[geos-devel] Can't build geos with ruby swig bindings on Mac OS
Ramie Blatt rblatt at warmlyyours.com
Tue Oct 23 20:59:21 EDT 2007
Hi Charlie,
After (a seemingly successful) build of geos-3.0.0rc4, I did cd to
the both the "/usr/local/src/geos-3.0.0rc4/" build directory and the
"/usr/local/lib/ruby/site_ruby/1.8/i686-darwin8.9.1/" directory
(which contains the resulting geos.a, geos.la, and geos.so files) and
try irb and got the "LoadError: no such file to load -- geos" error
when I typed "require 'geos'" in the irb console.
I'm attaching a full terminal log of the rc4 build process and the
irb sessions called "geos-3.0.0rc4_err.txt"
A partial trace for the make error on the geos-3.0.0rc1,2 and 3
tarballs is below. and I attach a full terminal log for the build
process on rc3 called "geos-3.0.0rc3_err.txt".
  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/
headers/geos -I/usr/local/lib/ruby/1.8/i686-darwin8.9.1 -I../../capi -
g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT geos_la-
geos_wrap.lo -MD -MP -MF .deps/geos_la-geos_wrap.Tpo -c
geos_wrap.cxx  -fno-common -DPIC -o .libs/geos_la-geos_wrap.o
geos_wrap.cxx: In function 'void checkCoordSeqBounds(GEOSCoordSeq_t*,
size_t)':
geos_wrap.cxx:1702: error: invalid conversion from 'size_t*' to
'unsigned int*'
geos_wrap.cxx: In function 'int GeosCoordinateSequence_getSize
(GeosCoordinateSequence*)':
geos_wrap.cxx:1844: error: invalid conversion from 'size_t*' to
'unsigned int*'
geos_wrap.cxx: In function 'int GeosCoordinateSequence_getDimensions
geos_wrap.cxx:1850: error: invalid conversion from 'size_t*' to
'unsigned int*'
make[4]: *** [geos_la-geos_wrap.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all] Error 2
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Many thanks for your help!
Ramie
On Oct 23, 2007, at 2:16 PM, Charlie Savage wrote:
>> I tried building GEOS with ruby enabled using the hourly svn
>> snapshot yesterday and get the same "make" issue I get with the
>> geos-3.0.0rc1,2 and 3 tarballs, namely:
>> "geos_wrap.cxx:1702: error: invalid conversion from 'size_t*' to
>> 'unsigned int*"
> What's the line of code?
>> Strangely, the geos-3.0.0rc4.tar.bz2 release builds fine, but then
>> I can't access GEOS in ruby, getting a "MissingSourceFile: no such
>> file to load -- geos" whenever 'require 'geos' is encountered
>> (though the library files seem to be where they should).
> Open a command line.  Go to that directory.  Type "irb"  Then try
> to load geos.  Does that work?
> Charlie
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Ramie Blatt
Skipped content of type multipart/mixed
