[geos-devel] Warning: passing arg 2 of of `execv' from incompatible pointer type when compiling geos 2.2.3
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 23 17:52:26 EST 2007
This may be related to me taking out the gettimeofday function to
resolve the ambiguous function error in MingW 5.1.2.
I've been getting the below warnings in all the .libs example files,
although the library seems to compile.  I'm not sure if these warnings
are common or if I should be concerned.
creating example.exe
..libs/lt-example.c: In function `main':
..libs/lt-example.c:79: warning: passing arg 2 of `execv' from
On another note - I noticed my libgeos-2.dll and libgeos_c-1.dll are
much huger than I would expect.
The libgeos-2.dll is a whopping 10.9 mb and the libgeos_c-1.dll is 1086
kb. I'm guessing I must be statically compiling something in that I
shouldn't be.
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
