[geos-devel] Union problem
Paul Ramsey pramsey at cleverelephant.ca
Thu Apr 3 13:50:29 EDT 2008
Most probably a bug... any chance you could run this same test case
under JTS so we can confirm if it's a problem at the algorithm level
or the port level?
Thanks,
P
On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com> wrote:
> All,
> When I union the two features USA and Mexico I end up with a geometry that
> has one point where the y or lat value for one point is zero.  See the
> attachment for what I mean.  Does anyone think this is a bug in GEOS or am I
> not doing something correctly?  Most other geometric unions create good
> geometries.  If you want I can send the original shape file.
> Thanks for any help.
> Best regards,
> Martin
>  geos-devel mailing list
>  geos-devel at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/geos-devel
