[geos-devel] missing python functions?
Ramie Blatt
rblatt at warmlyyours.com
Mon Feb 25 17:54:22 EST 2008
Hi there,
While you're looking at this, Charlie, a lot of the tests in the swig/
ruby/test/ directory don't work either, especially those using
Geos::GeometryFactory plus others.
Regards,
Ramie
On Feb 25, 2008, at 10:49 AM, Charlie Savage wrote:
> Hi Russell,
>> Just compiled and installed geos-3.0.0 and would like to write
>> some python code. However, I can't figure out how to create a
>> geometry collection in python. I checked out example.py. It
>> doesn't work either.
> Yeah - a lot of the python examples are out of date since they were
> originally done when the bindings worked against the C++ api and
> not the c api.
> It appears to me that a bunch of stuff is missing from the
>> python bindings. Here is a dir() of the geos module.
> Hmm, looks like for some reason I never exposed the
> createCollection method to Python/Ruby (see around line 947 in
> geos.i). I could add it easily enough if you need it.
> Charlie
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
