[geos-devel] GEOS SRID Patch
Paul Ramsey
pramsey at refractions.net
Wed Sep 19 00:54:33 EDT 2007
The readme on releasing spells out the policy if I recall correctly.
P
On 18-Sep-07, at 9:05 PM, Howard Butler wrote:
> Do we need to increment the API with these additions? What policy
> did Sandro have going?
> Howard
> On Sep 18, 2007, at 10:51 PM, Charlie Savage wrote:
>> So - any comments on this. Will people get upset if I commit it
>> (which I would like to do)?
>> Charlie
>>> I've attached a patch that implements what we discussed yesterday.
>>> More specifically:
>>> * It updates WkbWriter to support outputting SRID values in EWKB/
>>> HEX format. This is off by default so is backwards compatible.
>>> * Adds getter/setter methods for byte order, dimensions and
>>> include SRID to WkbWriter - these are needed for the C API
>>> changes below.
>>> * Adds new C API interfaces for WktReader, WktWriter, WkbReader,
>>> WkbWriter. These were added to the end of the *.h file and I did
>>> not change any existing C apis - so this should be backwards
>>> compatible.
>>> Here is what the new WkbWriter interface, which is the most
>>> complicated one, looks like:
>>> extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create();
>>> extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
>>> extern unsigned char GEOS_DLL *GEOSWKBWriter_write(GEOSWKBWriter*
>>> writer, const GEOSGeometry* g, size_t *size);
>>> extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX
>>> (GEOSWKBWriter* writer, const GEOSGeometry* g, size_t *size);
>>> extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(const
>>> extern void GEOS_DLL GEOSWKBWriter_setOutputDimension
>>> (GEOSWKBWriter* writer, int newDimension);
>>> extern int GEOS_DLL GEOSWKBWriter_getByteOrder(const
>>> extern void GEOS_DLL GEOSWKBWriter_setByteOrder(GEOSWKBWriter*
>>> writer, int byteOrder);
>>> extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(const
>>> extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter*
>>> writer, const char writeSRID);
>>> Here is some example ruby code that uses the new api via SWIG:
>>> writer = Geos::WktWriter.new
>>> writer.includes_srid = true
>>> writer.output_dimension = 3
>>> wkb = writer.write(geom)
>>> hex = writer.write_hex(geom)
>>> The other readers/writers work similarly.
>>> I think this is a better approach then the current API because:
>>> 1. It eliminates the need for the hacky static variables for
>>> byte order and output dimensions
>>> 2. It gives the client more control - you can create a reader/
>>> writer and reuse it instead of having a new one created every
>>> time you read/write a geometry
>>> 3. Its more extensible. For example, at some point we may wish
>>> that the WktReader supports the EWKT format. That would require
>>> doing this:
>>> extern char GEOS_DLL GEOSWKTWriter_getIncludeSRID(const
>>> GEOSWKTWriter* writer);
>>> extern void GEOS_DLL GEOSWKTWriter_setIncludeSRID(GEOSWKTWriter*
>>> So I think this patch meets my objectives (more client control,
>>> supports outputting SRID values), Frank's objectives (get rid of
>>> static fields) and Paul's (backwards compatible).
>>> I also tested it by exposing the new API via SWIG and updating
>>> the various Ruby tests I have. So at least every new method has
>>> been called/verified via a simple set of tests.
>>> Comments? If this looks ok, can I apply it?
>>> Charlie
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
