[geos-devel] Possible fix: #170: Intersection between valid and invalid polygon leaks
Denise MacLeod Denise.MacLeod at ingres.com
Fri Nov 7 15:10:12 EST 2008
Hi all -
I have found a possible fix for issue #170  http://trac.osgeo.org/geos/ticket/170
The patch file and analysis is attached to the ticket. As this fix was a bit tricky with the ownership of the objects leaking, I was hoping someone could peer review it before it is propped into the repository.
Thanks,
Denise
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081107/eae659ca/attachment.html
