[geos-devel] Union problem
Martin Chapman mchapman at texelinc.com
Thu Apr 3 16:42:27 EDT 2008
Martin,
Here you go.  It occurs when you union the US and Mexico. Thanks for your
help!
Best regards,
Martin
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
Sent: Thursday, April 03, 2008 12:32 PM
To: GEOS Development List
Subject: Re: [geos-devel] Union problem
Send me the shapefile and I'll try it out in JTS.
M
Martin Chapman wrote:
> Unfortunately, I do not have JTS but I will try to step through the code
and
> see if I can learn more about the problem.  Perhaps a careful inspection
of
> the input and output point sets will yield some clues because the problem
is
> predictable.
> Best regards,
> Martin
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Thursday, April 03, 2008 11:50 AM
> Most probably a bug... any chance you could run this same test case
> under JTS so we can confirm if it's a problem at the algorithm level
> or the port level?
> Thanks,
> P
> On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
> wrote:
>> All,
>> When I union the two features USA and Mexico I end up with a geometry
that
>> has one point where the y or lat value for one point is zero.  See the
>> attachment for what I mean.  Does anyone think this is a bug in GEOS or
am
> I
>> not doing something correctly?  Most other geometric unions create good
>> geometries.  If you want I can send the original shape file.
>> Thanks for any help.
>> Best regards,
>> Martin
>>  geos-devel mailing list
>>  geos-devel at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20080403/b9491c07/CNTRY92-0001.bin
