3033988750539720 10092797.7886967416852713,
3137393.5000000000000000 10092788.0000000000000000,
3137331.6966011249460280 10092797.7886967416852713,
3137275.9429495413787663 10092826.1966011244803667,
3137231.6966011249460280 10092870.4429495409131050,
3137203.2886967407539487 10092926.1966011244803667,
3137193.5000000000000000 10092988.0000000000000000,
3137203.2886967407539487 10093049.8033988755196333,
3137231.6966011249460280 10093105.5570504590868950,
3137275.9429495413787663 10093149.8033988755196333,
3137331.6966011249460280 10093178.2113032583147287,
3137393.5000000000000000 10093188.0000000000000000,
3137455.3033988750539720 10093178.2113032583147287,
3137511.0570504586212337 10093149.8033988755196333,
3137555.3033988750539720 10093105.5570504590868950,
3137583.7113032592460513 10093049.8033988755196333,
3137593.5000000000000000 10092988.0000000000000000)),
((3137360.2500000000000000 10094928.0000000000000000,
3137350.4613032592460513 10094866.1966011244803667,
3137322.0533988750539720 10094810.4429495409131050,
3137277.8070504586212337 10094766.1966011244803667,
3137222.0533988750539720 10094737.7886967416852713,
3137160.2500000000000000 10094728.0000000000000000,
3137098.4466011249460280 10094737.7886967416852713,
3137042.6929495413787663 10094766.1966011244803667,
3136998.4466011249460280 10094810.4429495409131050,
3136970.0386967407539487 10094866.1966011244803667,
3136960.2500000000000000 10094928.0000000000000000,
3136970.0386967407539487 10094989.8033988755196333,
3136998.4466011249460280 10095045.5570504590868950,
3137042.6929495413787663 10095089.8033988755196333,
3137098.4466011249460280 10095118.2113032583147287,
3137160.2500000000000000 10095128.0000000000000000,
3137222.0533988750539720 10095118.2113032583147287,
3137277.8070504586212337 10095089.8033988755196333,
3137322.0533988750539720 10095045.5570504590868950,
3137350.4613032592460513 10094989.8033988755196333,
3137360.2500000000000000 10094928.0000000000000000)),
((3137340.0000000000000000 10085508.0000000000000000,
3137330.2113032592460513 10085446.1966011244803667,
3137301.8033988750539720 10085390.4429495409131050,
3137257.5570504586212337 10085346.1966011244803667,
3137201.8033988750539720 10085317.7886967416852713,
3137140.0000000000000000 10085308.0000000000000000,
3137078.1966011249460280 10085317.7886967416852713,
3137022.4429495413787663 10085346.1966011244803667,
3136978.1966011249460280 10085390.4429495409131050,
3136949.7886967407539487 10085446.1966011244803667,
3136940.0000000000000000 10085508.0000000000000000,
3136949.7886967407539487 10085569.8033988755196333,
3136978.1966011249460280 10085625.5570504590868950,
3137022.4429495413787663 10085669.8033988755196333,
3137078.1966011249460280 10085698.2113032583147287,
3137140.0000000000000000 10085708.0000000000000000,
3137201.8033988750539720 10085698.2113032583147287,
3137257.5570504586212337 10085669.8033988755196333,
3137301.8033988750539720 10085625.5570504590868950,
3137330.2113032592460513 10085569.8033988755196333,
3137340.0000000000000000 10085508.0000000000000000)),
((3137315.5000000000000000 10093795.0000000000000000,
3137305.7113032592460513 10093733.1966011244803667,
3137277.3033988750539720 10093677.4429495409131050,
3137233.0570504586212337 10093633.1966011244803667,
3137177.3033988750539720 10093604.7886967416852713,
3137115.5000000000000000 10093595.0000000000000000,
3137053.6966011249460280 10093604.7886967416852713,
3136997.9429495413787663 10093633.1966011244803667,
3136953.6966011249460280 10093677.4429495409131050,
3136925.2886967407539487 10093733.1966011244803667,
3136915.5000000000000000 10093795.0000000000000000,
3136925.2886967407539487 10093856.8033988755196333,
3136953.6966011249460280 10093912.5570504590868950,
3136997.9429495413787663 10093956.8033988755196333,
3137053.6966011249460280 10093985.2113032583147287,
3137115.5000000000000000 10093995.0000000000000000,
3137177.3033988750539720 10093985.2113032583147287,
3137233.0570504586212337 10093956.8033988755196333,
3137277.3033988750539720 10093912.5570504590868950,
3137305.7113032592460513 10093856.8033988755196333,
3137315.5000000000000000 10093795.0000000000000000)),
((3136983.7500000000000000 10093007.0000000000000000,
3136973.9613032592460513 10092945.1966011244803667,
3136945.5533988750539720 10092889.4429495409131050,
3136901.3070504586212337 10092845.1966011244803667,
3136845.5533988750539720 10092816.7886967416852713,
3136783.7500000000000000 10092807.0000000000000000,
3136721.9466011249460280 10092816.7886967416852713,
3136666.1929495413787663 10092845.1966011244803667,
3136621.9466011249460280 10092889.4429495409131050,
3136593.5386967407539487 10092945.1966011244803667,
3136583.7500000000000000 10093007.0000000000000000,
3136593.5386967407539487 10093068.8033988755196333,
3136621.9466011249460280 10093124.5570504590868950,
3136666.1929495413787663 10093168.8033988755196333,
3136721.9466011249460280 10093197.2113032583147287,
3136783.7500000000000000 10093207.0000000000000000,
3136845.5533988750539720 10093197.2113032583147287,
3136901.3070504586212337 10093168.8033988755196333,
3136945.5533988750539720 10093124.5570504590868950,
3136973.9613032592460513 10093068.8033988755196333,
3136983.7500000000000000 10093007.0000000000000000)),
((3136980.2500000000000000 10098846.0000000000000000,
3136970.4613032592460513 10098784.1966011244803667,
3136942.0533988750539720 10098728.4429495409131050,
3136897.8070504586212337 10098684.1966011244803667,
3136842.0533988750539720 10098655.7886967416852713,
3136780.2500000000000000 10098646.0000000000000000,
3136718.4466011249460280 10098655.7886967416852713,
3136662.6929495413787663 10098684.1966011244803667,
3136618.4466011249460280 10098728.4429495409131050,
3136590.0386967407539487 10098784.1966011244803667,
3136580.2500000000000000 10098846.0000000000000000,
3136590.0386967407539487 10098907.8033988755196333,
3136618.4466011249460280 10098963.5570504590868950,
3136662.6929495413787663 10099007.8033988755196333,
3136718.4466011249460280 10099036.2113032583147287,
3136780.2500000000000000 10099046.0000000000000000,
3136842.0533988750539720 10099036.2113032583147287,
3136897.8070504586212337 10099007.8033988755196333,
3136942.0533988750539720 10098963.5570504590868950,
3136970.4613032592460513 10098907.8033988755196333,
3136980.2500000000000000 10098846.0000000000000000)),
((3136479.0811529960483313 10095137.0213648565113544,
3136434.7500000000000000 10095130.0000000000000000,
3136372.9466011249460280 10095139.7886967416852713,
3136317.1929495413787663 10095168.1966011244803667,
3136272.9466011249460280 10095212.4429495409131050,
3136244.5386967407539487 10095268.1966011244803667,
3136234.7500000000000000 10095330.0000000000000000,
3136244.5386967407539487 10095391.8033988755196333,
3136272.9466011249460280 10095447.5570504590868950,
3136317.1929495413787663 10095491.8033988755196333,
3136372.9466011249460280 10095520.2113032583147287,
3136434.7500000000000000 10095530.0000000000000000,
3136496.5533988750539720 10095520.2113032583147287,
3136552.3070504586212337 10095491.8033988755196333,
3136596.5533988750539720 10095447.5570504590868950,
3136624.9613032592460513 10095391.8033988755196333,
3136626.3029040037654340 10095383.3328651431947947,
3136670.6340569998137653 10095390.3542299997061491,
3136732.4374558748677373 10095380.5655332580208778,
3136788.1911074584349990 10095352.1576288752257824,
3136832.4374558748677373 10095307.9112804587930441,
3136860.8453602590598166 10095252.1576288752257824,
3136870.6340569998137653 10095190.3542299997061491,
3136860.8453602590598166 10095128.5508311241865158,
3136832.4374558748677373 10095072.7971795406192541,
3136788.1911074584349990 10095028.5508311241865158,
3136732.4374558748677373 10095000.1429267413914204,
3136670.6340569998137653 10094990.3542299997061491,
3136608.8306581247597933 10095000.1429267413914204,
3136553.0770065411925316 10095028.5508311241865158,
3136508.8306581247597933 10095072.7971795406192541,
3136480.4227537405677140 10095128.5508311241865158,
3136479.0811529960483313 10095137.0213648565113544)),
((3136783.2760279998183250 10091497.3104800004512072,
3136773.4873312590643764 10091435.5070811249315739,
3136745.0794268748722970 10091379.7534295413643122,
3136700.8330784584395587 10091335.5070811249315739,
3136645.0794268748722970 10091307.0991767421364784,
3136583.2760279998183250 10091297.3104800004512072,
3136521.4726291247643530 10091307.0991767421364784,
3136465.7189775411970913 10091335.5070811249315739,
3136421.4726291247643530 10091379.7534295413643122,
3136393.0647247405722737 10091435.5070811249315739,
3136383.2760279998183250 10091497.3104800004512072,
3136393.0647247405722737 10091559.1138788759708405,
3136421.4726291247643530 10091614.8675304595381021,
3136465.7189775411970913 10091659.1138788759708405,
3136521.4726291247643530 10091687.5217832587659359,
3136583.2760279998183250 10091697.3104800004512072,
3136645.0794268748722970 10091687.5217832587659359,
3136700.8330784584395587 10091659.1138788759708405,
3136745.0794268748722970 10091614.8675304595381021,
3136773.4873312590643764 10091559.1138788759708405,
3136783.2760279998183250 10091497.3104800004512072)),
((3135965.9308513822034001 10095193.7913007158786058,
3135934.6161211249418557 10095198.7510667424649000,
3135878.8624695413745940 10095227.1589711252599955,
3135834.6161211249418557 10095271.4053195416927338,
3135806.2082167407497764 10095327.1589711252599955,
3135796.4195199999958277 10095388.9623700007796288,
3135806.2082167407497764 10095450.7657688762992620,
3135834.6161211249418557 10095506.5194204598665237,
3135878.8624695413745940 10095550.7657688762992620,
3135934.6161211249418557 10095579.1736732590943575,
3135996.4195199999958277 10095588.9623700007796288,
3136058.2229188750497997 10095579.1736732590943575,
3136113.9765704586170614 10095550.7657688762992620,
3136158.2229188750497997 10095506.5194204598665237,
3136186.6308232592418790 10095450.7657688762992620,
3136196.4195199999958277 10095388.9623700007796288,
3136186.6308232592418790 10095327.1589711252599955,
3136158.2229188750497997 10095271.4053195416927338,
3136136.9886686177924275 10095250.1710692849010229,
3136168.3033988750539720 10095245.2113032583147287,
3136224.0570504586212337 10095216.8033988755196333,
3136268.3033988750539720 10095172.5570504590868950,
3136296.7113032592460513 10095116.8033988755196333,
3136306.5000000000000000 10095055.0000000000000000,
3136296.7113032592460513 10094993.1966011244803667,
3136268.3033988750539720 10094937.4429495409131050,
3136224.0570504586212337 10094893.1966011244803667,
3136168.3033988750539720 10094864.7886967416852713,
3136106.5000000000000000 10094855.0000000000000000,
3136044.6966011249460280 10094864.7886967416852713,
3135988.9429495413787663 10094893.1966011244803667,
3135944.6966011249460280 10094937.4429495409131050,
3135916.2886967407539487 10094993.1966011244803667,
3135906.5000000000000000 10095055.0000000000000000,
3135916.2886967407539487 10095116.8033988755196333,
3135944.6966011249460280 10095172.5570504590868950,
3135965.9308513822034001 10095193.7913007158786058)),
((3135011.9192220158874989 10083217.3137515150010586,
3135005.0000000000000000 10083261.0000000000000000,
3135014.7886967407539487 10083322.8033988755196333,
3135036.3676004856824875 10083365.1543820630759001,
3135041.5386967407539487 10083397.8033988755196333,
3135069.9466011249460280 10083453.5570504590868950,
3135114.1929495413787663 10083497.8033988755196333,
3135169.9466011249460280 10083526.2113032583147287,
3135231.7500000000000000 10083536.0000000000000000,
3135293.5533988750539720 10083526.2113032583147287,
3135349.3070504586212337 10083497.8033988755196333,
3135393.5533988750539720 10083453.5570504590868950,
3135421.9613032592460513 10083397.8033988755196333,
3135431.7500000000000000 10083336.0000000000000000,
3135426.3700395757332444 10083302.0322667192667723,
3135431.5533988750539720 10083301.2113032583147287,
3135487.3070504586212337 10083272.8033988755196333,
3135493.0000000000000000 10083267.1104493346065283,
3135529.6929495413787663 10083303.8033988755196333,
3135585.4466011249460280 10083332.2113032583147287,
3135647.2500000000000000 10083342.0000000000000000,
3135709.0533988750539720 10083332.2113032583147287,
3135764.8070504586212337 10083303.8033988755196333,
3135769.0346932280808687 10083299.5757561065256596,
3135777.6444400870241225 10083316.4733357410877943,
3135821.8907885034568608 10083360.7196841575205326,
3135877.6444400870241225 10083389.1275885403156281,
3135939.4478389620780945 10083398.9162852820008993,
3136001.2512378371320665 10083389.1275885403156281,
3136057.0048894206993282 10083360.7196841575205326,
3136101.2512378371320665 10083316.4733357410877943,
3136129.6591422213241458 10083260.7196841575205326,
3136139.4478389620780945 10083198.9162852820008993,
3136129.6591422213241458 10083137.1128864064812660,
3136109.9735063440166414 10083098.4776506256312132,
3136114.0825064848177135 10083072.5344447623938322,
3136104.2938097440637648 10083010.7310458868741989,
3136075.8859053598716855 10082954.9773943033069372,
3136031.6395569434389472 10082910.7310458868741989,
3135975.8859053598716855 10082882.3231415040791035,
3135914.0825064848177135 10082872.5344447623938322,
3135852.2791076097637415 10082882.3231415040791035,
3135796.5254560261964798 10082910.7310458868741989,
3135752.2791076097637415 10082954.9773943033069372,
3135744.6598255583085120 10082969.9310773015022278,
3135709.0533988750539720 10082951.7886967416852713,
3135647.2500000000000000 10082942.0000000000000000,
3135585.4466011249460280 10082951.7886967416852713,
3135583.7451542899943888 10082952.6556272059679031,
3135565.8033988750539720 10082917.4429495409131050,
3135521.5570504586212337 10082873.1966011244803667,
3135465.8033988750539720 10082844.7886967416852713,
3135404.0000000000000000 10082835.0000000000000000,
3135342.1966011249460280 10082844.7886967416852713,
3135286.4429495413787663 10082873.1966011244803667,
3135242.1966011249460280 10082917.4429495409131050,
3135218.7334701595827937 10082963.4919368661940098,
3135203.0000000000000000 10082961.0000000000000000,
3135141.1966011249460280 10082970.7886967416852713,
3135085.4429495413787663 10082999.1966011244803667,
3135041.1966011249460280 10083043.4429495409131050,
3135012.7886967407539487 10083099.1966011244803667,
3135003.0000000000000000 10083161.0000000000000000,
3135011.9192220158874989 10083217.3137515150010586)),
((3136071.7500000000000000 10100522.0000000000000000,
3136061.9613032592460513 10100460.1966011244803667,
3136033.5533988750539720 10100404.4429495409131050,
3135989.3070504586212337 10100360.1966011244803667,
3135933.5533988750539720 10100331.7886967416852713,
3135871.7500000000000000 10100322.0000000000000000,
3135809.9466011249460280 10100331.7886967416852713,
3135754.1929495413787663 10100360.1966011244803667,
3135709.9466011249460280 10100404.4429495409131050,
3135681.5386967407539487 10100460.1966011244803667,
3135671.7500000000000000 10100522.0000000000000000,
3135681.5386967407539487 10100583.8033988755196333,
3135709.9466011249460280 10100639.5570504590868950,
3135754.1929495413787663 10100683.8033988755196333,
3135809.9466011249460280 10100712.2113032583147287,
3135871.7500000000000000 10100722.0000000000000000,
3135933.5533988750539720 10100712.2113032583147287,
3135989.3070504586212337 10100683.8033988755196333,
3136033.5533988750539720 10100639.5570504590868950,
3136061.9613032592460513 10100583.8033988755196333,
3136071.7500000000000000 10100522.0000000000000000)),
((3136068.0000000000000000 10099066.0000000000000000,
3136058.2113032592460513 10099004.1966011244803667,
3136029.8033988750539720 10098948.4429495409131050,
3135985.5570504586212337 10098904.1966011244803667,
3135929.8033988750539720 10098875.7886967416852713,
3135868.0000000000000000 10098866.0000000000000000,
3135806.1966011249460280 10098875.7886967416852713,
3135750.4429495413787663 10098904.1966011244803667,
3135706.1966011249460280 10098948.4429495409131050,
3135677.7886967407539487 10099004.1966011244803667,
3135668.0000000000000000 10099066.0000000000000000,
3135677.7886967407539487 10099127.8033988755196333,
3135706.1966011249460280 10099183.5570504590868950,
3135750.4429495413787663 10099227.8033988755196333,
3135806.1966011249460280 10099256.2113032583147287,
3135868.0000000000000000 10099266.0000000000000000,
3135929.8033988750539720 10099256.2113032583147287,
3135985.5570504586212337 10099227.8033988755196333,
3136029.8033988750539720 10099183.5570504590868950,
3136058.2113032592460513 10099127.8033988755196333,
3136068.0000000000000000 10099066.0000000000000000)),
((3135644.7533988519571722 10084983.6157238278537989,
3135625.3033988750539720 10084945.4429495409131050,
3135581.0570504586212337 10084901.1966011244803667,
3135525.3033988750539720 10084872.7886967416852713,
3135463.5000000000000000 10084863.0000000000000000,
3135401.6966011249460280 10084872.7886967416852713,
3135345.9429495413787663 10084901.1966011244803667,
3135301.6966011249460280 10084945.4429495409131050,
3135273.2886967407539487 10085001.1966011244803667,
3135263.5000000000000000 10085063.0000000000000000,
3135273.2886967407539487 10085124.8033988755196333,
3135301.6966011249460280 10085180.5570504590868950,
3135345.9429495413787663 10085224.8033988755196333,
3135401.6966011249460280 10085253.2113032583147287,
3135463.5000000000000000 10085263.0000000000000000,
3135525.3033988750539720 10085253.2113032583147287,
3135581.0570504586212337 10085224.8033988755196333,
3135625.3033988750539720 10085180.5570504590868950,
3135653.7113032592460513 10085124.8033988755196333,
3135660.7466011480428278 10085080.3842761721462011,
3135680.1966011249460280 10085118.5570504590868950,
3135724.4429495413787663 10085162.8033988755196333,
3135780.1966011249460280 10085191.2113032583147287,
3135842.0000000000000000 10085201.0000000000000000,
3135903.8033988750539720 10085191.2113032583147287,
3135959.5570504586212337 10085162.8033988755196333,
3136003.8033988750539720 10085118.5570504590868950,
3136032.2113032592460513 10085062.8033988755196333,
3136042.0000000000000000 10085001.0000000000000000,
3136032.2113032592460513 10084939.1966011244803667,
3136003.8033988750539720 10084883.4429495409131050,
3135959.5570504586212337 10084839.1966011244803667,
3135903.8033988750539720 10084810.7886967416852713,
3135842.0000000000000000 10084801.0000000000000000,
3135780.1966011249460280 10084810.7886967416852713,
3135724.4429495413787663 10084839.1966011244803667,
3135680.1966011249460280 10084883.4429495409131050,
3135651.7886967407539487 10084939.1966011244803667,
3135644.7533988519571722 10084983.6157238278537989)),
((3135363.1430372083559632 10093168.4519253540784121,
3135336.5701712640002370 10093195.0247912984341383,
3135308.1622668798081577 10093250.7784428820014000,
3135298.3735701390542090 10093312.5818417575210333,
3135308.1622668798081577 10093374.3852406330406666,
3135336.5701712640002370 10093430.1388922166079283,
3135380.8165196804329753 10093474.3852406330406666,
3135436.5701712640002370 10093502.7931450158357620,
3135498.3735701390542090 10093512.5818417575210333,
3135558.7226356337778270 10093503.0234887935221195,
3135561.5386967407539487 10093520.8033988755196333,
3135589.9466011249460280 10093576.5570504590868950,
3135634.1929495413787663 10093620.8033988755196333,
3135689.9466011249460280 10093649.2113032583147287,
3135751.7500000000000000 10093659.0000000000000000,
3135813.5533988750539720 10093649.2113032583147287,
3135869.3070504586212337 10093620.8033988755196333,
3135913.5533988750539720 10093576.5570504590868950,
3135941.9613032592460513 10093520.8033988755196333,
3135951.7500000000000000 10093459.0000000000000000,
3135941.9613032592460513 10093397.1966011244803667,
3135913.5533988750539720 10093341.4429495409131050,
3135869.3070504586212337 10093297.1966011244803667,
3135813.5533988750539720 10093268.7886967416852713,
3135751.7500000000000000 10093259.0000000000000000,
3135691.4009345052763820 10093268.5583529639989138,
3135688.5848733983002603 10093250.7784428820014000,
3135660.2305329306982458 10093195.1299164034426212,
3135686.8033988750539720 10093168.5570504590868950,
3135715.2113032592460513 10093112.8033988755196333,
3135725.0000000000000000 10093051.0000000000000000,
3135715.2113032592460513 10092989.1966011244803667,
3135686.8033988750539720 10092933.4429495409131050,
3135642.5570504586212337 10092889.1966011244803667,
3135586.8033988750539720 10092860.7886967416852713,
3135525.0000000000000000 10092851.0000000000000000,
3135463.1966011249460280 10092860.7886967416852713,
3135407.4429495413787663 10092889.1966011244803667,
3135363.1966011249460280 10092933.4429495409131050,
3135334.7886967407539487 10092989.1966011244803667,
3135325.0000000000000000 10093051.0000000000000000,
3135334.7886967407539487 10093112.8033988755196333,
3135363.1430372083559632 10093168.4519253540784121)),
((3135214.6455022036097944 10095839.0197838973253965,
3135200.2886967407539487 10095867.1966011244803667,
3135190.5000000000000000 10095929.0000000000000000,
3135200.2886967407539487 10095990.8033988755196333,
3135228.6966011249460280 10096046.5570504590868950,
3135272.9429495413787663 10096090.8033988755196333,
3135328.6966011249460280 10096119.2113032583147287,
3135390.5000000000000000 10096129.0000000000000000,
3135452.3033988750539720 10096119.2113032583147287,
3135508.0570504586212337 10096090.8033988755196333,
3135511.7199808158911765 10096087.1404685191810131,
3135510.0000000000000000 10096098.0000000000000000,
3135519.7886967407539487 10096159.8033988755196333,
3135548.1966011249460280 10096215.5570504590868950,
3135592.4429495413787663 10096259.8033988755196333,
3135648.1966011249460280 10096288.2113032583147287,
3135710.0000000000000000 10096298.0000000000000000,
3135771.8033988750539720 10096288.2113032583147287,
3135827.5570504586212337 10096259.8033988755196333,
3135871.8033988750539720 10096215.5570504590868950,
3135900.2113032592460513 10096159.8033988755196333,
3135910.0000000000000000 10096098.0000000000000000,
3135900.2113032592460513 10096036.1966011244803667,
3135871.8033988750539720 10095980.4429495409131050,
3135827.5570504586212337 10095936.1966011244803667,
3135771.8033988750539720 10095907.7886967416852713,
3135751.3347590342164040 10095904.5467826761305332,
3135752.4613032592460513 10095902.3358151447027922,
3135762.2500000000000000 10095840.5324162691831589,
3135752.4613032592460513 10095778.7290173936635256,
3135724.0533988750539720 10095722.9753658100962639,
3135679.8070504586212337 10095678.7290173936635256,
3135624.0533988750539720 10095650.3211130108684301,
3135562.2500000000000000 10095640.5324162691831589,
3135500.4466011249460280 10095650.3211130108684301,
3135479.1378931580111384 10095661.1784420162439346,
3135480.7500000000000000 10095651.0000000000000000,
3135470.9613032592460513 10095589.1966011244803667,
3135442.5533988750539720 10095533.4429495409131050,
3135398.3070504586212337 10095489.1966011244803667,
3135342.5533988750539720 10095460.7886967416852713,
3135280.7500000000000000 10095451.0000000000000000,
3135218.9466011249460280 10095460.7886967416852713,
3135163.1929495413787663 10095489.1966011244803667,
3135118.9466011249460280 10095533.4429495409131050,
3135090.5386967407539487 10095589.1966011244803667,
3135080.7500000000000000 10095651.0000000000000000,
3135090.5386967407539487 10095712.8033988755196333,
3135118.9466011249460280 10095768.5570504590868950,
3135163.1929495413787663 10095812.8033988755196333,
3135214.6455022036097944 10095839.0197838973253965)),
((3135890.7500000000000000 10094022.0000000000000000,
3135880.9613032592460513 10093960.1966011244803667,
3135852.5533988750539720 10093904.4429495409131050,
3135808.3070504586212337 10093860.1966011244803667,
3135752.5533988750539720 10093831.7886967416852713,
3135690.7500000000000000 10093822.0000000000000000,
3135628.9466011249460280 10093831.7886967416852713,
3135573.1929495413787663 10093860.1966011244803667,
3135528.9466011249460280 10093904.4429495409131050,
3135500.5386967407539487 10093960.1966011244803667,
3135490.7500000000000000 10094022.0000000000000000,
3135500.5386967407539487 10094083.8033988755196333,
3135528.9466011249460280 10094139.5570504590868950,
3135573.1929495413787663 10094183.8033988755196333,
3135628.9466011249460280 10094212.2113032583147287,
3135690.7500000000000000 10094222.0000000000000000,
3135752.5533988750539720 10094212.2113032583147287,
3135808.3070504586212337 10094183.8033988755196333,
3135852.5533988750539720 10094139.5570504590868950,
3135880.9613032592460513 10094083.8033988755196333,
3135890.7500000000000000 10094022.0000000000000000)),
((3135840.7500000000000000 10098400.0000000000000000,
3135830.9613032592460513 10098338.1966011244803667,
3135802.5533988750539720 10098282.4429495409131050,
3135758.3070504586212337 10098238.1966011244803667,
3135702.5533988750539720 10098209.7886967416852713,
3135640.7500000000000000 10098200.0000000000000000,
3135578.9466011249460280 10098209.7886967416852713,
3135523.1929495413787663 10098238.1966011244803667,
3135478.9466011249460280 10098282.4429495409131050,
3135450.5386967407539487 10098338.1966011244803667,
3135440.7500000000000000 10098400.0000000000000000,
3135450.5386967407539487 10098461.8033988755196333,
3135478.9466011249460280 10098517.5570504590868950,
3135523.1929495413787663 10098561.8033988755196333,
3135578.9466011249460280 10098590.2113032583147287,
3135640.7500000000000000 10098600.0000000000000000,
3135702.5533988750539720 10098590.2113032583147287,
3135758.3070504586212337 10098561.8033988755196333,
3135802.5533988750539720 10098517.5570504590868950,
3135830.9613032592460513 10098461.8033988755196333,
3135840.7500000000000000 10098400.0000000000000000)),
((3135716.5000000000000000 10099410.0000000000000000,
3135706.7113032592460513 10099348.1966011244803667,
3135678.3033988750539720 10099292.4429495409131050,
3135634.0570504586212337 10099248.1966011244803667,
3135578.3033988750539720 10099219.7886967416852713,
3135516.5000000000000000 10099210.0000000000000000,
3135454.6966011249460280 10099219.7886967416852713,
3135398.9429495413787663 10099248.1966011244803667,
3135354.6966011249460280 10099292.4429495409131050,
3135326.2886967407539487 10099348.1966011244803667,
3135316.5000000000000000 10099410.0000000000000000,
3135326.2886967407539487 10099471.8033988755196333,
3135354.6966011249460280 10099527.5570504590868950,
3135398.9429495413787663 10099571.8033988755196333,
3135454.6966011249460280 10099600.2113032583147287,
3135516.5000000000000000 10099610.0000000000000000,
3135578.3033988750539720 10099600.2113032583147287,
3135634.0570504586212337 10099571.8033988755196333,
3135678.3033988750539720 10099527.5570504590868950,
3135706.7113032592460513 10099471.8033988755196333,
3135716.5000000000000000 10099410.0000000000000000)),
((3135702.1557247699238360 10094411.7714265864342451,
3135692.3670280291698873 10094349.9680277109146118,
3135663.9591236449778080 10094294.2143761273473501,
3135619.7127752285450697 10094249.9680277109146118,
3135563.9591236449778080 10094221.5601233281195164,
3135502.1557247699238360 10094211.7714265864342451,
3135440.3523258948698640 10094221.5601233281195164,
3135384.5986743113026023 10094249.9680277109146118,
3135340.3523258948698640 10094294.2143761273473501,
3135311.9444215106777847 10094349.9680277109146118,
3135302.1557247699238360 10094411.7714265864342451,
3135311.9444215106777847 10094473.5748254619538784,
3135340.3523258948698640 10094529.3284770455211401,
3135384.5986743113026023 10094573.5748254619538784,
3135440.3523258948698640 10094601.9827298447489738,
3135502.1557247699238360 10094611.7714265864342451,
3135563.9591236449778080 10094601.9827298447489738,
3135619.7127752285450697 10094573.5748254619538784,
3135663.9591236449778080 10094529.3284770455211401,
3135692.3670280291698873 10094473.5748254619538784,
3135702.1557247699238360 10094411.7714265864342451)),
((3135264.6535237450152636 10096725.2069255895912647,
3135255.5000000000000000 10096783.0000000000000000,
3135265.2886967407539487 10096844.8033988755196333,
3135293.6966011249460280 10096900.5570504590868950,
3135337.9429495413787663 10096944.8033988755196333,
3135393.6966011249460280 10096973.2113032583147287,
3135455.5000000000000000 10096983.0000000000000000,
3135517.3033988750539720 10096973.2113032583147287,
3135573.0570504586212337 10096944.8033988755196333,
3135617.3033988750539720 10096900.5570504590868950,
3135645.7113032592460513 10096844.8033988755196333,
3135655.5000000000000000 10096783.0000000000000000,
3135645.7113032592460513 10096721.1966011244803667,
3135617.3033988750539720 10096665.4429495409131050,
3135573.0570504586212337 10096621.1966011244803667,
3135517.3033988750539720 10096592.7886967416852713,
3135455.5000000000000000 10096583.0000000000000000,
3135393.6966011249460280 10096592.7886967416852713,
3135337.9429495413787663 10096621.1966011244803667,
3135334.3464762549847364 10096624.7930744104087353,
3135343.5000000000000000 10096567.0000000000000000,
3135333.7113032592460513 10096505.1966011244803667,
3135305.3033988750539720 10096449.4429495409131050,
3135261.0570504586212337 10096405.1966011244803667,
3135205.3033988750539720 10096376.7886967416852713,
3135143.5000000000000000 10096367.0000000000000000,
3135081.6966011249460280 10096376.7886967416852713,
3135025.9429495413787663 10096405.1966011244803667,
3134981.6966011249460280 10096449.4429495409131050,
3134953.2886967407539487 10096505.1966011244803667,
3134943.5000000000000000 10096567.0000000000000000,
3134953.2886967407539487 10096628.8033988755196333,
3134981.6966011249460280 10096684.5570504590868950,
3135025.9429495413787663 10096728.8033988755196333,
3135081.6966011249460280 10096757.2113032583147287,
3135143.5000000000000000 10096767.0000000000000000,
3135205.3033988750539720 10096757.2113032583147287,
3135261.0570504586212337 10096728.8033988755196333,
3135264.6535237450152636 10096725.2069255895912647)),
((3135642.5000000000000000 10091602.0000000000000000,
3135632.7113032592460513 10091540.1966011244803667,
3135604.3033988750539720 10091484.4429495409131050,
3135560.0570504586212337 10091440.1966011244803667,
3135504.3033988750539720 10091411.7886967416852713,
3135442.5000000000000000 10091402.0000000000000000,
3135380.6966011249460280 10091411.7886967416852713,
3135324.9429495413787663 10091440.1966011244803667,
3135280.6966011249460280 10091484.4429495409131050,
3135252.2886967407539487 10091540.1966011244803667,
3135242.5000000000000000 10091602.0000000000000000,
3135252.2886967407539487 10091663.8033988755196333,
3135280.6966011249460280 10091719.5570504590868950,
3135324.9429495413787663 10091763.8033988755196333,
3135380.6966011249460280 10091792.2113032583147287,
3135442.5000000000000000 10091802.0000000000000000,
3135504.3033988750539720 10091792.2113032583147287,
3135560.0570504586212337 10091763.8033988755196333,
3135604.3033988750539720 10091719.5570504590868950,
3135632.7113032592460513 10091663.8033988755196333,
3135642.5000000000000000 10091602.0000000000000000)),
((3134815.3865317041054368 10082639.9065262638032436,
3134804.5386967407539487 10082661.1966011244803667,
3134794.7500000000000000 10082723.0000000000000000,
3134804.5386967407539487 10082784.8033988755196333,
3134832.9466011249460280 10082840.5570504590868950,
3134877.1929495413787663 10082884.8033988755196333,
3134932.9466011249460280 10082913.2113032583147287,
3134994.7500000000000000 10082923.0000000000000000,
3135056.5533988750539720 10082913.2113032583147287,
3135112.3070504586212337 10082884.8033988755196333,
3135156.5533988750539720 10082840.5570504590868950,
3135184.9613032592460513 10082784.8033988755196333,
3135194.7500000000000000 10082723.0000000000000000,
3135184.9613032592460513 10082661.1966011244803667,
3135169.1134682958945632 10082630.0934737361967564,
3135179.9613032592460513 10082608.8033988755196333,
3135185.1949502024799585 10082575.7594525609165430,
3135190.6966011249460280 10082586.5570504590868950,
3135234.9429495413787663 10082630.8033988755196333,
3135290.6966011249460280 10082659.2113032583147287,
3135352.5000000000000000 10082669.0000000000000000,
3135414.3033988750539720 10082659.2113032583147287,
3135470.0570504586212337 10082630.8033988755196333,
3135514.3033988750539720 10082586.5570504590868950,
3135542.7113032592460513 10082530.8033988755196333,
3135552.5000000000000000 10082469.0000000000000000,
3135542.7113032592460513 10082407.1966011244803667,
3135514.3033988750539720 10082351.4429495409131050,
3135470.0570504586212337 10082307.1966011244803667,
3135414.3033988750539720 10082278.7886967416852713,
3135352.5000000000000000 10082269.0000000000000000,
3135290.6966011249460280 10082278.7886967416852713,
3135234.9429495413787663 10082307.1966011244803667,
3135190.6966011249460280 10082351.4429495409131050,
3135162.2886967407539487 10082407.1966011244803667,
3135157.0550497975200415 10082440.2405474390834570,
3135151.5533988750539720 10082429.4429495409131050,
3135107.3070504586212337 10082385.1966011244803667,
3135051.5533988750539720 10082356.7886967416852713,
3134989.7500000000000000 10082347.0000000000000000,
3134927.9466011249460280 10082356.7886967416852713,
3134872.1929495413787663 10082385.1966011244803667,
3134827.9466011249460280 10082429.4429495409131050,
3134799.5386967407539487 10082485.1966011244803667,
3134789.7500000000000000 10082547.0000000000000000,
3134799.5386967407539487 10082608.8033988755196333,
3134815.3865317041054368 10082639.9065262638032436)),
((3135130.2020069337449968 10098124.1098076272755861,
3135108.4429495413787663 10098135.1966011244803667,
3135064.1966011249460280 10098179.4429495409131050,
3135035.7886967407539487 10098235.1966011244803667,
3135026.0000000000000000 10098297.0000000000000000,
3135035.7886967407539487 10098358.8033988755196333,
3135064.1966011249460280 10098414.5570504590868950,
3135108.4429495413787663 10098458.8033988755196333,
3135164.1966011249460280 10098487.2113032583147287,
3135226.0000000000000000 10098497.0000000000000000,
3135287.8033988750539720 10098487.2113032583147287,
3135343.5570504586212337 10098458.8033988755196333,
3135387.8033988750539720 10098414.5570504590868950,
