[geos-devel] Crash when buffering a geometry
Paul Ramsey
pramsey at cleverelephant.ca
Mon Aug 11 14:42:30 EDT 2008
Stephen,
When I integrate your code into my OS/X build and run the unit tests,
I don't get as far as buffering...
---> group: geos::operation::BufferOp, test: test<1>
problem: unexpected exception
exception typeid: N4geos2io14ParseExceptionE
message: "ParseException: Unknown WKB type 0"
Are you certain that WKB fragment is good?
Paul
On Fri, Aug 8, 2008 at 11:48 AM, Stephen Wong <swongu at gmail.com> wrote:
> Hello,
> I have found that when using BufferOp on a specific polygon, GEOS crashes
> with an assertion failure. This failure appears to be within
> RightmostEdgeFinder, and I have documented it on a ticket
> (http://trac.osgeo.org/geos/ticket/188). On that ticket, I have also
> provided a .zip file that reproduces the error. The surprising this is that
> the geometry is not complicated at all!
> I have posted this problem in March
> (see http://lists.osgeo.org/pipermail/geos-devel/2008-March/003324.html),
> but didn't get a response thus far; hopefully posting here will help.
> Thanks in advance.
> Regards,
> Stephen
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
