[geos-devel] GEOS C API - WKB and WKT deprecated functions
Benjamin Chartier benjamin.chartier at cegetel.net
Wed Oct 31 02:44:59 EDT 2007
Thank you Robert and Charlie for your responses.
This is much clearer for me now.
Benjamin
Charlie Savage a écrit :
>> On 29/10/2007, *Benjamin Chartier* <benjamin.chartier at cegetel.net
>> <mailto:benjamin.chartier at cegetel.net>> wrote:
>>     Justin and Charlie, many thanks for your answers.
>>     By the way, is there a ggod reason why the Reader and Writer API
>> should
>>     be used in stead of the deprecated functions? Is there any
>> performance
>>     issue?
>> You can do things like write EWKT/EWKB which aren't possible using
>> the old C API.
> That's the most important thing.  But also:
> * the old api used global static variables for storing the byte order
> and output dimensions.  So on the off hand chance you wanted to write
> out 2d and 3d outputs in 2 different threads you couldn't do it.
> * the old api forced a creation of a new reader/writer each time you
> called it.  Probably not a big deal, but the new api let's you control
> that so you can reuse the same reader/writer.
> Hope that helps,
> Charlie