3135416.2113032592460513 10098358.8033988755196333,
3135426.0000000000000000 10098297.0000000000000000,
3135416.2113032592460513 10098235.1966011244803667,
3135402.2979930662550032 10098207.8901923727244139,
3135424.0570504586212337 10098196.8033988755196333,
3135468.3033988750539720 10098152.5570504590868950,
3135496.7113032592460513 10098096.8033988755196333,
3135506.5000000000000000 10098035.0000000000000000,
3135496.7113032592460513 10097973.1966011244803667,
3135468.3033988750539720 10097917.4429495409131050,
3135424.0570504586212337 10097873.1966011244803667,
3135368.3033988750539720 10097844.7886967416852713,
3135306.5000000000000000 10097835.0000000000000000,
3135244.6966011249460280 10097844.7886967416852713,
3135188.9429495413787663 10097873.1966011244803667,
3135144.6966011249460280 10097917.4429495409131050,
3135116.2886967407539487 10097973.1966011244803667,
3135106.5000000000000000 10098035.0000000000000000,
3135116.2886967407539487 10098096.8033988755196333,
3135130.2020069337449968 10098124.1098076272755861)),
((3134366.2467432995326817 10082526.6154448390007019,
3134357.2886967407539487 10082544.1966011244803667,
3134347.5000000000000000 10082606.0000000000000000,
3134357.2886967407539487 10082667.8033988755196333,
3134382.7287078369408846 10082717.7322319131344557,
3134373.5000000000000000 10082776.0000000000000000,
3134383.2886967407539487 10082837.8033988755196333,
3134411.6966011249460280 10082893.5570504590868950,
3134455.9429495413787663 10082937.8033988755196333,
3134511.6966011249460280 10082966.2113032583147287,
3134573.5000000000000000 10082976.0000000000000000,
3134635.3033988750539720 10082966.2113032583147287,
3134691.0570504586212337 10082937.8033988755196333,
3134735.3033988750539720 10082893.5570504590868950,
3134763.7113032592460513 10082837.8033988755196333,
3134773.5000000000000000 10082776.0000000000000000,
3134763.7113032592460513 10082714.1966011244803667,
3134738.2712921630591154 10082664.2677680868655443,
3134747.5000000000000000 10082606.0000000000000000,
3134737.7113032592460513 10082544.1966011244803667,
3134709.3033988750539720 10082488.4429495409131050,
3134665.0570504586212337 10082444.1966011244803667,
3134609.3033988750539720 10082415.7886967416852713,
3134547.5000000000000000 10082406.0000000000000000,
3134513.5032567004673183 10082411.3845551609992981,
3134522.4613032592460513 10082393.8033988755196333,
3134523.9621308338828385 10082384.3275465033948421,
3134525.6966011249460280 10082385.2113032583147287,
3134587.5000000000000000 10082395.0000000000000000,
3134649.3033988750539720 10082385.2113032583147287,
3134659.9085188228636980 10082379.8077247496694326,
3134673.7500000000000000 10082382.0000000000000000,
3134735.5533988750539720 10082372.2113032583147287,
3134791.3070504586212337 10082343.8033988755196333,
3134835.5533988750539720 10082299.5570504590868950,
3134863.9613032592460513 10082243.8033988755196333,
3134873.7500000000000000 10082182.0000000000000000,
3134863.9613032592460513 10082120.1966011244803667,
3134857.7301959642209113 10082107.9673644863069057,
3134864.2500000000000000 10082109.0000000000000000,
3134926.0533988750539720 10082099.2113032583147287,
3134962.8130525280721486 10082080.4813242089003325,
3134979.9466011249460280 10082089.2113032583147287,
3135041.7500000000000000 10082099.0000000000000000,
3135085.4563582055270672 10082092.0775929167866707,
3135087.7886967407539487 10082106.8033988755196333,
3135116.1966011249460280 10082162.5570504590868950,
3135160.4429495413787663 10082206.8033988755196333,
3135216.1966011249460280 10082235.2113032583147287,
3135278.0000000000000000 10082245.0000000000000000,
3135339.8033988750539720 10082235.2113032583147287,
3135395.5570504586212337 10082206.8033988755196333,
3135439.8033988750539720 10082162.5570504590868950,
3135468.2113032592460513 10082106.8033988755196333,
3135478.0000000000000000 10082045.0000000000000000,
3135468.2113032592460513 10081983.1966011244803667,
3135439.8033988750539720 10081927.4429495409131050,
3135395.5570504586212337 10081883.1966011244803667,
3135339.8033988750539720 10081854.7886967416852713,
3135295.6156646530143917 10081847.7900471873581409,
3135314.4613032592460513 10081810.8033988755196333,
3135324.2500000000000000 10081749.0000000000000000,
3135314.4613032592460513 10081687.1966011244803667,
3135286.0533988750539720 10081631.4429495409131050,
3135241.8070504586212337 10081587.1966011244803667,
3135194.4146388368681073 10081563.0489612910896540,
3135202.5000000000000000 10081512.0000000000000000,
3135192.7113032592460513 10081450.1966011244803667,
3135164.3033988750539720 10081394.4429495409131050,
3135151.0996551313437521 10081381.2392057962715626,
3135129.8033988750539720 10081339.4429495409131050,
3135085.5570504586212337 10081295.1966011244803667,
3135029.8033988750539720 10081266.7886967416852713,
3134968.0000000000000000 10081257.0000000000000000,
3134906.1966011249460280 10081266.7886967416852713,
3134850.4429495413787663 10081295.1966011244803667,
3134806.1966011249460280 10081339.4429495409131050,
3134777.7886967407539487 10081395.1966011244803667,
3134768.0000000000000000 10081457.0000000000000000,
3134777.7886967407539487 10081518.8033988755196333,
3134806.1966011249460280 10081574.5570504590868950,
3134819.4003448686562479 10081587.7607942037284374,
3134840.6966011249460280 10081629.5570504590868950,
3134884.9429495413787663 10081673.8033988755196333,
3134932.3353611631318927 10081697.9510387089103460,
3134928.8123504724353552 10081720.1944527942687273,
3134926.0533988750539720 10081718.7886967416852713,
3134864.2500000000000000 10081709.0000000000000000,
3134802.4466011249460280 10081718.7886967416852713,
3134746.6929495413787663 10081747.1966011244803667,
3134702.4466011249460280 10081791.4429495409131050,
3134674.0386967407539487 10081847.1966011244803667,
3134664.2500000000000000 10081909.0000000000000000,
3134674.0386967407539487 10081970.8033988755196333,
3134680.2698040357790887 10081983.0326355136930943,
3134673.7500000000000000 10081982.0000000000000000,
3134611.9466011249460280 10081991.7886967416852713,
3134601.3414811771363020 10081997.1922752503305674,
3134587.5000000000000000 10081995.0000000000000000,
3134525.6966011249460280 10082004.7886967416852713,
3134469.9429495413787663 10082033.1966011244803667,
3134425.6966011249460280 10082077.4429495409131050,
3134397.2886967407539487 10082133.1966011244803667,
3134395.7878691661171615 10082142.6724534966051579,
3134394.0533988750539720 10082141.7886967416852713,
3134332.2500000000000000 10082132.0000000000000000,
3134270.4466011249460280 10082141.7886967416852713,
3134214.6929495413787663 10082170.1966011244803667,
3134170.4466011249460280 10082214.4429495409131050,
3134142.0386967407539487 10082270.1966011244803667,
3134132.2500000000000000 10082332.0000000000000000,
3134142.0386967407539487 10082393.8033988755196333,
3134170.4466011249460280 10082449.5570504590868950,
3134214.6929495413787663 10082493.8033988755196333,
3134270.4466011249460280 10082522.2113032583147287,
3134332.2500000000000000 10082532.0000000000000000,
3134366.2467432995326817 10082526.6154448390007019)),
((3135272.4621080001816154 10092544.9000000003725290,
3135262.6734112594276667 10092483.0966011248528957,
3135234.2655068752355874 10092427.3429495412856340,
3135190.0191584588028491 10092383.0966011248528957,
3135134.2655068752355874 10092354.6886967420578003,
3135072.4621080001816154 10092344.9000000003725290,
3135010.6587091251276433 10092354.6886967420578003,
3134954.9050575415603817 10092383.0966011248528957,
3134910.6587091251276433 10092427.3429495412856340,
3134882.2508047409355640 10092483.0966011248528957,
3134872.4621080001816154 10092544.9000000003725290,
3134882.2508047409355640 10092606.7033988758921623,
3134910.6587091251276433 10092662.4570504594594240,
3134954.9050575415603817 10092706.7033988758921623,
3135010.6587091251276433 10092735.1113032586872578,
3135072.4621080001816154 10092744.9000000003725290,
3135134.2655068752355874 10092735.1113032586872578,
3135190.0191584588028491 10092706.7033988758921623,
3135234.2655068752355874 10092662.4570504594594240,
3135262.6734112594276667 10092606.7033988758921623,
3135272.4621080001816154 10092544.9000000003725290)),
((3133364.6880845781415701 10083690.0637887176126242,
3133378.6966011249460280 10083717.5570504590868950,
3133422.9429495413787663 10083761.8033988755196333,
3133478.6966011249460280 10083790.2113032583147287,
3133540.5000000000000000 10083800.0000000000000000,
3133602.3033988750539720 10083790.2113032583147287,
3133630.9650898934341967 10083775.6074422597885132,
3133644.6966011249460280 10083802.5570504590868950,
3133688.9429495413787663 10083846.8033988755196333,
3133744.6966011249460280 10083875.2113032583147287,
3133806.5000000000000000 10083885.0000000000000000,
3133808.8448109654709697 10083884.6286184266209602,
3133794.2886967407539487 10083913.1966011244803667,
3133784.5000000000000000 10083975.0000000000000000,
3133794.2886967407539487 10084036.8033988755196333,
3133822.6966011249460280 10084092.5570504590868950,
3133831.0161375352181494 10084100.8765868693590164,
3133833.5386967407539487 10084116.8033988755196333,
3133861.9466011249460280 10084172.5570504590868950,
3133876.1832828898914158 10084186.7937322240322828,
3133874.2500000000000000 10084199.0000000000000000,
3133884.0386967407539487 10084260.8033988755196333,
3133912.4466011249460280 10084316.5570504590868950,
3133915.1725581781938672 10084319.2830075118690729,
3133913.0000000000000000 10084333.0000000000000000,
3133922.7886967407539487 10084394.8033988755196333,
3133951.1966011249460280 10084450.5570504590868950,
3133976.5418535857461393 10084475.9023029208183289,
3133972.2500000000000000 10084503.0000000000000000,
3133982.0386967407539487 10084564.8033988755196333,
3134010.4466011249460280 10084620.5570504590868950,
3134054.6929495413787663 10084664.8033988755196333,
3134110.4466011249460280 10084693.2113032583147287,
3134172.2500000000000000 10084703.0000000000000000,
3134234.0533988750539720 10084693.2113032583147287,
3134289.8070504586212337 10084664.8033988755196333,
3134311.0350583884865046 10084643.5753909461200237,
3134329.9466011249460280 10084653.2113032583147287,
3134391.7500000000000000 10084663.0000000000000000,
3134453.5533988750539720 10084653.2113032583147287,
3134509.3070504586212337 10084624.8033988755196333,
3134553.5533988750539720 10084580.5570504590868950,
3134581.9613032592460513 10084524.8033988755196333,
3134591.7500000000000000 10084463.0000000000000000,
3134581.9613032592460513 10084401.1966011244803667,
3134553.5533988750539720 10084345.4429495409131050,
3134509.3070504586212337 10084301.1966011244803667,
3134453.5533988750539720 10084272.7886967416852713,
3134391.7500000000000000 10084263.0000000000000000,
3134358.9089357536286116 10084268.2015135809779167,
3134400.5533988750539720 10084226.5570504590868950,
3134428.9613032592460513 10084170.8033988755196333,
3134438.7500000000000000 10084109.0000000000000000,
3134428.9613032592460513 10084047.1966011244803667,
3134400.5533988750539720 10083991.4429495409131050,
3134356.3070504586212337 10083947.1966011244803667,
3134319.1072711292654276 10083928.2423668410629034,
3134319.3033988750539720 10083928.2113032583147287,
3134357.0950472829863429 10083908.9554966166615486,
3134393.9429495413787663 10083945.8033988755196333,
3134449.6966011249460280 10083974.2113032583147287,
3134511.5000000000000000 10083984.0000000000000000,
3134573.3033988750539720 10083974.2113032583147287,
3134629.0570504586212337 10083945.8033988755196333,
3134673.3033988750539720 10083901.5570504590868950,
3134675.4102439740672708 10083897.4221341349184513,
3134698.0000000000000000 10083901.0000000000000000,
3134759.8033988750539720 10083891.2113032583147287,
3134787.2913546473719180 10083877.2054902389645576,
3134773.5386967407539487 10083904.1966011244803667,
3134763.7500000000000000 10083966.0000000000000000,
3134773.5386967407539487 10084027.8033988755196333,
3134801.9466011249460280 10084083.5570504590868950,
3134810.1259183725342155 10084091.7363677062094212,
3134806.3033988750539720 10084089.7886967416852713,
3134744.5000000000000000 10084080.0000000000000000,
3134682.6966011249460280 10084089.7886967416852713,
3134626.9429495413787663 10084118.1966011244803667,
3134582.6966011249460280 10084162.4429495409131050,
3134554.2886967407539487 10084218.1966011244803667,
3134544.5000000000000000 10084280.0000000000000000,
3134554.2886967407539487 10084341.8033988755196333,
3134582.6966011249460280 10084397.5570504590868950,
3134626.9429495413787663 10084441.8033988755196333,
3134682.6966011249460280 10084470.2113032583147287,
3134744.5000000000000000 10084480.0000000000000000,
3134806.3033988750539720 10084470.2113032583147287,
3134862.0570504586212337 10084441.8033988755196333,
3134906.3033988750539720 10084397.5570504590868950,
3134934.7113032592460513 10084341.8033988755196333,
3134944.5000000000000000 10084280.0000000000000000,
3134934.7113032592460513 10084218.1966011244803667,
3134906.3033988750539720 10084162.4429495409131050,
3134898.1240816274657845 10084154.2636322937905788,
3134901.9466011249460280 10084156.2113032583147287,
3134963.7500000000000000 10084166.0000000000000000,
3135025.5533988750539720 10084156.2113032583147287,
3135081.3070504586212337 10084127.8033988755196333,
3135125.5533988750539720 10084083.5570504590868950,
3135153.9613032592460513 10084027.8033988755196333,
3135163.7500000000000000 10083966.0000000000000000,
3135153.9613032592460513 10083904.1966011244803667,
3135125.5533988750539720 10083848.4429495409131050,
3135081.3070504586212337 10083804.1966011244803667,
3135025.5533988750539720 10083775.7886967416852713,
3134963.7500000000000000 10083766.0000000000000000,
3134901.9466011249460280 10083775.7886967416852713,
3134874.4586453526280820 10083789.7945097610354424,
3134888.2113032592460513 10083762.8033988755196333,
3134898.0000000000000000 10083701.0000000000000000,
3134888.2113032592460513 10083639.1966011244803667,
3134859.8033988750539720 10083583.4429495409131050,
3134815.5570504586212337 10083539.1966011244803667,
3134759.8033988750539720 10083510.7886967416852713,
3134698.0000000000000000 10083501.0000000000000000,
3134688.8257904704660177 10083502.4530520420521498,
3134696.5000000000000000 10083454.0000000000000000,
3134686.7113032592460513 10083392.1966011244803667,
3134658.3033988750539720 10083336.4429495409131050,
3134614.0570504586212337 10083292.1966011244803667,
3134558.3033988750539720 10083263.7886967416852713,
3134496.5000000000000000 10083254.0000000000000000,
3134434.6966011249460280 10083263.7886967416852713,
3134378.9429495413787663 10083292.1966011244803667,
3134334.6966011249460280 10083336.4429495409131050,
3134333.6356441602110863 10083338.5251948256045580,
3134323.3070504586212337 10083328.1966011244803667,
3134267.5533988750539720 10083299.7886967416852713,
3134205.7500000000000000 10083290.0000000000000000,
3134160.9552420084364712 10083297.0947926752269268,
3134120.0570504586212337 10083256.1966011244803667,
3134064.3033988750539720 10083227.7886967416852713,
3134002.5000000000000000 10083218.0000000000000000,
3133940.6966011249460280 10083227.7886967416852713,
3133884.9429495413787663 10083256.1966011244803667,
3133880.8872446748428047 10083260.2523059900850058,
3133871.3033988750539720 10083241.4429495409131050,
3133827.0570504586212337 10083197.1966011244803667,
3133771.3033988750539720 10083168.7886967416852713,
3133709.5000000000000000 10083159.0000000000000000,
3133647.6966011249460280 10083168.7886967416852713,
3133591.9429495413787663 10083197.1966011244803667,
3133547.6966011249460280 10083241.4429495409131050,
3133519.2886967407539487 10083297.1966011244803667,
3133509.5000000000000000 10083359.0000000000000000,
3133513.7934554112143815 10083386.1078106071799994,
3133510.8493433394469321 10083404.6962026599794626,
3133478.6966011249460280 10083409.7886967416852713,
3133422.9429495413787663 10083438.1966011244803667,
3133378.6966011249460280 10083482.4429495409131050,
3133371.3119154218584299 10083496.9362112823873758,
3133357.3033988750539720 10083469.4429495409131050,
3133313.0570504586212337 10083425.1966011244803667,
3133257.3033988750539720 10083396.7886967416852713,
3133195.5000000000000000 10083387.0000000000000000,
3133133.6966011249460280 10083396.7886967416852713,
3133077.9429495413787663 10083425.1966011244803667,
3133033.6966011249460280 10083469.4429495409131050,
3133005.2886967407539487 10083525.1966011244803667,
3132995.5000000000000000 10083587.0000000000000000,
3133005.2886967407539487 10083648.8033988755196333,
3133033.6966011249460280 10083704.5570504590868950,
3133077.9429495413787663 10083748.8033988755196333,
3133133.6966011249460280 10083777.2113032583147287,
3133195.5000000000000000 10083787.0000000000000000,
3133257.3033988750539720 10083777.2113032583147287,
3133313.0570504586212337 10083748.8033988755196333,
3133357.3033988750539720 10083704.5570504590868950,
3133364.6880845781415701 10083690.0637887176126242),
(3134177.1427288707345724 10083918.7576331589370966,
3134176.9466011249460280 10083918.7886967416852713,
3134175.6977847991511226 10083919.4250004421919584,
3134175.4559604721143842 10083917.8981817327439785,
3134177.1427288707345724 10083918.7576331589370966)),
((3134679.3885878794826567 10085414.9990372136235237,
3134700.1929495413787663 10085435.8033988755196333,
3134755.9466011249460280 10085464.2113032583147287,
3134817.7500000000000000 10085474.0000000000000000,
3134879.5533988750539720 10085464.2113032583147287,
3134935.3070504586212337 10085435.8033988755196333,
3134979.5533988750539720 10085391.5570504590868950,
3135007.9613032592460513 10085335.8033988755196333,
3135017.7500000000000000 10085274.0000000000000000,
3135007.9613032592460513 10085212.1966011244803667,
3134979.5533988750539720 10085156.4429495409131050,
3134935.3070504586212337 10085112.1966011244803667,
3134879.5533988750539720 10085083.7886967416852713,
3134817.7500000000000000 10085074.0000000000000000,
3134779.8614121205173433 10085080.0009627863764763,
3134759.0570504586212337 10085059.1966011244803667,
3134703.3033988750539720 10085030.7886967416852713,
3134641.5000000000000000 10085021.0000000000000000,
3134579.6966011249460280 10085030.7886967416852713,
3134523.9429495413787663 10085059.1966011244803667,
3134479.6966011249460280 10085103.4429495409131050,
3134451.2886967407539487 10085159.1966011244803667,
3134441.5000000000000000 10085221.0000000000000000,
3134451.2886967407539487 10085282.8033988755196333,
3134479.6966011249460280 10085338.5570504590868950,
3134523.9429495413787663 10085382.8033988755196333,
3134579.6966011249460280 10085411.2113032583147287,
3134641.5000000000000000 10085421.0000000000000000,
3134679.3885878794826567 10085414.9990372136235237)),
((3134170.1185878752730787 10099314.2118700668215752,
3134147.7970292652025819 10099336.5334286764264107,
3134119.3891248810105026 10099392.2870802599936724,
3134109.6004281402565539 10099454.0904791355133057,
3134119.3891248810105026 10099515.8938780110329390,
3134147.7970292652025819 10099571.6475295946002007,
3134192.0433776816353202 10099615.8938780110329390,
3134247.7970292652025819 10099644.3017823938280344,
3134309.6004281402565539 10099654.0904791355133057,
3134340.2697111465968192 10099649.2329419106245041,
3134358.8748106677085161 10099685.7475056871771812,
3134403.1211590841412544 10099729.9938541036099195,
3134458.8748106677085161 10099758.4017584864050150,
3134520.6782095427624881 10099768.1904552280902863,
3134582.4816084178164601 10099758.4017584864050150,
3134638.2352600013837218 10099729.9938541036099195,
3134682.4816084178164601 10099685.7475056871771812,
3134710.8895128020085394 10099629.9938541036099195,
3134720.6782095427624881 10099568.1904552280902863,
3134710.8895128020085394 10099506.3870563525706530,
3134682.4816084178164601 10099450.6334047690033913,
3134638.2352600013837218 10099406.3870563525706530,
3134582.4816084178164601 10099377.9791519697755575,
3134520.6782095427624881 10099368.1904552280902863,
3134490.0089265364222229 10099373.0479924529790878,
3134471.4038270153105259 10099336.5334286764264107,
3134427.1574785988777876 10099292.2870802599936724,
3134371.4038270153105259 10099263.8791758771985769,
3134369.9434359590522945 10099263.6478726565837860,
3134392.2649945691227913 10099241.3263140469789505,
3134420.6728989533148706 10099185.5726624634116888,
3134430.4615956940688193 10099123.7692635878920555,
3134420.6728989533148706 10099061.9658647123724222,
3134392.2649945691227913 10099006.2122131288051605,
3134348.0186461526900530 10098961.9658647123724222,
3134292.2649945691227913 10098933.5579603295773268,
3134230.4615956940688193 10098923.7692635878920555,
3134168.6581968190148473 10098933.5579603295773268,
3134112.9045452354475856 10098961.9658647123724222,
3134068.6581968190148473 10099006.2122131288051605,
3134040.2502924348227680 10099061.9658647123724222,
3134030.4615956940688193 10099123.7692635878920555,
3134040.2502924348227680 10099185.5726624634116888,
3134068.6581968190148473 10099241.3263140469789505,
3134112.9045452354475856 10099285.5726624634116888,
3134168.6581968190148473 10099313.9805668462067842,
3134170.1185878752730787 10099314.2118700668215752)),
((3134561.0000000000000000 10089266.0000000000000000,
3134551.2113032592460513 10089204.1966011244803667,
3134522.8033988750539720 10089148.4429495409131050,
3134478.5570504586212337 10089104.1966011244803667,
3134422.8033988750539720 10089075.7886967416852713,
3134361.0000000000000000 10089066.0000000000000000,
3134299.1966011249460280 10089075.7886967416852713,
3134243.4429495413787663 10089104.1966011244803667,
3134199.1966011249460280 10089148.4429495409131050,
3134170.7886967407539487 10089204.1966011244803667,
3134161.0000000000000000 10089266.0000000000000000,
3134170.7886967407539487 10089327.8033988755196333,
3134199.1966011249460280 10089383.5570504590868950,
3134243.4429495413787663 10089427.8033988755196333,
3134299.1966011249460280 10089456.2113032583147287,
3134361.0000000000000000 10089466.0000000000000000,
3134422.8033988750539720 10089456.2113032583147287,
3134478.5570504586212337 10089427.8033988755196333,
3134522.8033988750539720 10089383.5570504590868950,
3134551.2113032592460513 10089327.8033988755196333,
3134561.0000000000000000 10089266.0000000000000000)),
((3134022.8502189335413277 10098672.3431504927575588,
3134036.0433317031711340 10098685.5362632628530264,
3134091.7969832867383957 10098713.9441676456481218,
3134153.6003821617923677 10098723.7328643873333931,
3134215.4037810368463397 10098713.9441676456481218,
3134271.1574326204136014 10098685.5362632628530264,
3134315.4037810368463397 10098641.2899148464202881,
3134343.8116854210384190 10098585.5362632628530264,
3134353.6003821617923677 10098523.7328643873333931,
3134343.8116854210384190 10098461.9294655118137598,
3134315.4037810368463397 10098406.1758139282464981,
3134271.1574326204136014 10098361.9294655118137598,
3134215.4037810368463397 10098333.5215611290186644,
3134153.6003821617923677 10098323.7328643873333931,
3134144.2519922284409404 10098325.2135038953274488,
3134131.0588794588111341 10098312.0203911252319813,
3134075.3052278752438724 10098283.6124867424368858,
3134013.5018290001899004 10098273.8237900007516146,
3133951.6984301251359284 10098283.6124867424368858,
3133895.9447785415686667 10098312.0203911252319813,
3133851.6984301251359284 10098356.2667395416647196,
3133823.2905257409438491 10098412.0203911252319813,
3133813.5018290001899004 10098473.8237900007516146,
3133823.2905257409438491 10098535.6271888762712479,
3133851.6984301251359284 10098591.3808404598385096,
3133895.9447785415686667 10098635.6271888762712479,
3133951.6984301251359284 10098664.0350932590663433,
3134013.5018290001899004 10098673.8237900007516146,
3134022.8502189335413277 10098672.3431504927575588)),
((3133467.9607481672428548 10094549.1640554983168840,
3133447.3233241247944534 10094569.8014795407652855,
3133418.9154197406023741 10094625.5551311243325472,
3133409.1267229998484254 10094687.3585299998521805,
3133418.9154197406023741 10094749.1619288753718138,
3133447.3233241247944534 10094804.9155804589390755,
3133491.5696725412271917 10094849.1619288753718138,
3133547.3233241247944534 10094877.5698332581669092,
3133609.1267229998484254 10094887.3585299998521805,
3133670.9301218749023974 10094877.5698332581669092,
3133726.6837734584696591 10094849.1619288753718138,
3133770.9301218749023974 10094804.9155804589390755,
3133799.3380262590944767 10094749.1619288753718138,
3133809.1267229998484254 10094687.3585299998521805,
3133804.6659748326055706 10094659.1944745015352964,
3133825.3033988750539720 10094638.5570504590868950,
3133853.7113032592460513 10094582.8033988755196333,
3133863.5000000000000000 10094521.0000000000000000,
3133853.7113032592460513 10094459.1966011244803667,
3133825.3033988750539720 10094403.4429495409131050,
3133781.0570504586212337 10094359.1966011244803667,
3133725.3033988750539720 10094330.7886967416852713,
3133663.5000000000000000 10094321.0000000000000000,
3133601.6966011249460280 10094330.7886967416852713,
3133545.9429495413787663 10094359.1966011244803667,
3133501.6966011249460280 10094403.4429495409131050,
3133473.2886967407539487 10094459.1966011244803667,
3133463.5000000000000000 10094521.0000000000000000,
3133467.9607481672428548 10094549.1640554983168840)),
((3132445.6047048824839294 10091656.2848457824438810,
3132416.0116486768238246 10091671.3632610477507114,
3132371.7653002603910863 10091715.6096094641834497,
3132343.3573958761990070 10091771.3632610477507114,
3132333.5686991354450583 10091833.1666599232703447,
3132343.3573958761990070 10091894.9700587987899780,
3132371.7653002603910863 10091950.7237103823572397,
3132416.0116486768238246 10091994.9700587987899780,
3132471.7653002603910863 10092023.3779631815850735,
3132497.6058698575943708 10092027.4707073345780373,
3132482.4429495413787663 10092035.1966011244803667,
3132438.1966011249460280 10092079.4429495409131050,
3132409.7886967407539487 10092135.1966011244803667,
3132400.0000000000000000 10092197.0000000000000000,
3132409.7886967407539487 10092258.8033988755196333,
3132438.1966011249460280 10092314.5570504590868950,
3132482.4429495413787663 10092358.8033988755196333,
3132538.1966011249460280 10092387.2113032583147287,
3132566.1558842123486102 10092391.6396186631172895,
3132555.7589660258963704 10092412.0447195190936327,
3132500.3033988750539720 10092383.7886967416852713,
3132438.5000000000000000 10092374.0000000000000000,
3132376.6966011249460280 10092383.7886967416852713,
3132320.9429495413787663 10092412.1966011244803667,
3132276.6966011249460280 10092456.4429495409131050,
3132248.2886967407539487 10092512.1966011244803667,
3132238.5000000000000000 10092574.0000000000000000,
3132248.2886967407539487 10092635.8033988755196333,
3132276.6966011249460280 10092691.5570504590868950,
3132320.9429495413787663 10092735.8033988755196333,
3132376.6966011249460280 10092764.2113032583147287,
3132438.5000000000000000 10092774.0000000000000000,
3132500.3033988750539720 10092764.2113032583147287,
3132556.0570504586212337 10092735.8033988755196333,
3132600.3033988750539720 10092691.5570504590868950,
3132620.9910339741036296 10092650.9552804809063673,
3132676.4466011249460280 10092679.2113032583147287,
3132738.2500000000000000 10092689.0000000000000000,
3132800.0533988750539720 10092679.2113032583147287,
3132855.8070504586212337 10092650.8033988755196333,
3132900.0533988750539720 10092606.5570504590868950,
3132928.4613032592460513 10092550.8033988755196333,
3132938.2500000000000000 10092489.0000000000000000,
3132928.4613032592460513 10092427.1966011244803667,
3132902.3194882278330624 10092375.8904003109782934,
3132950.8033988750539720 10092368.2113032583147287,
3132962.3604438798502088 10092362.3226947076618671,
3132987.4466011249460280 10092411.5570504590868950,
3133018.0046882363967597 10092442.1151375714689493,
3133043.1966011249460280 10092491.5570504590868950,
3133046.0145506658591330 10092494.3750000000000000,
3133010.9466011249460280 10092529.4429495409131050,
3132982.5386967407539487 10092585.1966011244803667,
3132972.7500000000000000 10092647.0000000000000000,
3132982.5386967407539487 10092708.8033988755196333,
3133010.9466011249460280 10092764.5570504590868950,
3133023.8521857620216906 10092777.4626350961625576,
3133022.5000000000000000 10092786.0000000000000000,
3133032.2886967407539487 10092847.8033988755196333,
3133060.6966011249460280 10092903.5570504590868950,
3133065.7518137758597732 10092908.6122631095349789,
3133045.6966011249460280 10092911.7886967416852713,
3132989.9429495413787663 10092940.1966011244803667,
3132986.9509281031787395 10092943.1886225622147322,
3132935.2500000000000000 10092935.0000000000000000,
3132873.4466011249460280 10092944.7886967416852713,
3132817.6929495413787663 10092973.1966011244803667,
3132773.4466011249460280 10093017.4429495409131050,
3132745.0386967407539487 10093073.1966011244803667,
3132735.2500000000000000 10093135.0000000000000000,
3132745.0386967407539487 10093196.8033988755196333,
3132773.4466011249460280 10093252.5570504590868950,
3132817.6929495413787663 10093296.8033988755196333,
3132873.4466011249460280 10093325.2113032583147287,
3132935.2500000000000000 10093335.0000000000000000,
3132997.0533988750539720 10093325.2113032583147287,
3133052.8070504586212337 10093296.8033988755196333,
3133055.7990718968212605 10093293.8113774377852678,
3133107.5000000000000000 10093302.0000000000000000,
3133169.3033988750539720 10093292.2113032583147287,
3133225.0570504586212337 10093263.8033988755196333,
3133269.3033988750539720 10093219.5570504590868950,
3133297.7113032592460513 10093163.8033988755196333,
3133307.5000000000000000 10093102.0000000000000000,
3133297.7113032592460513 10093040.1966011244803667,
3133269.3033988750539720 10092984.4429495409131050,
3133264.2481862241402268 10092979.3877368904650211,
3133284.3033988750539720 10092976.2113032583147287,
3133340.0570504586212337 10092947.8033988755196333,
3133384.3033988750539720 10092903.5570504590868950,
3133396.2826939551159739 10092880.0463600866496563,
3133446.5000000000000000 10092888.0000000000000000,
3133508.3033988750539720 10092878.2113032583147287,
3133516.3995579774491489 10092874.0861041527241468,
3133540.1966011249460280 10092886.2113032583147287,
3133602.0000000000000000 10092896.0000000000000000,
3133663.8033988750539720 10092886.2113032583147287,
3133719.5570504586212337 10092857.8033988755196333,
3133763.8033988750539720 10092813.5570504590868950,
3133792.2113032592460513 10092757.8033988755196333,
3133802.0000000000000000 10092696.0000000000000000,
3133792.2113032592460513 10092634.1966011244803667,
3133763.8033988750539720 10092578.4429495409131050,
3133719.5570504586212337 10092534.1966011244803667,
3133663.8033988750539720 10092505.7886967416852713,
3133602.0000000000000000 10092496.0000000000000000,
3133554.7194883953779936 10092503.4884973689913750,
3133553.4038793691433966 10092500.9064692724496126,
3133569.3070504586212337 10092492.8033988755196333,
3133613.5533988750539720 10092448.5570504590868950,
3133641.9613032592460513 10092392.8033988755196333,
3133651.7500000000000000 10092331.0000000000000000,
3133641.9613032592460513 10092269.1966011244803667,
3133613.5533988750539720 10092213.4429495409131050,
3133569.3070504586212337 10092169.1966011244803667,
3133525.1424776059575379 10092146.6936272904276848,
3133517.4613032592460513 10092098.1966011244803667,
3133489.0533988750539720 10092042.4429495409131050,
3133444.8070504586212337 10091998.1966011244803667,
3133389.0533988750539720 10091969.7886967416852713,
3133331.9065021742135286 10091960.7375174909830093,
3133337.2500000000000000 10091927.0000000000000000,
3133327.4613032592460513 10091865.1966011244803667,
3133309.5078160311095417 10091829.9608984794467688,
3133307.9613032592460513 10091820.1966011244803667,
3133294.1942170630209148 10091793.1771731264889240,
3133285.9613032592460513 10091741.1966011244803667,
3133257.5533988750539720 10091685.4429495409131050,
3133213.3070504586212337 10091641.1966011244803667,
3133157.5533988750539720 10091612.7886967416852713,
3133095.7500000000000000 10091603.0000000000000000,
3133033.9466011249460280 10091612.7886967416852713,
3132978.1929495413787663 10091641.1966011244803667,
3132960.4700184348039329 10091658.9195322301238775,
3132958.1720980103127658 10091654.4096094649285078,
3132913.9257495938800275 10091610.1632610484957695,
3132858.1720980103127658 10091581.7553566657006741,
3132796.3686991352587938 10091571.9666599240154028,
3132734.5653002602048218 10091581.7553566657006741,
3132726.9628497404046357 10091585.6289986837655306,
3132698.7289366237819195 10091590.1008112113922834,
3132651.0663365302607417 10091614.3861189465969801,
3132629.1323354989290237 10091610.9121144693344831,
3132577.4724695058539510 10091619.0942334327846766,
3132564.2500000000000000 10091617.0000000000000000,
3132502.4466011249460280 10091626.7886967416852713,
3132446.6929495413787663 10091655.1966011244803667,
3132445.6047048824839294 10091656.2848457824438810),
(3132812.9415557892061770 10091995.0520051233470440,
3132771.4429495413787663 10092016.1966011244803667,
3132735.0000000000000000 10092052.6395506653934717,
3132717.5570504586212337 10092035.1966011244803667,
3132661.8033988750539720 10092006.7886967416852713,
3132658.4849846488796175 10092006.2631115615367889,
3132690.9357343739829957 10092001.1234177276492119,
3132738.5983344675041735 10091976.8381099924445152,
3132760.5323354988358915 10091980.3121144697070122,
3132798.2229783865623176 10091974.3425030894577503,
3132804.4466011249460280 10091986.5570504590868950,
3132812.9415557892061770 10091995.0520051233470440)),
((3133693.2500000000000000 10089628.0000000000000000,
3133683.4613032592460513 10089566.1966011244803667,
3133655.0533988750539720 10089510.4429495409131050,
3133610.8070504586212337 10089466.1966011244803667,
3133555.0533988750539720 10089437.7886967416852713,
3133493.2500000000000000 10089428.0000000000000000,
3133431.4466011249460280 10089437.7886967416852713,
3133375.6929495413787663 10089466.1966011244803667,
3133331.4466011249460280 10089510.4429495409131050,
3133303.0386967407539487 10089566.1966011244803667,
