[geos-devel] GEOS 3 DLLs?
Sean Gillies
sgillies at frii.com
Mon Jan 14 15:54:10 EST 2008
Artem,
Thanks, man! My Vista user confirms that it works.
Cheers,
Sean
Artem Pavlenko wrote:
> On 14 Jan 2008, at 17:02, Charlie Savage wrote:
>>> Could it be a missing manifest?
>> That is almost always the issue I run into. VC 2005 will embed the
>> manifest for you, but I'm not sure if the Express versions do and
>> nmake definitely does not.
>> To fix, use the mt command link tool to embed the manifest:
>> http://msdn2.microsoft.com/en-us/library/ms235591.aspx
> I found this one, too:
> http://msdn2.microsoft.com/en-us/library/ms235591(VS.80).aspx
> OK, I embedded manifests into geos.dll and geos_c.dll, could you try ?
> http://artem.dev.openstreetmap.org/files/geos_c.dll
> http://artem.dev.openstreetmap.org/files/geos.dll
> Joy of windows dev :)
> Artem
>> Charlie
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
