[geos-devel] Can't build geos with ruby swig bindings on Mac OS
Ramie Blatt
rblatt at warmlyyours.com
Tue Oct 23 13:53:32 EDT 2007
I'm wondering if there's *anyone* out there who has successfully
built GEOS 3 with swig and ruby on Mac OS?
I've spent a lot of time on this and keep coming up empty...
I tried building GEOS with ruby enabled using the hourly svn snapshot
yesterday and get the same "make" issue I get with the
geos-3.0.0rc1,2 and 3 tarballs, namely:
"geos_wrap.cxx:1702: error: invalid conversion from 'size_t*' to
'unsigned int*"
Strangely, the geos-3.0.0rc4.tar.bz2 release builds fine, but then I
can't access GEOS in ruby, getting a "MissingSourceFile: no such file
to load -- geos" whenever 'require 'geos' is encountered (though the
library files seem to be where they should).
Again, any help on this is great;y appreciated!
Best,
Ramie
On Oct 12, 2007, at 4:41 PM, Ramie Blatt wrote:
> Hi there,
> I'm having quite a time of it trying to build geos with the ruby
> swig bindings on a MacBook Pro.
> Any help on this issue would be appreciated.
> When I try to build geos from any of the following releases
> (uninstalling between attempts):
> [2006/12/14] geos-3.0.0rc3.tar.bz2
> [2006/11/05] geos-3.0.0rc2.tar.bz2
> [2006/09/09] geos-3.0.0rc1.tar.bz2
> I get the following error at the make command:
> g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/
> headers/geos -I/usr/local/lib/ruby/1.8/i686-darwin8.9.1 -I../../
> capi -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
> geos_la-geos_wrap.lo -MD -MP -MF .deps/geos_la-geos_wrap.Tpo -c
> geos_wrap.cxx -fno-common -DPIC -o .libs/geos_la-geos_wrap.o
> geos_wrap.cxx: In function 'void checkCoordSeqBounds
> (GEOSCoordSeq_t*, size_t)':
> 'unsigned int*'
> geos_wrap.cxx: In function 'int GeosCoordinateSequence_getSize
> (GeosCoordinateSequence*)':
> geos_wrap.cxx:1844: error: invalid conversion from 'size_t*' to
> 'unsigned int*'
> geos_wrap.cxx: In function 'int GeosCoordinateSequence_getDimensions
> geos_wrap.cxx:1850: error: invalid conversion from 'size_t*' to
> 'unsigned int*'
> make[4]: *** [geos_la-geos_wrap.lo] Error 1
> make[3]: *** [all-recursive] Error 1
> make[2]: *** [all] Error 2
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> When I try to build geos from the [2007/02/02]
> geos-3.0.0rc4.tar.bz2 release, everything seems to work, but then I
> can't actually load the geos code in ruby, getting the following
> error whenever "require 'geos'" is encountered, even though I can
> see the geos.a, geos.la, and geos.so files in the /usr/local/lib/
> ruby/site_ruby/1.8/i686-darwin8.9.1/ directory:
> >> require 'geos'
> MissingSourceFile: no such file to load -- geos
> from /usr/local/lib/ruby/site_ruby/1.8/rubygems/
> custom_require.rb:27:in `gem_original_require'
> custom_require.rb:27:in `require'
> from ./script/../config/../config/../vendor/rails/
> activerecord/lib/../../activesupport/lib/active_support/
> dependencies.rb:147:in `require'
> from (irb):5
> from :0
> My environment, below, seems to be a good sane environment, and I
> run several ruby on rails applications.
> Mac OSX 10.4.10
> gcc version 4.0.1 (Apple Computer, Inc. build 5250)
> libtool Apple Computer, Inc. version cctools-590.23.2
> ruby 1.8.6 (2007-03-13 patchlevel 0) [i686-darwin8.9.1]
> rails 1.2.3
> Regards,
> Ramie Blatt
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Ramie Blatt
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20071023/df1a8e41/attachment.html