3133293.2500000000000000 10089628.0000000000000000,
3133303.0386967407539487 10089689.8033988755196333,
3133331.4466011249460280 10089745.5570504590868950,
3133375.6929495413787663 10089789.8033988755196333,
3133431.4466011249460280 10089818.2113032583147287,
3133493.2500000000000000 10089828.0000000000000000,
3133555.0533988750539720 10089818.2113032583147287,
3133610.8070504586212337 10089789.8033988755196333,
3133655.0533988750539720 10089745.5570504590868950,
3133683.4613032592460513 10089689.8033988755196333,
3133693.2500000000000000 10089628.0000000000000000)),
((3133683.5000000000000000 10095547.0000000000000000,
3133673.7113032592460513 10095485.1966011244803667,
3133645.3033988750539720 10095429.4429495409131050,
3133601.0570504586212337 10095385.1966011244803667,
3133545.3033988750539720 10095356.7886967416852713,
3133483.5000000000000000 10095347.0000000000000000,
3133421.6966011249460280 10095356.7886967416852713,
3133365.9429495413787663 10095385.1966011244803667,
3133321.6966011249460280 10095429.4429495409131050,
3133293.2886967407539487 10095485.1966011244803667,
3133283.5000000000000000 10095547.0000000000000000,
3133293.2886967407539487 10095608.8033988755196333,
3133321.6966011249460280 10095664.5570504590868950,
3133365.9429495413787663 10095708.8033988755196333,
3133421.6966011249460280 10095737.2113032583147287,
3133483.5000000000000000 10095747.0000000000000000,
3133545.3033988750539720 10095737.2113032583147287,
3133601.0570504586212337 10095708.8033988755196333,
3133645.3033988750539720 10095664.5570504590868950,
3133673.7113032592460513 10095608.8033988755196333,
3133683.5000000000000000 10095547.0000000000000000)),
((3133077.1441452940925956 10093829.9436381515115499,
3133073.4043901977129281 10093853.5555225554853678,
3133083.1930869384668767 10093915.3589214310050011,
3133111.6009913226589561 10093971.1125730145722628,
3133155.8473397390916944 10094015.3589214310050011,
3133211.6009913226589561 10094043.7668258138000965,
3133240.6602328498847783 10094048.3693575188517570,
3133229.5386967407539487 10094070.1966011244803667,
3133219.7500000000000000 10094132.0000000000000000,
3133229.5386967407539487 10094193.8033988755196333,
3133257.9466011249460280 10094249.5570504590868950,
3133302.1929495413787663 10094293.8033988755196333,
3133357.9466011249460280 10094322.2113032583147287,
3133419.7500000000000000 10094332.0000000000000000,
3133481.5533988750539720 10094322.2113032583147287,
3133537.3070504586212337 10094293.8033988755196333,
3133581.5533988750539720 10094249.5570504590868950,
3133609.9613032592460513 10094193.8033988755196333,
3133619.7500000000000000 10094132.0000000000000000,
3133609.9613032592460513 10094070.1966011244803667,
3133581.5533988750539720 10094014.4429495409131050,
3133537.3070504586212337 10093970.1966011244803667,
3133481.5533988750539720 10093941.7886967416852713,
3133452.4941573478281498 10093937.1861650366336107,
3133463.6156934569589794 10093915.3589214310050011,
3133473.4043901977129281 10093853.5555225554853678,
3133463.6156934569589794 10093791.7521236799657345,
3133435.2077890727669001 10093735.9984720963984728,
3133390.9614406563341618 10093691.7521236799657345,
3133335.2077890727669001 10093663.3442192971706390,
3133273.7602449036203325 10093653.6118844039738178,
3133277.5000000000000000 10093630.0000000000000000,
3133267.7113032592460513 10093568.1966011244803667,
3133239.3033988750539720 10093512.4429495409131050,
3133195.0570504586212337 10093468.1966011244803667,
3133139.3033988750539720 10093439.7886967416852713,
3133077.5000000000000000 10093430.0000000000000000,
3133015.6966011249460280 10093439.7886967416852713,
3132959.9429495413787663 10093468.1966011244803667,
3132915.6966011249460280 10093512.4429495409131050,
3132887.2886967407539487 10093568.1966011244803667,
3132877.5000000000000000 10093630.0000000000000000,
3132887.2886967407539487 10093691.8033988755196333,
3132915.6966011249460280 10093747.5570504590868950,
3132959.9429495413787663 10093791.8033988755196333,
3133015.6966011249460280 10093820.2113032583147287,
3133077.1441452940925956 10093829.9436381515115499)),
((3133296.2701623719185591 10097325.6403034031391144,
3133286.4814656311646104 10097263.8369045276194811,
3133258.0735612469725311 10097208.0832529440522194,
3133213.8272128305397928 10097163.8369045276194811,
3133158.0735612469725311 10097135.4290001448243856,
3133096.2701623719185591 10097125.6403034031391144,
3133034.4667634968645871 10097135.4290001448243856,
3132978.7131119132973254 10097163.8369045276194811,
3132934.4667634968645871 10097208.0832529440522194,
3132906.0588591126725078 10097263.8369045276194811,
3132896.2701623719185591 10097325.6403034031391144,
3132906.0588591126725078 10097387.4437022786587477,
3132934.4667634968645871 10097443.1973538622260094,
3132978.7131119132973254 10097487.4437022786587477,
3133034.4667634968645871 10097515.8516066614538431,
3133096.2701623719185591 10097525.6403034031391144,
3133158.0735612469725311 10097515.8516066614538431,
3133213.8272128305397928 10097487.4437022786587477,
3133258.0735612469725311 10097443.1973538622260094,
3133286.4814656311646104 10097387.4437022786587477,
3133296.2701623719185591 10097325.6403034031391144)),
((3133268.2677942002192140 10080255.8193339351564646,
3133258.4790974594652653 10080194.0159350596368313,
3133230.0711930752731860 10080138.2622834760695696,
3133185.8248446588404477 10080094.0159350596368313,
3133130.0711930752731860 10080065.6080306768417358,
3133068.2677942002192140 10080055.8193339351564646,
3133006.4643953251652420 10080065.6080306768417358,
3132950.7107437415979803 10080094.0159350596368313,
3132906.4643953251652420 10080138.2622834760695696,
3132878.0564909409731627 10080194.0159350596368313,
3132868.2677942002192140 10080255.8193339351564646,
3132878.0564909409731627 10080317.6227328106760979,
3132906.4643953251652420 10080373.3763843942433596,
3132950.7107437415979803 10080417.6227328106760979,
3133006.4643953251652420 10080446.0306371934711933,
3133068.2677942002192140 10080455.8193339351564646,
3133130.0711930752731860 10080446.0306371934711933,
3133185.8248446588404477 10080417.6227328106760979,
3133230.0711930752731860 10080373.3763843942433596,
3133258.4790974594652653 10080317.6227328106760979,
3133268.2677942002192140 10080255.8193339351564646)),
((3133249.5000000000000000 10082806.0000000000000000,
3133239.7113032592460513 10082744.1966011244803667,
3133211.3033988750539720 10082688.4429495409131050,
3133167.0570504586212337 10082644.1966011244803667,
3133111.3033988750539720 10082615.7886967416852713,
3133049.5000000000000000 10082606.0000000000000000,
3132987.6966011249460280 10082615.7886967416852713,
3132931.9429495413787663 10082644.1966011244803667,
3132887.6966011249460280 10082688.4429495409131050,
3132859.2886967407539487 10082744.1966011244803667,
3132849.5000000000000000 10082806.0000000000000000,
3132859.2886967407539487 10082867.8033988755196333,
3132887.6966011249460280 10082923.5570504590868950,
3132931.9429495413787663 10082967.8033988755196333,
3132987.6966011249460280 10082996.2113032583147287,
3133049.5000000000000000 10083006.0000000000000000,
3133111.3033988750539720 10082996.2113032583147287,
3133167.0570504586212337 10082967.8033988755196333,
3133211.3033988750539720 10082923.5570504590868950,
3133239.7113032592460513 10082867.8033988755196333,
3133249.5000000000000000 10082806.0000000000000000)),
((3133193.5000000000000000 10085288.0000000000000000,
3133183.7113032592460513 10085226.1966011244803667,
3133155.3033988750539720 10085170.4429495409131050,
3133111.0570504586212337 10085126.1966011244803667,
3133055.3033988750539720 10085097.7886967416852713,
3132993.5000000000000000 10085088.0000000000000000,
3132931.6966011249460280 10085097.7886967416852713,
3132875.9429495413787663 10085126.1966011244803667,
3132831.6966011249460280 10085170.4429495409131050,
3132803.2886967407539487 10085226.1966011244803667,
3132793.5000000000000000 10085288.0000000000000000,
3132803.2886967407539487 10085349.8033988755196333,
3132831.6966011249460280 10085405.5570504590868950,
3132875.9429495413787663 10085449.8033988755196333,
3132931.6966011249460280 10085478.2113032583147287,
3132993.5000000000000000 10085488.0000000000000000,
3133055.3033988750539720 10085478.2113032583147287,
3133111.0570504586212337 10085449.8033988755196333,
3133155.3033988750539720 10085405.5570504590868950,
3133183.7113032592460513 10085349.8033988755196333,
3133193.5000000000000000 10085288.0000000000000000)),
((3132801.3738949438557029 10084397.9198707770556211,
3132791.3033988750539720 10084392.7886967416852713,
3132729.5000000000000000 10084383.0000000000000000,
3132667.6966011249460280 10084392.7886967416852713,
3132611.9429495413787663 10084421.1966011244803667,
3132567.6966011249460280 10084465.4429495409131050,
3132539.2886967407539487 10084521.1966011244803667,
3132529.5000000000000000 10084583.0000000000000000,
3132539.2886967407539487 10084644.8033988755196333,
3132567.6966011249460280 10084700.5570504590868950,
3132611.9429495413787663 10084744.8033988755196333,
3132667.6966011249460280 10084773.2113032583147287,
3132729.5000000000000000 10084783.0000000000000000,
3132791.3033988750539720 10084773.2113032583147287,
3132840.6261050561442971 10084748.0801292229443789,
3132850.6966011249460280 10084753.2113032583147287,
3132912.5000000000000000 10084763.0000000000000000,
3132974.3033988750539720 10084753.2113032583147287,
3133030.0570504586212337 10084724.8033988755196333,
3133074.3033988750539720 10084680.5570504590868950,
3133102.7113032592460513 10084624.8033988755196333,
3133112.5000000000000000 10084563.0000000000000000,
3133102.7113032592460513 10084501.1966011244803667,
3133074.3033988750539720 10084445.4429495409131050,
3133030.0570504586212337 10084401.1966011244803667,
3132974.3033988750539720 10084372.7886967416852713,
3132912.5000000000000000 10084363.0000000000000000,
3132850.6966011249460280 10084372.7886967416852713,
3132801.3738949438557029 10084397.9198707770556211)),
((3132594.2500000000000000 10095096.0000000000000000,
3132584.4613032592460513 10095034.1966011244803667,
3132556.0533988750539720 10094978.4429495409131050,
3132511.8070504586212337 10094934.1966011244803667,
3132456.0533988750539720 10094905.7886967416852713,
3132394.2500000000000000 10094896.0000000000000000,
3132332.4466011249460280 10094905.7886967416852713,
3132276.6929495413787663 10094934.1966011244803667,
3132232.4466011249460280 10094978.4429495409131050,
3132204.0386967407539487 10095034.1966011244803667,
3132194.2500000000000000 10095096.0000000000000000,
3132204.0386967407539487 10095157.8033988755196333,
3132232.4466011249460280 10095213.5570504590868950,
3132276.6929495413787663 10095257.8033988755196333,
3132332.4466011249460280 10095286.2113032583147287,
3132394.2500000000000000 10095296.0000000000000000,
3132456.0533988750539720 10095286.2113032583147287,
3132511.8070504586212337 10095257.8033988755196333,
3132556.0533988750539720 10095213.5570504590868950,
3132584.4613032592460513 10095157.8033988755196333,
3132594.2500000000000000 10095096.0000000000000000)),
((3131287.5587792061269283 10093137.7733188141137362,
3131288.0386967407539487 10093140.8033988755196333,
3131316.4466011249460280 10093196.5570504590868950,
3131360.6929495413787663 10093240.8033988755196333,
3131416.4466011249460280 10093269.2113032583147287,
3131478.2500000000000000 10093279.0000000000000000,
3131540.0533988750539720 10093269.2113032583147287,
3131595.8070504586212337 10093240.8033988755196333,
3131640.0533988750539720 10093196.5570504590868950,
3131668.4613032592460513 10093140.8033988755196333,
3131675.8495450923219323 10093094.1558758094906807,
3131689.6966011249460280 10093101.2113032583147287,
3131751.5000000000000000 10093111.0000000000000000,
3131757.8193978900089860 10093109.9991057012230158,
3131776.4466011249460280 10093146.5570504590868950,
3131820.6929495413787663 10093190.8033988755196333,
3131856.8636625604704022 10093209.2332976851612329,
3131855.0000000000000000 10093221.0000000000000000,
3131864.7886967407539487 10093282.8033988755196333,
3131893.1966011249460280 10093338.5570504590868950,
3131937.4429495413787663 10093382.8033988755196333,
3131993.1966011249460280 10093411.2113032583147287,
3132055.0000000000000000 10093421.0000000000000000,
3132116.8033988750539720 10093411.2113032583147287,
3132172.5570504586212337 10093382.8033988755196333,
3132211.4806754509918392 10093343.8797738831490278,
3132261.1966011249460280 10093369.2113032583147287,
3132323.0000000000000000 10093379.0000000000000000,
3132384.8033988750539720 10093369.2113032583147287,
3132440.5570504586212337 10093340.8033988755196333,
3132484.8033988750539720 10093296.5570504590868950,
3132513.2113032592460513 10093240.8033988755196333,
3132523.0000000000000000 10093179.0000000000000000,
3132513.2113032592460513 10093117.1966011244803667,
3132484.8033988750539720 10093061.4429495409131050,
3132440.5570504586212337 10093017.1966011244803667,
3132384.8033988750539720 10092988.7886967416852713,
3132323.0000000000000000 10092979.0000000000000000,
3132261.1966011249460280 10092988.7886967416852713,
3132205.4429495413787663 10093017.1966011244803667,
3132202.6250000000000000 10093020.0145506653934717,
3132172.8070504586212337 10092990.1966011244803667,
3132128.5310305962339044 10092967.6368422023952007,
3132128.4613032592460513 10092967.1966011244803667,
3132100.0533988750539720 10092911.4429495409131050,
3132055.8070504586212337 10092867.1966011244803667,
3132000.0533988750539720 10092838.7886967416852713,
3131938.2500000000000000 10092829.0000000000000000,
3131931.9306021099910140 10092830.0008942987769842,
3131913.3033988750539720 10092793.4429495409131050,
3131869.0570504586212337 10092749.1966011244803667,
3131813.3033988750539720 10092720.7886967416852713,
3131751.5000000000000000 10092711.0000000000000000,
3131732.5964318099431694 10092713.9940310679376125,
3131687.0533988750539720 10092690.7886967416852713,
3131625.2500000000000000 10092681.0000000000000000,
3131563.4466011249460280 10092690.7886967416852713,
3131507.6929495413787663 10092719.1966011244803667,
3131463.4466011249460280 10092763.4429495409131050,
3131453.7346392036415637 10092782.5037480369210243,
3131401.3033988750539720 10092755.7886967416852713,
3131339.5000000000000000 10092746.0000000000000000,
3131277.6966011249460280 10092755.7886967416852713,
3131221.9429495413787663 10092784.1966011244803667,
3131177.6966011249460280 10092828.4429495409131050,
3131149.2886967407539487 10092884.1966011244803667,
3131139.5000000000000000 10092946.0000000000000000,
3131149.2886967407539487 10093007.8033988755196333,
3131177.6966011249460280 10093063.5570504590868950,
3131221.9429495413787663 10093107.8033988755196333,
3131277.6966011249460280 10093136.2113032583147287,
3131287.5587792061269283 10093137.7733188141137362)),
((3132519.8371540000662208 10093968.6206899993121624,
3132510.0484572593122721 10093906.8172911237925291,
3132481.6405528751201928 10093851.0636395402252674,
3132437.3942044586874545 10093806.8172911237925291,
3132381.6405528751201928 10093778.4093867409974337,
3132319.8371540000662208 10093768.6206899993121624,
3132258.0337551250122488 10093778.4093867409974337,
3132202.2801035414449871 10093806.8172911237925291,
3132158.0337551250122488 10093851.0636395402252674,
3132129.6258507408201694 10093906.8172911237925291,
3132119.8371540000662208 10093968.6206899993121624,
3132129.6258507408201694 10094030.4240888748317957,
3132158.0337551250122488 10094086.1777404583990574,
3132202.2801035414449871 10094130.4240888748317957,
3132258.0337551250122488 10094158.8319932576268911,
3132319.8371540000662208 10094168.6206899993121624,
3132381.6405528751201928 10094158.8319932576268911,
3132437.3942044586874545 10094130.4240888748317957,
3132481.6405528751201928 10094086.1777404583990574,
3132510.0484572593122721 10094030.4240888748317957,
3132519.8371540000662208 10093968.6206899993121624)),
((3132489.5000000000000000 10085291.0000000000000000,
3132479.7113032592460513 10085229.1966011244803667,
3132451.3033988750539720 10085173.4429495409131050,
3132407.0570504586212337 10085129.1966011244803667,
3132351.3033988750539720 10085100.7886967416852713,
3132289.5000000000000000 10085091.0000000000000000,
3132227.6966011249460280 10085100.7886967416852713,
3132171.9429495413787663 10085129.1966011244803667,
3132127.6966011249460280 10085173.4429495409131050,
3132099.2886967407539487 10085229.1966011244803667,
3132089.5000000000000000 10085291.0000000000000000,
3132099.2886967407539487 10085352.8033988755196333,
3132127.6966011249460280 10085408.5570504590868950,
3132171.9429495413787663 10085452.8033988755196333,
3132227.6966011249460280 10085481.2113032583147287,
3132289.5000000000000000 10085491.0000000000000000,
3132351.3033988750539720 10085481.2113032583147287,
3132407.0570504586212337 10085452.8033988755196333,
3132451.3033988750539720 10085408.5570504590868950,
3132479.7113032592460513 10085352.8033988755196333,
3132489.5000000000000000 10085291.0000000000000000)),
((3132399.0405893186107278 10096330.6733119841665030,
3132389.2518925778567791 10096268.8699131086468697,
3132360.8439881936646998 10096213.1162615250796080,
3132316.5976397772319615 10096168.8699131086468697,
3132260.8439881936646998 10096140.4620087258517742,
3132199.0405893186107278 10096130.6733119841665030,
3132137.2371904435567558 10096140.4620087258517742,
3132081.4835388599894941 10096168.8699131086468697,
3132037.2371904435567558 10096213.1162615250796080,
3132008.8292860593646765 10096268.8699131086468697,
3131999.0405893186107278 10096330.6733119841665030,
3132008.8292860593646765 10096392.4767108596861362,
3132037.2371904435567558 10096448.2303624432533979,
3132081.4835388599894941 10096492.4767108596861362,
3132137.2371904435567558 10096520.8846152424812317,
3132199.0405893186107278 10096530.6733119841665030,
3132260.8439881936646998 10096520.8846152424812317,
3132316.5976397772319615 10096492.4767108596861362,
3132360.8439881936646998 10096448.2303624432533979,
3132389.2518925778567791 10096392.4767108596861362,
3132399.0405893186107278 10096330.6733119841665030)),
((3131400.7255569100379944 10084323.4139937553554773,
3131395.6966011249460280 10084328.4429495409131050,
3131367.2886967407539487 10084384.1966011244803667,
3131357.5000000000000000 10084446.0000000000000000,
3131367.2886967407539487 10084507.8033988755196333,
3131395.6966011249460280 10084563.5570504590868950,
3131439.9429495413787663 10084607.8033988755196333,
3131495.6966011249460280 10084636.2113032583147287,
3131557.5000000000000000 10084646.0000000000000000,
3131619.3033988750539720 10084636.2113032583147287,
3131675.0570504586212337 10084607.8033988755196333,
3131686.4033466423861682 10084596.4571026917546988,
3131697.6966011249460280 10084602.2113032583147287,
3131759.5000000000000000 10084612.0000000000000000,
3131821.3033988750539720 10084602.2113032583147287,
3131877.0570504586212337 10084573.8033988755196333,
3131921.3033988750539720 10084529.5570504590868950,
3131949.7113032592460513 10084473.8033988755196333,
3131959.5000000000000000 10084412.0000000000000000,
3131949.7113032592460513 10084350.1966011244803667,
3131921.3033988750539720 10084294.4429495409131050,
3131877.0570504586212337 10084250.1966011244803667,
3131821.3033988750539720 10084221.7886967416852713,
3131759.5000000000000000 10084212.0000000000000000,
3131697.6966011249460280 10084221.7886967416852713,
3131695.5887155616655946 10084222.8627180811017752,
3131650.3033988750539720 10084199.7886967416852713,
3131588.5000000000000000 10084190.0000000000000000,
3131526.6966011249460280 10084199.7886967416852713,
3131470.9429495413787663 10084228.1966011244803667,
3131426.6966011249460280 10084272.4429495409131050,
3131400.7255569100379944 10084323.4139937553554773)),
((3131467.7318061250261962 10092120.2226822115480900,
3131466.5000000000000000 10092128.0000000000000000,
3131476.2886967407539487 10092189.8033988755196333,
3131504.6966011249460280 10092245.5570504590868950,
3131548.9429495413787663 10092289.8033988755196333,
3131604.6966011249460280 10092318.2113032583147287,
3131666.5000000000000000 10092328.0000000000000000,
3131728.3033988750539720 10092318.2113032583147287,
3131782.4194894204847515 10092290.6377779003232718,
3131804.0533988750539720 10092287.2113032583147287,
3131859.8070504586212337 10092258.8033988755196333,
3131904.0533988750539720 10092214.5570504590868950,
3131932.4613032592460513 10092158.8033988755196333,
3131942.2500000000000000 10092097.0000000000000000,
3131932.4613032592460513 10092035.1966011244803667,
3131904.0533988750539720 10091979.4429495409131050,
3131859.8070504586212337 10091935.1966011244803667,
3131804.0533988750539720 10091906.7886967416852713,
3131742.2500000000000000 10091897.0000000000000000,
3131680.4466011249460280 10091906.7886967416852713,
3131658.0100431735627353 10091918.2206940166652203,
3131605.3811745895072818 10091926.5562879126518965,
3131549.6275230059400201 10091954.9641922954469919,
3131505.3811745895072818 10091999.2105407118797302,
3131476.9732702053152025 10092054.9641922954469919,
3131467.1845734645612538 10092116.7675911709666252,
3131467.7318061250261962 10092120.2226822115480900)),
((3131842.7500000000000000 10085312.0000000000000000,
3131832.9613032592460513 10085250.1966011244803667,
3131804.5533988750539720 10085194.4429495409131050,
3131760.3070504586212337 10085150.1966011244803667,
3131704.5533988750539720 10085121.7886967416852713,
3131642.7500000000000000 10085112.0000000000000000,
3131580.9466011249460280 10085121.7886967416852713,
3131525.1929495413787663 10085150.1966011244803667,
3131480.9466011249460280 10085194.4429495409131050,
3131452.5386967407539487 10085250.1966011244803667,
3131442.7500000000000000 10085312.0000000000000000,
3131452.5386967407539487 10085373.8033988755196333,
3131480.9466011249460280 10085429.5570504590868950,
3131525.1929495413787663 10085473.8033988755196333,
3131580.9466011249460280 10085502.2113032583147287,
3131642.7500000000000000 10085512.0000000000000000,
3131704.5533988750539720 10085502.2113032583147287,
3131760.3070504586212337 10085473.8033988755196333,
3131804.5533988750539720 10085429.5570504590868950,
3131832.9613032592460513 10085373.8033988755196333,
3131842.7500000000000000 10085312.0000000000000000)),
((3131380.6685430491343141 10096818.7210076171904802,
3131336.5690999175421894 10096825.7056732363998890,
3131280.8154483339749277 10096854.1135776191949844,
3131236.5690999175421894 10096898.3599260356277227,
3131208.1611955333501101 10096954.1135776191949844,
3131198.3724987925961614 10097015.9169764947146177,
3131208.1611955333501101 10097077.7203753702342510,
3131236.5690999175421894 10097133.4740269538015127,
3131280.8154483339749277 10097177.7203753702342510,
3131336.5690999175421894 10097206.1282797530293465,
3131398.3724987925961614 10097215.9169764947146177,
3131460.1758976676501334 10097206.1282797530293465,
3131515.9295492512173951 10097177.7203753702342510,
3131528.4539557434618473 10097165.1959688775241375,
3131572.5533988750539720 10097158.2113032583147287,
3131628.3070504586212337 10097129.8033988755196333,
3131672.5533988750539720 10097085.5570504590868950,
3131700.9613032592460513 10097029.8033988755196333,
3131710.7500000000000000 10096968.0000000000000000,
3131700.9613032592460513 10096906.1966011244803667,
3131672.5533988750539720 10096850.4429495409131050,
3131628.3070504586212337 10096806.1966011244803667,
3131572.5533988750539720 10096777.7886967416852713,
3131510.7500000000000000 10096768.0000000000000000,
3131448.9466011249460280 10096777.7886967416852713,
3131393.1929495413787663 10096806.1966011244803667,
3131380.6685430491343141 10096818.7210076171904802)),
((3131009.9058093223720789 10100104.0162586569786072,
3131009.7500000000000000 10100105.0000000000000000,
3131019.5386967407539487 10100166.8033988755196333,
3131047.9466011249460280 10100222.5570504590868950,
3131092.1929495413787663 10100266.8033988755196333,
3131147.9466011249460280 10100295.2113032583147287,
3131209.7500000000000000 10100305.0000000000000000,
3131250.2408929169178009 10100298.5868725869804621,
3131248.7500000000000000 10100308.0000000000000000,
3131258.5386967407539487 10100369.8033988755196333,
3131286.9466011249460280 10100425.5570504590868950,
3131331.1929495413787663 10100469.8033988755196333,
3131386.9466011249460280 10100498.2113032583147287,
3131448.7500000000000000 10100508.0000000000000000,
3131510.5533988750539720 10100498.2113032583147287,
3131566.3070504586212337 10100469.8033988755196333,
3131610.5533988750539720 10100425.5570504590868950,
3131638.9613032592460513 10100369.8033988755196333,
3131648.7500000000000000 10100308.0000000000000000,
3131638.9613032592460513 10100246.1966011244803667,
3131610.5533988750539720 10100190.4429495409131050,
3131566.3070504586212337 10100146.1966011244803667,
3131510.5533988750539720 10100117.7886967416852713,
3131448.7500000000000000 10100108.0000000000000000,
3131408.2591070830821991 10100114.4131274130195379,
3131409.7500000000000000 10100105.0000000000000000,
3131408.3885755990631878 10100096.4043046254664660,
3131453.8033988750539720 10100089.2113032583147287,
3131509.5570504586212337 10100060.8033988755196333,
3131553.8033988750539720 10100016.5570504590868950,
3131582.2113032592460513 10099960.8033988755196333,
3131592.0000000000000000 10099899.0000000000000000,
3131582.2113032592460513 10099837.1966011244803667,
3131553.8033988750539720 10099781.4429495409131050,
3131509.5570504586212337 10099737.1966011244803667,
3131453.8033988750539720 10099708.7886967416852713,
3131392.0000000000000000 10099699.0000000000000000,
3131382.2480521067045629 10099700.5445568095892668,
3131374.5533988750539720 10099685.4429495409131050,
3131330.3070504586212337 10099641.1966011244803667,
3131274.5533988750539720 10099612.7886967416852713,
3131212.7500000000000000 10099603.0000000000000000,
3131150.9466011249460280 10099612.7886967416852713,
3131095.1929495413787663 10099641.1966011244803667,
3131050.9466011249460280 10099685.4429495409131050,
3131022.5386967407539487 10099741.1966011244803667,
3131016.6870483122766018 10099778.1424552537500858,
3131010.6929495413787663 10099781.1966011244803667,
3130966.4466011249460280 10099825.4429495409131050,
3130938.0386967407539487 10099881.1966011244803667,
3130928.2500000000000000 10099943.0000000000000000,
3130938.0386967407539487 10100004.8033988755196333,
3130966.4466011249460280 10100060.5570504590868950,
3131009.9058093223720789 10100104.0162586569786072)),
((3127277.2500000000000000 10098867.0000000000000000,
3127267.4613032592460513 10098805.1966011244803667,
3127239.0533988750539720 10098749.4429495409131050,
3127194.8070504586212337 10098705.1966011244803667,
3127139.0533988750539720 10098676.7886967416852713,
3127077.2500000000000000 10098667.0000000000000000,
3127015.4466011249460280 10098676.7886967416852713,
3126959.6929495413787663 10098705.1966011244803667,
3126915.4466011249460280 10098749.4429495409131050,
3126887.0386967407539487 10098805.1966011244803667,
3126877.2500000000000000 10098867.0000000000000000,
3126887.0386967407539487 10098928.8033988755196333,
3126915.4466011249460280 10098984.5570504590868950,
3126959.6929495413787663 10099028.8033988755196333,
3127015.4466011249460280 10099057.2113032583147287,
3127077.2500000000000000 10099067.0000000000000000,
3127139.0533988750539720 10099057.2113032583147287,
3127194.8070504586212337 10099028.8033988755196333,
3127239.0533988750539720 10098984.5570504590868950,
3127267.4613032592460513 10098928.8033988755196333,
3127277.2500000000000000 10098867.0000000000000000))),
MULTIPOLYGON (((3132347.2500000000000000 10081181.0000000000000000,
3132337.4613032592460513 10081119.1966011244803667,
3132309.0533988750539720 10081063.4429495409131050,
3132264.8070504586212337 10081019.1966011244803667,
3132209.0533988750539720 10080990.7886967416852713,
3132147.2500000000000000 10080981.0000000000000000,
3132085.4466011249460280 10080990.7886967416852713,
3132029.6929495413787663 10081019.1966011244803667,
3131985.4466011249460280 10081063.4429495409131050,
3131957.0386967407539487 10081119.1966011244803667,
3131947.2500000000000000 10081181.0000000000000000,
3131957.0386967407539487 10081242.8033988755196333,
3131985.4466011249460280 10081298.5570504590868950,
3132029.6929495413787663 10081342.8033988755196333,
3132085.4466011249460280 10081371.2113032583147287,
3132147.2500000000000000 10081381.0000000000000000,
3132209.0533988750539720 10081371.2113032583147287,
3132264.8070504586212337 10081342.8033988755196333,
3132309.0533988750539720 10081298.5570504590868950,
3132337.4613032592460513 10081242.8033988755196333,
3132347.2500000000000000 10081181.0000000000000000)),
((3131169.2105593103915453 10081549.7880717460066080,
3131118.6966011249460280 10081557.7886967416852713,
3131062.9429495413787663 10081586.1966011244803667,
3131018.6966011249460280 10081630.4429495409131050,
3130990.2886967407539487 10081686.1966011244803667,
3130980.5000000000000000 10081748.0000000000000000,
3130990.2886967407539487 10081809.8033988755196333,
3131018.6966011249460280 10081865.5570504590868950,
3131062.9429495413787663 10081909.8033988755196333,
3131118.6966011249460280 10081938.2113032583147287,
3131180.5000000000000000 10081948.0000000000000000,
3131242.3033988750539720 10081938.2113032583147287,
3131298.0570504586212337 10081909.8033988755196333,
3131342.3033988750539720 10081865.5570504590868950,
3131370.7113032592460513 10081809.8033988755196333,
3131374.2894406896084547 10081787.2119282539933920,
3131424.8033988750539720 10081779.2113032583147287,
3131480.5570504586212337 10081750.8033988755196333,
3131524.8033988750539720 10081706.5570504590868950,
3131553.2113032592460513 10081650.8033988755196333,
3131563.0000000000000000 10081589.0000000000000000,
3131556.7027526847086847 10081549.2407452240586281,
3131593.3230797019787133 10081512.6204182058572769,
3131621.7309840861707926 10081456.8667666222900152,
3131631.5196808269247413 10081395.0633677467703819,
3131621.7309840861707926 10081333.2599688712507486,
3131593.3230797019787133 10081277.5063172876834869,
3131549.0767312855459750 10081233.2599688712507486,
3131493.3230797019787133 10081204.8520644884556532,
3131431.5196808269247413 10081195.0633677467703819,
3131369.7162819518707693 10081204.8520644884556532,
3131313.9626303683035076 10081233.2599688712507486,
3131269.7162819518707693 10081277.5063172876834869,
3131241.3083775676786900 10081333.2599688712507486,
3131231.5196808269247413 10081395.0633677467703819,
3131237.8169281422160566 10081434.8226225227117538,
3131201.1966011249460280 10081471.4429495409131050,
3131172.7886967407539487 10081527.1966011244803667,
3131169.2105593103915453 10081549.7880717460066080)),
((3130865.5657762284390628 10079938.0688744615763426,
3130827.6437804959714413 10079957.3910963814705610,
3130783.3974320795387030 10080001.6374447979032993,
3130754.9895276953466237 10080057.3910963814705610,
3130745.2008309545926750 10080119.1944952569901943,
3130754.9895276953466237 10080180.9978941325098276,
3130783.3974320795387030 10080236.7515457160770893,
3130827.6437804959714413 10080280.9978941325098276,
3130883.3974320795387030 10080309.4057985153049231,
3130943.8375088651664555 10080318.9785662516951561,
3130960.9466011249460280 10080352.5570504590868950,
3131005.1929495413787663 10080396.8033988755196333,
3131060.9466011249460280 10080425.2113032583147287,
3131122.7500000000000000 10080435.0000000000000000,
3131184.5533988750539720 10080425.2113032583147287,
3131240.3070504586212337 10080396.8033988755196333,
3131284.5533988750539720 10080352.5570504590868950,
3131312.9613032592460513 10080296.8033988755196333,
3131322.7500000000000000 10080235.0000000000000000,
3131322.7219715188257396 10080234.8230351340025663,
3131325.4466011249460280 10080236.2113032583147287,
3131387.2500000000000000 10080246.0000000000000000,
3131449.0533988750539720 10080236.2113032583147287,
3131504.8070504586212337 10080207.8033988755196333,
3131549.0533988750539720 10080163.5570504590868950,
3131577.4613032592460513 10080107.8033988755196333,
3131587.2500000000000000 10080046.0000000000000000,
3131577.4613032592460513 10079984.1966011244803667,
3131549.0533988750539720 10079928.4429495409131050,
3131526.0568381357006729 10079905.4463888015598059,
3131541.0570504586212337 10079897.8033988755196333,
3131585.3033988750539720 10079853.5570504590868950,
3131613.7113032592460513 10079797.8033988755196333,
3131623.5000000000000000 10079736.0000000000000000,
3131613.7113032592460513 10079674.1966011244803667,
3131585.3033988750539720 10079618.4429495409131050,
3131541.0570504586212337 10079574.1966011244803667,
3131485.3033988750539720 10079545.7886967416852713,
3131423.5000000000000000 10079536.0000000000000000,
3131361.6966011249460280 10079545.7886967416852713,
3131305.9429495413787663 10079574.1966011244803667,
3131261.6966011249460280 10079618.4429495409131050,
3131233.2886967407539487 10079674.1966011244803667,
3131223.5000000000000000 10079736.0000000000000000,
3131229.7963356473483145 10079775.7534987311810255,
3131226.5290500517003238 10079776.2709859311580658,
3131208.5636688028462231 10079741.0119399577379227,
3131164.3173203864134848 10079696.7655915413051844,
3131108.5636688028462231 10079668.3576871585100889,
3131046.7602699277922511 10079658.5689904168248177,
3130984.9568710527382791 10079668.3576871585100889,
3130929.2032194691710174 10079696.7655915413051844,
3130884.9568710527382791 10079741.0119399577379227,
3130856.5489666685461998 10079796.7655915413051844,
3130846.7602699277922511 10079858.5689904168248177,
3130856.5489666685461998 10079920.3723892923444510,
3130865.5657762284390628 10079938.0688744615763426)),
((3129970.2669724728912115 10084143.6225781925022602,
3129933.3033988750539720 10084124.7886967416852713,
3129871.5000000000000000 10084115.0000000000000000,
3129809.6966011249460280 10084124.7886967416852713,
3129753.9429495413787663 10084153.1966011244803667,
3129709.6966011249460280 10084197.4429495409131050,
3129681.2886967407539487 10084253.1966011244803667,
3129671.5000000000000000 10084315.0000000000000000,
3129681.2886967407539487 10084376.8033988755196333,
