[geos-devel] C# Bindings?
Charlie Savage
cfis at savagexi.com
Tue Sep 11 17:36:19 EDT 2007
Simon Perkins wrote:
> Hi,
> Are there any C# bindings for GEOS out there?
Not that I know of - at least not as part of GEOS.
> We've been using the OGR interface to GEOS (which are exposed by the OGR
> C# bindings), but are running into some strange topology exceptions
> (side location conflicts and non-nodal intersections) and I'd like to
> use the GEOS isValid() method which is not exposed by OGR, AFAIK. Might
> using the GEOS library directly be more efficient than going through OGR
> as well?
Hmm, probably not a big difference.
> Anyway, I could go off and roll PInvoke stubs for the GEOS functions I
> need in not much time, but I figured I'd see what other people have
> already before I do that. Any interest in adding such bindings to geos?
> I could also take a look at SWIG, but it always scares me for some
> reason...
More recent versions of SWIG have a standard typemaps that apply for the
scripting languages - so Perl, Ruby, Python. Thus it would be very easy
to reuse the current bindings for one of those language.
However, SWIG's static languages (C#, Java, etc.) use a different
system. So you would have to take the current geos.i file and
significantly change it to work with C#. The OGR C# bindings could
probably provide some guidance.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070911/9f1fd0fc/smime.bin
