[geos-devel] Memory leak in RelateComputer?
Mateusz Loskot
mateusz at loskot.net
Tue May 6 03:45:49 EDT 2008
王永杰 wrote:
> Intend to know how to release the pointer return by Geometry::Relate,
> I trace the source code to class RelateComputer. There is a private
> member variable named "im" initialized in the constructor.
> RelateComputer::RelateComputer(std::vector<GeometryGraph*> *newArg):
> arg(newArg),
> nodes(RelateNodeFactory::instance()),
> im(new IntersectionMatrix())
> The variable "im" is created by operator "new", so I think it must
> destroyed in the destructor, but there is nothing in the destructor of
> RelateComputer.
> RelateComputer::~RelateComputer()
> I think "delete im; im = NULL" is needed, right?
Wang,
You are correct that RelateComputer allocates new IntersectionMatrix
object, though the computer instance does not own it.
Next, ownership of the intersection matrix is transfered to a
RelateComputer caller according to following scheme:
vool foo()
RelateComputer rc;
IntersectionMatrix* im = rccomp.computeIM(); // ownership transfer
bool res = im->matches(...);
delete im; // required deallocation
return res;
RelateComputer is not required to deallocate the matrix in its
destructor, and no memory leak should not occur.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