3129709.6966011249460280 10084432.5570504590868950,
3129753.9429495413787663 10084476.8033988755196333,
3129809.6966011249460280 10084505.2113032583147287,
3129871.5000000000000000 10084515.0000000000000000,
3129933.3033988750539720 10084505.2113032583147287,
3129989.0570504586212337 10084476.8033988755196333,
3130002.4830275271087885 10084463.3774218074977398,
3130008.8090698570013046 10084466.6007013693451881,
3129983.5386967407539487 10084516.1966011244803667,
3129973.7500000000000000 10084578.0000000000000000,
3129983.5386967407539487 10084639.8033988755196333,
3130011.9466011249460280 10084695.5570504590868950,
3130056.1929495413787663 10084739.8033988755196333,
3130111.9466011249460280 10084768.2113032583147287,
3130173.7500000000000000 10084778.0000000000000000,
3130235.5533988750539720 10084768.2113032583147287,
3130291.3070504586212337 10084739.8033988755196333,
3130335.5533988750539720 10084695.5570504590868950,
3130363.9613032592460513 10084639.8033988755196333,
3130366.8183174086734653 10084621.7649214621633291,
3130406.9466011249460280 10084642.2113032583147287,
3130468.7500000000000000 10084652.0000000000000000,
3130518.2927499432116747 10084644.1531992778182030,
3130555.9429495413787663 10084681.8033988755196333,
3130611.6966011249460280 10084710.2113032583147287,
3130673.5000000000000000 10084720.0000000000000000,
3130735.3033988750539720 10084710.2113032583147287,
3130791.0570504586212337 10084681.8033988755196333,
3130835.3033988750539720 10084637.5570504590868950,
3130836.3461241577751935 10084635.5105868652462959,
3130830.2500000000000000 10084674.0000000000000000,
3130832.3541938099078834 10084687.2853568568825722,
3130807.5736015490256250 10084712.0659491177648306,
3130796.6966011249460280 10084713.7886967416852713,
3130740.9429495413787663 10084742.1966011244803667,
3130696.6966011249460280 10084786.4429495409131050,
3130668.2886967407539487 10084842.1966011244803667,
3130658.5000000000000000 10084904.0000000000000000,
3130668.2886967407539487 10084965.8033988755196333,
3130696.6966011249460280 10085021.5570504590868950,
3130700.3895506658591330 10085025.2500000000000000,
3130680.1966011249460280 10085045.4429495409131050,
3130651.7886967407539487 10085101.1966011244803667,
3130642.0000000000000000 10085163.0000000000000000,
3130651.7886967407539487 10085224.8033988755196333,
3130680.1966011249460280 10085280.5570504590868950,
3130724.4429495413787663 10085324.8033988755196333,
3130780.1966011249460280 10085353.2113032583147287,
3130842.0000000000000000 10085363.0000000000000000,
3130903.8033988750539720 10085353.2113032583147287,
3130943.0998419085517526 10085333.1887654587626457,
3130940.0386967407539487 10085339.1966011244803667,
3130930.2500000000000000 10085401.0000000000000000,
3130940.0386967407539487 10085462.8033988755196333,
3130968.4466011249460280 10085518.5570504590868950,
3131012.6929495413787663 10085562.8033988755196333,
3131068.4466011249460280 10085591.2113032583147287,
3131130.2500000000000000 10085601.0000000000000000,
3131192.0533988750539720 10085591.2113032583147287,
3131247.8070504586212337 10085562.8033988755196333,
3131292.0533988750539720 10085518.5570504590868950,
3131295.8825202966108918 10085511.0419765301048756,
3131333.5000000000000000 10085517.0000000000000000,
3131395.3033988750539720 10085507.2113032583147287,
3131451.0570504586212337 10085478.8033988755196333,
3131495.3033988750539720 10085434.5570504590868950,
3131523.7113032592460513 10085378.8033988755196333,
3131533.5000000000000000 10085317.0000000000000000,
3131523.7113032592460513 10085255.1966011244803667,
3131495.3033988750539720 10085199.4429495409131050,
3131483.1773386686109006 10085187.3168893344700336,
3131466.4529372137039900 10085154.4934033416211605,
3131473.5000000000000000 10085110.0000000000000000,
3131463.7113032592460513 10085048.1966011244803667,
3131435.3033988750539720 10084992.4429495409131050,
3131423.6104493341408670 10084980.7500000000000000,
3131429.8033988750539720 10084974.5570504590868950,
3131458.2113032592460513 10084918.8033988755196333,
3131468.0000000000000000 10084857.0000000000000000,
3131458.2113032592460513 10084795.1966011244803667,
3131429.8033988750539720 10084739.4429495409131050,
3131385.5570504586212337 10084695.1966011244803667,
3131329.8033988750539720 10084666.7886967416852713,
3131268.0000000000000000 10084657.0000000000000000,
3131228.5471638026647270 10084663.2487153802067041,
3131220.4613032592460513 10084612.1966011244803667,
3131192.0533988750539720 10084556.4429495409131050,
3131147.8070504586212337 10084512.1966011244803667,
3131092.0533988750539720 10084483.7886967416852713,
3131030.2500000000000000 10084474.0000000000000000,
3130968.4466011249460280 10084483.7886967416852713,
3130912.6929495413787663 10084512.1966011244803667,
3130868.4466011249460280 10084556.4429495409131050,
3130867.4038758422248065 10084558.4894131347537041,
3130873.5000000000000000 10084520.0000000000000000,
3130868.2168630780652165 10084486.6435862556099892,
3130874.3033988750539720 10084480.5570504590868950,
3130884.2142877345904708 10084461.1058358643203974,
3130908.8033988750539720 10084457.2113032583147287,
3130964.5570504586212337 10084428.8033988755196333,
3131008.8033988750539720 10084384.5570504590868950,
3131037.2113032592460513 10084328.8033988755196333,
3131044.2598674744367599 10084284.3005158845335245,
3131105.5000000000000000 10084294.0000000000000000,
3131139.7196850073523819 10084288.5801343414932489,
3131142.9429495413787663 10084291.8033988755196333,
3131198.6966011249460280 10084320.2113032583147287,
3131260.5000000000000000 10084330.0000000000000000,
3131322.3033988750539720 10084320.2113032583147287,
3131378.0570504586212337 10084291.8033988755196333,
3131422.3033988750539720 10084247.5570504590868950,
3131450.7113032592460513 10084191.8033988755196333,
3131460.5000000000000000 10084130.0000000000000000,
3131450.7113032592460513 10084068.1966011244803667,
3131422.3033988750539720 10084012.4429495409131050,
3131392.4854493341408670 10083982.6250000000000000,
3131426.5533988750539720 10083948.5570504590868950,
3131454.9613032592460513 10083892.8033988755196333,
3131464.7500000000000000 10083831.0000000000000000,
3131458.8857659501954913 10083793.9746833834797144,
3131460.3033988750539720 10083792.5570504590868950,
3131488.7113032592460513 10083736.8033988755196333,
3131498.5000000000000000 10083675.0000000000000000,
3131488.7113032592460513 10083613.1966011244803667,
3131460.3033988750539720 10083557.4429495409131050,
3131440.8656401019543409 10083538.0051907673478127,
3131441.5000000000000000 10083534.0000000000000000,
3131431.7113032592460513 10083472.1966011244803667,
3131403.3033988750539720 10083416.4429495409131050,
3131360.3604493341408670 10083373.5000000000000000,
3131379.3033988750539720 10083354.5570504590868950,
3131406.6380189950577915 10083300.9098378475755453,
3131436.3033988750539720 10083296.2113032583147287,
3131492.0570504586212337 10083267.8033988755196333,
3131536.3033988750539720 10083223.5570504590868950,
3131564.7113032592460513 10083167.8033988755196333,
3131574.5000000000000000 10083106.0000000000000000,
3131564.7113032592460513 10083044.1966011244803667,
3131536.3033988750539720 10082988.4429495409131050,
3131500.2354493341408670 10082952.3750000000000000,
3131526.0533988750539720 10082926.5570504590868950,
3131554.4613032592460513 10082870.8033988755196333,
3131564.2500000000000000 10082809.0000000000000000,
3131554.4613032592460513 10082747.1966011244803667,
3131526.0533988750539720 10082691.4429495409131050,
3131481.8070504586212337 10082647.1966011244803667,
3131426.0533988750539720 10082618.7886967416852713,
3131364.2500000000000000 10082609.0000000000000000,
3131302.4466011249460280 10082618.7886967416852713,
3131246.6929495413787663 10082647.1966011244803667,
3131240.0899179661646485 10082653.7996327001601458,
3131234.3033988750539720 10082642.4429495409131050,
3131190.0570504586212337 10082598.1966011244803667,
3131134.3033988750539720 10082569.7886967416852713,
3131072.5000000000000000 10082560.0000000000000000,
3131010.6966011249460280 10082569.7886967416852713,
3130954.9429495413787663 10082598.1966011244803667,
3130910.6966011249460280 10082642.4429495409131050,
3130882.2886967407539487 10082698.1966011244803667,
3130872.5000000000000000 10082760.0000000000000000,
3130882.0369744473136961 10082820.2140868641436100,
3130868.2886967407539487 10082847.1966011244803667,
3130866.6180999884381890 10082857.7443339023739100,
3130835.3033988750539720 10082841.7886967416852713,
3130773.5000000000000000 10082832.0000000000000000,
3130731.9425092483870685 10082838.5820599142462015,
3130707.5570504586212337 10082814.1966011244803667,
3130651.8033988750539720 10082785.7886967416852713,
3130590.0000000000000000 10082776.0000000000000000,
3130528.1966011249460280 10082785.7886967416852713,
3130472.4429495413787663 10082814.1966011244803667,
3130428.1966011249460280 10082858.4429495409131050,
3130399.7886967407539487 10082914.1966011244803667,
3130390.0000000000000000 10082976.0000000000000000,
3130399.7886967407539487 10083037.8033988755196333,
3130428.1966011249460280 10083093.5570504590868950,
3130472.4429495413787663 10083137.8033988755196333,
3130528.1966011249460280 10083166.2113032583147287,
3130590.0000000000000000 10083176.0000000000000000,
3130631.5574907516129315 10083169.4179400857537985,
3130655.9429495413787663 10083193.8033988755196333,
3130668.7234854153357446 10083200.3154071606695652,
3130642.2886967407539487 10083252.1966011244803667,
3130632.5000000000000000 10083314.0000000000000000,
3130642.2886967407539487 10083375.8033988755196333,
3130655.9441332137212157 10083402.6037019547075033,
3130614.2500000000000000 10083396.0000000000000000,
3130552.4466011249460280 10083405.7886967416852713,
3130496.6929495413787663 10083434.1966011244803667,
3130452.4466011249460280 10083478.4429495409131050,
3130424.0386967407539487 10083534.1966011244803667,
3130414.2500000000000000 10083596.0000000000000000,
3130424.0386967407539487 10083657.8033988755196333,
3130452.4466011249460280 10083713.5570504590868950,
3130496.6929495413787663 10083757.8033988755196333,
3130552.4466011249460280 10083786.2113032583147287,
3130614.2500000000000000 10083796.0000000000000000,
3130640.3780604191124439 10083791.8617217727005482,
3130588.6929495413787663 10083818.1966011244803667,
3130544.4466011249460280 10083862.4429495409131050,
3130543.7507692789658904 10083863.8085964322090149,
3130540.9613032592460513 10083846.1966011244803667,
3130512.5533988750539720 10083790.4429495409131050,
3130468.3070504586212337 10083746.1966011244803667,
3130412.5533988750539720 10083717.7886967416852713,
3130350.7500000000000000 10083708.0000000000000000,
3130288.9466011249460280 10083717.7886967416852713,
3130270.5835135458037257 10083727.1451571937650442,
3130209.6966011249460280 10083736.7886967416852713,
3130167.9047404709272087 10083758.0827133264392614,
3130129.5000000000000000 10083752.0000000000000000,
3130067.6966011249460280 10083761.7886967416852713,
3130011.9429495413787663 10083790.1966011244803667,
3129967.6966011249460280 10083834.4429495409131050,
3129939.2886967407539487 10083890.1966011244803667,
3129929.5000000000000000 10083952.0000000000000000,
3129939.2886967407539487 10084013.8033988755196333,
3129967.6966011249460280 10084069.5570504590868950,
3130011.9429495413787663 10084113.8033988755196333,
3130013.9046850185841322 10084114.8029530253261328,
3129983.6929495413787663 10084130.1966011244803667,
3129970.2669724728912115 10084143.6225781925022602),
(3131100.5610343911685050 10085205.7022702023386955,
3131068.4466011249460280 10085210.7886967416852713,
3131029.1501580914482474 10085230.8112345412373543,
3131032.2113032592460513 10085224.8033988755196333,
3131042.0000000000000000 10085163.0000000000000000,
3131032.2113032592460513 10085101.1966011244803667,
3131003.8033988750539720 10085045.4429495409131050,
3131000.1104493341408670 10085041.7500000000000000,
3131016.9263984509743750 10085024.9340508822351694,
3131027.8033988750539720 10085023.2113032583147287,
3131083.5570504586212337 10084994.8033988755196333,
3131083.8867625822313130 10084994.4736867509782314,
3131114.5172577477060258 10084989.6222929190844297,
3131111.6966011249460280 10084992.4429495409131050,
3131083.2886967407539487 10085048.1966011244803667,
3131073.5000000000000000 10085110.0000000000000000,
3131083.2886967407539487 10085171.8033988755196333,
3131100.5610343911685050 10085205.7022702023386955),
(3130680.1219395808875561 10083784.1382782272994518,
3130729.2874125088565052 10083759.0872185342013836,
3130725.5000000000000000 10083783.0000000000000000,
3130725.5079443641006947 10083783.0501587409526110,
3130706.2500000000000000 10083780.0000000000000000,
3130680.1219395808875561 10083784.1382782272994518),
(3130216.8453149809502065 10084129.1970469728112221,
3130233.0952595290727913 10084120.9172866735607386,
3130271.5000000000000000 10084127.0000000000000000,
3130333.3033988750539720 10084117.2113032583147287,
3130351.6664864541962743 10084107.8548428062349558,
3130412.5533988750539720 10084098.2113032583147287,
3130468.3070504586212337 10084069.8033988755196333,
3130512.5533988750539720 10084025.5570504590868950,
3130513.2492307210341096 10084024.1914035677909851,
3130516.0386967407539487 10084041.8033988755196333,
3130529.6407058387994766 10084068.4988448265939951,
3130488.6966011249460280 10084109.4429495409131050,
3130472.9680830687284470 10084140.3119043130427599,
3130466.0533988750539720 10084136.7886967416852713,
3130404.2500000000000000 10084127.0000000000000000,
3130342.4466011249460280 10084136.7886967416852713,
3130286.6929495413787663 10084165.1966011244803667,
3130267.9116825484670699 10084183.9778681173920631,
3130263.0533988750539720 10084174.4429495409131050,
3130218.8070504586212337 10084130.1966011244803667,
3130216.8453149809502065 10084129.1970469728112221)),
((3129577.5385824376717210 10085577.1357893180102110,
3129586.0386967407539487 10085630.8033988755196333,
3129614.4466011249460280 10085686.5570504590868950,
3129658.6929495413787663 10085730.8033988755196333,
3129714.4466011249460280 10085759.2113032583147287,
3129776.2500000000000000 10085769.0000000000000000,
3129781.1184620317071676 10085768.2289113663136959,
3129814.6929495413787663 10085801.8033988755196333,
3129870.4466011249460280 10085830.2113032583147287,
3129932.2500000000000000 10085840.0000000000000000,
3129979.6345717832446098 10085832.4950211178511381,
3129980.9429495413787663 10085833.8033988755196333,
3129993.6005668840371072 10085840.2527770418673754,
3129996.5386967407539487 10085858.8033988755196333,
3130024.9466011249460280 10085914.5570504590868950,
3130069.1929495413787663 10085958.8033988755196333,
3130124.9466011249460280 10085987.2113032583147287,
3130186.7500000000000000 10085997.0000000000000000,
3130248.5533988750539720 10085987.2113032583147287,
3130304.3070504586212337 10085958.8033988755196333,
3130348.5533988750539720 10085914.5570504590868950,
3130361.0557899512350559 10085890.0197263900190592,
3130392.5000000000000000 10085895.0000000000000000,
3130454.3033988750539720 10085885.2113032583147287,
3130510.0570504586212337 10085856.8033988755196333,
3130554.3033988750539720 10085812.5570504590868950,
3130567.3519583083689213 10085786.9478106331080198,
3130571.1584564736112952 10085810.9810941927134991,
3130565.6966011249460280 10085816.4429495409131050,
3130537.2886967407539487 10085872.1966011244803667,
3130527.5000000000000000 10085934.0000000000000000,
3130530.6924782493151724 10085954.1565143819898367,
3130523.5386967407539487 10085968.1966011244803667,
3130513.7500000000000000 10086030.0000000000000000,
3130523.5386967407539487 10086091.8033988755196333,
3130551.9466011249460280 10086147.5570504590868950,
3130596.1929495413787663 10086191.8033988755196333,
3130651.9466011249460280 10086220.2113032583147287,
3130713.7500000000000000 10086230.0000000000000000,
3130775.5533988750539720 10086220.2113032583147287,
3130831.3070504586212337 10086191.8033988755196333,
3130875.5533988750539720 10086147.5570504590868950,
3130876.3963892119936645 10086145.9025887679308653,
3130901.6966011249460280 10086195.5570504590868950,
3130917.7898455378599465 10086211.6502948720008135,
3130914.2500000000000000 10086234.0000000000000000,
3130924.0386967407539487 10086295.8033988755196333,
3130952.4466011249460280 10086351.5570504590868950,
3130996.6929495413787663 10086395.8033988755196333,
3131052.4466011249460280 10086424.2113032583147287,
3131114.2500000000000000 10086434.0000000000000000,
3131114.5173625005409122 10086433.9576539397239685,
3131121.4466011249460280 10086447.5570504590868950,
3131165.6929495413787663 10086491.8033988755196333,
3131221.4466011249460280 10086520.2113032583147287,
3131283.2500000000000000 10086530.0000000000000000,
3131345.0533988750539720 10086520.2113032583147287,
3131400.8070504586212337 10086491.8033988755196333,
3131445.0533988750539720 10086447.5570504590868950,
3131473.4613032592460513 10086391.8033988755196333,
3131483.2500000000000000 10086330.0000000000000000,
3131473.4613032592460513 10086268.1966011244803667,
3131445.0533988750539720 10086212.4429495409131050,
3131400.8070504586212337 10086168.1966011244803667,
3131345.0533988750539720 10086139.7886967416852713,
3131283.2500000000000000 10086130.0000000000000000,
3131282.9826374994590878 10086130.0423460602760315,
3131276.0533988750539720 10086116.4429495409131050,
3131259.9601544621400535 10086100.3497051279991865,
3131263.5000000000000000 10086078.0000000000000000,
3131253.7113032592460513 10086016.1966011244803667,
3131231.6707903640344739 10085972.9396589696407318,
3131248.0533988750539720 10085956.5570504590868950,
3131276.4613032592460513 10085900.8033988755196333,
3131286.2500000000000000 10085839.0000000000000000,
3131276.4613032592460513 10085777.1966011244803667,
3131248.0533988750539720 10085721.4429495409131050,
3131203.8070504586212337 10085677.1966011244803667,
3131148.0533988750539720 10085648.7886967416852713,
3131086.2500000000000000 10085639.0000000000000000,
3131084.4338311650790274 10085639.2876528836786747,
3131073.3033988750539720 10085617.4429495409131050,
3131029.0570504586212337 10085573.1966011244803667,
3130973.3033988750539720 10085544.7886967416852713,
3130911.5000000000000000 10085535.0000000000000000,
3130849.6966011249460280 10085544.7886967416852713,
3130820.9797444655559957 10085559.4206660389900208,
3130761.5000000000000000 10085550.0000000000000000,
3130699.6966011249460280 10085559.7886967416852713,
3130643.9429495413787663 10085588.1966011244803667,
3130599.6966011249460280 10085632.4429495409131050,
3130586.6480416916310787 10085658.0521893668919802,
3130582.7113032592460513 10085633.1966011244803667,
3130554.3033988750539720 10085577.4429495409131050,
3130510.0570504586212337 10085533.1966011244803667,
3130454.3033988750539720 10085504.7886967416852713,
3130392.5000000000000000 10085495.0000000000000000,
3130330.6966011249460280 10085504.7886967416852713,
3130301.2258931123651564 10085519.8047724887728691,
3130288.3033988750539720 10085494.4429495409131050,
3130244.0570504586212337 10085450.1966011244803667,
3130188.3033988750539720 10085421.7886967416852713,
3130126.5000000000000000 10085412.0000000000000000,
3130064.6966011249460280 10085421.7886967416852713,
3130008.9429495413787663 10085450.1966011244803667,
3130004.1873486237600446 10085454.9522020425647497,
3129994.0533988750539720 10085449.7886967416852713,
3129932.2500000000000000 10085440.0000000000000000,
3129927.3815379682928324 10085440.7710886336863041,
3129893.8070504586212337 10085407.1966011244803667,
3129838.0533988750539720 10085378.7886967416852713,
3129806.9614175623282790 10085373.8642106819897890,
3129798.4613032592460513 10085320.1966011244803667,
3129770.0533988750539720 10085264.4429495409131050,
3129725.8070504586212337 10085220.1966011244803667,
3129670.0533988750539720 10085191.7886967416852713,
3129608.2500000000000000 10085182.0000000000000000,
3129546.4466011249460280 10085191.7886967416852713,
3129490.6929495413787663 10085220.1966011244803667,
3129446.4466011249460280 10085264.4429495409131050,
3129418.0386967407539487 10085320.1966011244803667,
3129408.2500000000000000 10085382.0000000000000000,
3129418.0386967407539487 10085443.8033988755196333,
3129446.4466011249460280 10085499.5570504590868950,
3129490.6929495413787663 10085543.8033988755196333,
3129546.4466011249460280 10085572.2113032583147287,
3129577.5385824376717210 10085577.1357893180102110)),
((3131076.6083601950667799 10087178.0020891390740871,
3131075.5000000000000000 10087185.0000000000000000,
3131085.2886967407539487 10087246.8033988755196333,
3131113.6966011249460280 10087302.5570504590868950,
3131157.9429495413787663 10087346.8033988755196333,
3131213.6966011249460280 10087375.2113032583147287,
3131275.5000000000000000 10087385.0000000000000000,
3131337.3033988750539720 10087375.2113032583147287,
3131393.0570504586212337 10087346.8033988755196333,
3131437.3033988750539720 10087302.5570504590868950,
3131465.7113032592460513 10087246.8033988755196333,
3131475.5000000000000000 10087185.0000000000000000,
3131465.7113032592460513 10087123.1966011244803667,
3131437.3033988750539720 10087067.4429495409131050,
3131393.0570504586212337 10087023.1966011244803667,
3131337.3033988750539720 10086994.7886967416852713,
3131275.5000000000000000 10086985.0000000000000000,
3131213.6966011249460280 10086994.7886967416852713,
3131157.9429495413787663 10087023.1966011244803667,
3131134.1416398049332201 10087046.9979108609259129,
3131135.2500000000000000 10087040.0000000000000000,
3131125.4613032592460513 10086978.1966011244803667,
3131097.0533988750539720 10086922.4429495409131050,
3131052.8070504586212337 10086878.1966011244803667,
3130997.0533988750539720 10086849.7886967416852713,
3130935.2500000000000000 10086840.0000000000000000,
3130873.4466011249460280 10086849.7886967416852713,
3130817.6929495413787663 10086878.1966011244803667,
3130773.4466011249460280 10086922.4429495409131050,
3130745.0386967407539487 10086978.1966011244803667,
3130735.2500000000000000 10087040.0000000000000000,
3130745.0386967407539487 10087101.8033988755196333,
3130773.4466011249460280 10087157.5570504590868950,
3130817.6929495413787663 10087201.8033988755196333,
3130873.4466011249460280 10087230.2113032583147287,
3130935.2500000000000000 10087240.0000000000000000,
3130997.0533988750539720 10087230.2113032583147287,
3131052.8070504586212337 10087201.8033988755196333,
3131076.6083601950667799 10087178.0020891390740871)),
((3130400.8352307076565921 10088149.5493578072637320,
3130386.6966011249460280 10088151.7886967416852713,
3130330.9429495413787663 10088180.1966011244803667,
3130286.6966011249460280 10088224.4429495409131050,
3130258.2886967407539487 10088280.1966011244803667,
3130248.5000000000000000 10088342.0000000000000000,
3130258.2886967407539487 10088403.8033988755196333,
3130286.6966011249460280 10088459.5570504590868950,
3130330.9429495413787663 10088503.8033988755196333,
3130386.6966011249460280 10088532.2113032583147287,
3130448.5000000000000000 10088542.0000000000000000,
3130474.0869723674841225 10088537.9474217016249895,
3130508.9429495413787663 10088572.8033988755196333,
3130564.6966011249460280 10088601.2113032583147287,
3130626.5000000000000000 10088611.0000000000000000,
3130688.3033988750539720 10088601.2113032583147287,
3130696.4499690793454647 10088597.0604184139519930,
3130716.1929495413787663 10088616.8033988755196333,
3130771.9466011249460280 10088645.2113032583147287,
3130824.1586683597415686 10088653.4808823056519032,
3130821.1966011249460280 10088656.4429495409131050,
3130792.7886967407539487 10088712.1966011244803667,
3130783.0000000000000000 10088774.0000000000000000,
3130792.7886967407539487 10088835.8033988755196333,
3130821.1966011249460280 10088891.5570504590868950,
3130852.1692782142199576 10088922.5297275483608246,
3130855.5386967407539487 10088943.8033988755196333,
3130883.9466011249460280 10088999.5570504590868950,
3130897.2550821714103222 10089012.8655315060168505,
3130898.2524744179099798 10089019.1628183126449585,
3130856.3033988750539720 10088997.7886967416852713,
3130794.5000000000000000 10088988.0000000000000000,
3130732.6966011249460280 10088997.7886967416852713,
3130676.9429495413787663 10089026.1966011244803667,
3130632.6966011249460280 10089070.4429495409131050,
3130604.2886967407539487 10089126.1966011244803667,
3130594.5000000000000000 10089188.0000000000000000,
3130604.2886967407539487 10089249.8033988755196333,
3130632.6966011249460280 10089305.5570504590868950,
3130676.9429495413787663 10089349.8033988755196333,
3130732.6966011249460280 10089378.2113032583147287,
3130794.5000000000000000 10089388.0000000000000000,
3130808.3300088825635612 10089385.8095417823642492,
3130789.6966011249460280 10089404.4429495409131050,
3130776.8255976885557175 10089429.7037161011248827,
3130734.5000000000000000 10089423.0000000000000000,
3130672.6966011249460280 10089432.7886967416852713,
3130616.9429495413787663 10089461.1966011244803667,
3130572.6966011249460280 10089505.4429495409131050,
3130545.6752652889117599 10089558.4753071255981922,
3130543.6966011249460280 10089558.7886967416852713,
3130487.9429495413787663 10089587.1966011244803667,
3130443.6966011249460280 10089631.4429495409131050,
3130415.2886967407539487 10089687.1966011244803667,
3130405.5000000000000000 10089749.0000000000000000,
3130415.2886967407539487 10089810.8033988755196333,
3130443.6966011249460280 10089866.5570504590868950,
3130487.9429495413787663 10089910.8033988755196333,
3130543.6966011249460280 10089939.2113032583147287,
3130605.5000000000000000 10089949.0000000000000000,
3130667.3033988750539720 10089939.2113032583147287,
3130723.0570504586212337 10089910.8033988755196333,
3130767.3033988750539720 10089866.5570504590868950,
3130794.3247347110882401 10089813.5246928744018078,
3130796.3033988750539720 10089813.2113032583147287,
3130852.0570504586212337 10089784.8033988755196333,
3130864.0000000000000000 10089772.8604493346065283,
3130904.9429495413787663 10089813.8033988755196333,
3130960.6966011249460280 10089842.2113032583147287,
3131022.5000000000000000 10089852.0000000000000000,
3131084.3033988750539720 10089842.2113032583147287,
3131140.0570504586212337 10089813.8033988755196333,
3131184.3033988750539720 10089769.5570504590868950,
3131204.1219468093477190 10089730.6609600801020861,
3131216.1958529474213719 10089728.7486412134021521,
3131271.9495045309886336 10089700.3407368306070566,
3131316.1958529474213719 10089656.0943884141743183,
3131344.6037573316134512 10089600.3407368306070566,
3131354.3924540723673999 10089538.5373379550874233,
3131344.6037573316134512 10089476.7339390795677900,
3131316.1958529474213719 10089420.9802874960005283,
3131300.2429878064431250 10089405.0274223554879427,
3131297.6188491866923869 10089388.4592631701380014,
3131269.2109448025003076 10089332.7056115865707397,
3131224.9645963860675693 10089288.4592631701380014,
3131205.1332889441400766 10089278.3547073323279619,
3131212.0000000000000000 10089235.0000000000000000,
3131202.2113032592460513 10089173.1966011244803667,
3131193.6596572166308761 10089156.4130507614463568,
3131210.5570504586212337 10089147.8033988755196333,
3131254.8033988750539720 10089103.5570504590868950,
3131283.2113032592460513 10089047.8033988755196333,
3131293.0000000000000000 10088986.0000000000000000,
3131283.2113032592460513 10088924.1966011244803667,
3131254.8033988750539720 10088868.4429495409131050,
3131241.4949178285896778 10088855.1344684939831495,
3131239.2028289986774325 10088840.6627891734242439,
3131242.0533988750539720 10088840.2113032583147287,
3131297.8070504586212337 10088811.8033988755196333,
3131342.0533988750539720 10088767.5570504590868950,
3131370.4613032592460513 10088711.8033988755196333,
3131380.2500000000000000 10088650.0000000000000000,
3131370.4613032592460513 10088588.1966011244803667,
3131342.0533988750539720 10088532.4429495409131050,
3131303.3488912461325526 10088493.7384419124573469,
3131303.4386364710517228 10088493.1718128640204668,
3131322.0533988750539720 10088474.5570504590868950,
3131350.4613032592460513 10088418.8033988755196333,
3131360.2500000000000000 10088357.0000000000000000,
3131350.4613032592460513 10088295.1966011244803667,
3131322.0533988750539720 10088239.4429495409131050,
3131288.8019763021729887 10088206.1915269680321217,
3131292.0000000000000000 10088186.0000000000000000,
3131282.2113032592460513 10088124.1966011244803667,
3131253.8033988750539720 10088068.4429495409131050,
3131209.5570504586212337 10088024.1966011244803667,
3131153.8033988750539720 10087995.7886967416852713,
3131092.0000000000000000 10087986.0000000000000000,
3131030.1966011249460280 10087995.7886967416852713,
3130974.4429495413787663 10088024.1966011244803667,
3130930.1966011249460280 10088068.4429495409131050,
3130901.7886967407539487 10088124.1966011244803667,
3130892.5760556622408330 10088182.3629276901483536,
3130870.9466011249460280 10088185.7886967416852713,
3130815.1929495413787663 10088214.1966011244803667,
3130770.9466011249460280 10088258.4429495409131050,
3130766.2288644574582577 10088267.7020290866494179,
3130764.5532818441279233 10088268.5557810701429844,
3130765.7500000000000000 10088261.0000000000000000,
3130755.9613032592460513 10088199.1966011244803667,
3130727.5533988750539720 10088143.4429495409131050,
3130683.3070504586212337 10088099.1966011244803667,
3130627.5533988750539720 10088070.7886967416852713,
3130565.7500000000000000 10088061.0000000000000000,
3130503.9466011249460280 10088070.7886967416852713,
3130448.1929495413787663 10088099.1966011244803667,
3130403.9466011249460280 10088143.4429495409131050,
3130400.8352307076565921 10088149.5493578072637320)),
((3129224.0991266998462379 10100137.3611749876290560,
3129190.2500000000000000 10100132.0000000000000000,
3129128.4466011249460280 10100141.7886967416852713,
3129072.6929495413787663 10100170.1966011244803667,
3129028.4466011249460280 10100214.4429495409131050,
3129000.0386967407539487 10100270.1966011244803667,
3128990.2500000000000000 10100332.0000000000000000,
3129000.0386967407539487 10100393.8033988755196333,
3129028.4466011249460280 10100449.5570504590868950,
3129072.6929495413787663 10100493.8033988755196333,
3129128.4466011249460280 10100522.2113032583147287,
3129190.2500000000000000 10100532.0000000000000000,
3129252.0533988750539720 10100522.2113032583147287,
3129294.4078813251107931 10100500.6306165512651205,
3129298.4466011249460280 10100508.5570504590868950,
3129342.6929495413787663 10100552.8033988755196333,
3129398.4466011249460280 10100581.2113032583147287,
3129460.2500000000000000 10100591.0000000000000000,
3129474.0391611629165709 10100588.8160114269703627,
3129478.7886967407539487 10100618.8033988755196333,
3129507.1966011249460280 10100674.5570504590868950,
3129551.4429495413787663 10100718.8033988755196333,
3129607.1966011249460280 10100747.2113032583147287,
3129669.0000000000000000 10100757.0000000000000000,
3129706.3566433405503631 10100751.0832889508455992,
3129728.1966011249460280 10100762.2113032583147287,
3129790.0000000000000000 10100772.0000000000000000,
3129851.8033988750539720 10100762.2113032583147287,
3129907.5570504586212337 10100733.8033988755196333,
3129912.2500000000000000 10100729.1104493346065283,
3129929.2006530030630529 10100746.0611023381352425,
3129910.7886967407539487 10100782.1966011244803667,
3129901.0000000000000000 10100844.0000000000000000,
3129910.7886967407539487 10100905.8033988755196333,
3129939.1966011249460280 10100961.5570504590868950,
3129983.4429495413787663 10101005.8033988755196333,
3130039.1966011249460280 10101034.2113032583147287,
3130101.0000000000000000 10101044.0000000000000000,
3130162.8033988750539720 10101034.2113032583147287,
3130218.5570504586212337 10101005.8033988755196333,
3130262.8033988750539720 10100961.5570504590868950,
3130291.2113032592460513 10100905.8033988755196333,
3130301.0000000000000000 10100844.0000000000000000,
3130291.2113032592460513 10100782.1966011244803667,
3130262.8033988750539720 10100726.4429495409131050,
3130230.2993469969369471 10100693.9388976618647575,
3130248.7113032592460513 10100657.8033988755196333,
3130258.5000000000000000 10100596.0000000000000000,
3130248.7113032592460513 10100534.1966011244803667,
3130220.3033988750539720 10100478.4429495409131050,
3130176.0570504586212337 10100434.1966011244803667,
3130149.4693299010396004 10100420.6494808569550514,
3130149.2411786951124668 10100419.2089908346533775,
3130164.9466011249460280 10100427.2113032583147287,
3130226.7500000000000000 10100437.0000000000000000,
3130288.5533988750539720 10100427.2113032583147287,
3130331.3089149850420654 10100405.4262796957045794,
3130366.5000000000000000 10100411.0000000000000000,
3130428.3033988750539720 10100401.2113032583147287,
3130457.9743705498985946 10100386.0931880790740252,
3130463.7886967407539487 10100422.8033988755196333,
3130492.1966011249460280 10100478.5570504590868950,
3130536.4429495413787663 10100522.8033988755196333,
3130592.1966011249460280 10100551.2113032583147287,
3130654.0000000000000000 10100561.0000000000000000,
3130715.8033988750539720 10100551.2113032583147287,
3130771.5570504586212337 10100522.8033988755196333,
3130815.8033988750539720 10100478.5570504590868950,
3130844.2113032592460513 10100422.8033988755196333,
3130854.0000000000000000 10100361.0000000000000000,
3130844.2113032592460513 10100299.1966011244803667,
3130815.8033988750539720 10100243.4429495409131050,
3130771.5570504586212337 10100199.1966011244803667,
3130715.8033988750539720 10100170.7886967416852713,
3130654.0000000000000000 10100161.0000000000000000,
3130592.1966011249460280 10100170.7886967416852713,
3130562.5256294501014054 10100185.9068119209259748,
3130556.7113032592460513 10100149.1966011244803667,
3130537.2023415034636855 10100110.9081078302115202,
3130558.5533988750539720 10100089.5570504590868950,
3130586.9613032592460513 10100033.8033988755196333,
3130596.7500000000000000 10099972.0000000000000000,
3130586.9613032592460513 10099910.1966011244803667,
3130565.0622474802657962 10099867.2172841913998127,
3130568.3024348914623260 10099860.8580583389848471,
3130584.6966011249460280 10099869.2113032583147287,
3130646.5000000000000000 10099879.0000000000000000,
