[geos-devel] supporting filters
Carl Anderson carl.anderson at vadose.org
Mon May 28 23:28:09 EDT 2007
OGC defines the DWithin and Beyond spatial operators recursively in
section 8.2 of the Filter Encoding 04-095 specification (further
referenced by the WFS and WMS specs)
http://www.opengeospatial.org/standards/filter
anybody feel like bringing up this confusion with the Open Geospatial
Consortium folk.
C.
Paul Ramsey wrote:
> Oracle's understanding is the same as mine:
> <http://download-west.oracle.com/docs/cd/B19306_01/appdev.102/b14255/sdo_operat.htm#i77653>
> On 28-May-07, at 7:41 PM, Paul Ramsey wrote:
>> Is this the Oracle defn also? I had always interpreted DWithin to
>> mean "within distance of", so that
>> DWIthin(A,B,100) was functionally equivalent to Distance(A,B) < 100
>> P
>> On 27-May-07, at 2:23 PM, Kralidis,Tom [Burlington] wrote:
>>> Further info from Peter Vretanos (FES 1.0.0 spec editor):
>>> "According to the BNF in the Cat 1.0 specification DWithin tests to see
>>> whether geometry A is completely within a certain distance of geometry
>>> B.
>>> I interpret this to mean a "buffer" query.  That is you create a buffer
>>> around A at the specified distance and then do a WITHIN (as defined in
>>> SFSQL) between this new buffer-expanded geometry (A') and the test
>>> geometry B.  If B is completely within A' then the operator
>>> evaluates to
>>> true
>>> BEYOND is the opposite of DWITHIN.   If B is completely outside of A'
>>> then the operator evaluates to true."
>>> Cheers
>>> ..Tom
>>> geos-devel mailing list
>>> geos-devel at geos.refractions.net
>>> http://geos.refractions.net/mailman/listinfo/geos-devel
