[geos-devel] supporting filters
Paul Ramsey pramsey at refractions.net
Mon May 28 22:50:10 EDT 2007
Oracle's understanding is the same as mine:
<http://download-west.oracle.com/docs/cd/B19306_01/appdev.102/b14255/
sdo_operat.htm#i77653>
On 28-May-07, at 7:41 PM, Paul Ramsey wrote:
> Is this the Oracle defn also? I had always interpreted DWithin to
> mean "within distance of", so that
> DWIthin(A,B,100) was functionally equivalent to Distance(A,B) < 100
> P
> On 27-May-07, at 2:23 PM, Kralidis,Tom [Burlington] wrote:
>> Further info from Peter Vretanos (FES 1.0.0 spec editor):
>> "According to the BNF in the Cat 1.0 specification DWithin tests
>> to see
>> whether geometry A is completely within a certain distance of
>> geometry
>> B.
>> I interpret this to mean a "buffer" query.  That is you create a
>> buffer
>> around A at the specified distance and then do a WITHIN (as
>> defined in
>> SFSQL) between this new buffer-expanded geometry (A') and the test
>> geometry B.  If B is completely within A' then the operator
>> evaluates to
>> true
>> BEYOND is the opposite of DWITHIN.   If B is completely outside of A'
>> then the operator evaluates to true."
>> Cheers
>> ..Tom
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