3130708.3033988750539720 10099869.2113032583147287,
3130764.0570504586212337 10099840.8033988755196333,
3130785.3334659659303725 10099819.5269833691418171,
3130795.0386967407539487 10099880.8033988755196333,
3130823.4466011249460280 10099936.5570504590868950,
3130867.6929495413787663 10099980.8033988755196333,
3130923.4466011249460280 10100009.2113032583147287,
3130985.2500000000000000 10100019.0000000000000000,
3131047.0533988750539720 10100009.2113032583147287,
3131102.8070504586212337 10099980.8033988755196333,
3131147.0533988750539720 10099936.5570504590868950,
3131175.4613032592460513 10099880.8033988755196333,
3131185.2500000000000000 10099819.0000000000000000,
3131175.4613032592460513 10099757.1966011244803667,
3131147.0533988750539720 10099701.4429495409131050,
3131143.3711115792393684 10099697.7606622446328402,
3131162.7113032592460513 10099659.8033988755196333,
3131172.5000000000000000 10099598.0000000000000000,
3131162.7113032592460513 10099536.1966011244803667,
3131136.2827683896757662 10099484.3276809453964233,
3131162.0533988750539720 10099458.5570504590868950,
3131190.4613032592460513 10099402.8033988755196333,
3131200.2500000000000000 10099341.0000000000000000,
3131190.4613032592460513 10099279.1966011244803667,
3131162.0533988750539720 10099223.4429495409131050,
3131150.3604493346065283 10099211.7500000000000000,
3131166.5533988750539720 10099195.5570504590868950,
3131194.9613032592460513 10099139.8033988755196333,
3131204.7500000000000000 10099078.0000000000000000,
3131194.9613032592460513 10099016.1966011244803667,
3131166.5533988750539720 10098960.4429495409131050,
3131166.1250056852586567 10098960.0145563501864672,
3131163.4613032592460513 10098943.1966011244803667,
3131135.0533988750539720 10098887.4429495409131050,
3131090.8070504586212337 10098843.1966011244803667,
3131035.0533988750539720 10098814.7886967416852713,
3130973.2500000000000000 10098805.0000000000000000,
3130911.4466011249460280 10098814.7886967416852713,
3130855.6929495413787663 10098843.1966011244803667,
3130811.4466011249460280 10098887.4429495409131050,
3130786.4712038175202906 10098936.4599266760051250,
3130777.3033988750539720 10098931.7886967416852713,
3130715.5000000000000000 10098922.0000000000000000,
3130653.6966011249460280 10098931.7886967416852713,
3130597.9429495413787663 10098960.1966011244803667,
3130553.6966011249460280 10099004.4429495409131050,
3130525.2886967407539487 10099060.1966011244803667,
3130516.2329274616204202 10099117.3724781274795532,
3130503.0570504586212337 10099104.1966011244803667,
3130447.3033988750539720 10099075.7886967416852713,
3130385.5000000000000000 10099066.0000000000000000,
3130323.6966011249460280 10099075.7886967416852713,
3130267.9429495413787663 10099104.1966011244803667,
3130223.6966011249460280 10099148.4429495409131050,
3130195.2886967407539487 10099204.1966011244803667,
3130185.5000000000000000 10099266.0000000000000000,
3130195.2886967407539487 10099327.8033988755196333,
3130197.4987257127650082 10099332.1408249530941248,
3130160.1966011249460280 10099369.4429495409131050,
3130131.7886967407539487 10099425.1966011244803667,
3130122.0000000000000000 10099487.0000000000000000,
3130131.7886967407539487 10099548.8033988755196333,
3130160.1966011249460280 10099604.5570504590868950,
3130204.4429495413787663 10099648.8033988755196333,
3130227.0715214009396732 10099660.3332321234047413,
3130208.2886967407539487 10099697.1966011244803667,
3130198.5000000000000000 10099759.0000000000000000,
3130199.9439552761614323 10099768.1167748123407364,
3130170.4466011249460280 10099772.7886967416852713,
3130164.3570455596782267 10099775.8914802782237530,
3130156.9613032592460513 10099729.1966011244803667,
3130128.5533988750539720 10099673.4429495409131050,
3130084.3070504586212337 10099629.1966011244803667,
3130028.5533988750539720 10099600.7886967416852713,
3129966.7500000000000000 10099591.0000000000000000,
3129904.9466011249460280 10099600.7886967416852713,
3129849.1929495413787663 10099629.1966011244803667,
3129804.9466011249460280 10099673.4429495409131050,
3129776.5386967407539487 10099729.1966011244803667,
3129766.7500000000000000 10099791.0000000000000000,
3129776.5386967407539487 10099852.8033988755196333,
3129804.9466011249460280 10099908.5570504590868950,
3129849.1929495413787663 10099952.8033988755196333,
3129875.2893643202260137 10099966.1001863460987806,
3129838.9466011249460280 10100002.4429495409131050,
3129810.5386967407539487 10100058.1966011244803667,
3129800.7500000000000000 10100120.0000000000000000,
3129810.5386967407539487 10100181.8033988755196333,
3129827.2618995173834264 10100214.6245323307812214,
3129791.7500000000000000 10100209.0000000000000000,
3129729.9466011249460280 10100218.7886967416852713,
3129674.1929495413787663 10100247.1966011244803667,
3129630.7933942950330675 10100290.5961563698947430,
3129622.0533988750539720 10100273.4429495409131050,
3129589.4799344907514751 10100240.8694851566106081,
3129613.4613032592460513 10100193.8033988755196333,
3129623.2500000000000000 10100132.0000000000000000,
3129613.4613032592460513 10100070.1966011244803667,
3129585.0533988750539720 10100014.4429495409131050,
3129540.8070504586212337 10099970.1966011244803667,
3129485.0533988750539720 10099941.7886967416852713,
3129423.2500000000000000 10099932.0000000000000000,
3129361.4466011249460280 10099941.7886967416852713,
3129305.6929495413787663 10099970.1966011244803667,
3129261.4466011249460280 10100014.4429495409131050,
3129233.0386967407539487 10100070.1966011244803667,
3129223.2500000000000000 10100132.0000000000000000,
3129224.0991266998462379 10100137.3611749876290560)),
((3131102.0000000000000000 10093941.0000000000000000,
3131092.2113032592460513 10093879.1966011244803667,
3131063.8033988750539720 10093823.4429495409131050,
3131019.5570504586212337 10093779.1966011244803667,
3130963.8033988750539720 10093750.7886967416852713,
3130902.0000000000000000 10093741.0000000000000000,
3130840.1966011249460280 10093750.7886967416852713,
3130784.4429495413787663 10093779.1966011244803667,
3130740.1966011249460280 10093823.4429495409131050,
3130711.7886967407539487 10093879.1966011244803667,
3130702.0000000000000000 10093941.0000000000000000,
3130711.7886967407539487 10094002.8033988755196333,
3130740.1966011249460280 10094058.5570504590868950,
3130784.4429495413787663 10094102.8033988755196333,
3130840.1966011249460280 10094131.2113032583147287,
3130902.0000000000000000 10094141.0000000000000000,
3130963.8033988750539720 10094131.2113032583147287,
3131019.5570504586212337 10094102.8033988755196333,
3131063.8033988750539720 10094058.5570504590868950,
3131092.2113032592460513 10094002.8033988755196333,
3131102.0000000000000000 10093941.0000000000000000)),
((3130313.7642070837318897 10092392.1233179029077291,
3130270.4429495413787663 10092414.1966011244803667,
3130226.1966011249460280 10092458.4429495409131050,
3130197.7886967407539487 10092514.1966011244803667,
3130188.0000000000000000 10092576.0000000000000000,
3130197.7886967407539487 10092637.8033988755196333,
3130226.1966011249460280 10092693.5570504590868950,
3130270.4429495413787663 10092737.8033988755196333,
3130326.1966011249460280 10092766.2113032583147287,
3130388.0000000000000000 10092776.0000000000000000,
3130449.8033988750539720 10092766.2113032583147287,
3130505.5570504586212337 10092737.8033988755196333,
3130549.8033988750539720 10092693.5570504590868950,
3130554.7357929162681103 10092683.8766820970922709,
3130598.0570504586212337 10092661.8033988755196333,
3130642.3033988750539720 10092617.5570504590868950,
3130652.1314125317148864 10092598.2684876080602407,
3130656.7500000000000000 10092599.0000000000000000,
3130718.5533988750539720 10092589.2113032583147287,
3130757.3555493559688330 10092569.4406200945377350,
3130758.8033988750539720 10092569.2113032583147287,
3130814.5570504586212337 10092540.8033988755196333,
3130817.5915365885011852 10092537.7689127456396818,
3130840.0533988750539720 10092534.2113032583147287,
3130895.8070504586212337 10092505.8033988755196333,
3130904.7438448155298829 10092496.8666045181453228,
3130934.3070504586212337 10092481.8033988755196333,
3130978.5533988750539720 10092437.5570504590868950,
3131006.9613032592460513 10092381.8033988755196333,
3131016.7500000000000000 10092320.0000000000000000,
3131006.9613032592460513 10092258.1966011244803667,
3130978.5533988750539720 10092202.4429495409131050,
3130934.3070504586212337 10092158.1966011244803667,
3130878.5533988750539720 10092129.7886967416852713,
3130816.7500000000000000 10092120.0000000000000000,
3130754.9466011249460280 10092129.7886967416852713,
3130699.1929495413787663 10092158.1966011244803667,
3130690.2561551844701171 10092167.1333954818546772,
3130660.6929495413787663 10092182.1966011244803667,
3130657.6584634114988148 10092185.2310872543603182,
3130635.1966011249460280 10092188.7886967416852713,
3130596.3944506440311670 10092208.5593799054622650,
3130594.9466011249460280 10092208.7886967416852713,
3130539.1929495413787663 10092237.1966011244803667,
3130494.9466011249460280 10092281.4429495409131050,
3130485.1185874682851136 10092300.7315123919397593,
3130480.5000000000000000 10092300.0000000000000000,
3130418.6966011249460280 10092309.7886967416852713,
3130362.9429495413787663 10092338.1966011244803667,
3130318.6966011249460280 10092382.4429495409131050,
3130313.7642070837318897 10092392.1233179029077291)),
((3130961.5852671060711145 10079102.8850269354879856,
3130951.7965703653171659 10079041.0816280599683523,
3130923.3886659811250865 10078985.3279764764010906,
3130879.1423175646923482 10078941.0816280599683523,
3130823.3886659811250865 10078912.6737236771732569,
3130761.5852671060711145 10078902.8850269354879856,
3130699.7818682310171425 10078912.6737236771732569,
3130644.0282166474498808 10078941.0816280599683523,
3130599.7818682310171425 10078985.3279764764010906,
3130571.3739638468250632 10079041.0816280599683523,
3130561.5852671060711145 10079102.8850269354879856,
3130571.3739638468250632 10079164.6884258110076189,
3130599.7818682310171425 10079220.4420773945748806,
3130644.0282166474498808 10079264.6884258110076189,
3130699.7818682310171425 10079293.0963301938027143,
3130761.5852671060711145 10079302.8850269354879856,
3130823.3886659811250865 10079293.0963301938027143,
3130879.1423175646923482 10079264.6884258110076189,
3130923.3886659811250865 10079220.4420773945748806,
3130951.7965703653171659 10079164.6884258110076189,
3130961.5852671060711145 10079102.8850269354879856)),
((3129684.2828150158748031 10093576.1067356504499912,
3129666.4429495413787663 10093585.1966011244803667,
3129622.1966011249460280 10093629.4429495409131050,
3129593.7886967407539487 10093685.1966011244803667,
3129584.0000000000000000 10093747.0000000000000000,
3129593.7886967407539487 10093808.8033988755196333,
3129622.1966011249460280 10093864.5570504590868950,
3129666.4429495413787663 10093908.8033988755196333,
3129722.1966011249460280 10093937.2113032583147287,
3129784.0000000000000000 10093947.0000000000000000,
3129845.8033988750539720 10093937.2113032583147287,
3129901.5570504586212337 10093908.8033988755196333,
3129912.2874540355987847 10093898.0729952976107597,
3129965.8070504586212337 10093870.8033988755196333,
3130010.0533988750539720 10093826.5570504590868950,
3130038.4613032592460513 10093770.8033988755196333,
3130038.5524002788588405 10093770.2282349299639463,
3130081.6966011249460280 10093792.2113032583147287,
3130143.5000000000000000 10093802.0000000000000000,
3130173.8349643195979297 10093797.1954136528074741,
3130194.4429495413787663 10093817.8033988755196333,
3130250.1966011249460280 10093846.2113032583147287,
3130312.0000000000000000 10093856.0000000000000000,
3130373.8033988750539720 10093846.2113032583147287,
3130429.5570504586212337 10093817.8033988755196333,
3130473.8033988750539720 10093773.5570504590868950,
3130502.2113032592460513 10093717.8033988755196333,
3130512.0000000000000000 10093656.0000000000000000,
3130502.2113032592460513 10093594.1966011244803667,
3130487.8020730633288622 10093565.9168945662677288,
3130482.4613032592460513 10093532.1966011244803667,
3130454.0533988750539720 10093476.4429495409131050,
3130409.8070504586212337 10093432.1966011244803667,
3130354.0533988750539720 10093403.7886967416852713,
3130292.2500000000000000 10093394.0000000000000000,
3130283.2696569599211216 10093395.4223466068506241,
3130281.2586681870743632 10093382.7254631966352463,
3130252.8507638028822839 10093326.9718116130679846,
3130208.6044153864495456 10093282.7254631966352463,
3130152.8507638028822839 10093254.3175588138401508,
3130091.0473649278283119 10093244.5288620721548796,
3130044.9417270566336811 10093251.8312777224928141,
3130040.3070504586212337 10093247.1966011244803667,
3129984.5533988750539720 10093218.7886967416852713,
3129950.0195365841500461 10093213.3190702907741070,
3129945.0533988750539720 10093210.7886967416852713,
3129883.2500000000000000 10093201.0000000000000000,
3129850.5948085612617433 10093206.1720742192119360,
3129873.7113032592460513 10093160.8033988755196333,
3129883.5000000000000000 10093099.0000000000000000,
3129878.4789042291231453 10093067.2980489693582058,
3129883.1966011249460280 10093076.5570504590868950,
3129927.4429495413787663 10093120.8033988755196333,
3129983.1966011249460280 10093149.2113032583147287,
3130045.0000000000000000 10093159.0000000000000000,
3130106.8033988750539720 10093149.2113032583147287,
3130162.5570504586212337 10093120.8033988755196333,
3130206.8033988750539720 10093076.5570504590868950,
3130208.2052322500385344 10093073.8057975508272648,
3130209.7886967407539487 10093083.8033988755196333,
3130238.1966011249460280 10093139.5570504590868950,
3130282.4429495413787663 10093183.8033988755196333,
3130338.1966011249460280 10093212.2113032583147287,
3130400.0000000000000000 10093222.0000000000000000,
3130461.8033988750539720 10093212.2113032583147287,
3130507.3664181958884001 10093188.9957853592932224,
3130510.8366529545746744 10093210.9059853255748749,
3130539.2445573387667537 10093266.6596369091421366,
3130583.4909057551994920 10093310.9059853255748749,
3130639.2445573387667537 10093339.3138897083699703,
3130701.0479562138207257 10093349.1025864500552416,
3130762.8513550888746977 10093339.3138897083699703,
3130818.6050066724419594 10093310.9059853255748749,
3130862.8513550888746977 10093266.6596369091421366,
3130891.2592594730667770 10093210.9059853255748749,
3130901.0479562138207257 10093149.1025864500552416,
3130891.2592594730667770 10093087.2991875745356083,
3130870.7712481059134007 10093047.0892012286931276,
3130912.3033988750539720 10093005.5570504590868950,
3130940.7113032592460513 10092949.8033988755196333,
3130950.5000000000000000 10092888.0000000000000000,
3130940.7113032592460513 10092826.1966011244803667,
3130912.3033988750539720 10092770.4429495409131050,
3130868.0570504586212337 10092726.1966011244803667,
3130812.3033988750539720 10092697.7886967416852713,
3130750.5000000000000000 10092688.0000000000000000,
3130688.6966011249460280 10092697.7886967416852713,
3130632.9429495413787663 10092726.1966011244803667,
3130588.6966011249460280 10092770.4429495409131050,
3130560.2886967407539487 10092826.1966011244803667,
3130550.5000000000000000 10092888.0000000000000000,
3130551.4672169750556350 10092894.1067676413804293,
3130517.5570504586212337 10092860.1966011244803667,
3130461.8033988750539720 10092831.7886967416852713,
3130400.0000000000000000 10092822.0000000000000000,
3130338.1966011249460280 10092831.7886967416852713,
3130282.4429495413787663 10092860.1966011244803667,
3130238.1966011249460280 10092904.4429495409131050,
3130236.7947677499614656 10092907.1942024491727352,
3130235.2113032592460513 10092897.1966011244803667,
3130206.8033988750539720 10092841.4429495409131050,
3130162.5570504586212337 10092797.1966011244803667,
3130106.8033988750539720 10092768.7886967416852713,
3130045.0000000000000000 10092759.0000000000000000,
3130026.5368399820290506 10092761.9242772664874792,
3130027.0000000000000000 10092759.0000000000000000,
3130017.2113032592460513 10092697.1966011244803667,
3129988.8033988750539720 10092641.4429495409131050,
3129944.5570504586212337 10092597.1966011244803667,
3129888.8033988750539720 10092568.7886967416852713,
3129827.0000000000000000 10092559.0000000000000000,
3129765.1966011249460280 10092568.7886967416852713,
3129709.4429495413787663 10092597.1966011244803667,
3129665.1966011249460280 10092641.4429495409131050,
3129636.7886967407539487 10092697.1966011244803667,
3129627.0000000000000000 10092759.0000000000000000,
3129636.7886967407539487 10092820.8033988755196333,
3129665.1966011249460280 10092876.5570504590868950,
3129688.4185766805894673 10092899.7790260147303343,
3129683.5000000000000000 10092899.0000000000000000,
3129621.6966011249460280 10092908.7886967416852713,
3129565.9429495413787663 10092937.1966011244803667,
3129521.6966011249460280 10092981.4429495409131050,
3129493.2886967407539487 10093037.1966011244803667,
3129483.5000000000000000 10093099.0000000000000000,
3129493.2886967407539487 10093160.8033988755196333,
3129521.6966011249460280 10093216.5570504590868950,
3129565.9429495413787663 10093260.8033988755196333,
3129621.6966011249460280 10093289.2113032583147287,
3129683.5000000000000000 10093299.0000000000000000,
3129716.1551914387382567 10093293.8279257807880640,
3129693.0386967407539487 10093339.1966011244803667,
3129683.2500000000000000 10093401.0000000000000000,
3129693.0386967407539487 10093462.8033988755196333,
3129721.4466011249460280 10093518.5570504590868950,
3129743.1568495365791023 10093540.2672988697886467,
3129696.1929495413787663 10093564.1966011244803667,
3129684.2828150158748031 10093576.1067356504499912),
(3129822.0814233194105327 10092958.2209739852696657,
3129827.0000000000000000 10092959.0000000000000000,
3129845.4631600179709494 10092956.0757227335125208,
3129845.0000000000000000 10092959.0000000000000000,
3129850.0210957708768547 10092990.7019510306417942,
3129845.3033988750539720 10092981.4429495409131050,
3129822.0814233194105327 10092958.2209739852696657)),
((3129799.1884902273304760 10086391.8373522162437439,
3129761.8033988750539720 10086372.7886967416852713,
3129700.0000000000000000 10086363.0000000000000000,
3129638.1966011249460280 10086372.7886967416852713,
3129582.4429495413787663 10086401.1966011244803667,
3129538.1966011249460280 10086445.4429495409131050,
3129509.7886967407539487 10086501.1966011244803667,
3129500.0000000000000000 10086563.0000000000000000,
3129509.7886967407539487 10086624.8033988755196333,
3129538.1966011249460280 10086680.5570504590868950,
3129582.4429495413787663 10086724.8033988755196333,
3129638.1966011249460280 10086753.2113032583147287,
3129700.0000000000000000 10086763.0000000000000000,
3129761.8033988750539720 10086753.2113032583147287,
3129817.5570504586212337 10086724.8033988755196333,
3129861.8033988750539720 10086680.5570504590868950,
3129865.0615097726695240 10086674.1626477837562561,
3129902.4466011249460280 10086693.2113032583147287,
3129915.4249139511957765 10086695.2668660711497068,
3129922.1966011249460280 10086708.5570504590868950,
3129966.4429495413787663 10086752.8033988755196333,
3130022.1966011249460280 10086781.2113032583147287,
3130084.0000000000000000 10086791.0000000000000000,
3130145.8033988750539720 10086781.2113032583147287,
3130201.5570504586212337 10086752.8033988755196333,
3130245.8033988750539720 10086708.5570504590868950,
3130274.2113032592460513 10086652.8033988755196333,
3130281.8281431971117854 10086604.7125641796737909,
3130305.6966011249460280 10086651.5570504590868950,
3130349.9429495413787663 10086695.8033988755196333,
3130405.6966011249460280 10086724.2113032583147287,
3130447.4047161578200758 10086730.8172197155654430,
3130445.0000000000000000 10086746.0000000000000000,
3130454.7886967407539487 10086807.8033988755196333,
3130483.1966011249460280 10086863.5570504590868950,
3130527.4429495413787663 10086907.8033988755196333,
3130583.1966011249460280 10086936.2113032583147287,
3130645.0000000000000000 10086946.0000000000000000,
3130706.8033988750539720 10086936.2113032583147287,
3130762.5570504586212337 10086907.8033988755196333,
3130806.8033988750539720 10086863.5570504590868950,
3130835.2113032592460513 10086807.8033988755196333,
3130845.0000000000000000 10086746.0000000000000000,
3130836.1960981264710426 10086690.4143512081354856,
3130837.0533988750539720 10086689.5570504590868950,
3130865.4613032592460513 10086633.8033988755196333,
3130875.2500000000000000 10086572.0000000000000000,
3130874.5814579180441797 10086567.7789914160966873,
3130888.8033988750539720 10086553.5570504590868950,
3130917.2113032592460513 10086497.8033988755196333,
3130927.0000000000000000 10086436.0000000000000000,
3130917.2113032592460513 10086374.1966011244803667,
3130888.8033988750539720 10086318.4429495409131050,
3130844.5570504586212337 10086274.1966011244803667,
3130788.8033988750539720 10086245.7886967416852713,
3130727.0000000000000000 10086236.0000000000000000,
3130665.1966011249460280 10086245.7886967416852713,
3130609.4429495413787663 10086274.1966011244803667,
3130603.5846569128334522 10086280.0548937525600195,
3130573.6966011249460280 10086284.7886967416852713,
3130517.9429495413787663 10086313.1966011244803667,
3130493.0869723674841225 10086338.0525782983750105,
3130467.5000000000000000 10086334.0000000000000000,
3130405.6966011249460280 10086343.7886967416852713,
3130349.9429495413787663 10086372.1966011244803667,
3130305.6966011249460280 10086416.4429495409131050,
3130277.2886967407539487 10086472.1966011244803667,
3130269.6718568028882146 10086520.2874358203262091,
3130245.8033988750539720 10086473.4429495409131050,
3130201.5570504586212337 10086429.1966011244803667,
3130145.8033988750539720 10086400.7886967416852713,
3130132.8250860488042235 10086398.7331339288502932,
3130126.0533988750539720 10086385.4429495409131050,
3130081.8070504586212337 10086341.1966011244803667,
3130026.0533988750539720 10086312.7886967416852713,
3129964.2500000000000000 10086303.0000000000000000,
3129902.4466011249460280 10086312.7886967416852713,
3129846.6929495413787663 10086341.1966011244803667,
3129802.4466011249460280 10086385.4429495409131050,
3129799.1884902273304760 10086391.8373522162437439)),
((3130887.0000000000000000 10091780.0000000000000000,
3130877.2113032592460513 10091718.1966011244803667,
3130848.8033988750539720 10091662.4429495409131050,
3130804.5570504586212337 10091618.1966011244803667,
3130748.8033988750539720 10091589.7886967416852713,
3130687.0000000000000000 10091580.0000000000000000,
3130625.1966011249460280 10091589.7886967416852713,
3130569.4429495413787663 10091618.1966011244803667,
3130525.1966011249460280 10091662.4429495409131050,
3130496.7886967407539487 10091718.1966011244803667,
3130487.0000000000000000 10091780.0000000000000000,
3130496.7886967407539487 10091841.8033988755196333,
3130525.1966011249460280 10091897.5570504590868950,
3130569.4429495413787663 10091941.8033988755196333,
3130625.1966011249460280 10091970.2113032583147287,
3130687.0000000000000000 10091980.0000000000000000,
3130748.8033988750539720 10091970.2113032583147287,
3130804.5570504586212337 10091941.8033988755196333,
3130848.8033988750539720 10091897.5570504590868950,
3130877.2113032592460513 10091841.8033988755196333,
3130887.0000000000000000 10091780.0000000000000000)),
((3129627.9146926272660494 10098250.2248580381274223,
3129626.6966011249460280 10098251.4429495409131050,
3129598.2886967407539487 10098307.1966011244803667,
3129588.5000000000000000 10098369.0000000000000000,
3129598.2886967407539487 10098430.8033988755196333,
3129626.6966011249460280 10098486.5570504590868950,
3129670.9429495413787663 10098530.8033988755196333,
3129726.6966011249460280 10098559.2113032583147287,
3129788.5000000000000000 10098569.0000000000000000,
3129810.4193903957493603 10098565.5283096209168434,
3129801.0000000000000000 10098625.0000000000000000,
3129810.7886967407539487 10098686.8033988755196333,
3129839.1966011249460280 10098742.5570504590868950,
3129883.4429495413787663 10098786.8033988755196333,
3129919.8051041448488832 10098805.3308420442044735,
3129934.6966011249460280 10098834.5570504590868950,
3129978.9429495413787663 10098878.8033988755196333,
3130034.6966011249460280 10098907.2113032583147287,
3130096.5000000000000000 10098917.0000000000000000,
3130158.3033988750539720 10098907.2113032583147287,
3130214.0570504586212337 10098878.8033988755196333,
3130258.3033988750539720 10098834.5570504590868950,
3130266.1088675879873335 10098819.2379555627703667,
3130311.1966011249460280 10098842.2113032583147287,
3130373.0000000000000000 10098852.0000000000000000,
3130434.8033988750539720 10098842.2113032583147287,
3130490.5570504586212337 10098813.8033988755196333,
3130534.8033988750539720 10098769.5570504590868950,
3130563.2113032592460513 10098713.8033988755196333,
3130573.0000000000000000 10098652.0000000000000000,
3130563.2113032592460513 10098590.1966011244803667,
3130544.9027392505668104 10098554.2640210613608360,
3130562.4613032592460513 10098519.8033988755196333,
3130567.3577539417892694 10098488.8884259629994631,
3130580.5993604143150151 10098482.1414904724806547,
3130624.8457088307477534 10098437.8951420560479164,
3130653.2536132149398327 10098382.1414904724806547,
3130663.0423099556937814 10098320.3380915969610214,
3130653.2536132149398327 10098258.5346927214413881,
3130624.8457088307477534 10098202.7810411378741264,
3130580.5993604143150151 10098158.5346927214413881,
3130524.8457088307477534 10098130.1267883386462927,
3130463.0423099556937814 10098120.3380915969610214,
3130401.2389110806398094 10098130.1267883386462927,
3130390.1874418696388602 10098135.7577931564301252,
3130393.0000000000000000 10098118.0000000000000000,
3130383.2113032592460513 10098056.1966011244803667,
3130354.8033988750539720 10098000.4429495409131050,
3130344.4854493341408670 10097990.1250000000000000,
3130369.0533988750539720 10097965.5570504590868950,
3130397.4613032592460513 10097909.8033988755196333,
3130407.2500000000000000 10097848.0000000000000000,
3130398.3777337581850588 10097791.9827155750244856,
3130424.8033988750539720 10097765.5570504590868950,
3130453.2113032592460513 10097709.8033988755196333,
3130463.0000000000000000 10097648.0000000000000000,
3130453.2113032592460513 10097586.1966011244803667,
3130424.8033988750539720 10097530.4429495409131050,
3130380.5570504586212337 10097486.1966011244803667,
3130324.8033988750539720 10097457.7886967416852713,
3130263.0000000000000000 10097448.0000000000000000,
3130201.1966011249460280 10097457.7886967416852713,
3130145.4429495413787663 10097486.1966011244803667,
3130101.1966011249460280 10097530.4429495409131050,
3130072.7886967407539487 10097586.1966011244803667,
3130069.4873263002373278 10097607.0406337436288595,
3130055.4429495413787663 10097614.1966011244803667,
3130011.1966011249460280 10097658.4429495409131050,
3129982.7886967407539487 10097714.1966011244803667,
3129973.0000000000000000 10097776.0000000000000000,
3129982.7886967407539487 10097837.8033988755196333,
3130000.7008544025011361 10097872.9579876791685820,
3129962.9429495413787663 10097892.1966011244803667,
3129918.6966011249460280 10097936.4429495409131050,
3129890.2886967407539487 10097992.1966011244803667,
3129887.4701451878063381 10098009.9922352619469166,
3129867.4429495413787663 10098020.1966011244803667,
3129831.0051907678134739 10098056.6343598980456591,
3129827.0000000000000000 10098056.0000000000000000,
3129765.1966011249460280 10098065.7886967416852713,
3129709.4429495413787663 10098094.1966011244803667,
3129665.1966011249460280 10098138.4429495409131050,
3129636.7886967407539487 10098194.1966011244803667,
3129627.9146926272660494 10098250.2248580381274223),
(3130240.3964035096578300 10098310.4931471552699804,
3130210.4466011249460280 10098340.4429495409131050,
3130206.7504836763255298 10098347.6969884745776653,
3130170.4429495413787663 10098366.1966011244803667,
3130160.7358562438748777 10098375.9036944210529327,
3130136.5533988750539720 10098328.4429495409131050,
3130127.2354493341408670 10098319.1250000000000000,
3130137.1985333925113082 10098309.1619159411638975,
3130193.0000000000000000 10098318.0000000000000000,
3130240.3964035096578300 10098310.4931471552699804)),
((3130658.1561590000055730 10082496.2404999993741512,
3130648.3674622592516243 10082434.4371011238545179,
3130619.9595578750595450 10082378.6834495402872562,
3130575.7132094586268067 10082334.4371011238545179,
3130519.9595578750595450 10082306.0291967410594225,
3130458.1561590000055730 10082296.2404999993741512,
3130396.3527601249516010 10082306.0291967410594225,
3130340.5991085413843393 10082334.4371011238545179,
3130296.3527601249516010 10082378.6834495402872562,
3130267.9448557407595217 10082434.4371011238545179,
3130258.1561590000055730 10082496.2404999993741512,
3130267.9448557407595217 10082558.0438988748937845,
3130296.3527601249516010 10082613.7975504584610462,
3130340.5991085413843393 10082658.0438988748937845,
3130396.3527601249516010 10082686.4518032576888800,
3130458.1561590000055730 10082696.2404999993741512,
3130519.9595578750595450 10082686.4518032576888800,
3130575.7132094586268067 10082658.0438988748937845,
3130619.9595578750595450 10082613.7975504584610462,
3130648.3674622592516243 10082558.0438988748937845,
3130658.1561590000055730 10082496.2404999993741512)),
((3130338.5000000000000000 10088914.0000000000000000,
3130328.7113032592460513 10088852.1966011244803667,
3130300.3033988750539720 10088796.4429495409131050,
3130256.0570504586212337 10088752.1966011244803667,
3130200.3033988750539720 10088723.7886967416852713,
3130138.5000000000000000 10088714.0000000000000000,
3130076.6966011249460280 10088723.7886967416852713,
3130020.9429495413787663 10088752.1966011244803667,
3129976.6966011249460280 10088796.4429495409131050,
3129948.2886967407539487 10088852.1966011244803667,
3129938.5000000000000000 10088914.0000000000000000,
3129948.2886967407539487 10088975.8033988755196333,
3129976.6966011249460280 10089031.5570504590868950,
3130020.9429495413787663 10089075.8033988755196333,
3130076.6966011249460280 10089104.2113032583147287,
3130138.5000000000000000 10089114.0000000000000000,
3130200.3033988750539720 10089104.2113032583147287,
3130256.0570504586212337 10089075.8033988755196333,
3130300.3033988750539720 10089031.5570504590868950,
3130328.7113032592460513 10088975.8033988755196333,
3130338.5000000000000000 10088914.0000000000000000)),
((3130296.9657731303013861 10087784.7674239557236433,
3130287.1770763895474374 10087722.9640250802040100,
3130258.7691720053553581 10087667.2103734966367483,
3130214.5228235889226198 10087622.9640250802040100,
3130158.7691720053553581 10087594.5561206974089146,
3130096.9657731303013861 10087584.7674239557236433,
3130035.1623742552474141 10087594.5561206974089146,
3129979.4087226716801524 10087622.9640250802040100,
3129935.1623742552474141 10087667.2103734966367483,
3129906.7544698710553348 10087722.9640250802040100,
3129896.9657731303013861 10087784.7674239557236433,
3129906.7544698710553348 10087846.5708228312432766,
3129935.1623742552474141 10087902.3244744148105383,
3129979.4087226716801524 10087946.5708228312432766,
3130035.1623742552474141 10087974.9787272140383720,
3130096.9657731303013861 10087984.7674239557236433,
3130158.7691720053553581 10087974.9787272140383720,
3130214.5228235889226198 10087946.5708228312432766,
3130258.7691720053553581 10087902.3244744148105383,
3130287.1770763895474374 10087846.5708228312432766,
3130296.9657731303013861 10087784.7674239557236433)),
((3130189.6287270002067089 10082107.2066200003027916,
3130179.8400302594527602 10082045.4032211247831583,
3130151.4321258752606809 10081989.6495695412158966,
3130107.1857774588279426 10081945.4032211247831583,
3130051.4321258752606809 10081916.9953167419880629,
3129989.6287270002067089 10081907.2066200003027916,
3129927.8253281251527369 10081916.9953167419880629,
3129872.0716765415854752 10081945.4032211247831583,
3129827.8253281251527369 10081989.6495695412158966,
3129799.4174237409606576 10082045.4032211247831583,
3129789.6287270002067089 10082107.2066200003027916,
3129799.4174237409606576 10082169.0100188758224249,
3129827.8253281251527369 10082224.7636704593896866,
3129872.0716765415854752 10082269.0100188758224249,
3129927.8253281251527369 10082297.4179232586175203,
3129989.6287270002067089 10082307.2066200003027916,
3130051.4321258752606809 10082297.4179232586175203,
3130107.1857774588279426 10082269.0100188758224249,
3130151.4321258752606809 10082224.7636704593896866,
3130179.8400302594527602 10082169.0100188758224249,
3130189.6287270002067089 10082107.2066200003027916)),
((3129363.7478430476039648 10089914.3582923822104931,
3129368.1929495413787663 10089918.8033988755196333,
3129423.9466011249460280 10089947.2113032583147287,
3129485.7500000000000000 10089957.0000000000000000,
3129547.5533988750539720 10089947.2113032583147287,
3129584.7813968434929848 10089928.2426908612251282,
3129575.0000000000000000 10089990.0000000000000000,
3129584.7886967407539487 10090051.8033988755196333,
3129613.1966011249460280 10090107.5570504590868950,
3129657.4429495413787663 10090151.8033988755196333,
3129713.1966011249460280 10090180.2113032583147287,
3129775.0000000000000000 10090190.0000000000000000,
3129836.8033988750539720 10090180.2113032583147287,
3129892.5570504586212337 10090151.8033988755196333,
3129936.8033988750539720 10090107.5570504590868950,
3129950.2813203153200448 10090081.1051402483135462,
3129987.5000000000000000 10090087.0000000000000000,
3130049.3033988750539720 10090077.2113032583147287,
3130105.0570504586212337 10090048.8033988755196333,
3130149.3033988750539720 10090004.5570504590868950,
3130177.7113032592460513 10089948.8033988755196333,
3130187.5000000000000000 10089887.0000000000000000,
3130177.7113032592460513 10089825.1966011244803667,
3130149.3033988750539720 10089769.4429495409131050,
3130105.0570504586212337 10089725.1966011244803667,
3130049.3033988750539720 10089696.7886967416852713,
3129987.5000000000000000 10089687.0000000000000000,
3129925.6966011249460280 10089696.7886967416852713,
3129869.9429495413787663 10089725.1966011244803667,
3129825.6966011249460280 10089769.4429495409131050,
3129812.2186796846799552 10089795.8948597516864538,
