[geos-devel] Trouble compiling Geos 2.2.3
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 23 09:29:49 EST 2007
Mark,
Thanks that got me further.  I had to as you hinted - also remove the
gettimeofday function from the timeval.h file to get it to completely
compile.  Without removing that I was getting an ambiguous function call
error.
Thanks,
Regina
---Original Message ----
Hi Regina, It looks as if the MingW guys have finally added an in-built
"struct timezone" to the latest version of their runtime here which is
causing the problem:
http://sourceforge.net/project/shownotes.php?group_id=2435&release_id=15
8845 (as a side note, it also looks as if they have added in their own
version of gettimeofday() at the same time). The reason this hasn't
shown up in my builds is that I'm currently still using the older
version of MingW (4.1.0) which doesn't have this change. The solution
here should be to remove the "struct timezone { ... }" from timeval.h
and then trying "make" again to see if it allows the build to get any
further. Kind regards, Mark.
-----Original Message-----
Sent: Monday, January 22, 2007 10:16 AM
To: geos-devel at geos.refractions.net
Subject: [geos-devel] Trouble compiling Geos 2.2.3
I'm getting an error when trying to compile Geos 2.2.3 on a Windows XP
box.  I'm using MinGW-5.1.2, Msys-1.0.11.
The error I get is below.
In file included from ../../source/headers/geos/profiler.h:27,
                 from ../geomgraph/EdgeList.cpp:19:
.../../source/headers/geos/timeval.h:25: error: redefinition of `struct
timezone'
C:/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/sys/time.h:27:
error: previous definition of `struct timezone'
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
