[geos-devel] Can't build geos with ruby swig bindings on Mac
OS
Charlie Savage
cfis at savagexi.com
Tue Oct 23 16:16:08 EDT 2007
> I tried building GEOS with ruby enabled using the hourly svn snapshot
> yesterday and get the same "make" issue I get with the geos-3.0.0rc1,2
> and 3 tarballs, namely:
> "geos_wrap.cxx:1702: error: invalid conversion from 'size_t*' to
> 'unsigned int*"
What's the line of code?
> Strangely, the geos-3.0.0rc4.tar.bz2 release builds fine, but then I
> can't access GEOS in ruby, getting a "MissingSourceFile: no such file to
> load -- geos" whenever 'require 'geos' is encountered (though the
> library files seem to be where they should).
Open a command line. Go to that directory. Type "irb" Then try to
load geos. Does that work?
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20071023/c85180f7/smime.bin