3129775.0000000000000000 10089790.0000000000000000,
3129713.1966011249460280 10089799.7886967416852713,
3129675.9686031565070152 10089818.7573091387748718,
3129685.7500000000000000 10089757.0000000000000000,
3129675.9613032592460513 10089695.1966011244803667,
3129647.5533988750539720 10089639.4429495409131050,
3129603.3070504586212337 10089595.1966011244803667,
3129547.5533988750539720 10089566.7886967416852713,
3129485.7500000000000000 10089557.0000000000000000,
3129437.5021569523960352 10089564.6417076177895069,
3129433.0570504586212337 10089560.1966011244803667,
3129377.3033988750539720 10089531.7886967416852713,
3129315.5000000000000000 10089522.0000000000000000,
3129253.6966011249460280 10089531.7886967416852713,
3129197.9429495413787663 10089560.1966011244803667,
3129153.6966011249460280 10089604.4429495409131050,
3129125.2886967407539487 10089660.1966011244803667,
3129115.5000000000000000 10089722.0000000000000000,
3129125.2886967407539487 10089783.8033988755196333,
3129153.6966011249460280 10089839.5570504590868950,
3129197.9429495413787663 10089883.8033988755196333,
3129253.6966011249460280 10089912.2113032583147287,
3129315.5000000000000000 10089922.0000000000000000,
3129363.7478430476039648 10089914.3582923822104931)),
((3128637.4251130041666329 10095779.0990040097385645,
3128636.1387796052731574 10095778.8952688146382570,
3128574.3353807302191854 10095788.6839655563235283,
3128518.5817291466519237 10095817.0918699391186237,
3128474.3353807302191854 10095861.3382183555513620,
3128445.9274763460271060 10095917.0918699391186237,
3128436.1387796052731574 10095978.8952688146382570,
3128445.9274763460271060 10096040.6986676901578903,
3128474.3353807302191854 10096096.4523192737251520,
3128518.5817291466519237 10096140.6986676901578903,
3128574.3353807302191854 10096169.1065720729529858,
3128636.1387796052731574 10096178.8952688146382570,
3128697.9421784803271294 10096169.1065720729529858,
3128753.6958300638943911 10096140.6986676901578903,
3128797.9421784803271294 10096096.4523192737251520,
3128826.3500828645192087 10096040.6986676901578903,
3128836.1387796052731574 10095978.8952688146382570,
3128826.3500828645192087 10095917.0918699391186237,
3128800.2136666011065245 10095865.7962648048996925,
3128801.5000000000000000 10095866.0000000000000000,
3128863.3033988750539720 10095856.2113032583147287,
3128919.0570504586212337 10095827.8033988755196333,
3128963.3033988750539720 10095783.5570504590868950,
3128991.7113032592460513 10095727.8033988755196333,
3128999.7416070182807744 10095677.1020563524216413,
3129019.4429495413787663 10095696.8033988755196333,
3129075.1966011249460280 10095725.2113032583147287,
3129137.0000000000000000 10095735.0000000000000000,
3129198.8033988750539720 10095725.2113032583147287,
3129254.5570504586212337 10095696.8033988755196333,
3129284.6164736007340252 10095666.7439757343381643,
3129344.8033988750539720 10095657.2113032583147287,
3129400.5570504586212337 10095628.8033988755196333,
3129444.8033988750539720 10095584.5570504590868950,
3129473.2113032592460513 10095528.8033988755196333,
3129483.0000000000000000 10095467.0000000000000000,
3129479.1323246159590781 10095442.5804586857557297,
3129483.1966011249460280 10095450.5570504590868950,
3129527.4429495413787663 10095494.8033988755196333,
3129583.1966011249460280 10095523.2113032583147287,
3129645.0000000000000000 10095533.0000000000000000,
3129706.8033988750539720 10095523.2113032583147287,
3129762.5570504586212337 10095494.8033988755196333,
3129773.4757858519442379 10095483.8846634831279516,
3129775.5584920085966587 10095487.9722044654190540,
3129819.8048404250293970 10095532.2185528818517923,
3129875.5584920085966587 10095560.6264572646468878,
3129937.3618908836506307 10095570.4151540063321590,
3129999.1652897587046027 10095560.6264572646468878,
3130054.9189413422718644 10095532.2185528818517923,
3130099.1652897587046027 10095487.9722044654190540,
3130127.5731941428966820 10095432.2185528818517923,
3130137.3618908836506307 10095370.4151540063321590,
3130127.5731941428966820 10095308.6117551308125257,
3130099.1652897587046027 10095252.8581035472452641,
3130054.9189413422718644 10095208.6117551308125257,
3130015.4069930864498019 10095188.4794119354337454,
3130016.7500000000000000 10095180.0000000000000000,
3130006.9613032592460513 10095118.1966011244803667,
3130006.2494436735287309 10095116.7994980234652758,
3130055.3070504586212337 10095091.8033988755196333,
3130099.5533988750539720 10095047.5570504590868950,
3130127.9613032592460513 10094991.8033988755196333,
3130137.7500000000000000 10094930.0000000000000000,
3130127.9613032592460513 10094868.1966011244803667,
3130099.5533988750539720 10094812.4429495409131050,
3130055.3070504586212337 10094768.1966011244803667,
3129999.5533988750539720 10094739.7886967416852713,
3129937.7500000000000000 10094730.0000000000000000,
3129875.9466011249460280 10094739.7886967416852713,
3129841.5800286391749978 10094757.2993400339037180,
3129833.9613032592460513 10094709.1966011244803667,
3129805.5533988750539720 10094653.4429495409131050,
3129761.3070504586212337 10094609.1966011244803667,
3129716.1087480555288494 10094586.1669157780706882,
3129709.4613032592460513 10094544.1966011244803667,
3129681.0533988750539720 10094488.4429495409131050,
3129662.7836740459315479 10094470.1732247117906809,
3129662.7687156940810382 10094470.0787813961505890,
3129701.8546046526171267 10094450.1635262556374073,
3129746.1009530690498650 10094405.9171778392046690,
3129774.5088574532419443 10094350.1635262556374073,
3129784.2975541939958930 10094288.3601273801177740,
3129774.5088574532419443 10094226.5567285045981407,
3129746.1009530690498650 10094170.8030769210308790,
3129701.8546046526171267 10094126.5567285045981407,
3129655.9011703184805810 10094103.1422842200845480,
3129650.6456778752617538 10094092.8277995400130749,
3129606.3993294588290155 10094048.5814511235803366,
3129550.6456778752617538 10094020.1735467407852411,
3129488.8422790002077818 10094010.3848499990999699,
3129427.0388801251538098 10094020.1735467407852411,
3129371.2852285415865481 10094048.5814511235803366,
3129327.0388801251538098 10094092.8277995400130749,
3129298.6309757409617305 10094148.5814511235803366,
3129288.8422790002077818 10094210.3848499990999699,
3129298.6309757409617305 10094272.1882488746196032,
3129327.0388801251538098 10094327.9419004581868649,
3129349.9932651664130390 10094350.8962854985147715,
3129345.6250000000000000 10094355.2645506653934717,
3129318.5570504586212337 10094328.1966011244803667,
3129262.8033988750539720 10094299.7886967416852713,
3129201.0000000000000000 10094290.0000000000000000,
3129139.1966011249460280 10094299.7886967416852713,
3129083.4429495413787663 10094328.1966011244803667,
3129039.1966011249460280 10094372.4429495409131050,
3129010.7886967407539487 10094428.1966011244803667,
3129001.0000000000000000 10094490.0000000000000000,
3129010.7886967407539487 10094551.8033988755196333,
3129039.1966011249460280 10094607.5570504590868950,
3129083.4429495413787663 10094651.8033988755196333,
3129139.1966011249460280 10094680.2113032583147287,
3129201.0000000000000000 10094690.0000000000000000,
3129262.8033988750539720 10094680.2113032583147287,
3129318.5570504586212337 10094651.8033988755196333,
3129324.6250000000000000 10094645.7354493346065283,
3129325.7163259540684521 10094646.8267752882093191,
3129329.0386967407539487 10094667.8033988755196333,
3129357.4466011249460280 10094723.5570504590868950,
3129401.6929495413787663 10094767.8033988755196333,
3129446.8912519444711506 10094790.8330842219293118,
3129453.5386967407539487 10094832.8033988755196333,
3129464.4120326512493193 10094854.1435221638530493,
3129462.3261577207595110 10094867.3132181670516729,
3129446.6966011249460280 10094869.7886967416852713,
3129390.9429495413787663 10094898.1966011244803667,
3129346.6966011249460280 10094942.4429495409131050,
3129318.2886967407539487 10094998.1966011244803667,
3129308.5000000000000000 10095060.0000000000000000,
3129318.2886967407539487 10095121.8033988755196333,
3129346.6966011249460280 10095177.5570504590868950,
3129349.9780284059233963 10095180.8384777400642633,
3129369.1966011249460280 10095218.5570504590868950,
3129413.4429495413787663 10095262.8033988755196333,
3129452.9313035495579243 10095282.9237201996147633,
3129445.0000000000000000 10095333.0000000000000000,
3129448.8676753840409219 10095357.4195413142442703,
3129444.8033988750539720 10095349.4429495409131050,
3129400.5570504586212337 10095305.1966011244803667,
3129344.8033988750539720 10095276.7886967416852713,
3129283.0000000000000000 10095267.0000000000000000,
3129221.1966011249460280 10095276.7886967416852713,
3129165.4429495413787663 10095305.1966011244803667,
3129135.3835263992659748 10095335.2560242656618357,
3129075.1966011249460280 10095344.7886967416852713,
3129019.4429495413787663 10095373.1966011244803667,
3128975.1966011249460280 10095417.4429495409131050,
3128946.7886967407539487 10095473.1966011244803667,
3128938.7583929817192256 10095523.8979436475783587,
3128919.0570504586212337 10095504.1966011244803667,
3128863.3033988750539720 10095475.7886967416852713,
3128801.5000000000000000 10095466.0000000000000000,
3128739.6966011249460280 10095475.7886967416852713,
3128683.9429495413787663 10095504.1966011244803667,
3128639.6966011249460280 10095548.4429495409131050,
3128611.2886967407539487 10095604.1966011244803667,
3128601.5000000000000000 10095666.0000000000000000,
3128611.2886967407539487 10095727.8033988755196333,
3128637.4251130041666329 10095779.0990040097385645)),
((3127634.5866099777631462 10087922.4293429665267467,
3127627.1929495413787663 10087926.1966011244803667,
3127582.9466011249460280 10087970.4429495409131050,
3127554.5386967407539487 10088026.1966011244803667,
3127544.7500000000000000 10088088.0000000000000000,
3127554.5386967407539487 10088149.8033988755196333,
3127582.9466011249460280 10088205.5570504590868950,
3127627.1929495413787663 10088249.8033988755196333,
3127682.9466011249460280 10088278.2113032583147287,
3127744.7500000000000000 10088288.0000000000000000,
3127806.5533988750539720 10088278.2113032583147287,
3127862.3070504586212337 10088249.8033988755196333,
3127903.3689717254601419 10088208.7414776086807251,
3127908.2886967407539487 10088239.8033988755196333,
3127936.6966011249460280 10088295.5570504590868950,
3127980.9429495413787663 10088339.8033988755196333,
3128036.6966011249460280 10088368.2113032583147287,
3128098.5000000000000000 10088378.0000000000000000,
3128160.3033988750539720 10088368.2113032583147287,
3128195.6108228522352874 10088350.2212721873074770,
3128206.1929495413787663 10088360.8033988755196333,
3128261.9466011249460280 10088389.2113032583147287,
3128323.7500000000000000 10088399.0000000000000000,
3128385.5533988750539720 10088389.2113032583147287,
3128441.3070504586212337 10088360.8033988755196333,
3128485.5533988750539720 10088316.5570504590868950,
3128513.9613032592460513 10088260.8033988755196333,
3128523.7500000000000000 10088199.0000000000000000,
3128513.9613032592460513 10088137.1966011244803667,
3128485.5533988750539720 10088081.4429495409131050,
3128441.3070504586212337 10088037.1966011244803667,
3128385.5533988750539720 10088008.7886967416852713,
3128323.7500000000000000 10087999.0000000000000000,
3128261.9466011249460280 10088008.7886967416852713,
3128226.6391771477647126 10088026.7787278126925230,
3128223.9949640599079430 10088024.1345147248357534,
3128226.7113032592460513 10088018.8033988755196333,
3128236.5000000000000000 10087957.0000000000000000,
3128226.7113032592460513 10087895.1966011244803667,
3128225.8024740638211370 10087893.4129233974963427,
3128258.1929495413787663 10087925.8033988755196333,
3128313.9466011249460280 10087954.2113032583147287,
3128375.7500000000000000 10087964.0000000000000000,
3128437.5533988750539720 10087954.2113032583147287,
3128493.3070504586212337 10087925.8033988755196333,
3128526.7500000000000000 10087892.3604493346065283,
3128541.1929495413787663 10087906.8033988755196333,
3128596.9466011249460280 10087935.2113032583147287,
3128658.7500000000000000 10087945.0000000000000000,
3128676.3110043359920382 10087942.2186101563274860,
3128681.7886967407539487 10087976.8033988755196333,
3128710.1966011249460280 10088032.5570504590868950,
3128754.4429495413787663 10088076.8033988755196333,
3128810.1966011249460280 10088105.2113032583147287,
3128872.0000000000000000 10088115.0000000000000000,
3128933.8033988750539720 10088105.2113032583147287,
3128989.5570504586212337 10088076.8033988755196333,
3129033.8033988750539720 10088032.5570504590868950,
3129053.0915240417234600 10087994.7019733749330044,
3129077.1929495413787663 10088018.8033988755196333,
3129132.9466011249460280 10088047.2113032583147287,
3129194.7500000000000000 10088057.0000000000000000,
3129256.5533988750539720 10088047.2113032583147287,
3129266.9988949438557029 10088041.8890571780502796,
3129311.8743052189238369 10088064.7542207688093185,
3129305.5000000000000000 10088105.0000000000000000,
3129315.2886967407539487 10088166.8033988755196333,
3129343.6966011249460280 10088222.5570504590868950,
3129387.9429495413787663 10088266.8033988755196333,
3129443.6966011249460280 10088295.2113032583147287,
3129505.5000000000000000 10088305.0000000000000000,
3129554.6111143114976585 10088297.2215636447072029,
3129585.1929495413787663 10088327.8033988755196333,
3129640.9466011249460280 10088356.2113032583147287,
3129702.7500000000000000 10088366.0000000000000000,
3129764.5533988750539720 10088356.2113032583147287,
3129820.3070504586212337 10088327.8033988755196333,
3129864.5533988750539720 10088283.5570504590868950,
3129892.9613032592460513 10088227.8033988755196333,
3129902.7500000000000000 10088166.0000000000000000,
3129892.9613032592460513 10088104.1966011244803667,
3129864.5533988750539720 10088048.4429495409131050,
3129820.3070504586212337 10088004.1966011244803667,
3129764.5533988750539720 10087975.7886967416852713,
3129702.7500000000000000 10087966.0000000000000000,
3129653.6388856885023415 10087973.7784363552927971,
3129623.0570504586212337 10087943.1966011244803667,
3129572.1256947810761631 10087917.2457792311906815,
3129578.5000000000000000 10087877.0000000000000000,
3129568.7113032592460513 10087815.1966011244803667,
3129540.3033988750539720 10087759.4429495409131050,
3129537.6021808958612382 10087756.7417315617203712,
3129558.4613032592460513 10087715.8033988755196333,
3129568.2500000000000000 10087654.0000000000000000,
3129558.8168283980339766 10087594.4412985090166330,
3129573.8070504586212337 10087586.8033988755196333,
3129618.0533988750539720 10087542.5570504590868950,
3129646.4613032592460513 10087486.8033988755196333,
3129656.2500000000000000 10087425.0000000000000000,
3129646.4613032592460513 10087363.1966011244803667,
3129618.0533988750539720 10087307.4429495409131050,
3129580.0714881680905819 10087269.4610388334840536,
3129574.9613032592460513 10087237.1966011244803667,
3129546.5533988750539720 10087181.4429495409131050,
3129502.3070504586212337 10087137.1966011244803667,
3129446.5533988750539720 10087108.7886967416852713,
3129384.7500000000000000 10087099.0000000000000000,
3129322.9466011249460280 10087108.7886967416852713,
3129267.1929495413787663 10087137.1966011244803667,
3129222.9466011249460280 10087181.4429495409131050,
3129194.5386967407539487 10087237.1966011244803667,
3129184.7500000000000000 10087299.0000000000000000,
3129194.5386967407539487 10087360.8033988755196333,
3129222.9466011249460280 10087416.5570504590868950,
3129260.9285118319094181 10087454.5389611665159464,
3129265.2158056474290788 10087481.6078689899295568,
3129251.4466011249460280 10087483.7886967416852713,
3129195.6929495413787663 10087512.1966011244803667,
3129162.6849395111203194 10087545.2046111542731524,
3129112.8033988750539720 10087519.7886967416852713,
3129051.0000000000000000 10087510.0000000000000000,
3128989.1966011249460280 10087519.7886967416852713,
3128984.3024939931929111 10087522.2823688779026270,
3128976.2113032592460513 10087471.1966011244803667,
3128947.8033988750539720 10087415.4429495409131050,
3128903.5570504586212337 10087371.1966011244803667,
3128847.8033988750539720 10087342.7886967416852713,
3128786.0000000000000000 10087333.0000000000000000,
3128724.1966011249460280 10087342.7886967416852713,
3128668.4429495413787663 10087371.1966011244803667,
3128624.1966011249460280 10087415.4429495409131050,
3128595.7886967407539487 10087471.1966011244803667,
3128586.0000000000000000 10087533.0000000000000000,
3128590.0107222297228873 10087558.3227035533636808,
3128541.1929495413787663 10087583.1966011244803667,
3128507.7500000000000000 10087616.6395506653934717,
3128493.3070504586212337 10087602.1966011244803667,
3128437.5533988750539720 10087573.7886967416852713,
3128425.3841829407028854 10087571.8612822871655226,
3128427.9613032592460513 10087566.8033988755196333,
3128437.7500000000000000 10087505.0000000000000000,
3128427.9613032592460513 10087443.1966011244803667,
3128399.5533988750539720 10087387.4429495409131050,
3128357.4829203695990145 10087345.3724710363894701,
3128350.9613032592460513 10087304.1966011244803667,
3128322.5533988750539720 10087248.4429495409131050,
3128278.3070504586212337 10087204.1966011244803667,
3128222.5533988750539720 10087175.7886967416852713,
3128160.7500000000000000 10087166.0000000000000000,
3128156.7729329494759440 10087166.6299055386334658,
3128164.0000000000000000 10087121.0000000000000000,
3128154.2113032592460513 10087059.1966011244803667,
3128125.8033988750539720 10087003.4429495409131050,
3128081.5570504586212337 10086959.1966011244803667,
3128025.8033988750539720 10086930.7886967416852713,
3127964.0000000000000000 10086921.0000000000000000,
3127902.1966011249460280 10086930.7886967416852713,
3127846.4429495413787663 10086959.1966011244803667,
3127802.1966011249460280 10087003.4429495409131050,
3127773.7886967407539487 10087059.1966011244803667,
3127764.0000000000000000 10087121.0000000000000000,
3127773.7886967407539487 10087182.8033988755196333,
3127802.1966011249460280 10087238.5570504590868950,
3127846.4429495413787663 10087282.8033988755196333,
3127892.9100046502426267 10087306.4795460160821676,
3127877.9466011249460280 10087321.4429495409131050,
3127849.5386967407539487 10087377.1966011244803667,
3127839.7500000000000000 10087439.0000000000000000,
3127849.5386967407539487 10087500.8033988755196333,
3127877.9466011249460280 10087556.5570504590868950,
3127922.1929495413787663 10087600.8033988755196333,
3127977.9466011249460280 10087629.2113032583147287,
3128039.7500000000000000 10087639.0000000000000000,
3128085.1922114393673837 10087631.8026607744395733,
3128120.1929495413787663 10087666.8033988755196333,
3128175.9466011249460280 10087695.2113032583147287,
3128188.1158170592971146 10087697.1387177128344774,
3128185.5386967407539487 10087702.1966011244803667,
3128175.7500000000000000 10087764.0000000000000000,
3128185.5386967407539487 10087825.8033988755196333,
3128186.4475259361788630 10087827.5870766025036573,
3128154.0570504586212337 10087795.1966011244803667,
3128098.3033988750539720 10087766.7886967416852713,
3128036.5000000000000000 10087757.0000000000000000,
3127988.4679747684858739 10087764.6075254343450069,
3127946.0570504586212337 10087722.1966011244803667,
3127890.3033988750539720 10087693.7886967416852713,
3127828.5000000000000000 10087684.0000000000000000,
3127766.6966011249460280 10087693.7886967416852713,
3127710.9429495413787663 10087722.1966011244803667,
3127666.6966011249460280 10087766.4429495409131050,
3127638.2886967407539487 10087822.1966011244803667,
3127628.5000000000000000 10087884.0000000000000000,
3127634.5866099777631462 10087922.4293429665267467)),
((3129896.2152143297716975 10096449.9256476629525423,
3129886.4265175890177488 10096388.1222487874329090,
3129858.0186132048256695 10096332.3685972038656473,
3129813.7722647883929312 10096288.1222487874329090,
3129758.0186132048256695 10096259.7143444046378136,
3129696.2152143297716975 10096249.9256476629525423,
3129634.4118154547177255 10096259.7143444046378136,
3129578.6581638711504638 10096288.1222487874329090,
3129534.4118154547177255 10096332.3685972038656473,
3129506.0039110705256462 10096388.1222487874329090,
3129496.2152143297716975 10096449.9256476629525423,
3129506.0039110705256462 10096511.7290465384721756,
3129534.4118154547177255 10096567.4826981220394373,
3129578.6581638711504638 10096611.7290465384721756,
3129634.4118154547177255 10096640.1369509212672710,
3129696.2152143297716975 10096649.9256476629525423,
3129758.0186132048256695 10096640.1369509212672710,
3129813.7722647883929312 10096611.7290465384721756,
3129858.0186132048256695 10096567.4826981220394373,
3129886.4265175890177488 10096511.7290465384721756,
3129896.2152143297716975 10096449.9256476629525423)),
((3129346.0313772074878216 10096842.3807362671941519,
3129331.0000000000000000 10096840.0000000000000000,
3129269.1966011249460280 10096849.7886967416852713,
3129213.4429495413787663 10096878.1966011244803667,
3129169.1966011249460280 10096922.4429495409131050,
3129140.7886967407539487 10096978.1966011244803667,
3129131.0000000000000000 10097040.0000000000000000,
3129140.7886967407539487 10097101.8033988755196333,
3129169.1966011249460280 10097157.5570504590868950,
3129213.4429495413787663 10097201.8033988755196333,
3129269.1966011249460280 10097230.2113032583147287,
3129331.0000000000000000 10097240.0000000000000000,
3129392.8033988750539720 10097230.2113032583147287,
3129448.5570504586212337 10097201.8033988755196333,
3129466.4584804745391011 10097183.9019688591361046,
3129481.4898576820269227 10097186.2827051263302565,
3129543.2932565570808947 10097176.4940083846449852,
3129599.0469081406481564 10097148.0861040018498898,
3129643.2932565570808947 10097103.8397555854171515,
3129671.7011609412729740 10097048.0861040018498898,
3129681.4898576820269227 10096986.2827051263302565,
3129671.7011609412729740 10096924.4793062508106232,
3129643.2932565570808947 10096868.7256546672433615,
3129599.0469081406481564 10096824.4793062508106232,
3129543.2932565570808947 10096796.0714018680155277,
3129481.4898576820269227 10096786.2827051263302565,
3129419.6864588069729507 10096796.0714018680155277,
3129363.9328072234056890 10096824.4793062508106232,
3129346.0313772074878216 10096842.3807362671941519)),
((3129641.5000000000000000 10091931.0000000000000000,
3129631.7113032592460513 10091869.1966011244803667,
3129603.3033988750539720 10091813.4429495409131050,
3129559.0570504586212337 10091769.1966011244803667,
3129503.3033988750539720 10091740.7886967416852713,
3129441.5000000000000000 10091731.0000000000000000,
3129379.6966011249460280 10091740.7886967416852713,
3129323.9429495413787663 10091769.1966011244803667,
3129279.6966011249460280 10091813.4429495409131050,
3129251.2886967407539487 10091869.1966011244803667,
3129241.5000000000000000 10091931.0000000000000000,
3129251.2886967407539487 10091992.8033988755196333,
3129279.6966011249460280 10092048.5570504590868950,
3129323.9429495413787663 10092092.8033988755196333,
3129379.6966011249460280 10092121.2113032583147287,
3129441.5000000000000000 10092131.0000000000000000,
3129503.3033988750539720 10092121.2113032583147287,
3129559.0570504586212337 10092092.8033988755196333,
3129603.3033988750539720 10092048.5570504590868950,
3129631.7113032592460513 10091992.8033988755196333,
3129641.5000000000000000 10091931.0000000000000000)),
((3129406.2500000000000000 10084733.0000000000000000,
3129396.4613032592460513 10084671.1966011244803667,
3129368.0533988750539720 10084615.4429495409131050,
3129323.8070504586212337 10084571.1966011244803667,
3129268.0533988750539720 10084542.7886967416852713,
3129206.2500000000000000 10084533.0000000000000000,
3129144.4466011249460280 10084542.7886967416852713,
3129088.6929495413787663 10084571.1966011244803667,
3129044.4466011249460280 10084615.4429495409131050,
3129016.0386967407539487 10084671.1966011244803667,
3129006.2500000000000000 10084733.0000000000000000,
3129016.0386967407539487 10084794.8033988755196333,
3129044.4466011249460280 10084850.5570504590868950,
3129088.6929495413787663 10084894.8033988755196333,
3129144.4466011249460280 10084923.2113032583147287,
3129206.2500000000000000 10084933.0000000000000000,
3129268.0533988750539720 10084923.2113032583147287,
3129323.8070504586212337 10084894.8033988755196333,
3129368.0533988750539720 10084850.5570504590868950,
3129396.4613032592460513 10084794.8033988755196333,
3129406.2500000000000000 10084733.0000000000000000)),
((3129356.1899470235221088 10079212.8888563159853220,
3129346.4012502827681601 10079151.0854574404656887,
3129317.9933458985760808 10079095.3318058568984270,
3129273.7469974821433425 10079051.0854574404656887,
3129217.9933458985760808 10079022.6775530576705933,
3129156.1899470235221088 10079012.8888563159853220,
3129094.3865481484681368 10079022.6775530576705933,
3129038.6328965649008751 10079051.0854574404656887,
3128994.3865481484681368 10079095.3318058568984270,
3128965.9786437642760575 10079151.0854574404656887,
3128956.1899470235221088 10079212.8888563159853220,
3128965.9786437642760575 10079274.6922551915049553,
3128994.3865481484681368 10079330.4459067750722170,
3129038.6328965649008751 10079374.6922551915049553,
3129094.3865481484681368 10079403.1001595743000507,
3129156.1899470235221088 10079412.8888563159853220,
3129217.9933458985760808 10079403.1001595743000507,
3129273.7469974821433425 10079374.6922551915049553,
3129317.9933458985760808 10079330.4459067750722170,
3129346.4012502827681601 10079274.6922551915049553,
3129356.1899470235221088 10079212.8888563159853220)),
((3128898.8215470877476037 10096102.3180035781115294,
3128890.5000000000000000 10096101.0000000000000000,
3128828.6966011249460280 10096110.7886967416852713,
3128772.9429495413787663 10096139.1966011244803667,
3128728.6966011249460280 10096183.4429495409131050,
3128700.2886967407539487 10096239.1966011244803667,
3128690.5000000000000000 10096301.0000000000000000,
3128700.2886967407539487 10096362.8033988755196333,
3128728.6966011249460280 10096418.5570504590868950,
3128772.9429495413787663 10096462.8033988755196333,
3128828.6966011249460280 10096491.2113032583147287,
3128890.5000000000000000 10096501.0000000000000000,
3128952.3033988750539720 10096491.2113032583147287,
3129008.0570504586212337 10096462.8033988755196333,
3129029.1784529122523963 10096441.6819964218884706,
3129037.5000000000000000 10096443.0000000000000000,
3129099.3033988750539720 10096433.2113032583147287,
3129155.0570504586212337 10096404.8033988755196333,
3129199.3033988750539720 10096360.5570504590868950,
3129227.7113032592460513 10096304.8033988755196333,
3129237.5000000000000000 10096243.0000000000000000,
3129227.7113032592460513 10096181.1966011244803667,
3129199.3033988750539720 10096125.4429495409131050,
3129155.0570504586212337 10096081.1966011244803667,
3129099.3033988750539720 10096052.7886967416852713,
3129037.5000000000000000 10096043.0000000000000000,
3128975.6966011249460280 10096052.7886967416852713,
3128919.9429495413787663 10096081.1966011244803667,
3128898.8215470877476037 10096102.3180035781115294)),
((3128589.2331022392027080 10089964.0935515742748976,
3128624.9429495413787663 10089999.8033988755196333,
3128680.6966011249460280 10090028.2113032583147287,
3128742.5000000000000000 10090038.0000000000000000,
3128804.3033988750539720 10090028.2113032583147287,
3128860.0534402849152684 10089999.8052383512258530,
3128863.8033988750539720 10089999.2113032583147287,
3128919.5570504586212337 10089970.8033988755196333,
3128963.8033988750539720 10089926.5570504590868950,
3128992.2113032592460513 10089870.8033988755196333,
3129002.0000000000000000 10089809.0000000000000000,
3128992.2113032592460513 10089747.1966011244803667,
3128963.8033988750539720 10089691.4429495409131050,
3128919.5570504586212337 10089647.1966011244803667,
3128863.8033988750539720 10089618.7886967416852713,
3128802.0000000000000000 10089609.0000000000000000,
3128740.1966011249460280 10089618.7886967416852713,
3128685.8434565137140453 10089646.4830071795731783,
3128650.5570504586212337 10089611.1966011244803667,
3128594.8033988750539720 10089582.7886967416852713,
3128533.0000000000000000 10089573.0000000000000000,
3128471.1966011249460280 10089582.7886967416852713,
3128415.4429495413787663 10089611.1966011244803667,
3128371.1966011249460280 10089655.4429495409131050,
3128342.7886967407539487 10089711.1966011244803667,
3128333.0000000000000000 10089773.0000000000000000,
3128342.7886967407539487 10089834.8033988755196333,
3128371.1966011249460280 10089890.5570504590868950,
3128415.4429495413787663 10089934.8033988755196333,
3128471.1966011249460280 10089963.2113032583147287,
3128533.0000000000000000 10089973.0000000000000000,
3128589.2331022392027080 10089964.0935515742748976)),
((3128901.7500000000000000 10090796.0000000000000000,
3128891.9613032592460513 10090734.1966011244803667,
3128863.5533988750539720 10090678.4429495409131050,
3128819.3070504586212337 10090634.1966011244803667,
3128763.5533988750539720 10090605.7886967416852713,
3128701.7500000000000000 10090596.0000000000000000,
3128639.9466011249460280 10090605.7886967416852713,
3128584.1929495413787663 10090634.1966011244803667,
3128539.9466011249460280 10090678.4429495409131050,
3128511.5386967407539487 10090734.1966011244803667,
3128501.7500000000000000 10090796.0000000000000000,
3128511.5386967407539487 10090857.8033988755196333,
3128539.9466011249460280 10090913.5570504590868950,
3128584.1929495413787663 10090957.8033988755196333,
3128639.9466011249460280 10090986.2113032583147287,
3128701.7500000000000000 10090996.0000000000000000,
3128763.5533988750539720 10090986.2113032583147287,
3128819.3070504586212337 10090957.8033988755196333,
3128863.5533988750539720 10090913.5570504590868950,
3128891.9613032592460513 10090857.8033988755196333,
3128901.7500000000000000 10090796.0000000000000000)),
((3128893.5000000000000000 10084691.0000000000000000,
3128883.7113032592460513 10084629.1966011244803667,
3128855.3033988750539720 10084573.4429495409131050,
3128811.0570504586212337 10084529.1966011244803667,
3128755.3033988750539720 10084500.7886967416852713,
3128693.5000000000000000 10084491.0000000000000000,
3128631.6966011249460280 10084500.7886967416852713,
3128575.9429495413787663 10084529.1966011244803667,
3128531.6966011249460280 10084573.4429495409131050,
3128503.2886967407539487 10084629.1966011244803667,
3128493.5000000000000000 10084691.0000000000000000,
3128503.2886967407539487 10084752.8033988755196333,
3128531.6966011249460280 10084808.5570504590868950,
3128575.9429495413787663 10084852.8033988755196333,
3128631.6966011249460280 10084881.2113032583147287,
3128693.5000000000000000 10084891.0000000000000000,
3128755.3033988750539720 10084881.2113032583147287,
3128811.0570504586212337 10084852.8033988755196333,
3128855.3033988750539720 10084808.5570504590868950,
3128883.7113032592460513 10084752.8033988755196333,
3128893.5000000000000000 10084691.0000000000000000)),
((3128892.2500000000000000 10091470.0000000000000000,
3128882.4613032592460513 10091408.1966011244803667,
3128854.0533988750539720 10091352.4429495409131050,
3128809.8070504586212337 10091308.1966011244803667,
3128754.0533988750539720 10091279.7886967416852713,
3128692.2500000000000000 10091270.0000000000000000,
3128630.4466011249460280 10091279.7886967416852713,
3128574.6929495413787663 10091308.1966011244803667,
3128530.4466011249460280 10091352.4429495409131050,
3128502.0386967407539487 10091408.1966011244803667,
3128492.2500000000000000 10091470.0000000000000000,
3128502.0386967407539487 10091531.8033988755196333,
3128530.4466011249460280 10091587.5570504590868950,
3128574.6929495413787663 10091631.8033988755196333,
3128630.4466011249460280 10091660.2113032583147287,
3128692.2500000000000000 10091670.0000000000000000,
3128754.0533988750539720 10091660.2113032583147287,
3128809.8070504586212337 10091631.8033988755196333,
3128854.0533988750539720 10091587.5570504590868950,
3128882.4613032592460513 10091531.8033988755196333,
3128892.2500000000000000 10091470.0000000000000000)),
((3128619.2500000000000000 10078747.0000000000000000,
3128609.4613032592460513 10078685.1966011244803667,
3128581.0533988750539720 10078629.4429495409131050,
3128536.8070504586212337 10078585.1966011244803667,
3128481.0533988750539720 10078556.7886967416852713,
3128419.2500000000000000 10078547.0000000000000000,
3128357.4466011249460280 10078556.7886967416852713,
3128301.6929495413787663 10078585.1966011244803667,
3128257.4466011249460280 10078629.4429495409131050,
3128229.0386967407539487 10078685.1966011244803667,
3128219.2500000000000000 10078747.0000000000000000,
3128229.0386967407539487 10078808.8033988755196333,
3128257.4466011249460280 10078864.5570504590868950,
3128301.6929495413787663 10078908.8033988755196333,
3128357.4466011249460280 10078937.2113032583147287,
3128419.2500000000000000 10078947.0000000000000000,
3128481.0533988750539720 10078937.2113032583147287,
3128536.8070504586212337 10078908.8033988755196333,
3128581.0533988750539720 10078864.5570504590868950,
3128609.4613032592460513 10078808.8033988755196333,
3128619.2500000000000000 10078747.0000000000000000)),
((3128230.1898077568039298 10090293.0502570904791355,
3128258.9429495413787663 10090321.8033988755196333,
3128314.6966011249460280 10090350.2113032583147287,
3128376.5000000000000000 10090360.0000000000000000,
3128438.3033988750539720 10090350.2113032583147287,
3128494.0570504586212337 10090321.8033988755196333,
3128538.3033988750539720 10090277.5570504590868950,
3128566.7113032592460513 10090221.8033988755196333,
3128576.5000000000000000 10090160.0000000000000000,
3128566.7113032592460513 10090098.1966011244803667,
3128538.3033988750539720 10090042.4429495409131050,
3128494.0570504586212337 10089998.1966011244803667,
3128438.3033988750539720 10089969.7886967416852713,
3128388.8101922431960702 10089961.9497429095208645,
3128360.0570504586212337 10089933.1966011244803667,
3128304.3033988750539720 10089904.7886967416852713,
3128242.5000000000000000 10089895.0000000000000000,
3128180.6966011249460280 10089904.7886967416852713,
3128124.9429495413787663 10089933.1966011244803667,
3128080.6966011249460280 10089977.4429495409131050,
3128052.2886967407539487 10090033.1966011244803667,
3128042.5000000000000000 10090095.0000000000000000,
