[geos-devel] Problems compiling GEOS on windows, missing *.inl
files
Anders Moe
anders.moe at geocap.no
Tue Jul 15 07:09:24 EDT 2008
Thanks a lot! Everything worked when I checked out using svn rather than using the nightly tarball.
For the record, I used VC2008 on Vista64 this time.
Again, thanks for a quick reply.
Cheers,
Anders
________________________________________________________Anders Moe
Software Integration ManagerGeocapw: +47 22 95 56 66
anders.moe at geocap.no________________________________________________________
> Date: Tue, 15 Jul 2008 12:27:10 +0200> From: mateusz at loskot.net> To: geos-devel at lists.osgeo.org> Subject: Re: [geos-devel] Problems compiling GEOS on windows, missing *.inl files> > Anders Moe pisze:> > I've downloaded the SVN nightly, but I'm experiencing several> > problems (using VC 2005)> > > > 1) The dirlist.mk file doesn't exist, so the make immediately fails.> > I had to remove the> > > > !INCLUDE dirlist.mk> > > > statement from makefile.vc> > > I don't know what is the exact procedure generating SVN Nightly > packages, but perhaps it's broken.> So, I'd suggest to get sources directly from SVN trunk:> > svn checkout http://svn.osgeo.org/geos/trunk geos-svn> > dirlist.mk file is available in SVN trunk (I've confirmed).> > > 2) I then get lots of errors because the *.inl files are missing. I> > did get a compile simply by commenting out statements like> > > > #include myfil.inl> > > > but ended up getting a lot of linking errors at the end.> > > > Same problem with 3.0. Is GEOS supported at all on windows ?> > Yes, GEOS is supported on Windows with Visual C++ compiler, for sure.> Please, tell me what steps you have taken to build it, what commands?> Verify, if it looks like this:> > http://trac.osgeo.org/geos/wiki/WikiStart#Windows> > All commands are supposed to be issued from the top-level directory,> the same where bootstrap.bat lives.> > > However, I've checked and can confirm that the geos-3.0.0.tar.bz2 > package is incomplete. The dirlist.mak and bootstrap.bat files are not > included. The procedure generating .tar.gz/.zip package obviously need > to be updated to include missing files.> > Paul, could you check it?> > Regards> -- > Mateusz Loskot, http://mateusz.loskot.net> Charter Member of OSGeo, http://osgeo.org> _______________________________________________> geos-devel mailing list> geos-devel at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/geos-devel
_________________________________________________________________
Hold kontakten med Windows Live Messenger.
http://clk.atdmt.com/GBL/go/msnnkdre0010000003gbl/direct/01/
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080715/bc8340c4/attachment.html
