[geos-devel] supporting filters
Paul Ramsey pramsey at refractions.net
Mon May 28 22:41:13 EDT 2007
Is this the Oracle defn also? I had always interpreted DWithin to
mean "within distance of", so that
DWIthin(A,B,100) was functionally equivalent to Distance(A,B) < 100
P
On 27-May-07, at 2:23 PM, Kralidis,Tom [Burlington] wrote:
> Further info from Peter Vretanos (FES 1.0.0 spec editor):
> "According to the BNF in the Cat 1.0 specification DWithin tests to
> see
> whether geometry A is completely within a certain distance of geometry
> B.
> I interpret this to mean a "buffer" query.  That is you create a
> buffer
> around A at the specified distance and then do a WITHIN (as defined in
> SFSQL) between this new buffer-expanded geometry (A') and the test
> geometry B.  If B is completely within A' then the operator
> evaluates to
> true
> BEYOND is the opposite of DWITHIN.   If B is completely outside of A'
> then the operator evaluates to true."
> Cheers
> ..Tom
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