3128052.2886967407539487 10090156.8033988755196333,
3128080.6966011249460280 10090212.5570504590868950,
3128124.9429495413787663 10090256.8033988755196333,
3128180.6966011249460280 10090285.2113032583147287,
3128230.1898077568039298 10090293.0502570904791355)),
((3128254.2500000000000000 10095879.0000000000000000,
3128244.4613032592460513 10095817.1966011244803667,
3128216.0533988750539720 10095761.4429495409131050,
3128171.8070504586212337 10095717.1966011244803667,
3128116.0533988750539720 10095688.7886967416852713,
3128054.2500000000000000 10095679.0000000000000000,
3127992.4466011249460280 10095688.7886967416852713,
3127936.6929495413787663 10095717.1966011244803667,
3127892.4466011249460280 10095761.4429495409131050,
3127864.0386967407539487 10095817.1966011244803667,
3127854.2500000000000000 10095879.0000000000000000,
3127864.0386967407539487 10095940.8033988755196333,
3127892.4466011249460280 10095996.5570504590868950,
3127936.6929495413787663 10096040.8033988755196333,
3127992.4466011249460280 10096069.2113032583147287,
3128054.2500000000000000 10096079.0000000000000000,
3128116.0533988750539720 10096069.2113032583147287,
3128171.8070504586212337 10096040.8033988755196333,
3128216.0533988750539720 10095996.5570504590868950,
3128244.4613032592460513 10095940.8033988755196333,
3128254.2500000000000000 10095879.0000000000000000)),
((3128060.7500000000000000 10100865.0000000000000000,
3128050.9613032592460513 10100803.1966011244803667,
3128022.5533988750539720 10100747.4429495409131050,
3127978.3070504586212337 10100703.1966011244803667,
3127922.5533988750539720 10100674.7886967416852713,
3127860.7500000000000000 10100665.0000000000000000,
3127798.9466011249460280 10100674.7886967416852713,
3127743.1929495413787663 10100703.1966011244803667,
3127698.9466011249460280 10100747.4429495409131050,
3127670.5386967407539487 10100803.1966011244803667,
3127660.7500000000000000 10100865.0000000000000000,
3127670.5386967407539487 10100926.8033988755196333,
3127698.9466011249460280 10100982.5570504590868950,
3127743.1929495413787663 10101026.8033988755196333,
3127798.9466011249460280 10101055.2113032583147287,
3127860.7500000000000000 10101065.0000000000000000,
3127922.5533988750539720 10101055.2113032583147287,
3127978.3070504586212337 10101026.8033988755196333,
3128022.5533988750539720 10100982.5570504590868950,
3128050.9613032592460513 10100926.8033988755196333,
3128060.7500000000000000 10100865.0000000000000000)),
((3127974.1829699999652803 10098482.1327199991792440,
3127964.3942732592113316 10098420.3293211236596107,
3127935.9863688750192523 10098364.5756695400923491,
3127891.7400204585865140 10098320.3293211236596107,
3127835.9863688750192523 10098291.9214167408645153,
3127774.1829699999652803 10098282.1327199991792440,
3127712.3795711249113083 10098291.9214167408645153,
3127656.6259195413440466 10098320.3293211236596107,
3127612.3795711249113083 10098364.5756695400923491,
3127583.9716667407192290 10098420.3293211236596107,
3127574.1829699999652803 10098482.1327199991792440,
3127583.9716667407192290 10098543.9361188746988773,
3127612.3795711249113083 10098599.6897704582661390,
3127656.6259195413440466 10098643.9361188746988773,
3127712.3795711249113083 10098672.3440232574939728,
3127774.1829699999652803 10098682.1327199991792440,
3127835.9863688750192523 10098672.3440232574939728,
3127891.7400204585865140 10098643.9361188746988773,
3127935.9863688750192523 10098599.6897704582661390,
3127964.3942732592113316 10098543.9361188746988773,
3127974.1829699999652803 10098482.1327199991792440)),
((3127859.7500000000000000 10097109.0000000000000000,
3127849.9613032592460513 10097047.1966011244803667,
3127821.5533988750539720 10096991.4429495409131050,
3127777.3070504586212337 10096947.1966011244803667,
3127721.5533988750539720 10096918.7886967416852713,
3127659.7500000000000000 10096909.0000000000000000,
3127597.9466011249460280 10096918.7886967416852713,
3127542.1929495413787663 10096947.1966011244803667,
3127497.9466011249460280 10096991.4429495409131050,
3127469.5386967407539487 10097047.1966011244803667,
3127459.7500000000000000 10097109.0000000000000000,
3127469.5386967407539487 10097170.8033988755196333,
3127497.9466011249460280 10097226.5570504590868950,
3127542.1929495413787663 10097270.8033988755196333,
3127597.9466011249460280 10097299.2113032583147287,
3127659.7500000000000000 10097309.0000000000000000,
3127721.5533988750539720 10097299.2113032583147287,
3127777.3070504586212337 10097270.8033988755196333,
3127821.5533988750539720 10097226.5570504590868950,
3127849.9613032592460513 10097170.8033988755196333,
3127859.7500000000000000 10097109.0000000000000000)),
((3127849.7500000000000000 10091011.0000000000000000,
3127839.9613032592460513 10090949.1966011244803667,
3127811.5533988750539720 10090893.4429495409131050,
3127767.3070504586212337 10090849.1966011244803667,
3127711.5533988750539720 10090820.7886967416852713,
3127649.7500000000000000 10090811.0000000000000000,
3127587.9466011249460280 10090820.7886967416852713,
3127532.1929495413787663 10090849.1966011244803667,
3127487.9466011249460280 10090893.4429495409131050,
3127459.5386967407539487 10090949.1966011244803667,
3127449.7500000000000000 10091011.0000000000000000,
3127459.5386967407539487 10091072.8033988755196333,
3127487.9466011249460280 10091128.5570504590868950,
3127532.1929495413787663 10091172.8033988755196333,
3127587.9466011249460280 10091201.2113032583147287,
3127649.7500000000000000 10091211.0000000000000000,
3127711.5533988750539720 10091201.2113032583147287,
3127767.3070504586212337 10091172.8033988755196333,
3127811.5533988750539720 10091128.5570504590868950,
3127839.9613032592460513 10091072.8033988755196333,
3127849.7500000000000000 10091011.0000000000000000)),
((3127815.7500000000000000 10078364.0000000000000000,
3127805.9613032592460513 10078302.1966011244803667,
3127777.5533988750539720 10078246.4429495409131050,
3127733.3070504586212337 10078202.1966011244803667,
3127677.5533988750539720 10078173.7886967416852713,
3127615.7500000000000000 10078164.0000000000000000,
3127553.9466011249460280 10078173.7886967416852713,
3127498.1929495413787663 10078202.1966011244803667,
3127453.9466011249460280 10078246.4429495409131050,
3127425.5386967407539487 10078302.1966011244803667,
3127415.7500000000000000 10078364.0000000000000000,
3127425.5386967407539487 10078425.8033988755196333,
3127453.9466011249460280 10078481.5570504590868950,
3127498.1929495413787663 10078525.8033988755196333,
3127553.9466011249460280 10078554.2113032583147287,
3127615.7500000000000000 10078564.0000000000000000,
3127677.5533988750539720 10078554.2113032583147287,
3127733.3070504586212337 10078525.8033988755196333,
3127777.5533988750539720 10078481.5570504590868950,
3127805.9613032592460513 10078425.8033988755196333,
3127815.7500000000000000 10078364.0000000000000000)),
((3127168.3778342278674245 10096621.4947336185723543,
3127158.7341544735245407 10096640.4215208161622286,
3127148.9454577327705920 10096702.2249196916818619,
3127158.7341544735245407 10096764.0283185672014952,
3127187.1420588577166200 10096819.7819701507687569,
3127231.3884072741493583 10096864.0283185672014952,
3127287.1420588577166200 10096892.4362229499965906,
3127348.9454577327705920 10096902.2249196916818619,
3127410.7488566078245640 10096892.4362229499965906,
3127466.5025081913918257 10096864.0283185672014952,
3127510.7488566078245640 10096819.7819701507687569,
3127539.1567609920166433 10096764.0283185672014952,
3127548.9454577327705920 10096702.2249196916818619,
3127539.1567609920166433 10096640.4215208161622286,
3127510.7488566078245640 10096584.6678692325949669,
3127466.5025081913918257 10096540.4215208161622286,
3127410.7488566078245640 10096512.0136164333671331,
3127385.0842595351859927 10096507.9487435892224312,
3127394.7279392895288765 10096489.0219563916325569,
3127404.5166360302828252 10096427.2185575161129236,
3127394.7279392895288765 10096365.4151586405932903,
3127366.3200349053367972 10096309.6615070570260286,
3127322.0736864889040589 10096265.4151586405932903,
3127266.3200349053367972 10096237.0072542577981949,
3127204.5166360302828252 10096227.2185575161129236,
3127142.7132371552288532 10096237.0072542577981949,
3127086.9595855716615915 10096265.4151586405932903,
3127042.7132371552288532 10096309.6615070570260286,
3127014.3053327710367739 10096365.4151586405932903,
3127004.5166360302828252 10096427.2185575161129236,
3127014.3053327710367739 10096489.0219563916325569,
3127042.7132371552288532 10096544.7756079751998186,
3127086.9595855716615915 10096589.0219563916325569,
3127142.7132371552288532 10096617.4298607744276524,
3127168.3778342278674245 10096621.4947336185723543)),
((3127033.3846382289193571 10078327.4382845386862755,
3127021.7886967407539487 10078350.1966011244803667,
3127012.0000000000000000 10078412.0000000000000000,
3127021.7886967407539487 10078473.8033988755196333,
3127050.1966011249460280 10078529.5570504590868950,
3127094.4429495413787663 10078573.8033988755196333,
3127150.1966011249460280 10078602.2113032583147287,
3127212.0000000000000000 10078612.0000000000000000,
3127273.8033988750539720 10078602.2113032583147287,
3127329.5570504586212337 10078573.8033988755196333,
3127373.8033988750539720 10078529.5570504590868950,
3127402.2113032592460513 10078473.8033988755196333,
3127412.0000000000000000 10078412.0000000000000000,
3127402.2113032592460513 10078350.1966011244803667,
3127377.8143849014304578 10078302.3149528540670872,
3127389.4103263895958662 10078279.5566362682729959,
3127399.1990231303498149 10078217.7532373927533627,
3127389.4103263895958662 10078155.9498385172337294,
3127361.0024220054037869 10078100.1961869336664677,
3127316.7560735889710486 10078055.9498385172337294,
3127261.0024220054037869 10078027.5419341344386339,
3127199.1990231303498149 10078017.7532373927533627,
3127137.3956242552958429 10078027.5419341344386339,
3127081.6419726717285812 10078055.9498385172337294,
3127037.3956242552958429 10078100.1961869336664677,
3127008.9877198711037636 10078155.9498385172337294,
3126999.1990231303498149 10078217.7532373927533627,
3127008.9877198711037636 10078279.5566362682729959,
3127033.3846382289193571 10078327.4382845386862755)),
((3126545.6749690365977585 10097505.6390845030546188,
3126538.6929495413787663 10097509.1966011244803667,
3126494.4466011249460280 10097553.4429495409131050,
3126466.0386967407539487 10097609.1966011244803667,
3126456.2500000000000000 10097671.0000000000000000,
3126466.0386967407539487 10097732.8033988755196333,
3126494.4466011249460280 10097788.5570504590868950,
3126538.6929495413787663 10097832.8033988755196333,
3126594.4466011249460280 10097861.2113032583147287,
3126656.2500000000000000 10097871.0000000000000000,
3126718.0533988750539720 10097861.2113032583147287,
3126773.8070504586212337 10097832.8033988755196333,
3126818.0533988750539720 10097788.5570504590868950,
3126846.4613032592460513 10097732.8033988755196333,
3126856.2500000000000000 10097671.0000000000000000,
3126846.4613032592460513 10097609.1966011244803667,
3126845.3125646901316941 10097606.9420747403055429,
3126852.2945841853506863 10097603.3845581188797951,
3126896.5409326017834246 10097559.1382097024470568,
3126924.9488369859755039 10097503.3845581188797951,
3126934.7375337267294526 10097441.5811592433601618,
3126924.9488369859755039 10097379.7777603678405285,
3126896.5409326017834246 10097324.0241087842732668,
3126852.2945841853506863 10097279.7777603678405285,
3126796.5409326017834246 10097251.3698559850454330,
3126734.7375337267294526 10097241.5811592433601618,
3126672.9341348516754806 10097251.3698559850454330,
3126617.1804832681082189 10097279.7777603678405285,
3126572.9341348516754806 10097324.0241087842732668,
3126544.5262304674834013 10097379.7777603678405285,
3126534.7375337267294526 10097441.5811592433601618,
3126544.5262304674834013 10097503.3845581188797951,
3126545.6749690365977585 10097505.6390845030546188)),
((3126627.2500000000000000 10091559.0000000000000000,
3126617.4613032592460513 10091497.1966011244803667,
3126589.0533988750539720 10091441.4429495409131050,
3126544.8070504586212337 10091397.1966011244803667,
3126489.0533988750539720 10091368.7886967416852713,
3126427.2500000000000000 10091359.0000000000000000,
3126365.4466011249460280 10091368.7886967416852713,
3126309.6929495413787663 10091397.1966011244803667,
3126265.4466011249460280 10091441.4429495409131050,
3126237.0386967407539487 10091497.1966011244803667,
3126227.2500000000000000 10091559.0000000000000000,
3126237.0386967407539487 10091620.8033988755196333,
3126265.4466011249460280 10091676.5570504590868950,
3126309.6929495413787663 10091720.8033988755196333,
3126365.4466011249460280 10091749.2113032583147287,
3126427.2500000000000000 10091759.0000000000000000,
3126489.0533988750539720 10091749.2113032583147287,
3126544.8070504586212337 10091720.8033988755196333,
3126589.0533988750539720 10091676.5570504590868950,
3126617.4613032592460513 10091620.8033988755196333,
3126627.2500000000000000 10091559.0000000000000000)),
((3126357.5000000000000000 10085181.0000000000000000,
3126347.7113032592460513 10085119.1966011244803667,
3126319.3033988750539720 10085063.4429495409131050,
3126275.0570504586212337 10085019.1966011244803667,
3126219.3033988750539720 10084990.7886967416852713,
3126157.5000000000000000 10084981.0000000000000000,
3126095.6966011249460280 10084990.7886967416852713,
3126039.9429495413787663 10085019.1966011244803667,
3125995.6966011249460280 10085063.4429495409131050,
3125967.2886967407539487 10085119.1966011244803667,
3125957.5000000000000000 10085181.0000000000000000,
3125967.2886967407539487 10085242.8033988755196333,
3125995.6966011249460280 10085298.5570504590868950,
3126039.9429495413787663 10085342.8033988755196333,
3126095.6966011249460280 10085371.2113032583147287,
3126157.5000000000000000 10085381.0000000000000000,
3126219.3033988750539720 10085371.2113032583147287,
3126275.0570504586212337 10085342.8033988755196333,
3126319.3033988750539720 10085298.5570504590868950,
3126347.7113032592460513 10085242.8033988755196333,
3126357.5000000000000000 10085181.0000000000000000)),
((3126321.5000000000000000 10096852.0000000000000000,
3126311.7113032592460513 10096790.1966011244803667,
3126283.3033988750539720 10096734.4429495409131050,
3126239.0570504586212337 10096690.1966011244803667,
3126183.3033988750539720 10096661.7886967416852713,
3126121.5000000000000000 10096652.0000000000000000,
3126059.6966011249460280 10096661.7886967416852713,
3126003.9429495413787663 10096690.1966011244803667,
3125959.6966011249460280 10096734.4429495409131050,
3125931.2886967407539487 10096790.1966011244803667,
3125921.5000000000000000 10096852.0000000000000000,
3125931.2886967407539487 10096913.8033988755196333,
3125959.6966011249460280 10096969.5570504590868950,
3126003.9429495413787663 10097013.8033988755196333,
3126059.6966011249460280 10097042.2113032583147287,
3126121.5000000000000000 10097052.0000000000000000,
3126183.3033988750539720 10097042.2113032583147287,
3126239.0570504586212337 10097013.8033988755196333,
3126283.3033988750539720 10096969.5570504590868950,
3126311.7113032592460513 10096913.8033988755196333,
3126321.5000000000000000 10096852.0000000000000000)),
((3125744.7929619303904474 10091953.4829814359545708,
3125689.2919652964919806 10091925.2038111798465252,
3125627.4885664214380085 10091915.4151144381612539,
3125565.6851675463840365 10091925.2038111798465252,
3125509.9315159628167748 10091953.6117155626416206,
3125465.6851675463840365 10091997.8580639790743589,
3125437.2772631621919572 10092053.6117155626416206,
3125427.4885664214380085 10092115.4151144381612539,
3125437.2772631621919572 10092177.2185133136808872,
3125465.6851675463840365 10092232.9721648972481489,
3125509.9315159628167748 10092277.2185133136808872,
3125565.6851675463840365 10092305.6264176964759827,
3125627.4885664214380085 10092315.4151144381612539,
3125689.2919652964919806 10092305.6264176964759827,
3125745.0456168800592422 10092277.2185133136808872,
3125789.2919652964919806 10092232.9721648972481489,
3125791.0153631931170821 10092229.5898060798645020,
3125846.5163598270155489 10092257.8689763359725475,
3125908.3197587020695210 10092267.6576730776578188,
3125970.1231575771234930 10092257.8689763359725475,
3126025.8768091606907547 10092229.4610719531774521,
3126070.1231575771234930 10092185.2147235367447138,
3126098.5310619613155723 10092129.4610719531774521,
3126108.3197587020695210 10092067.6576730776578188,
3126098.5310619613155723 10092005.8542742021381855,
3126070.1231575771234930 10091950.1006226185709238,
3126025.8768091606907547 10091905.8542742021381855,
3125970.1231575771234930 10091877.4463698193430901,
3125908.3197587020695210 10091867.6576730776578188,
3125846.5163598270155489 10091877.4463698193430901,
3125790.7627082434482872 10091905.8542742021381855,
3125746.5163598270155489 10091950.1006226185709238,
3125744.7929619303904474 10091953.4829814359545708)),
((3125978.5000000000000000 10091257.0000000000000000,
3125968.7113032592460513 10091195.1966011244803667,
3125940.3033988750539720 10091139.4429495409131050,
3125896.0570504586212337 10091095.1966011244803667,
3125840.3033988750539720 10091066.7886967416852713,
3125778.5000000000000000 10091057.0000000000000000,
3125716.6966011249460280 10091066.7886967416852713,
3125660.9429495413787663 10091095.1966011244803667,
3125616.6966011249460280 10091139.4429495409131050,
3125588.2886967407539487 10091195.1966011244803667,
3125578.5000000000000000 10091257.0000000000000000,
3125588.2886967407539487 10091318.8033988755196333,
3125616.6966011249460280 10091374.5570504590868950,
3125660.9429495413787663 10091418.8033988755196333,
3125716.6966011249460280 10091447.2113032583147287,
3125778.5000000000000000 10091457.0000000000000000,
3125840.3033988750539720 10091447.2113032583147287,
3125896.0570504586212337 10091418.8033988755196333,
3125940.3033988750539720 10091374.5570504590868950,
3125968.7113032592460513 10091318.8033988755196333,
3125978.5000000000000000 10091257.0000000000000000)),
((3125566.3644968769513071 10096010.9987329095602036,
3125569.1966011249460280 10096016.5570504590868950,
3125613.4429495413787663 10096060.8033988755196333,
3125669.1966011249460280 10096089.2113032583147287,
3125731.0000000000000000 10096099.0000000000000000,
3125792.8033988750539720 10096089.2113032583147287,
3125848.5570504586212337 10096060.8033988755196333,
3125892.8033988750539720 10096016.5570504590868950,
3125921.2113032592460513 10095960.8033988755196333,
3125931.0000000000000000 10095899.0000000000000000,
3125921.2113032592460513 10095837.1966011244803667,
3125892.8033988750539720 10095781.4429495409131050,
3125848.5570504586212337 10095737.1966011244803667,
3125792.8033988750539720 10095708.7886967416852713,
3125743.6355031230486929 10095701.0012670904397964,
3125740.8033988750539720 10095695.4429495409131050,
3125696.5570504586212337 10095651.1966011244803667,
3125640.8033988750539720 10095622.7886967416852713,
3125579.0000000000000000 10095613.0000000000000000,
3125517.1966011249460280 10095622.7886967416852713,
3125461.4429495413787663 10095651.1966011244803667,
3125417.1966011249460280 10095695.4429495409131050,
3125388.7886967407539487 10095751.1966011244803667,
3125379.0000000000000000 10095813.0000000000000000,
3125388.7886967407539487 10095874.8033988755196333,
3125417.1966011249460280 10095930.5570504590868950,
3125461.4429495413787663 10095974.8033988755196333,
3125517.1966011249460280 10096003.2113032583147287,
3125566.3644968769513071 10096010.9987329095602036)),
((3125759.2500000000000000 10078466.0000000000000000,
3125749.4613032592460513 10078404.1966011244803667,
3125721.0533988750539720 10078348.4429495409131050,
3125676.8070504586212337 10078304.1966011244803667,
3125621.0533988750539720 10078275.7886967416852713,
3125559.2500000000000000 10078266.0000000000000000,
3125497.4466011249460280 10078275.7886967416852713,
3125441.6929495413787663 10078304.1966011244803667,
3125397.4466011249460280 10078348.4429495409131050,
3125369.0386967407539487 10078404.1966011244803667,
3125359.2500000000000000 10078466.0000000000000000,
3125369.0386967407539487 10078527.8033988755196333,
3125397.4466011249460280 10078583.5570504590868950,
3125441.6929495413787663 10078627.8033988755196333,
3125497.4466011249460280 10078656.2113032583147287,
3125559.2500000000000000 10078666.0000000000000000,
3125621.0533988750539720 10078656.2113032583147287,
3125676.8070504586212337 10078627.8033988755196333,
3125721.0533988750539720 10078583.5570504590868950,
3125749.4613032592460513 10078527.8033988755196333,
3125759.2500000000000000 10078466.0000000000000000)),
((3124071.8329624687321484 10078708.1283756420016289,
3124023.6752885584719479 10078732.6659360863268375,
3123979.4289401420392096 10078776.9122845027595758,
3123951.0210357578471303 10078832.6659360863268375,
3123941.2323390170931816 10078894.4693349618464708,
3123951.0210357578471303 10078956.2727338373661041,
3123979.4289401420392096 10079012.0263854209333658,
3124023.6752885584719479 10079056.2727338373661041,
3124079.4289401420392096 10079084.6806382201611996,
3124141.2323390170931816 10079094.4693349618464708,
3124203.0357378921471536 10079084.6806382201611996,
3124258.7893894757144153 10079056.2727338373661041,
3124303.0357378921471536 10079012.0263854209333658,
3124331.4436422763392329 10078956.2727338373661041,
3124341.2323390170931816 10078894.4693349618464708,
3124339.2268648589961231 10078881.8072694595903158,
3124349.3033988750539720 10078880.2113032583147287,
3124405.0570504586212337 10078851.8033988755196333,
3124439.9393441416323185 10078816.9211051929742098,
3124444.0386967407539487 10078842.8033988755196333,
3124468.6687016207724810 10078891.1425052024424076,
3124449.7886967407539487 10078928.1966011244803667,
3124440.0000000000000000 10078990.0000000000000000,
3124449.7886967407539487 10079051.8033988755196333,
3124467.6943427752703428 10079086.9452078901231289,
3124465.1966011249460280 10079089.4429495409131050,
3124436.7886967407539487 10079145.1966011244803667,
3124427.0000000000000000 10079207.0000000000000000,
3124436.7886967407539487 10079268.8033988755196333,
3124465.1966011249460280 10079324.5570504590868950,
3124500.5145506658591330 10079359.8750000000000000,
3124478.9466011249460280 10079381.4429495409131050,
3124450.5386967407539487 10079437.1966011244803667,
3124441.2459202934987843 10079495.8688824959099293,
3124385.2500000000000000 10079487.0000000000000000,
3124323.4466011249460280 10079496.7886967416852713,
3124267.6929495413787663 10079525.1966011244803667,
3124223.4466011249460280 10079569.4429495409131050,
3124195.0386967407539487 10079625.1966011244803667,
3124188.7423885641619563 10079664.9499264117330313,
3124183.4466011249460280 10079665.7886967416852713,
3124127.6929495413787663 10079694.1966011244803667,
3124083.4466011249460280 10079738.4429495409131050,
3124055.0386967407539487 10079794.1966011244803667,
3124045.2500000000000000 10079856.0000000000000000,
3124055.0386967407539487 10079917.8033988755196333,
3124083.4466011249460280 10079973.5570504590868950,
3124127.6929495413787663 10080017.8033988755196333,
3124161.0051270406693220 10080034.7768010888248682,
3124146.4429495413787663 10080042.1966011244803667,
3124102.1966011249460280 10080086.4429495409131050,
3124073.7886967407539487 10080142.1966011244803667,
3124064.0000000000000000 10080204.0000000000000000,
3124073.7886967407539487 10080265.8033988755196333,
3124102.1966011249460280 10080321.5570504590868950,
3124107.7724122097715735 10080327.1328615434467793,
3124102.2500000000000000 10080362.0000000000000000,
3124112.0386967407539487 10080423.8033988755196333,
3124140.4466011249460280 10080479.5570504590868950,
3124184.6929495413787663 10080523.8033988755196333,
3124240.4466011249460280 10080552.2113032583147287,
3124302.2500000000000000 10080562.0000000000000000,
3124364.0533988750539720 10080552.2113032583147287,
3124419.8070504586212337 10080523.8033988755196333,
3124464.0533988750539720 10080479.5570504590868950,
3124492.4613032592460513 10080423.8033988755196333,
3124498.1353369075804949 10080387.9789603333920240,
3124512.6966011249460280 10080416.5570504590868950,
3124525.4904885729774833 10080429.3509379066526890,
3124517.9429495413787663 10080433.1966011244803667,
3124473.6966011249460280 10080477.4429495409131050,
3124445.2886967407539487 10080533.1966011244803667,
3124435.5000000000000000 10080595.0000000000000000,
3124445.2886967407539487 10080656.8033988755196333,
3124473.6966011249460280 10080712.5570504590868950,
3124517.9429495413787663 10080756.8033988755196333,
3124573.6966011249460280 10080785.2113032583147287,
3124635.5000000000000000 10080795.0000000000000000,
3124697.3033988750539720 10080785.2113032583147287,
3124753.0570504586212337 10080756.8033988755196333,
3124797.3033988750539720 10080712.5570504590868950,
3124825.7113032592460513 10080656.8033988755196333,
3124835.5000000000000000 10080595.0000000000000000,
3124825.7113032592460513 10080533.1966011244803667,
3124797.3033988750539720 10080477.4429495409131050,
3124784.5095114270225167 10080464.6490620933473110,
3124792.0570504586212337 10080460.8033988755196333,
3124836.3033988750539720 10080416.5570504590868950,
3124864.7113032592460513 10080360.8033988755196333,
3124874.5000000000000000 10080299.0000000000000000,
3124864.7113032592460513 10080237.1966011244803667,
3124836.3033988750539720 10080181.4429495409131050,
3124792.0570504586212337 10080137.1966011244803667,
3124736.3033988750539720 10080108.7886967416852713,
3124689.4252832117490470 10080101.3639326281845570,
3124690.7500000000000000 10080093.0000000000000000,
3124680.9613032592460513 10080031.1966011244803667,
3124657.6159091917797923 10079985.3786854725331068,
3124655.2113032592460513 10079970.1966011244803667,
3124626.8033988750539720 10079914.4429495409131050,
3124582.5570504586212337 10079870.1966011244803667,
3124526.8033988750539720 10079841.7886967416852713,
3124512.1436316240578890 10079839.4668177105486393,
3124547.0533988750539720 10079804.5570504590868950,
3124575.4613032592460513 10079748.8033988755196333,
3124575.5613403306342661 10079748.1717896647751331,
3124586.1929495413787663 10079758.8033988755196333,
3124641.9466011249460280 10079787.2113032583147287,
3124643.0024902792647481 10079787.3785396702587605,
3124650.0386967407539487 10079831.8033988755196333,
3124678.4466011249460280 10079887.5570504590868950,
3124679.4902380737476051 10079888.6006874088197947,
3124673.2500000000000000 10079928.0000000000000000,
3124683.0386967407539487 10079989.8033988755196333,
3124711.4466011249460280 10080045.5570504590868950,
3124755.6929495413787663 10080089.8033988755196333,
3124811.4466011249460280 10080118.2113032583147287,
3124873.2500000000000000 10080128.0000000000000000,
3124935.0533988750539720 10080118.2113032583147287,
3124990.8070504586212337 10080089.8033988755196333,
3125035.0533988750539720 10080045.5570504590868950,
3125063.4613032592460513 10079989.8033988755196333,
3125073.2500000000000000 10079928.0000000000000000,
3125063.4613032592460513 10079866.1966011244803667,
3125035.0533988750539720 10079810.4429495409131050,
3125034.0097619262523949 10079809.3993125911802053,
3125039.6633377000689507 10079773.7040399853140116,
3125061.0570504586212337 10079762.8033988755196333,
3125105.3033988750539720 10079718.5570504590868950,
3125133.7113032592460513 10079662.8033988755196333,
3125143.5000000000000000 10079601.0000000000000000,
3125133.7113032592460513 10079539.1966011244803667,
3125105.3033988750539720 10079483.4429495409131050,
3125101.8604493341408670 10079480.0000000000000000,
3125105.3033988750539720 10079476.5570504590868950,
3125133.7113032592460513 10079420.8033988755196333,
3125143.5000000000000000 10079359.0000000000000000,
3125133.7113032592460513 10079297.1966011244803667,
3125105.3033988750539720 10079241.4429495409131050,
3125089.7857000320218503 10079225.9252506978809834,
3125144.8033988750539720 10079217.2113032583147287,
3125200.5570504586212337 10079188.8033988755196333,
3125244.8033988750539720 10079144.5570504590868950,
3125273.2113032592460513 10079088.8033988755196333,
3125274.2774320123717189 10079082.0721268448978662,
3125314.0570504586212337 10079061.8033988755196333,
3125358.3033988750539720 10079017.5570504590868950,
3125377.5512208156287670 10078979.7810729108750820,
3125377.9466011249460280 10078980.5570504590868950,
3125422.1929495413787663 10079024.8033988755196333,
3125477.9466011249460280 10079053.2113032583147287,
3125539.7500000000000000 10079063.0000000000000000,
3125601.5533988750539720 10079053.2113032583147287,
3125657.3070504586212337 10079024.8033988755196333,
3125701.5533988750539720 10078980.5570504590868950,
3125729.9613032592460513 10078924.8033988755196333,
3125739.7500000000000000 10078863.0000000000000000,
3125729.9613032592460513 10078801.1966011244803667,
3125701.5533988750539720 10078745.4429495409131050,
3125657.3070504586212337 10078701.1966011244803667,
3125601.5533988750539720 10078672.7886967416852713,
3125539.7500000000000000 10078663.0000000000000000,
3125477.9466011249460280 10078672.7886967416852713,
3125422.1929495413787663 10078701.1966011244803667,
3125377.9466011249460280 10078745.4429495409131050,
3125358.6987791843712330 10078783.2189270891249180,
3125358.3033988750539720 10078782.4429495409131050,
3125314.0570504586212337 10078738.1966011244803667,
3125258.3033988750539720 10078709.7886967416852713,
3125196.5000000000000000 10078700.0000000000000000,
3125134.6966011249460280 10078709.7886967416852713,
3125078.9429495413787663 10078738.1966011244803667,
3125034.6966011249460280 10078782.4429495409131050,
3125006.2886967407539487 10078838.1966011244803667,
3125005.2225679876282811 10078844.9278731551021338,
3124965.4429495413787663 10078865.1966011244803667,
3124921.1966011249460280 10078909.4429495409131050,
3124892.7886967407539487 10078965.1966011244803667,
3124883.0000000000000000 10079027.0000000000000000,
3124892.7886967407539487 10079088.8033988755196333,
3124901.6142458040267229 10079106.1245141830295324,
3124869.5533988750539720 10079089.7886967416852713,
3124815.2399700493551791 10079081.1862947139889002,
3124830.2113032592460513 10079051.8033988755196333,
3124840.0000000000000000 10078990.0000000000000000,
3124830.2113032592460513 10078928.1966011244803667,
3124805.5812983792275190 10078879.8574947975575924,
3124824.4613032592460513 10078842.8033988755196333,
3124834.2500000000000000 10078781.0000000000000000,
3124824.4613032592460513 10078719.1966011244803667,
3124808.5944173969328403 10078688.0560842417180538,
3124821.4613032592460513 10078662.8033988755196333,
3124831.2500000000000000 10078601.0000000000000000,
3124821.4613032592460513 10078539.1966011244803667,
3124802.5210256380960345 10078502.0242132879793644,
3124850.0570504586212337 10078477.8033988755196333,
3124894.3033988750539720 10078433.5570504590868950,
3124922.7113032592460513 10078377.8033988755196333,
3124932.5000000000000000 10078316.0000000000000000,
3124922.7113032592460513 10078254.1966011244803667,
3124896.5967355137690902 10078202.9438761211931705,
3124895.2113032592460513 10078194.1966011244803667,
3124866.8033988750539720 10078138.4429495409131050,
3124822.5570504586212337 10078094.1966011244803667,
3124766.8033988750539720 10078065.7886967416852713,
3124705.0000000000000000 10078056.0000000000000000,
3124643.1966011249460280 10078065.7886967416852713,
3124620.0876814844086766 10078077.5632794089615345,
3124614.9613032592460513 10078045.1966011244803667,
3124586.5533988750539720 10077989.4429495409131050,
3124542.3070504586212337 10077945.1966011244803667,
3124486.5533988750539720 10077916.7886967416852713,
3124424.7500000000000000 10077907.0000000000000000,
3124362.9466011249460280 10077916.7886967416852713,
3124307.1929495413787663 10077945.1966011244803667,
3124262.9466011249460280 10077989.4429495409131050,
3124234.5386967407539487 10078045.1966011244803667,
3124224.7500000000000000 10078107.0000000000000000,
3124234.5386967407539487 10078168.8033988755196333,
3124262.9466011249460280 10078224.5570504590868950,
3124307.1929495413787663 10078268.8033988755196333,
3124342.6990427994169295 10078286.8946570008993149,
3124324.4429495413787663 10078296.1966011244803667,
3124280.1966011249460280 10078340.4429495409131050,
3124267.7436640341766179 10078364.8832146991044283,
3124267.0570504586212337 10078364.1966011244803667,
3124211.3033988750539720 10078335.7886967416852713,
3124149.5000000000000000 10078326.0000000000000000,
3124087.6966011249460280 10078335.7886967416852713,
3124031.9429495413787663 10078364.1966011244803667,
3123987.6966011249460280 10078408.4429495409131050,
3123959.2886967407539487 10078464.1966011244803667,
3123949.5000000000000000 10078526.0000000000000000,
3123959.2886967407539487 10078587.8033988755196333,
3123987.6966011249460280 10078643.5570504590868950,
3124031.9429495413787663 10078687.8033988755196333,
3124071.8329624687321484 10078708.1283756420016289)),
((3124013.1178170037455857 10095678.7717336621135473,
3123993.4466011249460280 10095698.4429495409131050,
3123965.0386967407539487 10095754.1966011244803667,
3123955.2500000000000000 10095816.0000000000000000,
3123965.0386967407539487 10095877.8033988755196333,
3123993.4466011249460280 10095933.5570504590868950,
3124037.6929495413787663 10095977.8033988755196333,
3124093.4466011249460280 10096006.2113032583147287,
3124104.0058298720978200 10096007.8837207946926355,
3124081.4466011249460280 10096030.4429495409131050,
3124053.0386967407539487 10096086.1966011244803667,
3124043.2500000000000000 10096148.0000000000000000,
3124053.0386967407539487 10096209.8033988755196333,
3124081.4466011249460280 10096265.5570504590868950,
3124125.6929495413787663 10096309.8033988755196333,
3124136.1749963792972267 10096315.1442685015499592,
3124139.2886967407539487 10096334.8033988755196333,
3124167.6966011249460280 10096390.5570504590868950,
3124211.9429495413787663 10096434.8033988755196333,
3124243.3902225340716541 10096450.8265847824513912,
3124249.6533728563226759 10096490.3705596160143614,
3124241.0000000000000000 10096489.0000000000000000,
3124179.1966011249460280 10096498.7886967416852713,
3124123.4429495413787663 10096527.1966011244803667,
3124079.1966011249460280 10096571.4429495409131050,
