[geos-devel] missing python functions?
Russell Strong russell at strong.id.au
Mon Feb 25 16:02:45 EST 2008
Charlie,
That would be good if you would do that.  I've never used swig before.
I probably should learn it.  It looks quite useful.
Russell
Charlie Savage wrote:
> Hi Russell,
>> Just compiled and installed geos-3.0.0 and would like to write some
>> python code.  However, I can't figure out how to create a geometry
>> collection in python.  I checked out example.py.  It doesn't work
>> either.
> Yeah - a lot of the python examples are out of date since they were
> originally done when the bindings worked against the C++ api and not
> the  c api.
>  It appears to me that a bunch of stuff is missing from the
>> python bindings.  Here is a dir() of the geos module.
> Hmm, looks like for some reason I never exposed the createCollection
> method to Python/Ruby (see around line 947 in geos.i).   I could add
> it easily enough if you need it.
> Charlie
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
