[geos-devel] Windows Build
Charlie Savage
cfis at savagexi.com
Wed Sep 5 22:35:54 EDT 2007
> copy headers/geos/platform.h.vc headers/geos/platform.h
> copy headers/geos/version.h.vc headers/geos/version.h
> AFAIR, makefile.vc does it for you, at least for platform.h.
The VC++ project files already do this as a pre-build step. So this
shouldn't be an issue.
Note I did the same thing for the capi file recently.
>> We switched to using project files, but then there were errors
>> building the python and ruby bindings (which we don't need).
> These projects for scripting langs have been added quite recently,
> by Charlie Savage. Perhaps something is not completed or not working
> well yet, but you can just remove these projects from the solution.
Yes, just don't build them. The problem with those project files is
that they assume where ruby/python are located. I suppose I could setup
the project files to call out to a script and try to figure it out, but
that didn't seem worth the bother.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070905/8bc9e3c7/smime.bin