3124050.7886967407539487 10096627.1966011244803667,
3124041.0000000000000000 10096689.0000000000000000,
3124050.7886967407539487 10096750.8033988755196333,
3124079.1966011249460280 10096806.5570504590868950,
3124096.6571328979916871 10096824.0175822321325541,
3124091.7500000000000000 10096855.0000000000000000,
3124101.5386967407539487 10096916.8033988755196333,
3124129.9466011249460280 10096972.5570504590868950,
3124139.6001777141354978 10096982.2106270473450422,
3124139.0000000000000000 10096986.0000000000000000,
3124148.7886967407539487 10097047.8033988755196333,
3124177.1966011249460280 10097103.5570504590868950,
3124211.8944001379422843 10097138.2548494730144739,
3124207.5000000000000000 10097166.0000000000000000,
3124210.2878374899737537 10097183.6017131749540567,
3124185.4466011249460280 10097208.4429495409131050,
3124157.0386967407539487 10097264.1966011244803667,
3124149.1029839655384421 10097314.3007196802645922,
3124115.9429495413787663 10097331.1966011244803667,
3124071.6966011249460280 10097375.4429495409131050,
3124043.2886967407539487 10097431.1966011244803667,
3124033.5000000000000000 10097493.0000000000000000,
3124043.2886967407539487 10097554.8033988755196333,
3124071.6966011249460280 10097610.5570504590868950,
3124115.9429495413787663 10097654.8033988755196333,
3124171.6966011249460280 10097683.2113032583147287,
3124204.3083638576790690 10097688.3764990475028753,
3124200.2500000000000000 10097714.0000000000000000,
3124207.5840679616667330 10097760.3054827041924000,
3124199.4466011249460280 10097768.4429495409131050,
3124171.0386967407539487 10097824.1966011244803667,
3124161.2500000000000000 10097886.0000000000000000,
3124166.5331369219347835 10097919.3564137443900108,
3124125.4466011249460280 10097960.4429495409131050,
3124097.0386967407539487 10098016.1966011244803667,
3124087.2500000000000000 10098078.0000000000000000,
3124093.2509627859108150 10098115.8885878808796406,
3124080.6966011249460280 10098128.4429495409131050,
3124052.2886967407539487 10098184.1966011244803667,
3124042.5000000000000000 10098246.0000000000000000,
3124052.2886967407539487 10098307.8033988755196333,
3124080.6966011249460280 10098363.5570504590868950,
3124124.9429495413787663 10098407.8033988755196333,
3124180.6966011249460280 10098436.2113032583147287,
3124242.5000000000000000 10098446.0000000000000000,
3124304.3033988750539720 10098436.2113032583147287,
3124360.0570504586212337 10098407.8033988755196333,
3124404.3033988750539720 10098363.5570504590868950,
3124432.7113032592460513 10098307.8033988755196333,
3124442.5000000000000000 10098246.0000000000000000,
3124436.4990372140891850 10098208.1114121191203594,
3124449.0533988750539720 10098195.5570504590868950,
3124477.4613032592460513 10098139.8033988755196333,
3124484.1157186529599130 10098097.7890736013650894,
3124524.1966011249460280 10098118.2113032583147287,
3124586.0000000000000000 10098128.0000000000000000,
3124647.8033988750539720 10098118.2113032583147287,
3124703.5570504586212337 10098089.8033988755196333,
3124720.0000000000000000 10098073.3604493346065283,
3124740.5703653772361577 10098093.9308147113770247,
3124743.9466011249460280 10098100.5570504590868950,
3124788.1929495413787663 10098144.8033988755196333,
3124843.9466011249460280 10098173.2113032583147287,
3124905.7500000000000000 10098183.0000000000000000,
3124967.5533988750539720 10098173.2113032583147287,
3125023.3070504586212337 10098144.8033988755196333,
3125067.5533988750539720 10098100.5570504590868950,
3125095.9613032592460513 10098044.8033988755196333,
3125105.7500000000000000 10097983.0000000000000000,
3125095.9613032592460513 10097921.1966011244803667,
3125067.5533988750539720 10097865.4429495409131050,
3125033.1796346227638423 10097831.0691852886229753,
3125029.8033988750539720 10097824.4429495409131050,
3124985.5570504586212337 10097780.1966011244803667,
3124929.8033988750539720 10097751.7886967416852713,
3124868.0000000000000000 10097742.0000000000000000,
3124806.1966011249460280 10097751.7886967416852713,
3124750.4429495413787663 10097780.1966011244803667,
3124734.0000000000000000 10097796.6395506653934717,
3124703.5570504586212337 10097766.1966011244803667,
3124647.8033988750539720 10097737.7886967416852713,
3124597.7381587182171643 10097729.8591416999697685,
3124600.2500000000000000 10097714.0000000000000000,
3124590.4613032592460513 10097652.1966011244803667,
3124562.0533988750539720 10097596.4429495409131050,
3124547.7272145696915686 10097582.1167652364820242,
3124597.5000000000000000 10097590.0000000000000000,
3124659.3033988750539720 10097580.2113032583147287,
3124715.0570504586212337 10097551.8033988755196333,
3124759.3033988750539720 10097507.5570504590868950,
3124782.3345598890446126 10097462.3558518998324871,
3124782.9466011249460280 10097463.5570504590868950,
3124827.1929495413787663 10097507.8033988755196333,
3124882.9466011249460280 10097536.2113032583147287,
3124944.7500000000000000 10097546.0000000000000000,
3125006.5533988750539720 10097536.2113032583147287,
3125062.3070504586212337 10097507.8033988755196333,
3125106.5533988750539720 10097463.5570504590868950,
3125121.6602533929981291 10097433.9081790763884783,
3125172.7500000000000000 10097442.0000000000000000,
3125234.5533988750539720 10097432.2113032583147287,
3125236.2409855602309108 10097431.3514348939061165,
3125278.6929495413787663 10097473.8033988755196333,
3125334.4466011249460280 10097502.2113032583147287,
3125396.2500000000000000 10097512.0000000000000000,
3125458.0533988750539720 10097502.2113032583147287,
3125513.8070504586212337 10097473.8033988755196333,
3125516.5601922431960702 10097471.0502570904791355,
3125566.0533988750539720 10097463.2113032583147287,
3125621.8070504586212337 10097434.8033988755196333,
3125666.0533988750539720 10097390.5570504590868950,
3125694.4613032592460513 10097334.8033988755196333,
3125704.2500000000000000 10097273.0000000000000000,
3125694.4613032592460513 10097211.1966011244803667,
3125666.0533988750539720 10097155.4429495409131050,
3125621.8070504586212337 10097111.1966011244803667,
3125566.0533988750539720 10097082.7886967416852713,
3125504.2500000000000000 10097073.0000000000000000,
3125442.4466011249460280 10097082.7886967416852713,
3125386.6929495413787663 10097111.1966011244803667,
3125383.9398077568039298 10097113.9497429095208645,
3125351.5270261508412659 10097119.0834231842309237,
3125389.0533988750539720 10097081.5570504590868950,
3125417.4613032592460513 10097025.8033988755196333,
3125427.2500000000000000 10096964.0000000000000000,
3125417.4613032592460513 10096902.1966011244803667,
3125389.0533988750539720 10096846.4429495409131050,
3125344.8070504586212337 10096802.1966011244803667,
3125289.0533988750539720 10096773.7886967416852713,
3125287.2333753742277622 10096773.5004333388060331,
3125285.8803252591751516 10096764.9576111249625683,
3125257.4724208749830723 10096709.2039595413953066,
3125213.2260724585503340 10096664.9576111249625683,
3125177.0734959859400988 10096646.5369533486664295,
3125198.0533988750539720 10096625.5570504590868950,
3125226.4613032592460513 10096569.8033988755196333,
3125236.2500000000000000 10096508.0000000000000000,
3125226.4613032592460513 10096446.1966011244803667,
3125198.0533988750539720 10096390.4429495409131050,
3125153.8070504586212337 10096346.1966011244803667,
3125098.0533988750539720 10096317.7886967416852713,
3125036.2500000000000000 10096308.0000000000000000,
3124974.4466011249460280 10096317.7886967416852713,
3124918.6929495413787663 10096346.1966011244803667,
3124915.2500000000000000 10096349.6395506653934717,
3124883.8070504586212337 10096318.1966011244803667,
3124828.0533988750539720 10096289.7886967416852713,
3124766.2500000000000000 10096280.0000000000000000,
3124735.1957758292555809 10096284.9185059145092964,
3124713.5533988750539720 10096242.4429495409131050,
3124669.3070504586212337 10096198.1966011244803667,
3124613.5533988750539720 10096169.7886967416852713,
3124578.0070611163973808 10096164.1587099302560091,
3124625.8070504586212337 10096139.8033988755196333,
3124670.0533988750539720 10096095.5570504590868950,
3124698.4613032592460513 10096039.8033988755196333,
3124708.2500000000000000 10095978.0000000000000000,
3124698.4613032592460513 10095916.1966011244803667,
3124670.0533988750539720 10095860.4429495409131050,
3124625.8070504586212337 10095816.1966011244803667,
3124570.0533988750539720 10095787.7886967416852713,
3124520.8909587552770972 10095780.0021311771124601,
3124532.7113032592460513 10095756.8033988755196333,
3124542.5000000000000000 10095695.0000000000000000,
3124532.7113032592460513 10095633.1966011244803667,
3124526.1132523128762841 10095620.2471970207989216,
3124532.4743882860057056 10095613.8860610481351614,
3124568.3033988750539720 10095608.2113032583147287,
3124624.0570504586212337 10095579.8033988755196333,
3124668.3033988750539720 10095535.5570504590868950,
3124696.7113032592460513 10095479.8033988755196333,
3124706.5000000000000000 10095418.0000000000000000,
3124696.7113032592460513 10095356.1966011244803667,
3124668.3033988750539720 10095300.4429495409131050,
3124660.9299883740022779 10095293.0695390403270721,
3124663.0000000000000000 10095280.0000000000000000,
3124653.2113032592460513 10095218.1966011244803667,
3124624.8033988750539720 10095162.4429495409131050,
3124585.8307138555683196 10095123.4702645204961300,
3124615.9605916342698038 10095093.3403867427259684,
3124644.3684960184618831 10095037.5867351591587067,
3124654.1571927592158318 10094975.7833362836390734,
3124644.3684960184618831 10094913.9799374081194401,
3124615.9605916342698038 10094858.2262858245521784,
3124610.7714207405224442 10094853.0371149312704802,
3124604.4613032592460513 10094813.1966011244803667,
3124576.0533988750539720 10094757.4429495409131050,
3124531.8070504586212337 10094713.1966011244803667,
3124517.5596424136310816 10094705.9371841363608837,
3124518.5000000000000000 10094700.0000000000000000,
3124508.7113032592460513 10094638.1966011244803667,
3124493.2528233258053660 10094607.8576260078698397,
3124524.5533988750539720 10094576.5570504590868950,
3124552.9613032592460513 10094520.8033988755196333,
3124562.7500000000000000 10094459.0000000000000000,
3124552.9613032592460513 10094397.1966011244803667,
3124524.5533988750539720 10094341.4429495409131050,
3124480.3070504586212337 10094297.1966011244803667,
3124438.3976174718700349 10094275.8426784444600344,
3124445.5000000000000000 10094231.0000000000000000,
3124435.7113032592460513 10094169.1966011244803667,
3124418.3042908716015518 10094135.0334157422184944,
3124442.3070504586212337 10094122.8033988755196333,
3124486.5533988750539720 10094078.5570504590868950,
3124514.9613032592460513 10094022.8033988755196333,
3124524.7500000000000000 10093961.0000000000000000,
3124514.9613032592460513 10093899.1966011244803667,
3124486.5533988750539720 10093843.4429495409131050,
3124442.3070504586212337 10093799.1966011244803667,
3124386.5533988750539720 10093770.7886967416852713,
3124324.7500000000000000 10093761.0000000000000000,
3124262.9466011249460280 10093770.7886967416852713,
3124207.1929495413787663 10093799.1966011244803667,
3124162.9466011249460280 10093843.4429495409131050,
3124134.5386967407539487 10093899.1966011244803667,
3124124.7500000000000000 10093961.0000000000000000,
3124134.5386967407539487 10094022.8033988755196333,
3124151.9457091283984482 10094056.9665842577815056,
3124127.9429495413787663 10094069.1966011244803667,
3124083.6966011249460280 10094113.4429495409131050,
3124055.2886967407539487 10094169.1966011244803667,
3124054.3103532395325601 10094175.3736188858747482,
3124013.4429495413787663 10094196.1966011244803667,
3123969.1966011249460280 10094240.4429495409131050,
3123940.7886967407539487 10094296.1966011244803667,
3123931.0000000000000000 10094358.0000000000000000,
3123940.7886967407539487 10094419.8033988755196333,
3123969.1966011249460280 10094475.5570504590868950,
3124013.4429495413787663 10094519.8033988755196333,
3124063.0710913171060383 10094545.0902001205831766,
3124056.7500000000000000 10094585.0000000000000000,
3124066.5386967407539487 10094646.8033988755196333,
3124094.9466011249460280 10094702.5570504590868950,
3124123.4137505320832133 10094731.0241998657584190,
3124128.2886967407539487 10094761.8033988755196333,
3124156.6966011249460280 10094817.5570504590868950,
3124200.9429495413787663 10094861.8033988755196333,
3124215.1903575863689184 10094869.0628158636391163,
3124214.2500000000000000 10094875.0000000000000000,
3124215.5673367218114436 10094883.3173367213457823,
3124207.2500000000000000 10094882.0000000000000000,
3124145.4466011249460280 10094891.7886967416852713,
3124089.6929495413787663 10094920.1966011244803667,
3124045.4466011249460280 10094964.4429495409131050,
3124017.0386967407539487 10095020.1966011244803667,
3124007.2500000000000000 10095082.0000000000000000,
3124017.0386967407539487 10095143.8033988755196333,
3124045.4466011249460280 10095199.5570504590868950,
3124089.6929495413787663 10095243.8033988755196333,
3124145.4466011249460280 10095272.2113032583147287,
3124161.3852384644560516 10095274.7357354126870632,
3124169.4466011249460280 10095290.5570504590868950,
3124213.6929495413787663 10095334.8033988755196333,
3124239.6237493585795164 10095348.0158013068139553,
3124211.1966011249460280 10095376.4429495409131050,
3124195.3967460868880153 10095407.4519110247492790,
3124136.4466011249460280 10095416.7886967416852713,
3124080.6929495413787663 10095445.1966011244803667,
3124036.4466011249460280 10095489.4429495409131050,
3124008.0386967407539487 10095545.1966011244803667,
3123998.2500000000000000 10095607.0000000000000000,
3124008.0386967407539487 10095668.8033988755196333,
3124013.1178170037455857 10095678.7717336621135473),
(3124530.6842556223273277 10096933.4964563362300396,
3124564.0533988750539720 10096928.2113032583147287,
3124619.8070504586212337 10096899.8033988755196333,
3124664.0533988750539720 10096855.5570504590868950,
3124692.4613032592460513 10096799.8033988755196333,
3124702.2500000000000000 10096738.0000000000000000,
3124692.4613032592460513 10096676.1966011244803667,
3124684.1396209886297584 10096659.8643800765275955,
3124704.4466011249460280 10096670.2113032583147287,
3124766.2500000000000000 10096680.0000000000000000,
3124828.0533988750539720 10096670.2113032583147287,
3124883.8070504586212337 10096641.8033988755196333,
3124887.2500000000000000 10096638.3604493346065283,
3124918.6929495413787663 10096669.8033988755196333,
3124954.8455260139890015 10096688.2240566518157721,
3124947.3668481241911650 10096695.7027345411479473,
3124934.1966011249460280 10096697.7886967416852713,
3124878.4429495413787663 10096726.1966011244803667,
3124834.1966011249460280 10096770.4429495409131050,
3124805.7886967407539487 10096826.1966011244803667,
3124796.0000000000000000 10096888.0000000000000000,
3124805.7886967407539487 10096949.8033988755196333,
3124805.8235894739627838 10096949.8718797191977501,
3124768.7500000000000000 10096944.0000000000000000,
3124706.9466011249460280 10096953.7886967416852713,
3124651.1929495413787663 10096982.1966011244803667,
3124606.9466011249460280 10097026.4429495409131050,
3124582.5202200557105243 10097074.3824216388165951,
3124569.3033988750539720 10097048.4429495409131050,
3124534.6055998620577157 10097013.7451505269855261,
3124539.0000000000000000 10096986.0000000000000000,
3124530.6842556223273277 10096933.4964563362300396),
(3124433.7059594723396003 10097503.6501962393522263,
3124435.6966011249460280 10097507.5570504590868950,
3124450.0227854298427701 10097521.8832347635179758,
3124429.4416361427865922 10097518.6235009524971247,
3124431.6470160344615579 10097504.6992803197354078,
3124433.7059594723396003 10097503.6501962393522263)),
((3125670.0000000000000000 10096475.0000000000000000,
3125660.2113032592460513 10096413.1966011244803667,
3125631.8033988750539720 10096357.4429495409131050,
3125587.5570504586212337 10096313.1966011244803667,
3125531.8033988750539720 10096284.7886967416852713,
3125470.0000000000000000 10096275.0000000000000000,
3125408.1966011249460280 10096284.7886967416852713,
3125352.4429495413787663 10096313.1966011244803667,
3125308.1966011249460280 10096357.4429495409131050,
3125279.7886967407539487 10096413.1966011244803667,
3125270.0000000000000000 10096475.0000000000000000,
3125279.7886967407539487 10096536.8033988755196333,
3125308.1966011249460280 10096592.5570504590868950,
3125352.4429495413787663 10096636.8033988755196333,
3125408.1966011249460280 10096665.2113032583147287,
3125470.0000000000000000 10096675.0000000000000000,
3125531.8033988750539720 10096665.2113032583147287,
3125587.5570504586212337 10096636.8033988755196333,
3125631.8033988750539720 10096592.5570504590868950,
3125660.2113032592460513 10096536.8033988755196333,
3125670.0000000000000000 10096475.0000000000000000)),
((3125458.0000000000000000 10098506.0000000000000000,
3125448.2113032592460513 10098444.1966011244803667,
3125419.8033988750539720 10098388.4429495409131050,
3125375.5570504586212337 10098344.1966011244803667,
3125319.8033988750539720 10098315.7886967416852713,
3125258.0000000000000000 10098306.0000000000000000,
3125196.1966011249460280 10098315.7886967416852713,
3125140.4429495413787663 10098344.1966011244803667,
3125096.1966011249460280 10098388.4429495409131050,
3125067.7886967407539487 10098444.1966011244803667,
3125058.0000000000000000 10098506.0000000000000000,
3125067.7886967407539487 10098567.8033988755196333,
3125096.1966011249460280 10098623.5570504590868950,
3125140.4429495413787663 10098667.8033988755196333,
3125196.1966011249460280 10098696.2113032583147287,
3125258.0000000000000000 10098706.0000000000000000,
3125319.8033988750539720 10098696.2113032583147287,
3125375.5570504586212337 10098667.8033988755196333,
3125419.8033988750539720 10098623.5570504590868950,
3125448.2113032592460513 10098567.8033988755196333,
3125458.0000000000000000 10098506.0000000000000000)),
((3125404.7500000000000000 10080865.0000000000000000,
3125394.9613032592460513 10080803.1966011244803667,
3125366.5533988750539720 10080747.4429495409131050,
3125322.3070504586212337 10080703.1966011244803667,
3125266.5533988750539720 10080674.7886967416852713,
3125204.7500000000000000 10080665.0000000000000000,
3125142.9466011249460280 10080674.7886967416852713,
3125087.1929495413787663 10080703.1966011244803667,
3125042.9466011249460280 10080747.4429495409131050,
3125014.5386967407539487 10080803.1966011244803667,
3125004.7500000000000000 10080865.0000000000000000,
3125014.5386967407539487 10080926.8033988755196333,
3125042.9466011249460280 10080982.5570504590868950,
3125087.1929495413787663 10081026.8033988755196333,
3125142.9466011249460280 10081055.2113032583147287,
3125204.7500000000000000 10081065.0000000000000000,
3125266.5533988750539720 10081055.2113032583147287,
3125322.3070504586212337 10081026.8033988755196333,
3125366.5533988750539720 10080982.5570504590868950,
3125394.9613032592460513 10080926.8033988755196333,
3125404.7500000000000000 10080865.0000000000000000)),
((3124854.5201781522482634 10082086.3050167448818684,
3124877.4575720387510955 10082097.9922026749700308,
3124939.2609709138050675 10082107.7808994166553020,
3125001.0643697888590395 10082097.9922026749700308,
3125056.8180213724263012 10082069.5842982921749353,
3125101.0643697888590395 10082025.3379498757421970,
3125129.4722741730511189 10081969.5842982921749353,
3125139.2609709138050675 10081907.7808994166553020,
3125129.4722741730511189 10081845.9775005411356688,
3125101.0643697888590395 10081790.2238489575684071,
3125056.8180213724263012 10081745.9775005411356688,
3125001.0643697888590395 10081717.5695961583405733,
3124939.2609709138050675 10081707.7808994166553020,
3124877.4575720387510955 10081717.5695961583405733,
3124863.0956920166499913 10081724.8873395323753357,
3124840.1582981301471591 10081713.2001536022871733,
3124778.3548992550931871 10081703.4114568606019020,
3124716.5515003800392151 10081713.2001536022871733,
3124660.7978487964719534 10081741.6080579850822687,
3124616.5515003800392151 10081785.8544064015150070,
3124588.1435959958471358 10081841.6080579850822687,
3124578.3548992550931871 10081903.4114568606019020,
3124588.1435959958471358 10081965.2148557361215353,
3124616.5515003800392151 10082020.9685073196887970,
3124660.7978487964719534 10082065.2148557361215353,
3124716.5515003800392151 10082093.6227601189166307,
3124778.3548992550931871 10082103.4114568606019020,
3124840.1582981301471591 10082093.6227601189166307,
3124854.5201781522482634 10082086.3050167448818684)),
((3125086.7500000000000000 10089263.0000000000000000,
3125076.9613032592460513 10089201.1966011244803667,
3125048.5533988750539720 10089145.4429495409131050,
3125004.3070504586212337 10089101.1966011244803667,
3124948.5533988750539720 10089072.7886967416852713,
3124886.7500000000000000 10089063.0000000000000000,
3124824.9466011249460280 10089072.7886967416852713,
3124769.1929495413787663 10089101.1966011244803667,
3124724.9466011249460280 10089145.4429495409131050,
3124696.5386967407539487 10089201.1966011244803667,
3124686.7500000000000000 10089263.0000000000000000,
3124696.5386967407539487 10089324.8033988755196333,
3124724.9466011249460280 10089380.5570504590868950,
3124769.1929495413787663 10089424.8033988755196333,
3124824.9466011249460280 10089453.2113032583147287,
3124886.7500000000000000 10089463.0000000000000000,
3124948.5533988750539720 10089453.2113032583147287,
3125004.3070504586212337 10089424.8033988755196333,
3125048.5533988750539720 10089380.5570504590868950,
3125076.9613032592460513 10089324.8033988755196333,
3125086.7500000000000000 10089263.0000000000000000)),
((3124065.0145506658591330 10087338.8750000000000000,
3124030.4466011249460280 10087373.4429495409131050,
3124002.0386967407539487 10087429.1966011244803667,
3123992.2500000000000000 10087491.0000000000000000,
3124002.0386967407539487 10087552.8033988755196333,
3124030.4466011249460280 10087608.5570504590868950,
3124074.6929495413787663 10087652.8033988755196333,
3124130.4466011249460280 10087681.2113032583147287,
3124192.2500000000000000 10087691.0000000000000000,
3124215.2471585753373802 10087687.3576079104095697,
3124241.4174564681015909 10087713.5279058031737804,
3124249.5386967407539487 10087764.8033988755196333,
3124261.6217751554213464 10087788.5177755113691092,
3124240.6966011249460280 10087809.4429495409131050,
3124212.2886967407539487 10087865.1966011244803667,
3124202.5000000000000000 10087927.0000000000000000,
3124212.2886967407539487 10087988.8033988755196333,
3124240.6966011249460280 10088044.5570504590868950,
3124284.9429495413787663 10088088.8033988755196333,
3124320.7970870481804013 10088107.0719944033771753,
3124323.2886967407539487 10088122.8033988755196333,
3124351.6966011249460280 10088178.5570504590868950,
3124395.9429495413787663 10088222.8033988755196333,
3124451.6966011249460280 10088251.2113032583147287,
3124456.8729916857555509 10088252.0311629809439182,
3124456.7886967407539487 10088252.1966011244803667,
3124450.1406735377386212 10088294.1705676913261414,
3124442.7500000000000000 10088293.0000000000000000,
3124380.9466011249460280 10088302.7886967416852713,
3124325.1929495413787663 10088331.1966011244803667,
3124280.9466011249460280 10088375.4429495409131050,
3124252.5386967407539487 10088431.1966011244803667,
3124242.7500000000000000 10088493.0000000000000000,
3124244.8112476789392531 10088506.0142056550830603,
3124195.3033988750539720 10088480.7886967416852713,
3124133.5000000000000000 10088471.0000000000000000,
3124071.6966011249460280 10088480.7886967416852713,
3124015.9429495413787663 10088509.1966011244803667,
3123971.6966011249460280 10088553.4429495409131050,
3123943.2886967407539487 10088609.1966011244803667,
3123933.5000000000000000 10088671.0000000000000000,
3123943.2886967407539487 10088732.8033988755196333,
3123971.6966011249460280 10088788.5570504590868950,
3124015.9429495413787663 10088832.8033988755196333,
3124071.6966011249460280 10088861.2113032583147287,
3124082.0095563000068069 10088862.8447148911654949,
3124089.2886967407539487 10088908.8033988755196333,
3124117.6966011249460280 10088964.5570504590868950,
3124161.9429495413787663 10089008.8033988755196333,
3124217.6966011249460280 10089037.2113032583147287,
3124279.5000000000000000 10089047.0000000000000000,
3124341.3033988750539720 10089037.2113032583147287,
3124397.0570504586212337 10089008.8033988755196333,
3124441.3033988750539720 10088964.5570504590868950,
3124462.0310120303183794 10088923.8768191263079643,
3124481.7500000000000000 10088927.0000000000000000,
3124543.5533988750539720 10088917.2113032583147287,
3124599.3070504586212337 10088888.8033988755196333,
3124643.5533988750539720 10088844.5570504590868950,
3124671.9613032592460513 10088788.8033988755196333,
3124681.7500000000000000 10088727.0000000000000000,
3124681.6283728620037436 10088726.2320764716714621,
3124708.3033988750539720 10088699.5570504590868950,
3124736.7113032592460513 10088643.8033988755196333,
3124746.5000000000000000 10088582.0000000000000000,
3124736.7113032592460513 10088520.1966011244803667,
3124724.4930895599536598 10088496.2170065604150295,
3124764.5570504586212337 10088475.8033988755196333,
3124808.8033988750539720 10088431.5570504590868950,
3124837.2113032592460513 10088375.8033988755196333,
3124847.0000000000000000 10088314.0000000000000000,
3124837.2113032592460513 10088252.1966011244803667,
3124808.8033988750539720 10088196.4429495409131050,
3124764.5570504586212337 10088152.1966011244803667,
3124708.8033988750539720 10088123.7886967416852713,
3124703.6270083142444491 10088122.9688370190560818,
3124703.7113032592460513 10088122.8033988755196333,
3124713.5000000000000000 10088061.0000000000000000,
3124703.7113032592460513 10087999.1966011244803667,
3124675.3033988750539720 10087943.4429495409131050,
3124655.8604493341408670 10087924.0000000000000000,
3124683.3033988750539720 10087896.5570504590868950,
3124711.7113032592460513 10087840.8033988755196333,
3124721.5000000000000000 10087779.0000000000000000,
3124711.7113032592460513 10087717.1966011244803667,
3124683.3033988750539720 10087661.4429495409131050,
3124639.0570504586212337 10087617.1966011244803667,
3124610.2552891056984663 10087602.5213707257062197,
3124601.5533988750539720 10087585.4429495409131050,
3124574.5825435318984091 10087558.4720941968262196,
3124566.4613032592460513 10087507.1966011244803667,
3124538.0533988750539720 10087451.4429495409131050,
3124493.8070504586212337 10087407.1966011244803667,
3124486.3300345353782177 10087403.3868712261319160,
3124487.5000000000000000 10087396.0000000000000000,
3124477.7113032592460513 10087334.1966011244803667,
3124449.3033988750539720 10087278.4429495409131050,
3124405.0570504586212337 10087234.1966011244803667,
3124377.9456330905668437 10087220.3826440032571554,
3124384.5000000000000000 10087179.0000000000000000,
3124374.7113032592460513 10087117.1966011244803667,
3124346.3033988750539720 10087061.4429495409131050,
3124302.0570504586212337 10087017.1966011244803667,
3124246.3033988750539720 10086988.7886967416852713,
3124184.5000000000000000 10086979.0000000000000000,
3124122.6966011249460280 10086988.7886967416852713,
3124066.9429495413787663 10087017.1966011244803667,
3124022.6966011249460280 10087061.4429495409131050,
3123994.2886967407539487 10087117.1966011244803667,
3123984.5000000000000000 10087179.0000000000000000,
3123994.2886967407539487 10087240.8033988755196333,
3124022.6966011249460280 10087296.5570504590868950,
3124065.0145506658591330 10087338.8750000000000000)),
((3124392.9423482501879334 10091032.7952412497252226,
3124373.3033988750539720 10091022.7886967416852713,
3124311.5000000000000000 10091013.0000000000000000,
3124249.6966011249460280 10091022.7886967416852713,
3124193.9429495413787663 10091051.1966011244803667,
3124149.6966011249460280 10091095.4429495409131050,
3124121.2886967407539487 10091151.1966011244803667,
3124111.5000000000000000 10091213.0000000000000000,
3124121.2886967407539487 10091274.8033988755196333,
3124149.6966011249460280 10091330.5570504590868950,
3124193.9429495413787663 10091374.8033988755196333,
3124249.6966011249460280 10091403.2113032583147287,
3124311.5000000000000000 10091413.0000000000000000,
3124373.3033988750539720 10091403.2113032583147287,
3124429.0570504586212337 10091374.8033988755196333,
3124473.3033988750539720 10091330.5570504590868950,
3124501.7113032592460513 10091274.8033988755196333,
3124506.5576517498120666 10091244.2047587502747774,
3124526.1966011249460280 10091254.2113032583147287,
3124588.0000000000000000 10091264.0000000000000000,
3124649.8033988750539720 10091254.2113032583147287,
3124705.5570504586212337 10091225.8033988755196333,
3124749.8033988750539720 10091181.5570504590868950,
3124778.2113032592460513 10091125.8033988755196333,
3124788.0000000000000000 10091064.0000000000000000,
3124778.2113032592460513 10091002.1966011244803667,
3124749.8033988750539720 10090946.4429495409131050,
3124705.5570504586212337 10090902.1966011244803667,
3124649.8033988750539720 10090873.7886967416852713,
3124588.0000000000000000 10090864.0000000000000000,
3124526.1966011249460280 10090873.7886967416852713,
3124470.4429495413787663 10090902.1966011244803667,
3124426.1966011249460280 10090946.4429495409131050,
3124397.7886967407539487 10091002.1966011244803667,
3124392.9423482501879334 10091032.7952412497252226)),
((3124772.5000000000000000 10085970.0000000000000000,
3124762.7113032592460513 10085908.1966011244803667,
3124734.3033988750539720 10085852.4429495409131050,
3124690.0570504586212337 10085808.1966011244803667,
3124634.3033988750539720 10085779.7886967416852713,
3124572.5000000000000000 10085770.0000000000000000,
3124510.6966011249460280 10085779.7886967416852713,
3124454.9429495413787663 10085808.1966011244803667,
3124410.6966011249460280 10085852.4429495409131050,
3124382.2886967407539487 10085908.1966011244803667,
3124372.5000000000000000 10085970.0000000000000000,
3124382.2886967407539487 10086031.8033988755196333,
3124410.6966011249460280 10086087.5570504590868950,
3124454.9429495413787663 10086131.8033988755196333,
3124510.6966011249460280 10086160.2113032583147287,
3124572.5000000000000000 10086170.0000000000000000,
3124634.3033988750539720 10086160.2113032583147287,
3124690.0570504586212337 10086131.8033988755196333,
3124734.3033988750539720 10086087.5570504590868950,
3124762.7113032592460513 10086031.8033988755196333,
3124772.5000000000000000 10085970.0000000000000000)),
((3124606.6243613059632480 10086827.8653797619044781,
3124596.8356645652092993 10086766.0619808863848448,
3124568.4277601810172200 10086710.3083293028175831,
3124524.1814117645844817 10086666.0619808863848448,
3124468.4277601810172200 10086637.6540765035897493,
3124406.6243613059632480 10086627.8653797619044781,
3124344.8209624309092760 10086637.6540765035897493,
3124289.0673108473420143 10086666.0619808863848448,
3124244.8209624309092760 10086710.3083293028175831,
3124216.4130580467171967 10086766.0619808863848448,
3124206.6243613059632480 10086827.8653797619044781,
3124216.4130580467171967 10086889.6687786374241114,
3124244.8209624309092760 10086945.4224302209913731,
3124289.0673108473420143 10086989.6687786374241114,
3124344.8209624309092760 10087018.0766830202192068,
3124406.6243613059632480 10087027.8653797619044781,
3124468.4277601810172200 10087018.0766830202192068,
3124524.1814117645844817 10086989.6687786374241114,
3124568.4277601810172200 10086945.4224302209913731,
3124596.8356645652092993 10086889.6687786374241114,
3124606.6243613059632480 10086827.8653797619044781)),
((3124539.4284850610420108 10092394.7599573582410812,
3124529.6397883202880621 10092332.9565584827214479,
3124501.2318839360959828 10092277.2029068991541862,
3124456.9855355196632445 10092232.9565584827214479,
3124401.2318839360959828 10092204.5486540999263525,
3124339.4284850610420108 10092194.7599573582410812,
3124277.6250861859880388 10092204.5486540999263525,
3124221.8714346024207771 10092232.9565584827214479,
3124177.6250861859880388 10092277.2029068991541862,
3124149.2171818017959595 10092332.9565584827214479,
3124139.4284850610420108 10092394.7599573582410812,
3124149.2171818017959595 10092456.5633562337607145,
3124177.6250861859880388 10092512.3170078173279762,
3124221.8714346024207771 10092556.5633562337607145,
3124277.6250861859880388 10092584.9712606165558100,
3124339.4284850610420108 10092594.7599573582410812,
3124401.2318839360959828 10092584.9712606165558100,
3124456.9855355196632445 10092556.5633562337607145,
3124501.2318839360959828 10092512.3170078173279762,
3124529.6397883202880621 10092456.5633562337607145,
3124539.4284850610420108 10092394.7599573582410812)),
((3124115.0631883610039949 10089998.9897972401231527,
3124092.5386967407539487 10090043.1966011244803667,
3124082.7500000000000000 10090105.0000000000000000,
3124092.5386967407539487 10090166.8033988755196333,
3124120.9466011249460280 10090222.5570504590868950,
3124165.1929495413787663 10090266.8033988755196333,
3124220.9466011249460280 10090295.2113032583147287,
3124282.7500000000000000 10090305.0000000000000000,
3124344.5533988750539720 10090295.2113032583147287,
3124400.3070504586212337 10090266.8033988755196333,
3124444.5533988750539720 10090222.5570504590868950,
3124472.9613032592460513 10090166.8033988755196333,
3124482.7500000000000000 10090105.0000000000000000,
3124472.9613032592460513 10090043.1966011244803667,
3124444.5533988750539720 10089987.4429495409131050,
3124413.9517089775763452 10089956.8412596434354782,
3124436.4762005978263915 10089912.6344557590782642,
3124446.2648973385803401 10089850.8310568835586309,
3124436.4762005978263915 10089789.0276580080389977,
3124408.0682962136343122 10089733.2740064244717360,
3124363.8219477972015738 10089689.0276580080389977,
3124308.0682962136343122 10089660.6197536252439022,
3124246.2648973385803401 10089650.8310568835586309,
3124184.4614984635263681 10089660.6197536252439022,
3124128.7078468799591064 10089689.0276580080389977,
3124084.4614984635263681 10089733.2740064244717360,
3124056.0535940793342888 10089789.0276580080389977,
3124046.2648973385803401 10089850.8310568835586309,
3124056.0535940793342888 10089912.6344557590782642,
3124084.4614984635263681 10089968.3881073426455259,
3124115.0631883610039949 10089998.9897972401231527))))
</op>
</test>
</case>
</run>
