[geos-devel] Union problem
Martin Davis
mbdavis at refractions.net
Thu Apr 3 14:32:25 EDT 2008
Send me the shapefile and I'll try it out in JTS.
M
Martin Chapman wrote:
> Unfortunately, I do not have JTS but I will try to step through the code and
> see if I can learn more about the problem. Perhaps a careful inspection of
> the input and output point sets will yield some clues because the problem is
> predictable.
> Best regards,
> Martin
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Thursday, April 03, 2008 11:50 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] Union problem
> Most probably a bug... any chance you could run this same test case
> under JTS so we can confirm if it's a problem at the algorithm level
> or the port level?
> Thanks,
> P
> On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
> wrote:
>> All,
>> When I union the two features USA and Mexico I end up with a geometry that
>> has one point where the y or lat value for one point is zero. See the
>> attachment for what I mean. Does anyone think this is a bug in GEOS or am
> I
>> not doing something correctly? Most other geometric unions create good
>> geometries. If you want I can send the original shape file.
>> Thanks for any help.
>> Best regards,
>> Martin
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
