[geos-devel] Fw: 3.0
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Mon Nov 17 15:49:00 EST 2008
On Sun, 2008-11-16 at 01:29 +0900, Sanak wrote:
> Mark,
> I had tested the 2 cases as follows on Windows MSVC environment.
> 1) overwrite attached inlines.cpp on my svn-tags/geos-3.0.3rc1
> working-copy.
> 2) apply attached geos-3.0.3svn-cygwin.patch on my svn-trunk
> working-copy. (use MSYS patch command)
> after that, open build/msvc80/geos.sln with Microsoft Visual C++
> Express Edition 2005 SP1,
> and build debug/release mode.
> the result as follows.
> 1) build(debug/release) -> ok
>     regression tests(geos_unit.exe) (debug/release) -> - passed: 402
> 2) build(debug/release) -> ok
>     regression tests(geos_unit.exe) (debug/release) -> - passed: 431
> * the cause of regression tests(geos_unit.exe) results difference
> between 1) and 2)
>   seems PreparedGeometryFactory improvement.
> 3>geos::geom::prep::PreparedGeometryFactory: ............................. 29
> I think that there is no probrem on Windows MSVC environment.
> Regards,
> Sanak.
Sanak,
Thanks for testing :)
ATB,
Mark.
