[geos-devel] GEOS 3 DLLs?
Artem Pavlenko
artem.mapnik at googlemail.com
Mon Jan 14 17:21:32 EST 2008
Sean,
Great! Glad it works. Another happy vista user :)
Cheers
Artem
> Artem,
> Thanks, man! My Vista user confirms that it works.
> Cheers,
> Sean
> Artem Pavlenko wrote:
>> On 14 Jan 2008, at 17:02, Charlie Savage wrote:
>>>> Could it be a missing manifest?
>>> That is almost always the issue I run into. VC 2005 will embed the
>>> manifest for you, but I'm not sure if the Express versions do and
>>> nmake definitely does not.
>>> To fix, use the mt command link tool to embed the manifest:
>>> http://msdn2.microsoft.com/en-us/library/ms235591.aspx
>> I found this one, too:
>> http://msdn2.microsoft.com/en-us/library/ms235591(VS.80).aspx
>> OK, I embedded manifests into geos.dll and geos_c.dll, could you
>> try ?
>> http://artem.dev.openstreetmap.org/files/geos_c.dll
>> http://artem.dev.openstreetmap.org/files/geos.dll
>> Joy of windows dev :)
>> Artem
>>> Charlie
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
