[geos-devel] Crash when buffering a geometry
Stephen Wong swongu at gmail.com
Fri Aug 8 14:48:10 EDT 2008
Hello,
I have found that when using BufferOp on a specific polygon, GEOS crashes
with an assertion failure.  This failure appears to be within
RightmostEdgeFinder, and I have documented it on a ticket (
http://trac.osgeo.org/geos/ticket/188). On that ticket, I have also provided
a .zip file that reproduces the error. The surprising this is that the
geometry is not complicated at all!
I have posted this problem in March (see
http://lists.osgeo.org/pipermail/geos-devel/2008-March/003324.html), but
didn't get a response thus far; hopefully posting here will help.  Thanks in
advance.
Regards,
Stephen
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080808/7bc5ca8d/attachment.html
