[geos-devel] Buffer op - end cap styles
Ben Supnik bsupnik at xsquawkbox.net
Wed Jan 31 11:23:59 EST 2007
Hi Y'all,
I am now using the GEOS buffer op and am VERY excited about it.  My own
implementation of straight skeleton isn't robust, but the GOES buffer op
worked the first time. :-)
A few questions:
I tried changing the cap style to round but I see no change.  Is there
something basic I'm missing?
geos::operation::buffer::BufferOp bufOp(poly);
bufOp.setQuadrantSegments(4);
bufOp.setEndCapStyle(geos::operation::buffer::BufferOp::CAP_SQUARE);
geos::geom::Geometry * buf = bufOp.getResultGeometry(
	-30.0 * MTR_TO_NM * NM_TO_DEG_LAT);
(The code is written using a buffer op object because I was trying to
eliminate wrapper layers as possible causes of the wrong end-cap style.)
Also, how can I compile a debug build of GEOS?  Are there flags in the
configure file for this?  I'd like to be able to break within the lib in
gdb.  (I am compiling on Mac OS X using the std unix configure file.)
Finally, would it be algorithmically possible to modify the buffer
operation to buffer different line segments by different amounts, or
does the algorithm require uniform buffering?
Thanks!
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
Scenery mailing list: x-plane-scenery at yahoogroups.com
Developer mailing list: x-plane-dev at yahoogroups.com
