[geos-devel] Re: Memory leak in RelateComputer?
=?GB2312?B?zfXTwL3c?=
wang.yongjie.2008 at gmail.com
Tue May 6 22:44:33 EDT 2008
> 王永杰 wrote:
> > Intend to know how to release the pointer return by Geometry::Relate,
> > I trace the source code to class RelateComputer. There is a private
> > member variable named "im" initialized in the constructor.
> > RelateComputer::RelateComputer(std::vector<GeometryGraph*> *newArg):
> > arg(newArg),
> > nodes(RelateNodeFactory::instance()),
> > im(new IntersectionMatrix())
> > The variable "im" is created by operator "new", so I think it must
> > destroyed in the destructor, but there is nothing in the destructor of
> > RelateComputer.
> > RelateComputer::~RelateComputer()
> > I think "delete im; im = NULL" is needed, right?
> Wang,
> You are correct that RelateComputer allocates new IntersectionMatrix
> object, though the computer instance does not own it.
> Next, ownership of the intersection matrix is transfered to a
> RelateComputer caller according to following scheme:
> vool foo()
> RelateComputer rc;
> IntersectionMatrix* im = rccomp.computeIM(); // ownership transfer
> bool res = im->matches(...);
> delete im; // required deallocation
> return res;
> RelateComputer is not required to deallocate the matrix in its
> destructor, and no memory leak should not occur.
> Greetings
> Mateusz Loskot
> http://mateusz.loskot.net
Mateusz,
First, thanks very much for your reply.
That's great you provide a solution to avoid memory leak in class
RelateComputer. It work very well, but I don't think that idea is good
enough to solve this problem. For example, if I create a
RelateComputer pointer and delete it immediately.
RelateComputer* rc = new (RelateComputer);
delete rc;
rc = NULL;
Does Memory leak ocurr?
need I do this before the pointer destroyed?
delete rc->computeIM(); // destroy the pointer im.
I don't think that codes are graceful.
So I still consider deallocate the matrix in its destructor is a betty way.
"Who created, who destroyed"
How do you think?
Thank you for your patience.
Best regards to everyone.
Wang Yongjie
Tel: +86(10)8282 5800 Ext. 8411
Fax: +86(10)8282 5816
Email: yongjiemail at gmail.com
MSN/Gtalk: yongjiemail at gmail.com
Blog: www.iseeker.org/blog
