[geos-devel] Union problem
Martin Chapman mchapman at texelinc.com
Thu Apr 3 14:22:58 EDT 2008
Unfortunately, I do not have JTS but I will try to step through the code and
see if I can learn more about the problem.  Perhaps a careful inspection of
the input and output point sets will yield some clues because the problem is
predictable.
Best regards,
Martin
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Thursday, April 03, 2008 11:50 AM
To: GEOS Development List
Subject: Re: [geos-devel] Union problem
Most probably a bug... any chance you could run this same test case
under JTS so we can confirm if it's a problem at the algorithm level
or the port level?
Thanks,
P
On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
wrote:
> All,
> When I union the two features USA and Mexico I end up with a geometry that
> has one point where the y or lat value for one point is zero.  See the
> attachment for what I mean.  Does anyone think this is a bug in GEOS or am
I
> not doing something correctly?  Most other geometric unions create good
> geometries.  If you want I can send the original shape file.
> Thanks for any help.
> Best regards,
> Martin
>  geos-devel mailing list
>  geos-devel at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/geos-devel
