[geos-devel] testrunner fail
Gilles Bassière
gilles.bassiere at makina-corpus.com
Tue Oct 23 09:11:49 EDT 2007
Mateusz Loskot wrote:
> Gilles Bassière wrote:
>> Geos is compiled with "--enable-python" and "--disable-inline" options,
>> I also set a custom "--prefix".
> Could you try to build without --disable-inline and see if it changes
> anything?
> Cheers
Hi Mateusz,
Thanks for help. I tried your solution and also dropped the Python
option as I don't really need it. After compilation, Geos passed all
tests ("make check" ok). I proceed with postgis upgrade :
make clean
make
make install
ldconfig
psql -d topo -f share/lwpostgis_upgrade.sql
Unfortunately, I still have a Fatal error in PostGIS when using
LineMerge() :
topo=> SELECT nom_rue, astext(LineMerge(Collect(wkb_geometry)))
topo-> FROM route
topo-> GROUP BY nom_rue
topo-> HAVING nom_rue IS NOT NULL;
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Succeeded.
So, the only progress is the Postgres' "Attempting reset" success (with
--disable-inline, the error message ended with "Attempting reset: Failed.")
Postgres' log give me the following error message:
al] SELECT: CoordinateArraySequence.cpp:105: virtual const
geos::geom::Coordinate&
geos::geom::CoordinateArraySequence::getAt(size_t) const: Assertion
`pos<vect->size()' failed.
I'm wondering whether it's a good idea to rely on geos 3.0. On the one
hand, I use GeoDjango which only works when linked against geos 3.0, on
the other hand I use postgis, qgis and many others that require a stable
background... Would it be possible to install geos 2.2.3 as the default
geos and build the 3.0.0 RC version only for apps that really require
it? Any hints?
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
