[geos-devel] nasty ring bug
Carl Anderson
carl.anderson at vadose.org
Wed Feb 21 07:12:59 EST 2007
strk,
you are free to uses these examples as you want.
hole_from shell.xml is the example we hit in production use
hole_red.xml is a reduced form of that
big_nasty.xml is a cut and paste from your email about a reduced form of
the big bad nasty buffer
I want to run a few more tests in the production environment to see if
any consequences of the patch pop up.
I'll let you know in a few hours.
C.
is the strk at refractions.net wrote:
> All tests i nGEOS testsuite still pass with this patch,
> and the badguy.xml testcase doesn't abort. Still, the result
> for badguy.xml doesn't seem completely fine. A couple of cirlcles
> are missing from the obtained result.
> Can you send me the bug_nasty.xml and hole_red.xml files to include
> in repository ?
> Can you find the badguy.xml testcase or should I send it to you ?
> --strk;
> On Wed, Feb 21, 2007 at 12:25:39AM -0500, Carl Anderson wrote:
>> strk,
>> This patch avoids the defective logic (that exists later, somewhere)
>> It makes a logic short circuit more robust instead of fixing the
>> underlying logic defect.
>> So be it.
>> It works for me.. for now.
>> I'll let you know how further testing goes.
>> bug_nasty.xml
>> and
>> hole_red.xml
>> both pass testing with this patch.
>> --- source/operation/buffer/SubgraphDepthLocater.cpp (revision 1972)
>> +++ source/operation/buffer/SubgraphDepthLocater.cpp (working copy)
>> @@ -180,11 +180,16 @@
>> BufferSubgraph *bsg=(*subgraphs)[i];
>> +#ifdef GEOS_DEBUG > 1
>> + std::cerr << "findStabbedSegments envelope: " <<
>> bsg->getEnvelope() << " RayLeftpt: " << stabbingRayLeftPt << std::endl;
>> +#endif
>> // optimization - don't bother checking subgraphs
>> // which the ray does not intersect
>> Envelope *env = bsg->getEnvelope();
>> if ( stabbingRayLeftPt.y < env->getMinY()
>> - || stabbingRayLeftPt.y > env->getMaxY() )
>> + || stabbingRayLeftPt.y > env->getMaxY()
>> + || stabbingRayLeftPt.x < env->getMinX()
>> + || stabbingRayLeftPt.x > env->getMaxX())
>> continue;
>> findStabbedSegments(stabbingRayLeftPt,
>> bsg->getDirectedEdges(),
>> C.
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070221/38f13ff7/big_nasty.xml
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070221/38f13ff7/hole_from_shell.xml
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070221/38f13ff7/hole_red.xml
